Results 1 to 10 of 19
Thread: 2001 Allroad, 6MT swap and other...
    Mar 2020
    Grand Junction, CO, USA
    Please let me know if this needs to be posted in another section, or has been addressed elsewhere. Thanks.
    I have a 2001 Allroad that has a 2.7t motor and 6-sp. MT that came out of a 2000 S4, and the car will not start. Mods not native to the Allroad are:
    Stage 3 parts
    6spd 01e transmission rebuilt synchros
    6spd driveshaft
    6spd differential
    6speed axles
    150,531 new motor 173,863 body
    2.7 w/ k04s from s4
    Ev14 550 injectors
    OEM Rs4 k04 turbos
    OEM Rs4 maf and housing
    OEM Rs4 side mount intercoolers
    Upgraded diverted valves
    Samco silicon hose kit
    Fuel pressure gauge
    Boost gauge
    Manual boost controller
    New southbend stage 2 endurance clutch
    new rs4 pressure plate
    resurfaced dual mass flywheel
    New flywheel to crank and flywheel to clutch bolts
    New OEM tranny mount
    New upper end seal kit including valve covers and cam seals.
    The motor and tranny were taken from the S4 and transplanted into the Allroad. All else, other than above, is the Allroad, such as key, ECU, instrument cluster, etc. Here is the scan:
    Wednesday,20,May,2020,10:57:39:24553
    VIN: WAUYP64B31N104139   License Plate:
              75 76 77
    Address 01: Engine        Labels: 078-907-551-AZA.lbl
       Part No: 4Z7 907 551 K
       Component: 2.7l V6/5VT     G   0001
       Coding: 06752
       Shop #: WSC 02313
       VCID: 4BC36169FAD0EEC3F60-5118
       WAUYP64B31N104139     AUZ7Z0Y1726283
    12 Faults Found:
    17833 - EVAP Purge Valve (N80)
                P1425 - 35-10 - Short to Ground - Intermittent
    17880 - EVAP Leak Detection Pump
                P1472 - 35-10 - Short to Ground - Intermittent
    17843 - Secondary Air Pump Relay (J299)
                P1435 - 35-10 - Short to Ground - Intermittent
    17938 - Camshaft Timing Adjustment
                P1530 - 35-10 - Short to Ground - Intermittent
    17829 - Secondary Air Injection Solenoid Valve (N112)
                P1421 - 35-10 - Short to Ground - Intermittent
    17955 - Boost Pressure Regulation Valve (N75)
                P1547 - 35-10 - Short to Ground - Intermittent
    17697 - Boost Pressure Control Valve (N249)
                P1289 - 35-10 - Short to Ground - Intermittent
    17529 - Oxygen (Lambda) Sensor Heating Circuit: B2 S2
                P1121 - 35-10 - Short to Ground - Intermittent
    17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2
                P1117 - 35-10 - Short to Ground - Intermittent
    17800 - Camshaft Position Sensor Bank 2 (G163)
                P1392 - 35-10 - Open Short to Plus - Intermittent
    18010 - Power Supply Terminal 30
                P1602 - 35-10 - Voltage too Low - Intermittent
    18034 - Powertrain Data Bus
                P1626 - 35-00 - Missing Message from TCU
    Readiness: 0110 1101
    Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
       Part No: 4Z7 907 389
       Component: ABS/ESP allrad      D47
       Coding: 06397
       Shop #: WSC 02325
       VCID: 094F9B61B02CBCD304C-513C
    00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                30-00 - Open or Short to Plus
       Part No: 4B0 959 760 C
       Component: Sitzmemory R1 BF    0102
       Coding: 00003
       VCID: 2D070FF16404C0F3C84-4AE0
                06-10 - Signal too High - Intermittent
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY1.lbl
       Part No: 4B0 820 043 AH
       Component: A6-Klimavollautomat D65
       Coding: 00160
       Shop #: WSC 02313
       VCID: 6099A6C563565D9B332-2586
    00792 - A/C Pressure Switch (F129)
    Address 15: Airbags        Labels: 4B0-959-655-AI8.lbl
       Part No: 4Z7 959 655 C
       Component: Airbag Front+Kopf  1002
       Coding: 00307
       Shop #: WSC 02325
       VCID: 4FFB75790EC8D2E39A8-5160
    01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
    00532 - Supply Voltage B+
    Address 16: Steering wheel        Labels: 4B0-907-487.lbl
       Part No: 4B0 907 487 L
       Component: Lenkradelektronik    D03
       Coding: 00112
       Shop #: WSC 65535
       VCID: 353727918C548833B04-4FB8
                49-00 - No Communications
    Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
       Part No: 4Z7 920 980 B
       Component: C5-KOMBIINSTR. VDO D13
       Coding: 02264
       Shop #: WSC 40107
       VCID: 43D34949D28026830E0-5118
    9 Faults Found:
    00771 - Fuel Level Sensor (G)
    01176 - Key
                65-10 - Unauthorized - Intermittent
    01312 - Powertrain Data Bus
                37-10 - Faulty - Intermittent
    01310 - Level Control System Control Module (J197)
                29-10 - Short to Ground - Intermittent
    Address 34: Level Control        Labels: 4Z7-907-553.lbl
       Part No: 4Z7 907 553 B
       Component:  - 2C1A1          X031
       Coding: 25500
       Shop #: WSC 09999
       VCID: 44D14A55D78E21BB37A-50F4
    01400 - Suspension Level Control
                53-10 - Supply Voltage Too Low - Intermittent
    01397 - Venting Solenoid for Level Control (N111)
    01437 - Control Position not Learned
                35-00 - -
                79-10 - Please Check Fault Codes - Intermittent
    Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
       Part No: 4B0 962 258 J
       Component: Central Lock/Alarm  D34
       Coding: 15208
       Shop #: WSC 02313
       VCID: 303916857336AD1BE32-4EC8
    20 Faults Found:
    01366 - Opened Due to Crash Signal
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
    01370 - Alarm triggered by Interior Monitoring
                35-00 - -
                35-00 - -
    01558 - Contact Switch in Locking Cyl; Driver Side; Close (F241)
    01389 - Tailgate Open Switch (F124)
                29-00 - Short to Ground
    01563 - Interior Lock Switch; Driver Side (E150); Lock
    01564 - Interior Lock Switch; Driver Side (E151); Unlock
    00947 - Trunk Lid remote Control Switch (E188)
    00956 - Key 2
                09-10 - Adaptation Limit Surpassed - Intermittent
    01570 - Turn-Off Delay; Terminal 15
    01560 - Passenger Door
    01561 - Rear left door
    01574 - Alarm triggered by Door Contact Switch; Rear Right
                35-00 - -
    01573 - Alarm triggered by Door Contact Switch; Rear Left
                35-00 - -
    00951 - Tailgate Central Locking Motor Relay (J398)
       Part No: 4B0 959 760 B
       Component: Sitzmemory R1 F     0101
       Coding: 00001
       VCID: 2C0102F55F1EC9FBDFA-4AE0
    Address 37: Navigation        Labels: 4B0-919-887-BNS3.lbl
       Part No: 4B0 919 887 B
       Component: Navigation     BNO 0001
       VCID: 323D1C8D7D3A9F0B956-4AC2
    65535 - Internal Control Module Memory Error
                00-00 - -
    Address 45: Inter. Monitor        Labels: 4B0-951-178.lbl
       Part No: 4B0 951 178 A
       Component: Innenraumueberw.    D04
       Coding: 00102
       Shop #: WSC 02313
       VCID: 2615F0DD41F2F3AB09E-508A
    01349 - Alarm via Theft Warning System; Front
                35-00 - -
    01462 - Anti-theft alarm ultra sonic Sensor (G209)
       Part No: 4Z7 907 357
       Component: dynamische LWR       D05
       Coding: 00030
       Shop #: WSC 02313
       VCID: 04518A55970EE1BB77A-4AE0
    Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
       Part No: 4B0 035 195 A
       Component:  Radio              D00
       Coding: 00115
       Shop #: WSC 08316
       VCID: 1E65D83D19A22B6B41E-4AC2
    Address 76: Park Assist        Labels: 8Z0-919-283.lbl
       Part No: 8Z0 919 283
       Component: Parkingsyst. A6 RDW D05
       Coding: 01186
       Shop #: WSC 02313
       VCID: 025D8C4D8D1AEF8B456-5118
    01543 - Parking Aid Warning Chime (H15)
    End----------(Elapsed Time: 04:39, VBatt start/end: 12.3V/12.4V)-----------
    I have tried the Immobilizer III ECU swapping procedure to no avail. Any help is greatly appreciated.
    Nov 2014
    New Zealand
    Doesn't crank, or doesn't start?
    Doesn't crank: The engine ECU is still looking for a TCU, has the wiring and/or coding been altered to allow cranking without the trans reporting it's in Park?
    Doesn't start: Is the wiring between the Allroad and S4 engines the same? Have you done basic checks for fuel and spark?
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
    Mar 2020
    Quote Originally Posted by NZDubNurd View Post
    Doesn't crank. How do alter the coding for the missing TCU?
    In principle, changing the ECU's coding from 06752 to 06762 should tell it it's connected to a manual transmission, but it's entirely possible it won't accept that because the an MT ECU uses requires different software than an AT ECU.
    I also doubt that this will clear up a non-cranking problem. I don't think the ECU itself has control of that in this car.
    Mar 2020
    Would it help, or make life simpler, of i got an ecu from a manual car and reprogrammed it to this key and instrument cluster?
    Mar 2020
    Is this reprogramming something I can do through VAGCOM?
    Quote Originally Posted by apbreaux View Post
    You can certainly try the coding change, but I don't have high hopes for it.
  9. #8
    Mar 2020
    Gotta start somewhere. Able to point me in right direction of how to do this coding? Much appreciated.
  10. #9
    Nov 2014
    New Zealand
    On my Touran, I had to code the BCM to manual, and change the wire from the TCU to permanent ground, as per the manual cars wiring diagram.
    There is probably something similar in yours, but it may be done via a mechanical switch, or the TCU/BCM - I'm not familiar with your car.
    And as Uwe suggests, you may need to physically change the engine ECU to a manual version - my R32 DSG-type engine ECU would not accept a coding change, so required the correct ECU. In my case, this also corrected the ABS TCU error message - again, yours may be different. To try the coding, you have to enter the engine ECU screen, select coding and change it to the number Uwe suggested above. It will possibly/probably say rejected.
    Allan
    The R32ran Thread
  11. Likes Uwe liked this post
  12. #10
    Dallas (McKinney) ,TX ,USA
    His car do not have BCM , it is 2001 way older then your Touran.
    Immobilizer/ECU
    /Cluster Programing (Used or NEW)
    email: marinmm2001@gmail.com , info@advancedcarelectronics.com
    https://www.advancedcarelectronics.com/
  13. Likes Uwe liked this post
