Results 1 to 2 of 2
Thread: Audi A1 2014 Rear tail lights as daylights
    Sep 2019
    Croatia
    Hello, is it possible to activate rear tail lights as daylights?
    Here is the auto-scan:
    Tuesday,19,May,2020,16:07:28:60999
    VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
    VIN: WAUZZZ8VXEA009305   License Plate:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F 69 BB BC
    VIN: WAUZZZ8VXEA009305   Mileage: 127159km-79012miles
    Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
       Component: R4 2,0L EDC   H22 5514
       Revision: 83H22---
       Coding: 02190012033401082000
       Shop #: WSC 41075 001 1048576
       ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
       ROD: EV_ECM20TDI01104L906021DS_002.rod
       VCID: 79AE16DB7957B6B3145-802C
       Part No SW: 5Q0 907 379 AA    HW: 5Q0 907 379 G
       Component: ESC           H31 0457
       Revision: 00000000    Serial number: 6146300000039A
       Coding: 12F162A224200A75017A060041C8294846245080608294F2026100748508
       Shop #: WSC 06314 790 00021
       ROD: EV_Brake1UDSContiMK100IPB_033.rod
       VCID: 7BA20CD3736B84A3069-802E
    8232 - Databus
              [FCAN: Kombi_02 message is not received]
                        Fault Frequency: 20
                        Reset counter: 70
                        Mileage: 119370 km
                        Date: 2020.01.22
                        Time: 00:00:00
    8234 - Databus
              [FCAN: Kombi_03 messag is not received]
                        Fault Frequency: 20
                        Reset counter: 70
                        Mileage: 119370 km
                        Date: 2020.01.22
                        Time: 00:00:00
    8236 - Databus
              [FCAN: Kombi_01 messagei is not received]
                        Fault Frequency: 186
                        Reset counter: 77
                        Mileage: 119370 km
                        Date: 2020.01.22
                        Time: 00:00:00
       Part No SW: 8V0 820 043 A    HW: 8V0 820 043 A
       Component: AC Automat    H13 0031
       Revision: 20021000    Serial number: 00000000093988
       Coding: 03000104002000011000000000001100
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
       VCID: 3038EBFFEAADB7FBE3B-8064
       Serial number: D4A80EA6000000000001
    328196 - Motor for Right Temperature Flap
              B108D 71 [008] - Actuator stuck
                        Reset counter: 65
                        Mileage: 126235 km
                        Date: 2020.05.10
                        Time: 18:34:27
                        Voltage terminal 30: 13.1 V
                        Interior temperature: 31.0 °C
                        Outside air temperature: 26 °C
                        Right temperature flap: actual value: 0.0 %
                        Right temperature flap: actual value: 98
                        Right temperature flap: specified value: 92
    329476 - Motor for Fresh Air / Recirculated Air Flap
              B108B 71 [008] - Actuator stuck
                        Reset counter: 65
                        Mileage: 123982 km
                        Date: 2020.04.27
                        Time: 05:46:22
                        Voltage terminal 30: 14.5 V
                        Interior temperature: 14.4 °C
                        Outside air temperature: 13.5 °C
                        Specified value for fresh air/recirc air flow flap: 876
                        Actual value for fresh air/recirculation air flow flap: 100.0 %
                        Actual value for fresh air/recirculation air flow flap: 872
       Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
       Component: BCM MQBAB H   H14 0112
       Serial number: 00011315100511
       Coding: 04020A46C2C122FD43844004001C07A8000C000000000000000000000000
       ROD: EV_BCMBOSCH_011.rod
       VCID: 77AA10E34F43A0C3621-8022
       Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 130515  041 0580
       Serial number:         130521061818
       Coding: 0A47F7
       Serial number: 21362392
       Coding: 00006C
       Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
       Serial number: 05 05 2013  00000601
    Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
       Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H09 0033
       Revision: --------    Serial number: 60831315100627
       Coding: 0000040101
       ASAM Dataset: EV_EPHVA14AU3700000 002018
       VCID: 3828D3DF02DD6FBBABB-806C
       Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
       Serial number: 003M2R01T1HG
       Coding: 98CCC0000C0000005C5400CA004800000065
       ROD: EV_AirbaVW20SMEVW37X_VW48.rod
       VCID: 4BC29C13634BF423F69-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 002 805 13
       Serial number: 35767000000B56313D0R
       Subsystem 2 - Part No SW: -----------    HW: 480 002 805 13
       Serial number: 35867000000BD7313D0.
       Subsystem 3 - Part No SW: -----------    HW: 480 403 105 13
       Serial number: 3516502BF1050661514Y
       Subsystem 4 - Part No SW: -----------    HW: 480 403 105 13
       Serial number: 3526502BF105066392C7
       Subsystem 5 - Part No SW: -----------    HW: 480 402 504 13
       Serial number: 3556502C11012331A16O
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 401 105 13
       Component: PedP_Sensor_D  001 6149
       Serial number: 2286502B11050665720Q
       Subsystem 7 - Part No SW: -----------    HW: 480 401 105 13
       Component: PedP_Sensor_P  001 6149
       Serial number: 2296502B5105066370A.
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 400 605 13
       Component: PedP_Sensor_C  001 6149
       Serial number: 2306502C91050652F19/
       Part No SW: 8V0 953 521 B    HW: 5Q0 953 549 A
       Revision: --------    Serial number: 31051308490322
       Coding: A418
       ROD: EV_SMLSKLOMQB_009_AU37.rod
       VCID: 392ED6DB39D776B3545-806C
       Part No SW: 8V0 920 870 H    HW: 8V0 920 870 H
       Component: KOMBI         H03 2210
       Coding: 03A509002B8000080001EE00000000
       VCID: 40D8BB3F5A0D277B13B-8014
       Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1144
       Revision: --------    Serial number: 0000650917
       Coding: 030100040B0876005B000248080B00000001000000000000000000000000
       Shop #: WSC 33027 001 1048576
       ROD: EV_GatewLear_009.rod
       VCID: 3B22CCD333EB44A3469-806E
       Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
       Serial number: 25 05 2013  D0233566
       Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
       Component: J367-BDM  H08 0192
       Serial number: 00000000004051407106
       Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
       Component: TSG FS        012 0006
       Serial number: 18051303111255
       Coding: 001C8E204000040000001002
       VCID: 3FDAB8C327F358836A1-806A
       Coding: 81
       ROD: EV_SteerAssisMQB_008.rod
       VCID: 3D26C2CB2DFF4A9378D-8068
       Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
       Component: TSG BFS       012 0006
       Serial number: 16051304081253
       Coding: 001C86204000040000001002
       VCID: 3E24C5C720F9518B617-806A
       Component: LWR-ECU       005 0070
       Coding: 019A000001000000
       VCID: 75B61AEB554FD2D370D-8020
       Part No SW: 8V0 035 043 B    HW: 8V0 035 043
       Component: MU-H-N-EU     H42 0171
       Serial number: A303A0GB011911
       Coding: 01730301FF00000021110001000A00002F00010501000100DE
       Shop #: WSC 10977 002 1048576
       ASAM Dataset: EV_MUHig4CHBAS 001040
       ROD: EV_MUHig4CHBAS_AU37.rod
       VCID: 2F3AE883F793A803FA1-807A
       Subsystem 1 - Part No SW: V03 959 800 QA    HW: -----------
       Component: ECE 2016  --- 0134
       Component: DU High  H49 0013
       Serial number: AUZ8Z9EY201KZU
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 H    HW: 8V0 919 614 D
       Component: ControlUnit_H  H64 0764
       Serial number: C1000026031300020410
       Component: Gracenote  --- 1008
    6706 - Databus
              [Instrument cluster: no communication]
                        Reset counter: 77
                        Mileage: 119370 km
                        Date: 2020.01.22
                        Time: 00:00:00
                        Voltage terminal 30: 12.4 V
                        Network diagnosis-Status: Enabled
    6714 - Databus
              [VIN: no communication]
                        Reset counter: 77
                        Mileage: 119370 km
                        Date: 2020.01.22
                        Time: 00:00:00
    6927 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Trip computer setup (0x0F) - function restriction due to communication error - BapErr_timeout: heartbeat]
                        Reset counter: 77
                        Mileage: 119370 km
                        Date: 2020.01.22
                        Time: 00:00:00
                        Voltage terminal 30: 12.3 V
    6929 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Time/date (0x11) - function restriction due to communication error - BapErr_timeout: heartbeat]
                        Reset counter: 77
                        Mileage: 119370 km
                        Date: 2020.01.22
                        Time: 00:00:00
    6930 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Service interval display + oil level display (0x12) - function restriction due to communication error - BapErr_timeout: heartbeat]
                        Reset counter: 77
                        Mileage: 119370 km
                        Date: 2020.01.22
                        Time: 00:00:00
    6931 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Central unit master (0x13) - function restriction due to communication error - BapErr_timeout: heartbeat]
                        Reset counter: 77
                        Mileage: 119370 km
                        Date: 2020.01.22
                        Time: 00:00:00
       Part No SW: 5Q0 907 383     HW: 5Q0 907 383
       Component: Anhaenger     H11 0030
       Revision: 6A001003    Serial number: 00000326940929
       Coding: 0101000200000000
       ASAM Dataset: EV_TrailFunctDemouHella 001001
       ROD: EV_TrailFunctDemouHella.rod
       VCID: 74B027EF5E35CBDB473-8020
       Part No SW: 5Q0 959 595 A    HW: 5Q0 959 595
       Component: TSG HFS       010 0006
       Serial number: 21051301100167
       Coding: 000C86204000040000001002
       VCID: 41DEBE3B51072E731C5-8014
       Component: TSG HBFS      010 0006
       Serial number: 21051306070165
    End----------(Elapsed Time: 01:23, VBatt start/end: 12.4V/12.3V)-----------
    If it is the correct Autoscan, then you mean an Audi A3 (8V) ?
    If so, it is Adaptation [BCM-09], search for this Channel:
    Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht (IDE06864-ENG116593)
    Change to "Active"
    First use Security Access.
  3. Likes Uwe, PetrolDave liked this post
