Results 1 to 9 of 9
Thread: MQB cars - different manufactures for gateways
    Aug 2014
    Long story short...
    (Perhaps not directly relevant, however here's a log for my car: https://forums.ross-tech.com/showthr...tires&p=201558)
    My car was originally born with the following gateway:
    5Q0 907 530 AM (hardware 5Q0 907 530 F) - software 1265
    Manufacture: Lear
    Because of retrofitting Active Info Display (winter 2019) I've replaced it with the following:
    3Q0 907 530 AA (hardware 3Q0 907 530 C) - software 5362
    Manufacture: Continental
    Dataset from Touran was loaded onto the gateway - otherwise the alternator kept saying that the car was not charging - but it still did after 2-3 min with ignition on (engine off)
    Problems: Start/stop was working... hmm... totally random. Engine was working as normal, but still... Not the same as with the 5Q0 gw. Hard to explain, but it was not running as smooth as normal.
    Got a new gateway last month
    3Q0 907 530 AA (hardware 3Q0 907 530 C) - software 4368
    Manufacture: Lear
    Problems: None at all. Start/stop is working 100%, engine is running totally smooth and it seems like a brand new car. Again - it's hard to explain, but it's a new feeling when I've start the engine compared to Continental gateway.
    Upgraded to 3Q0 907 530 AC - still no problems and car is perfect.
    There is no information in ETKA, but for me it seems that gasoline cars uses Lear and diesel uses Continental gateway.
    I can see there is a quite difference in the software version 4xxx vs 5xxx
    Can anyone explain why?
    Apr 2018
    ITALY
    I don't have a definitive answer for you, just a few observations:
    - in the few gateway upgrades I have done, I have always put the same brand without even wondering, and I never had a single problem;
    - ETKA actually does not say that you have to follow the brand AND
    - people here say that again no need to follow the brand...
    but you're proving both wrong.
    curious, at least.
    my Golf left the factory with 18 ECUs. now she has 27. and counting
    May 2017
    Quote Originally Posted by diskoboy View Post
    I have diesel and Lear gateway so that theory is not valid.
  4. Likes Uwe liked this post
    Aug 2014
    Hmm. It was a good theory though
    Jun 2014
    Poland
    Hmmm.
    AM was also my genuine GW
    Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
    Component: GW MQB High 128 1265
    and I swap AID cluster 2 years ago and no problem at all
    Part No SW: 5G1 920 791 HW: 5G1 920 791
    Component: KOMBI 405 2153
    so 100% no need to change that
  7. Likes darkchina811 liked this post
    Apr 2018
    ITALY
    I have read this deceiving information before, and not only here. somebody spread the word around than AID requires 3Q0 gateway but it is incorrect.
    May 2017
    I also have the same gateway as Spacewalker and AID and works fine.
    The 3Q0 gateway is needed if you have a hybrid car and AID. So in some occasions the 3Q0 gateway is needed. The other occasions might be that you retrofit the newer AID, that does not work with 5Q0 gateway anymore. You will face the dreaded "Range calculation error".
       Revision: --------    Serial number: 0005002497
       Coding: 030500341F087300FB07225E1E0F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 7CA1F4E3966FFC57961-8028
       Serial number: 29160001037370086211
       Coding: 2DFFFF
       Serial number: 8958780404
       Part No SW: 5NA 920 790 A    HW: 5NA 920 790 A
       Coding: 07A500086F88000801883B0B1401000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009052
       VCID: 40D94013BA0758B78A9-8014
    16777020 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_TEL_0x28 keine Kommunikation]
                        Fault Frequency: 10
                        Reset counter: 208
                        Mileage: 79550 km
                        Date: 2019.09.27
                        Time: 18:37:07
  10. #8
    Jan 2015
    Bosnia and Herzegovina
    gateway update fixed this for me, retrofitted facelift AID and gateway flashed from E or something to AM fixed range error.
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
  11. Likes downtime liked this post
  12. #9
    May 2017
    Seems that the gateway issue is concerning Seat virtual cockpit according to the other forum. VW does not seem to suffer from this problem.
  13. Likes m87a liked this post
