Results 1 to 10 of 17
Thread: Audi A3 8P Driver door window auto close / open
    May 2019
    Romania
    Hey,
    Looking for some ideeas on a weird issue .
    2003 A3 8p.
    Removed battery to change steerigng wheel.
    After this the window for the driver side will not auto close/open from the driver switch.
    Ends have been learned , up,down , confirmed in measuring blocks in VCDS.
    The button works, I can see the auto close and auto open command being issued in the measuring blocks. The passenger window works fine.
    Tried another window switch , same behavior.
    Tried to let controller with not power for a few minutes , still nothing.
    Auto running is coded on the controller, tried coding controller to 0 , power cycle and code it back , still nothing.
    If I close the windows from the remote it will go up automatically as I have automatic closing coded in the Convenience Module 46.
    My next step will be taking a new controller but I have never seen a car do this ...
    Any ideas, anyone seen this before ?
    HQ
    Please post Auto-Scan.
    If I understand correctly, you can only roll the driver's window up with the remote?
    Jef
    May 2019
    Romania
    I can post an autoscan in a few hours need to go down to the car again. There is no error logged on the car.
    Basic settings are done.
    Yes I can roll it up and down with the key. It also auto rolls all the way up when holding down close for 2s and then releasing as set in the convince module.
    The problem seems to be it stops the auto roll down/up when using the driver window switch ...
    Near Philadelphia, PA, USA
    Quote Originally Posted by DjDvr View Post
    The autoscan tells much more than just fault codes. It tells how the car is equiped with which module and which software. We need that to look things up and help you.
    Battery reset again with full reboot yet?
    May 2019
    Romania
    Friday,22,May,2020,16:40:15:23804
    VCDS Version: 20.4.1.0  HEX-NET CB: 0.4508.4
    VIN: WAUZZZ8P84A051357   License Plate: SB23XUS
    Mileage: 292940km-182024mi   Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 76 7D
    VIN: WAUZZZ8P84A051357   Mileage: 292940km-182024miles
    Address 01: Engine        Labels: 03G-906-016-BKC.clb
       Part No SW: 03G 906 016 J    HW: 028 101 138 3
       Component: R4 1,9L EDC G000SG  5347
       Revision: 12345678    Serial number: AUX7Z0C6FNT06F
       Coding: 0000071
       Shop #: WSC 06435 000 00000
       VCID: AA187BE905A355D6F5-80FE
    Readiness: 0 0 1 1 1
       Part No: 1K0 907 379 D
       Coding: 0053894
       VCID: B326668DD269141E46-80E6
       Part No SW: 8U0 820 043 J    HW: 8U0 820 043 J
       Component: E87  Klimavoll      0220
       Revision: 00H05000    Serial number: 8U0820043J
       VCID: B83C51A1CB0FF74673-80EC
    01855 - Temperature Sensor for Heated Seat; Left Front (G344)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 132
                        Mileage: 291656 km
                        Date: 2000.02.10
                        Time: 20:03:56
                        Temperature: 23.5°C
                        Voltage: 12.60 V
                        Current: 0.000 A
                        (no units): 3.0
                        Temperature: -50.0°C
                        Temperature: 65.0°C
    01856 - Temperature Sensor for Heated Seat; Front Right (G345)
                        Reset counter: 132
                        Mileage: 291656 km
                        Date: 2000.02.10
                        Time: 20:03:56
                        Temperature: 23.5°C
                        Voltage: 12.60 V
                        Current: 0.000 A
                        (no units): 0.0
                        Temperature: -99.0°C
                        Reset counter: 132
                        Mileage: 291656 km
                        Date: 2020.02.10
                        Time: 20:03:56
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
       Part No SW: 8P0 907 279 P    HW: 8P0 907 279 P
       Component: Bordnetz-SG     H63 2904
       Revision: 00H63000    Serial number: 00000004681726
       Coding: AD8857208294109E00002800000000000009FF1F0001020E008000000000
       Shop #: WSC 16070 123 104857
       VCID: CAD81B69A5E375D615-809E
       Subsystem 1 - Part No: 8P1 955 119   Labels: 1TX-955-119.CLB
       Component: Wischer WWS Audi350 0130
       Coding: 16711696
       Shop #: WSC 16070
    Address 15: Airbags        Labels: 8P0-959-655-84.lbl
       Part No SW: 8P0 959 655 F    HW: 8P0 959 655 F
       Component: Airbag 8.4ED    H01 0130
       Coding: 0010602
       VCID: C5C228558CFD9AAEF8-8090
       Part No SW: 8P0 953 549 G    HW: 8P0 953 549 G
       Component: Lenksäulenmodul H36 0070
       Coding: 0000042
       Shop #: WSC 73571 136 85310
       VCID: C2C833499DD3AD96DD-8096
       Part No SW: 8P0 920 930 F    HW: 8P0 920 930 F
       Component: KOMBIINSTR. VDO H25 0080
       Revision: D05         Serial number: 2246CD05000370
       Coding: 0004003
       Shop #: WSC 00001 001 00001
       VCID: B5225895DC1D0A2E68-80E0
       Part No SW: 1K0 907 530 B    HW: 1K0 907 951
       Component: Gateway         H08 0090
       Revision: 08          Serial number: 240010371891D2
       Coding: 3D0F0F42070100
       VCID: A6008FD911BB71B6D1-80F2
       Revision: D05         Serial number: AUX7Z0C6FNT06F
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
       Part No SW: 8P0 959 801 J    HW: 8P0 959 801 J
       Component: Tuer-SG         H03 0060
       Coding: 0004208
       Shop #: WSC 06314 000 00000
    Address 44: Steering Assist        Labels: 1Kx-909-143-GEN1.clb
       Part No: 1K1 909 143 L
       Component: EPS_ZFLS Kl.6       0402
       Part No: 8P0 959 433 B
       Component:    KSG          H02 0030
       Coding: 58A000583F008505488A016000
       Shop #: WSC 06435 123 12345
       VCID: BB364EADFA39DC5E9E-80EE
       Part No SW: 8P3 035 382     HW: 8P3 035 382
       Component: AB2 SUBWOOFERBOXH23 0100
       Revision: 00001       Serial number: 10000001038019
       VCID: F0ACA981E3FF6F067B-80A4
    Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MAX2.lbl
       Part No: 8P0 959 802 G
       Component: Tuer-SG         020 0100
       Coding: 0000368
       VCID: C0CC394193DFBF86CB-8094
       Part No SW: 8P0 035 186 AB    HW: 8P0 035 186 AB
       Component: R Concert2+     H05 0293
       Revision: 00H05000    Serial number: AUZ1Z3L2337145
       Coding: 0120211
       VCID: F2A8A389EDF35D168D-80A6
    00856 - Radio Antenna
                        Reset counter: 203
                        Mileage: 292943 km
                        Date: 2020.05.22
                        Time: 12:17:36
    Address 76: Park Assist        Labels: 8P0-919-283.lbl
       Part No SW: 8P0 919 283     HW: 8P0 919 283
       Component: Parkhilfe 4-Kan H06 0020
       Coding: 0000003
       VCID: F8BC91A18B8F3746B3-80AC
       Part No SW: 1K0 963 235 C    HW: 1K0 963 235 C
       Revision: 00600000    Serial number:
       VCID: AB167EED0A594CDE0E-80FE
                014 - Defective
    End----------(Elapsed Time: 01:27, VBatt start/end: 12.1V/12.2V)-----------
    Ignore the HVAC error as it's a Q3 climate control on A3 , all works fine there and seats are not connected yet. It is working like this for over 6 months now.
    There is a J controller on the driver door for auto closing mirrors with remote in FL controllers, it has been in there for over 2 years and working fine, removed battery loads of times no issue.[IMG] https://ibb.co/7RZvm8D [/IMG]
  7. #7
    May 2019
    Romania
    What do you mean full reboot ? Removed batter 2 times left it 5 minutes and tried to learn ends again.
  8. #8
    May 2019
    Romania
    Left controller off power for 12 h, connected this morning , still the same ... Anyone else have an ideea? Other than new controller ...
  9. #9
    Mar 2017
    Have you checked the door loom wires to see if they are all ok
  10. Likes Uwe liked this post
  11. #10
    May 2019
    Romania
    Quote Originally Posted by ch1z64 View Post
    Everything works , I can see the command being issued, windows goes UP automatically if I close it with the remote.
    Just left it for 12h with no power still the same ... I guess a new controller is the only next step ...
