Results 1 to 7 of 7
Thread: Tiguan Steering angle sensor problem
    May 2020
    Question Tiguan Steering angle sensor problem
    We changed the clock spring after its cable has failed. With new clock spring module there appeared several fault codes. Most of the codes and indicator lights turned off when we made steering angle configuration through ABS module and teached the steering wheel turning limits by turning wheel from one limit to another. We also modified the steering wheel module long coding to be proper (cruise control and some other buttons were mixed). Now the power steering MIL is still on and i have no more ideas what to redefine or modify.
    According to autoscan it seems that G85 has no connection to other systems, i suppose. When we tried to calibrate steering angle sensor through Steering wheel module, VCDS says that data is in wrong form.
    New clock spring part should be same kind as original, spare part is OE part from VW seller and it has been ordered with part number from original part.
    Sunday,17,May,2020,17:21:06:05483
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
    VCDS Version: 20.4.1.0
    Dealer/Shop Name: Valtterin Paja Oy
    VIN: WVGZZZ5NZDW101302   License Plate: CIZ-307
    Mileage: 150600km-93578mi   Repair Order: tiguan skannaus3
    Chassis Type: 5N-VW36 (7N0)
    Scan: 01 03 08 09 15 16 17 18 19 22 25 42 44 46 4C 52 53 56 61 62
              69 72
    VIN: WVGZZZ5NZDW101302   Mileage: 150600km-93578miles
    04-Steering Angle -- Status: Sporadic communication error 1000
    16-Steering wheel -- Status: Sporadic communication error 1000
       Part No SW: 03L 906 018 E    HW: 03L 907 309 AE
       Component: R4 2.0l TDI   X28 9977
       Revision: 41X28---    Serial number: 00000000000000
       Coding: 0019001A043601080000
       Shop #: WSC 16004 205 00000
       ASAM Dataset: EV_ECM20TDI01103L906018E 003010
       ROD: EV_ECM20TDI01103L906018E_VW36.rod
       VCID: 2C570AEC471E5CE687-8078
    4984 - Cylinder 1 Glow Plug Circuit (Q10)
              P0671 00 [101] - Electrical Fault
                        Mileage: 150601 km
                        Date: 2020.05.17
                        Time: 00:21:39
                        Engine speed: 890.50 /min
                        Normed load value: 34.1 %
                        Coolant temperature: 19 C
                        Intake air temperature: 9 C
                        Voltage terminal 30: 12.380 V
                        Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                        Electric auxiliary heater: shut-off conditions-Bits 0-7: 2
                        Electric auxiliary heater: relay activation-Bits 0-7: 0
                        Preheat time: 300 ms
                        Glow status-Bits 0-7: 0
                        Glow status-Bits 0-7: 176
                        Glow cycles above temperature threshold-Bits 0-7: 8
                        Glow cycles above temperature threshold-Bits 0-7: 10
                        Glow cycles below temperature threshold-Bits 0-7: 6
                        Glow cycles below temperature threshold-Bits 0-7: 74
                        Outside air temperature: 8.0 C
    4729 - Steering Effort Control Module
              U0130 00 [038] - No Communications
                        Mileage: 150601 km
                        Date: 2020.05.17
                        Time: 00:21:30
                        Limitation: accelerator pedal: 126.6 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 40
                        selected gear-Bits 0-7: 0
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 BD    HW: 5N0 614 109 BD
       Component: J104   C6 450M VD61 0011
       Revision: --H07---    Serial number: 00000006828627
       Coding: 0037950
       VCID: 6ED3C0E479826EF6E9-803A
       Part No SW: 5K0 907 044 GM    HW: 5K0 907 044 GM
       Component: Climatronic   H19 1313
       Revision: 00001004
       Coding: 0010004003
       VCID: 7CF7FAACF7FE0C6657-8028
       Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
       Component: BCM PQ35 M    021 0068
       Revision: BC021001
       Coding: 40180A3B88251AC0408800C0340081644B51AA88636DAD606480C7000041
       VCID: 3E7330A4A962DE7639-806A
       Subsystem 1 - Part No SW: 5N1 955 119 C    HW: 5N1 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 19021  10  0603
       Coding: 009795
       Component: RLS 040413 05  54  0403
       Coding: 02304D
                        Reset counter: 136
                        Mileage: 150591 km
                        Date: 2014.10.07
                        Time: 05:41:30
                            Term 15 Off
                        Voltage: 12.30 V
                        Reset counter: 137
                        Mileage: 150591 km
                        Date: 2014.10.07
                        Time: 05:25:42
                        Voltage: 12.35 V
    01259 - Fuel Pump Relay (J17)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 97
                        Mileage: 150601 km
                        Date: 2014.10.08
                        Time: 00:00:05
                            Term 15 Off
                        Voltage: 12.75 V
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__20J VW10 HI   2118
       Revision: 26019000    Serial number: 003L7P5XT1VQ
       Coding: 0012362
       VCID: 7CF7FAAC3FFE0C6657-8028
       Subsystem 1 - Serial number: 6332MTS612120733
       Subsystem 2 - Serial number: 6342MTS632030723
       Subsystem 3 - Serial number: 6351HTS6EQ4FRBKR
       Subsystem 4 - Serial number: 6361HTS60MVFRBKJ
       Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
       Revision: --X01---    Serial number: 20200303200218
       Coding: 1182140000
       Shop #: WSC 01286 386 08256
       VCID: 020B8454951A7A961D-8056
       Component: E221__MFL-TAS  H31 0033
       Serial number: 0560351
       Coding: 820000
       Part No SW: 5N0 920 883 A    HW: 5N0 920 883 A
       Component: KOMBI         H05 0505
       Coding: 111F01
       VCID: 326B1494653A0A16CD-8066
    Address 18: Aux. Heat        Labels: 1K0-815-007.clb
       Part No: 7N0 963 272 C
       Component: Standheizer     044 4840
       Revision: 00044000    Serial number: 09024302000000
       Coding: 0031032
       VCID: 35612F885C541D2EE8-8060
       Part No SW: 7N0 907 530 AG    HW: 7N0 907 530 AG
       Component: J533  Gateway H53 1634
       Revision:   H53       Serial number: 290313F1001044
       Coding: 356002
       VCID: 75E1EF88DCD45D2E28-8020
                        Reset counter: 137
                        Mileage: 150591 km
                        Date: 2014.10.07
                        Time: 05:25:41
                        Fault Status: 00110100
                        Reset counter: 136
                        Mileage: 150591 km
                        Date: 2014.10.07
                        Time: 05:41:31
       Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
       Component: Haldex 4Motion      0043
       Coding: 0000005
       VCID: 4D916768D4C475EEB0-8018
                        Reset counter: 10
                        Mileage: 150583 km
                        Date: 2014.10.07
                        Time: 03:58:40
       Component: IMMO          H05 0505
       VCID: 6ADBCCF48D6A82D6B5-803E
       Part No SW: 5N0 959 701 G    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0503
       Revision: 12110009    Serial number: 0006728189
       Coding: 0210BE
       VCID: 397923B8B84CF94E0C-806C
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  009 1504
       Serial number: 00000007793485
       Coding: 000090
       Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.287 1202
       Revision: 1BH04839    Serial number: 00130800160701
       Coding: 0000258
       VCID: 3F8D4DA06E68D77E32-806A
    03375 - Steering Motor
                003 - Mechanical Failure - MIL ON
                        Fault Status: 11100011
                        Reset counter: 95
                        Mileage: 150583 km
                        Date: 2014.09.23
                        Time: 02:14:53
                        (no units): 7.0
                        Steering Angle: 0.00
                            OK
                        (no units): 11
                        Reset counter: 137
                        Mileage: 150601 km
                        Date: 2014.10.08
                        Time: 00:21:52
                        RPM: 902 /min
                        (no units): 7.0
                        Voltage: 14.70 V
       Part No SW: 5N0 959 702 G    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0503
       Revision: 14110009    Serial number: 0006722182
       Coding: 0211BE
       VCID: 3A7B3CB4BD4AF25605-806E
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  009 1504
       Serial number: 00000007790997
       Coding: 000090
       Revision:   H19       Serial number: 00000000865900
       Coding: 0026167
       VCID: 3663288441521636E1-8062
    Address 56: Radio
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AG
       Component: Batt.regelung H53 1634
       Coding: 230F1859
       VCID: 71E9DB98A8BC710EF4-8024
       Component: J367-BDM  H07 0180
       Serial number: 40081A55571491170082
       Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
       Component: Anhaenger     H10 0110
       Revision: 3B001001    Serial number: 00000193132056
       Coding: 410D000101000000
       VCID: 31691B98683C310EB4-8064
    End-------------------------(Elapsed Time: 02:47)--------------------------
    Address 09: DTCs cleared
    Address 16,5K0 953 569 AL,recoded (Long Coding),from,1182140000,to,1182150000,(01286/386/08256),
    Address 16,5K0 953 569 AL,recoded (Long Coding),from,1182140000,to,1182140002,(01286/386/08256),
    Address 16,5K0 953 569 AL,recoded (Long Coding),from,1182140002,to,1182140000,(01286/386/08256),
    Address 44: DTCs cleared
    What should i do next? Thanks in advance
    Hi and welcome.
    Do you have a scan from before you replaced the clock spring?
    PS: Based on the scan, I've been able to Verify the OP, so moving to Car Repair Support.
  3. Likes Dana liked this post
    May 2020
    Thanks about getting verified
    Here is the scan with old clock spring:
    Saturday,02,May,2020,14:52:08:05483
    Mileage: 150580km-93566mi   Repair Order:
              69 72
    VIN: WVGZZZ5NZDW101302   Mileage: 150580km-93566miles
    15-Airbags -- Status: Malfunction 1010
    5132 - Valve for Fuel Metering (N290)
              P0090 00 [032] - Open Circuit
                        Mileage: 150334 km
                        Date: 2020.04.05
                        Time: 09:57:58
                        Coolant temperature: 16 C
                        Intake air temperature: 4 C
                        Voltage terminal 30: 13.160 V
                        Unlearning counter according OBD: 36
                        Engine status: COENG_FINISH
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 5
              P0671 00 [047] - Electrical Fault
                        Mileage: 91968 km
                        Date: 2018.01.18
                        Time: 10:38:44
                        Engine speed: 1039.00 /min
                        Normed load value: 56.1 %
                        Vehicle speed: 2 km/h
                        Coolant temperature: 22 C
                        Intake air temperature: 19 C
                        Voltage terminal 30: 12.220 V
                        Preheat time: 0 ms
                        Glow cycles above temperature threshold-Bits 0-7: 4
                        Glow cycles above temperature threshold-Bits 0-7: 200
                        Glow cycles below temperature threshold-Bits 0-7: 4
                        Glow cycles below temperature threshold-Bits 0-7: 52
                        Outside air temperature: 19.5 C
    4710 - No Communications with Airbag Control Module
              U0151 00 [032] - -
                        Mileage: 150334 km
                        Time: 00:00:00
                        Coolant temperature: 0 C
                        Intake air temperature: 1 C
                        Voltage terminal 30: 11.540 V
                        Cruise Control System (CCS): status-Bits 0-7: 44
       Component: J104   C6 450M VD5F 0011
       Coding: 0037950
                        Reset counter: 131
                        Mileage: 150334 km
                        Date: 2014.08.27
                        Time: 09:55:11
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 11.25 V
                        Bin. Bits: 00011111
                        Count: 257
                        Hex Value: 0x0000
       Revision: 00001004
       Coding: 0010004003
       Revision: BC021001
       Coding: 009795
       Coding: 02304D
    8 Faults Found:
    00059 - Terminal 30 for Interior Lighting
                        Fault Status: 00101011
                        Reset counter: 135
                        Mileage: 150334 km
                        Date: 2014.08.27
                        Time: 09:40:50
                            Term 15 Off
                        Voltage: 12.50 V
                        Reset counter: 135
                        Mileage: 150582 km
                        Date: 2014.09.23
                        Time: 14:30:03
                            Term 15 Off
                        Voltage: 12.25 V
    00834 - Signal for Activation of Heated Rear Window
                        Fault Status: 00101001
                        Reset counter: 135
                        Mileage: 150582 km
                        Date: 2014.09.23
                        Time: 14:26:56
                            Term 15 Off
                        Voltage: 12.30 V
                        Reset counter: 135
                        Mileage: 150334 km
                        Date: 2014.08.27
                        Time: 09:40:50
                            Term 15 Off
                        Voltage: 12.50 V
                        Reset counter: 131
                        Mileage: 150334 km
                        Date: 2014.08.27
                        Time: 09:55:14
                        Voltage: 11.85 V
                        Fault Status: 00101010
                        Fault Frequency: 7
                        Reset counter: 131
                        Mileage: 147138 km
                        Date: 2014.06.04
                        Time: 11:47:35
                        Voltage: 11.95 V
    03266 - Control Circuit for Signal Horn
                        Reset counter: 135
                        Mileage: 150582 km
                        Date: 2014.09.23
                        Time: 14:26:56
                            Term 15 Off
                        Voltage: 12.30 V
    03396 - Supply voltage terminal 30 for central locking
                        Reset counter: 135
                        Mileage: 150334 km
                        Date: 2014.08.27
                        Time: 09:40:50
                            Term 15 Off
                        Voltage: 12.50 V
       Coding: 0012362
                        Fault Status: 11100001
                        Mileage: 148213 km
                        Date: 2014.06.30
                        Time: 14:27:56
       Part No SW: 5K0 953 501 BH    HW: 5K0 953 569 L
       Revision: FF010041    Serial number: 20130402200667
       Coding: 1182140000
       VCID: 71E9DB98A0BC710EF4-8024
    365080 - Controls in Steering Wheel
                        Reset counter: 27
                        Mileage: 148213 km
                        Date: 2020.02.07
                        Time: 14:27:53
       Coding: 111F01
    12669184 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 131
                        Mileage: 150334 km
                        Date: 2020.04.05
                        Time: 09:55:12
    12718592 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 135
                        Mileage: 150582 km
                        Date: 2020.05.02
                        Time: 14:30:02
       Coding: 0031032
                        Reset counter: 131
                        Mileage: 150334 km
                        Date: 2014.08.27
                        Time: 09:55:14
    00664 - Fuel gauge
                        Fault Frequency: 107
                        Reset counter: 130
                        Mileage: 140650 km
                        Date: 2014.02.25
                        Time: 11:04:42
       Coding: 356002
                        Reset counter: 131
                        Mileage: 150334 km
                        Date: 2014.08.27
                        Time: 09:55:12
                        Reset counter: 135
                        Mileage: 150582 km
                        Date: 2014.09.23
                        Time: 14:30:02
       Coding: 0000005
       Coding: 0210BE
       Slave Driver:
       Coding: 000090
    68107 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 131
                        Mileage: 150334 km
                        Date: 2020.04.05
                        Time: 09:55:13
       Coding: 0000258
       Coding: 0211BE
       Slave Passenger:
       Coding: 000090
              U1111 00 [008] - -
                        Reset counter: 131
                        Mileage: 150334 km
                        Date: 2020.04.05
                        Time: 09:55:13
       Coding: 0026167
                        Reset counter: 131
                        Mileage: 150334 km
                        Date: 2014.08.27
                        Time: 09:55:11
                        Voltage: 11.40 V
                        Count: 74
                        Hex Value: 0x1273
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    Address 56: Radio
       Coding: 230F1859
    02563 - Trailer; Right Tail Lamps (M61)
                        Fault Status: 11101010
                        Reset counter: 94
                        Mileage: 150551 km
                        Date: 2014.08.30
                        Time: 12:53:33
    End-------------------------(Elapsed Time: 03:15)--------------------------
  5. Likes Uwe, Dana, Jack@European_Parts liked this post
  6. #4
    United States
    Thanks for including the older scan! The original 5K0-953-501-BH module does super several times but the 5K0-953-569-AL unit they sold you appears to be correct. We do have some 5K0-953-569-AL specific notes here but that (5N) Tiguan Limited horror story had a conflict with 02-Auto transmission. Since this vehicle has a manual transmission I don't believe that's the issue.
    Instead, I wonder if the brand new slip ring/16 module has problems? We encountered a brand new, dealer sourced, faulty new slip ring last week on a NAR market 2014 Passat and that car used:
    >    Revision: --X01---    Serial number: Removed
    >    Coding: 098A140000
    >    Shop #: Removed
    >    Multifunction steering wheel control module:
    >    Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
    >    Component: E221__MFL-YVJ  H07 0022
    >    Coding: E20000
    > 1 Fault Found:
    > 1140738 - Steering angle sensor
    >           B1168 54 [009] - Missing Calibration / Basic Setting
    That car needed G85 activated in address 16 coding (just like yours) and the ABS module would NOT calibrate G85 until the new module was replaced with another new unit from the dealer.
    I don't usually point blame at brand new dealer sourced parts but if the manufacture happened to have a bad run of parts you may have the same problem. I don't see any signs of G85 problems prior to the new 16 module installation and it looks more like it had the common N95 Airbag issue previously.
  7. Likes Uwe, Jack@European_Parts liked this post
  8. #5
    United States
    P.S. I never really looked at serial numbers in those modules but I tend to remove them when I'm posting scan data that I don't have explicit permission to share. In this case that was the new defective module so I believe it OK to share:
    Serial number: 20200121300539 (His)
    Serial number: 20200303200218 (Yours)
    My guess is they were manufactured on Jan 21st and March 3rd of this year. I don't have a final scan from that exact Passat but if you end up determining it twas a faulty new unit please post the final scan. It might help if we end up receiving more of these inquiries with new G85 problems after repairs.
  9. Likes Jack@European_Parts liked this post
  10. #6
    You may find that SVM dealer session is needed and I'm hearing this more and more, so please let us know if that is the case?
  11. Likes Dana liked this post
  12. #7
    May 2020
    Thanks a lot about your tips and advises!
    1. I talked with local VW dealer about the situation and they ordered a new clock spring.
    2.I installed it. And scan looked like this:
    Wednesday,03,June,2020,22:35:43:05483
    Mileage: 150600km-93578mi   Repair Order: 1. scan with 3.clock spring
              69 72
    4481 - Cruise Control Switch (E45)
              P0568 00 [039] - Implausible Signal
                        Mileage: 150601 km
                        Date: 2020.06.03
                        Time: 06:44:54
                        Coolant temperature: 23 C
                        Intake air temperature: 17 C
                        Voltage terminal 30: 11.440 V
                        Cruise Control System (CCS): switch position-Bits 0-7: 128
                        Cruise Control System (CCS): status-Bits 0-7: 8
                        Cruise control switch-off: irreversible-Bits 0-7: 255
                        Cruise control switch-off: reversible-Bits 0-7: 255
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
    4483 - Function Restriction due to Faults in Other Modules
              U1113 00 [039] - -
                        Mileage: 150601 km
                        Date: 2020.06.03
                        Time: 06:44:54
                        Cruise Control System (CCS): switch position-Bits 0-7: 192
                        Cruise Control System (CCS): status-Bits 0-7: 200
              P0671 00 [109] - Electrical Fault
                        Mileage: 150601 km
                        Date: 2020.05.17
                        Time: 00:21:39
              U0130 00 [032] - No Communications
                        Mileage: 150601 km
                        Date: 2020.05.17
                        Time: 00:21:30
       Coding: 0037950
                        Reset counter: 97
                        Mileage: 150601 km
                        Date: 2014.10.25
                        Time: 06:45:04
                        Hex Value: 0x0000
                        Voltage: 12.50 V
                        Bin. Bits: 00011110
                        Count: 191
                        Hex Value: 0x0000
                        Reset counter: 97
                        Mileage: 150601 km
                        Date: 2014.10.25
                        Time: 06:45:04
       Revision: 00001004
       Coding: 0010004003
       Revision: BC021001
       Coding: 009795
       Coding: 02304D
       Coding: 0012362
       Revision: --X01---    Serial number: 20200306100810
       Coding: 7982A00000
       Coding: 820000
    13 Faults Found:
    0516 - Databus
                        Reset counter: 97
                        Mileage: 150601 km
                        Date: 2020.06.03
                        Time: 06:44:55
    147462 - Terminal 15
              B1148 12 [009] - Short to Plus
    226827 - Turn Signal Switch
              B1144 13 [008] - Open Circuit
                        Fault Frequency: 7
                        Reset counter: 137
    226839 - Turn Signal Switch
              B1144 11 [008] - Short to Ground
                        Reset counter: 137
    227339 - Windshield Wiper Switch
              B1145 13 [008] - Open Circuit
                        Reset counter: 137
              B1149 13 [009] - Open Circuit
                        Reset counter: 97
    229127 - Cruise Control Switch
              B1154 11 [009] - Short to Ground
    229147 - Cruise Control Switch
              B1154 13 [009] - Open Circuit
    332660 - Databus
                        Reset counter: 137
    342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
              U0011 00 [008] - Performance
              U108E 00 [008] - No Communications
                        Reset counter: 137
    617736 - Selector Lever Park Position Lock Switch
              B1162 29 [008] - Signal Implausible
                        UBat: 13.30 V
                        MC1 interner Fehlercode: 0
                        MC2 interner Fehlercode: 0
       Coding: 111F01
       Coding: 0031032
       Coding: 356002
                        Reset counter: 137
                        Mileage: 150591 km
                        Date: 2014.10.07
                        Time: 05:25:41
                        Reset counter: 136
                        Mileage: 150591 km
                        Date: 2014.10.07
                        Time: 05:41:31
       Coding: 0000005
                        Reset counter: 138
                        Mileage: 150583 km
                        Date: 2014.10.07
                        Time: 03:58:40
       Coding: 0210BE
       Slave Driver:
       Coding: 000090
       Coding: 0000258
                        Reset counter: 95
                        Mileage: 150583 km
                        Date: 2014.09.23
                        Time: 02:14:53
                        (no units): 7.0
                            OK
                        (no units): 11
    02546 - Steering Limit Stop
                        Fault Status: 11100101
                        Reset counter: 97
                        (no units): 4.0
                        Voltage: 11.40 V
                        Reset counter: 97
                        Mileage: 150601 km
                        Date: 2014.10.25
                        Time: 06:48:04
                        (no units): 4.0
                            Not OK
                        (no units): 2
       Coding: 0211BE
       Slave Passenger:
       Coding: 000090
       Coding: 0026167
    Address 56: Radio
       Coding: 230F1859
    End-------------------------(Elapsed Time: 03:17)--------------------------
    3. I tried to configure G85 through steering wheel module basic settings. basic settings gave exactly same error as with the previous clock spring: ERROR: incorrect message length or invalid format.
    4. Through ABS module the calibration was accepted in some level and some faults was erased.
    5. Then I taught steering wheel limits by turning wheel from one limit to another as told here.
    6. I edited the steering wheel module coding to be as supposed. Cruise control button generated some "impalusible signal" fault code to engine module but that was erased after the button was turned on and off few times.
    7. I took a new scan and it looks like this:
    Wednesday,03,June,2020,23:28:34:05483
              69 72
       Coding: 0037950
       Revision: 00001004
       Coding: 0010004003
       Revision: BC021001
       Coding: 009795
       Coding: 02304D
                        Reset counter: 97
                        Mileage: 150601 km
                        Date: 2014.10.25
                        Time: 07:15:50
                        Voltage: 11.80 V
       Coding: 0012362
       Coding: 118A100000
       Coding: 820000
       Coding: 111F01
       Coding: 0031032
       Coding: 356002
       Coding: 0000005
       Coding: 0210BE
       Slave Driver:
       Coding: 000090
       Coding: 0000258
                        Reset counter: 95
                        Mileage: 150583 km
                        Date: 2014.09.23
                        Time: 02:14:53
                        (no units): 7.0
                            OK
                        (no units): 11
       Coding: 0211BE
       Slave Passenger:
       Coding: 000090
       Coding: 0026167
    Address 56: Radio
       Coding: 230F1859
    End-------------------------(Elapsed Time: 02:44)--------------------------
    8. Now the situation with G85 seems to be fixed!!! But the fault code related to power steering sounds relatively fatal. Power steering works perfectly and that fault appeared after the first new clock spring was installed. So my suggest is that fault code is some kind of ghost but what do you think? Is there some trick to erase that fault or is it really true that now power steering motor is faulty in some way
    Ps. what SVM delaer session means?
