Results 1 to 9 of 9
Thread: Limp Mode CJAA wrenchers please help!
    New User
    May 2020
    WA, USA
    Car is occasionally studdering. It gave me a camshaft position sensor code and a throttle body code with limp mode. Cleaned and lubed throttle body thought all is well. 2000 miles later the cam shift position sensor code went on without a check engine light up or any issues. The next day on my way to work the car started shuddering real bad while just driving normal, tried to accelerate and limp mode again with a bunch of other codes. Maybe bad camshaft sensor or a bad wiring harness? Ecu? What do you think?
    Thursday,21,May,2020,13:38:12:38103
    VIN: 3VWPL7AJ1BM667128   License Plate:
    Mileage: 146370km-90950mi   Repair Order:
                    Address 01: Engine       Labels: 03L-906-022-CBE.clb
    Control Module Part Number: 03L 997 030 B    HW: 03L 906 019 DA
      Component and/or Version: R4 2.0l TDI G000AG  9983
               Software Coding: 0050078
                Work Shop Code: WSC 13327 002 1048576
                          VCID: 2D070B6891187313C8D-8078
    7 Faults Found:
    000833 - Camshaft Position Sensor (G40)
                   P0341 - 000 - Implausible Signal - Intermittent
                        Fault Frequency: 53
                        Mileage: 146258 km
                        Date: 2020.05.20
                        Time: 12:22:30
                        RPM: 3473 /min
                        Speed: 74.0 km/h
                        Voltage: 14.06 V
                        Temperature: 77.4C
                        Idle Stabilization: -2.7KW
                        RPM: 1721 /min
                        (no units): 48.0
    001151 - Exhaust Pressure Control Valve
                   P047F - 000 - Stuck Open - Intermittent
                        Mileage: 146310 km
                        Date: 2020.05.21
                        Time: 02:40:29
                        RPM: 2139 /min
                        Speed: 109.0 km/h
                        Load: 47.1 %
                        Load: 21.6 %
                        Lambda: 26.8 %
                        Temperature: 384.0C
                        Temperature: 79.2C
    001162 - Exhaust Pressure Control Valve 1
                   P048A - 000 - Stuck Closed - Intermittent
                        Mileage: 146310 km
                        Date: 2020.05.21
                        Time: 02:40:29
                        RPM: 2162 /min
                        Speed: 109.0 km/h
                        Load: 44.3 %
                        Load: 100.0 %
                        Lambda: 52.9 %
                        Temperature: 384.0C
                        Temperature: 79.2C
    008196 - Intake Manifold Flap; Bank 1
                   P2004 - 000 - Stuck Open - Intermittent
                        Mileage: 146316 km
                        Date: 2020.05.21
                        Time: 02:44:23
                        RPM: 2162 /min
                        Speed: 110.0 km/h
                        Load: 45.1 %
                        Load: 100.0 %
                        Lambda: 11.8 %
                        Mass Air / Rev.: 735.0 mg/str
                        Temperature: 81.0C
    008198 - Intake Manifold Flap; Bank 1
                   P2006 - 000 - Stuck Closed - Intermittent
                        Mileage: 146316 km
                        Date: 2020.05.21
                        Time: 02:44:23
                        RPM: 2162 /min
                        Speed: 110.0 km/h
                        Load: 45.1 %
                        Load: 100.0 %
                        Lambda: 42.6 %
                        Mass Air / Rev.: 740.0 mg/str
                        Temperature: 81.0C
    001601 - Sensor Reference Voltage A
                   P0641 - 000 - Open Circuit - Intermittent
                        Mileage: 146299 km
                        Date: 2020.05.21
                        Time: 02:31:26
                        RPM: 1978 /min
                        Speed: 100.0 km/h
                        Load: 38.0 %
                        Voltage: 13.60 V
                        Temperature: 81.9C
                        (no units): 0.0
                        Torque: 105.0 Nm
    008504 - Accelerator Position Sensors (G79) / (G185)
                   P2138 - 001 - Implausible Correlation - Intermittent
                        Fault Status: 00100001
                        Mileage: 146323 km
                        Date: 2020.05.21
                        Time: 02:48:54
                        RPM: 1495 /min
                        Speed: 75.0 km/h
                        Load: 39.2 %
                        Voltage: 13.68 V
                        Voltage: 0.836 V
                        Voltage: 0.988 V
                        Bin. Bits:  1 00  0
    New User
    May 2020
    WA, USA
    Car drove great today without any issues.... i didn't do anything to it. Any idea why the hick up?
    Clear the fault codes and see if any come back.
    It's not unknown for the ECU software to 'get out of bed the wrong side'
  4. Likes Uwe liked this post
    New User
    May 2020
    WA, USA
    car is having some serious issues. Updated faults. I inspected the throttle body again. All the gears on the inside look good. Did an output test of the throttle body and visual watched the butterfly flap open and close. Figured might as well clean the egr since I got the throttle boddy off. Put it all back together still having issues. The car will go through spurts of full power no issues then just start to stutter. Not sure whats going on.
    Sunday,31,May,2020,10:25:46:38103
                          VCID: 2D070B6891087313C8D-5184
    10 Faults Found:
    001592 - Throttle Body Actuator Bank 1 (J338)
                   P0638 - 000 - Implausible Signal - Intermittent - MIL ON
                        Fault Status: 10100000
                        Mileage: 147425 km
                        Date: 2020.06.01
                        Time: 09:56:00
                        Voltage: 12.39 V
                        Lambda: 99.4 %
                        Bin. Bits: 00000000
                        Fault Frequency: 142
                        Mileage: 147393 km
                        Date: 2020.06.01
                        Time: 02:34:34
                        RPM: 2185 /min
                        Speed: 111.0 km/h
                        Voltage: 13.53 V
                        Temperature: 82.8C
                        Idle Stabilization: -5.0KW
                        RPM: 2177 /min
                        (no units): 48.0
                   P2004 - 000 - Stuck Open - Intermittent - MIL ON
                        Fault Frequency: 7
                        Mileage: 147395 km
                        Date: 2020.06.01
                        Time: 02:35:32
                        RPM: 2116 /min
                        Speed: 107.0 km/h
                        Load: 54.1 %
                        Load: 94.9 %
                        Lambda: 100.2 %
                        Mass Air / Rev.: 665.0 mg/str
                        Temperature: 82.8C
                   P2006 - 000 - Stuck Closed - Intermittent - MIL ON
                        Fault Frequency: 7
                        Mileage: 147395 km
                        Date: 2020.06.01
                        Time: 02:35:32
                        RPM: 2116 /min
                        Speed: 107.0 km/h
                        Load: 54.1 %
                        Load: 94.9 %
                        Lambda: 38.7 %
                        Mass Air / Rev.: 700.0 mg/str
                        Temperature: 82.8C
                        Mileage: 147396 km
                        Date: 2020.06.01
                        Time: 02:36:28
                        RPM: 2116 /min
                        Speed: 107.0 km/h
                        Load: 34.5 %
                        Load: 40.8 %
                        Lambda: 45.8 %
                        Temperature: 594.0C
                        Temperature: 83.7C
                        Mileage: 147396 km
                        Date: 2020.06.01
                        Time: 02:36:28
                        RPM: 2116 /min
                        Speed: 107.0 km/h
                        Load: 24.7 %
                        Load: 41.2 %
                        Lambda: 71.8 %
                        Temperature: 594.0C
                        Temperature: 83.7C
    005000 - Control Module Malfunction - DBW Throttle Monitoring
                   P1388 - 004 -  - Intermittent - MIL ON
                        Fault Status: 10100100
                        Mileage: 147449 km
                        Date: 2020.06.01
                        Time: 10:16:02
                        RPM: 1518 /min
                        Speed: 77.0 km/h
                        Voltage: 13.83 V
                        Voltage: 2.736 V
                        Voltage: 1.368 V
                        Torque: -70.0 Nm
                        Bin. Bits:  0000000
                   P1388 - 000 -  - Intermittent
                        Fault Frequency: 21
                        Mileage: 147449 km
                        Date: 2020.06.01
                        Time: 10:16:02
                        RPM: 1518 /min
                        Speed: 77.0 km/h
                        Bin. Bits:  0000000
                        Inj. Quantity: 6.3 mg/str
                        Hex Value: 0xFF6C
                        Hex Value: 0xFF01
    009305 - Diesel Particulate Filter
                   P2459 - 000 - Regeneration Frequency
                        Mileage: 147409 km
                        Date: 2020.06.01
                        Time: 02:44:32
                        RPM: 1863 /min
                        Speed: 58.0 km/h
                            21.3
                            4.2
                        Pressure: 0 mbar
                        milliliters: 108 ml
    008482 - Accelerator Position Sensor (G79)
                   P2122 - 000 - Signal too Low - Intermittent
                        Mileage: 147458 km
                        Date: 2020.06.01
                        Time: 10:22:41
                        RPM: 1587 /min
                        Speed: 67.0 km/h
                        Voltage: 14.14 V
                        Voltage: 0.684 V
                        Voltage: 0.380 V
                        Bin. Bits:  0 01  0
    Readiness: 1 6 0 0 1
    Address 01: DTCs clearedMonday,01,June,2020,17:56:36:38103
    7 Faults Found:
                        Fault Frequency: 7
                        Mileage: 147459 km
                        Date: 2037.14.24
                        Time: 10:27:05
                        RPM: 2093 /min
                        Speed: 64.0 km/h
                        Voltage: 13.91 V
                        Temperature: 75.6C
                        RPM: 1026 /min
                        (no units): 48.0
                        Mileage: 147462 km
                        Date: 2037.14.24
                        Time: 10:29:08
                        RPM: 2093 /min
                        Speed: 105.0 km/h
                        Load: 45.5 %
                        Load: 94.9 %
                        Lambda: 78.9 %
                        Mass Air / Rev.: 525.0 mg/str
                        Temperature: 81.9C
                        Mileage: 147462 km
                        Date: 2037.14.24
                        Time: 10:29:08
                        RPM: 2093 /min
                        Speed: 105.0 km/h
                        Load: 39.6 %
                        Load: 46.3 %
                        Lambda: 71.8 %
                        Temperature: 456.0C
                        Temperature: 81.9C
                        Mileage: 147462 km
                        Date: 2037.14.24
                        Time: 10:29:08
                        RPM: 2093 /min
                        Speed: 105.0 km/h
                        Load: 37.6 %
                        Load: 94.9 %
                        Lambda: 97.1 %
                        Mass Air / Rev.: 515.0 mg/str
                        Temperature: 81.9C
                        Mileage: 147462 km
                        Date: 2037.14.24
                        Time: 10:29:08
                        RPM: 2070 /min
                        Speed: 105.0 km/h
                        Load: 34.9 %
                        Load: 45.9 %
                        Lambda: 86.0 %
                        Temperature: 456.0C
                        Temperature: 81.9C
                   P0641 - 000 - Open Circuit - MIL ON
                        Fault Status: 11100000
                        Mileage: 147463 km
                        Date: 2037.14.24
                        Time: 10:29:39
                        RPM: 2001 /min
                        Speed: 102.0 km/h
                        Load: 47.1 %
                        Voltage: 13.68 V
                        Temperature: 82.8C
                        (no units): 0.0
                        Torque: 198.0 Nm
    000618 - Charge Air Cooler
                   P026A - 000 - Efficiency Below Threshold
                        Mileage: 147466 km
                        Date: 2037.14.24
                        Time: 10:31:29
                        RPM: 1817 /min
                        Speed: 92.0 km/h
                        Temperature: 15.3C
                        Temperature: 12.6C
                        (no units): 132.6
                        Temperature: 78.0C
                        (no units): 0.0
                    Address 01: Engine       Labels: 03L-906-022-CBE.CLB
                        Mileage: 147470 km
                        Date: 2037.14.25
                        Time: 17:57:26
                        Voltage: 11.78 V
                        Temperature: 13.5C
                        (no units): 0.0
                        Torque: -150.0 Nm
    Readiness: 0 0 0 1 1
                        Mileage: 147470 km
                        Date: 2037.14.25
                        Time: 18:00:46
                        Voltage: 11.86 V
                        Temperature: 13.5C
                        (no units): 0.0
                        Torque: -150.0 Nm
                   P2122 - 000 - Signal too Low - MIL ON
                        Mileage: 147470 km
                        Date: 2037.14.25
                        Time: 20:03:26
                        RPM: 138 /min
                        Voltage: 9.20 V
                        Voltage: 0.684 V
                        Voltage: 0.380 V
                        Bin. Bits:  1 00  0
                          VCID: 2D070B6891087313C8D-5160
                        Mileage: 147470 km
                        Date: 2037.14.25
                        Time: 20:08:22
                        RPM: 1380 /min
                        Voltage: 13.91 V
                        Temperature: 32.4C
                        Idle Stabilization: -1.4KW
                        RPM: 1037 /min
                        (no units): 48.0
                        Mileage: 147472 km
                        Date: 2037.14.25
                        Time: 20:15:07
                        RPM: 1265 /min
                        Speed: 36.0 km/h
                        Load: 55.3 %
                        Load: 94.9 %
                        Lambda: 85.2 %
                        Mass Air / Rev.: 565.0 mg/str
                        Temperature: 63.9C
                        Mileage: 147472 km
                        Date: 2037.14.25
                        Time: 20:15:07
                        RPM: 1265 /min
                        Speed: 36.0 km/h
                        Load: 55.3 %
                        Load: 94.9 %
                        Lambda: 99.4 %
                        Mass Air / Rev.: 555.0 mg/str
                        Temperature: 63.9C
                        Mileage: 147472 km
                        Date: 2037.14.25
                        Time: 20:15:19
                        RPM: 966 /min
                        Speed: 34.0 km/h
                        Load: 4.3 %
                        Voltage: 13.76 V
                        Temperature: 65.7C
                        (no units): 0.0
                        Torque: 111.0 Nm
                        Mileage: 147470 km
                        Date: 2037.14.25
                        Time: 20:08:22
                        RPM: 1380 /min
                        Voltage: 13.91 V
                        Temperature: 32.4C
                        RPM: 1037 /min
                        (no units): 48.0
                        Mileage: 147472 km
                        Date: 2037.14.25
                        Time: 20:15:07
                        RPM: 1265 /min
                        Speed: 36.0 km/h
                        Load: 55.3 %
                        Load: 94.9 %
                        Lambda: 85.2 %
                        Temperature: 63.9C
                        Mileage: 147472 km
                        Date: 2037.14.25
                        Time: 20:15:07
                        RPM: 1265 /min
                        Speed: 36.0 km/h
                        Load: 55.3 %
                        Load: 94.9 %
                        Lambda: 99.4 %
                        Temperature: 63.9C
                        Mileage: 147472 km
                        Date: 2037.14.25
                        Time: 20:15:19
                        RPM: 966 /min
                        Speed: 34.0 km/h
                        Load: 4.3 %
                        Voltage: 13.76 V
                        Temperature: 65.7C
                        (no units): 0.0
                        Torque: 111.0 Nm
                        Fault Frequency: 12
                        Mileage: 147472 km
                        Date: 2037.14.25
                        Time: 20:18:41
                        RPM: 3726 /min
                        Speed: 48.0 km/h
                        Voltage: 13.76 V
                        Temperature: 65.7C
                        Idle Stabilization: -4.5KW
                        RPM: 1938 /min
                        (no units): 48.0
                        Mileage: 147474 km
                        Date: 2037.14.25
                        Time: 20:21:20
                        RPM: 1679 /min
                        Speed: 13.0 km/h
                        Load: 31.8 %
                        Load: 94.9 %
                        Lambda: 96.3 %
                        Mass Air / Rev.: 215.0 mg/str
                        Temperature: 76.5C
                        Mileage: 147474 km
                        Date: 2037.14.25
                        Time: 20:21:20
                        RPM: 1679 /min
                        Speed: 13.0 km/h
                        Load: 23.1 %
                        Load: 94.9 %
                        Lambda: 37.1 %
                        Mass Air / Rev.: 275.0 mg/str
                        Temperature: 76.5C
                        Mileage: 147474 km
                        Date: 2037.14.25
                        Time: 20:21:48
                        RPM: 1288 /min
                        Speed: 29.0 km/h
                        Voltage: 13.53 V
                        Voltage: 0.684 V
                        Voltage: 0.380 V
                        Bin. Bits:  1 01  0
                        Mileage: 147474 km
                        Date: 2037.14.25
                        Time: 20:22:11
                        RPM: 966 /min
                        Speed: 18.0 km/h
                        Voltage: 13.76 V
                        Temperature: 76.5C
                        (no units): 0.0
                        Torque: 0.0 Nm
    Fault Codes have been Erased
                        Mileage: 147474 km
                        Date: 2037.14.25
                        Time: 20:24:00
                        RPM: 828 /min
                        Load: 100.0 %
                        Lambda: 99.4 %
                        Mass Air / Rev.: 500.0 mg/str
                        Temperature: 75.6C
                        Mileage: 147474 km
                        Date: 2037.14.25
                        Time: 20:24:25
                        RPM: 828 /min
                        Load: 10.6 %
                        Lambda: 100.2 %
                        Mass Air / Rev.: 265.0 mg/str
                        Temperature: 74.7C
    Address 01: DTCs clearedMonday,01,June,2020,20:36:06:38103
                        Mileage: 147474 km
                        Date: 2037.14.25
                        Time: 20:32:49
                        RPM: 2185 /min
                        Speed: 28.0 km/h
                        Voltage: 13.68 V
                        Temperature: 77.4C
                        RPM: 2063 /min
                        (no units): 48.0
                        Mileage: 147474 km
                        Date: 2037.14.25
                        Time: 20:33:36
                        RPM: 966 /min
                        Speed: 6.0 km/h
                        Voltage: 13.45 V
                        Temperature: 78.3C
                        (no units): 0.0
                        Torque: 60.0 Nm
                   P0638 - 000 - Implausible Signal - MIL ON
                        Mileage: 147475 km
                        Date: 2037.14.25
                        Time: 20:35:45
                        Voltage: 12.62 V
                        Lambda: 99.4 %
                        Bin. Bits: 00000000
                        Mileage: 147475 km
                        Date: 2037.14.25
                        Time: 20:37:22
                        Voltage: 12.01 V
                        Lambda: 99.4 %
                        Bin. Bits: 00000000
    The fact that you have an "Accelerator Position Sensor" fault pretty consistently makes me suspect you have a flaky ECU and the rest of those faults may be due to the flaky ECU rather than anything real with that stuff. Check wiring diagrams to be sure, but I think the accelerator position sensors go directly back to the ECU; they have no connection to anything else.
    Now verifying the wiring between the ECU and swapping out that sensor assembly if the wiring checks out is much cheaper/easier than swapping out the ECU, so I'd suggest doing that first, but I doubt it will yield any joy.
    New User
    May 2020
    WA, USA
    I'll check into it. Thank you
    New User
    May 2020
    WA, USA
    Updated fault code from today's drive.
    Tuesday,02,June,2020,09:19:01:38103
                        Mileage: 147475 km
                        Date: 2037.14.26
                        Time: 09:18:59
                        RPM: 299 /min
                        Voltage: 10.41 V
                        Temperature: 12.6C
                        (no units): 0.0
                        Torque: 171.0 Nm
    Address 01: DTCs clearedTuesday,02,June,2020,09:42:51:38103
    8 Faults Found:
                        Fault Frequency: 22
                        Mileage: 147475 km
                        Date: 2037.14.26
                        Time: 09:26:17
                        RPM: 3519 /min
                        Speed: 46.0 km/h
                        Voltage: 14.06 V
                        Temperature: 40.5C
                        RPM: 2907 /min
                        (no units): 48.0
                        Mileage: 147482 km
                        Date: 2037.14.26
                        Time: 09:32:21
                        RPM: 1794 /min
                        Speed: 91.0 km/h
                        Load: 40.8 %
                        Load: 38.0 %
                        Lambda: 100.2 %
                        Temperature: 546.0C
                        Temperature: 80.1C
                        Mileage: 147482 km
                        Date: 2037.14.26
                        Time: 09:32:21
                        RPM: 1794 /min
                        Speed: 91.0 km/h
                        Load: 40.4 %
                        Load: 38.4 %
                        Lambda: 60.0 %
                        Temperature: 546.0C
                        Temperature: 80.1C
                        Mileage: 147482 km
                        Date: 2037.14.26
                        Time: 09:32:21
                        RPM: 1794 /min
                        Speed: 91.0 km/h
                        Load: 41.2 %
                        Load: 94.9 %
                        Lambda: 7.9 %
                        Mass Air / Rev.: 460.0 mg/str
                        Temperature: 80.1C
                        Mileage: 147482 km
                        Date: 2037.14.26
                        Time: 09:32:21
                        RPM: 1794 /min
                        Speed: 91.0 km/h
                        Load: 41.2 %
                        Load: 94.9 %
                        Lambda: 100.2 %
                        Temperature: 80.1C
    001166 - Sensor for Exhaust Flap
                   P048E - 000 - Short to Plus
                        Mileage: 147483 km
                        Date: 2037.14.26
                        Time: 09:33:59
                        RPM: 3381 /min
                        Speed: 106.0 km/h
                        Voltage: 13.91 V
                        Lambda: 100.2 %
                        Lambda: 0.0 %
                        Bin. Bits: 00000000
                        Voltage: 5.016 V
                        Mileage: 147489 km
                        Date: 2037.14.26
                        Time: 09:37:22
                        RPM: 3082 /min
                        Speed: 98.0 km/h
                        Voltage: 13.91 V
                        Voltage: 0.684 V
                        Voltage: 0.304 V
                        Bin. Bits:  1 01  0
                        Mileage: 147489 km
                        Date: 2037.14.26
                        Time: 09:37:22
                        RPM: 2944 /min
                        Speed: 97.0 km/h
                        Voltage: 13.83 V
                        Temperature: 80.1C
                        (no units): 0.0
                        Torque: 0.0 Nm
                        Mileage: 147492 km
                        Date: 2037.14.26
                        Time: 09:44:18
                        RPM: 828 /min
                        Load: 100.0 %
                        Lambda: 99.4 %
                        Mass Air / Rev.: 495.0 mg/str
                        Temperature: 78.3C
                        Mileage: 147492 km
                        Date: 2037.14.26
                        Time: 09:44:18
                        RPM: 828 /min
                        Load: 100.0 %
                        Lambda: 100.2 %
                        Temperature: 186.0C
                        Temperature: 78.3C
  10. #8
    New User
    May 2020
    WA, USA
    Log of drive during Faults codes
    https://drive.google.com/file/d/18oX...w?usp=drivesdk
    I don't know another way to share log besides convert to pdf and upload to Google drive.
  11. #9
    Quote Originally Posted by Dedman View Post
    Since .CSV is just text, you can open it with Notepad and paste the contents here.
    But the best thing for large logs like that one might be to put it in a Google Spreadsheet, share it, and link it here.
