Hi all,
I have a few questions that i'm hoping you can help me with:
1. What can cause the 05 module to stay awake (other than the keys)?
2. Is it under the carpet on LHS regardless of LHD or RHD?
3. Has anyone seen this module cause a 0.15 amp drain?
Background and details below - hope someone can give me a few pointers.
thanks
Alan
Background:
I have this A8 thats been with me for a few months. It has lots of problems. But the customer only really wanted to find the cause of the battery drain. Other people had been trying to fix it over a long period of time before me.
I found a constant battery drain present of well over 2amp after allowing time for everything to shut down.
Some obvious faults i thought could be relevant were, The mmi system was not operational.
The central locking works but the keyless entry and start functions don't. It starts OK with the key in the ignition though.
The air bag suspension drops after a couple of days.
The battery had been replaced but not coded. And the 61 battery regulation module I'm told had been replaced wihout any coding anyway.
After some testing of fuses i found no blown fuses but three fuses that when removed dropped the
current drain down to 0.05amp.
Two of the fuses were 5 amp for the MMI system and one 25amp for the keyless start module.
I have (I think) found the problem with the MMI. Both the control head and the cd changer are faulty.
Now with a second hand control head and the changer disconnected and a bypass loop inplace everything else
switches on. If ether one is returned to original it will not work again. The display however has striped the teeth off its gear wheels. I can fix that with a repair kit. And most of the drain is gone.
However I'm left with a much better but still I think too high 0.2amps drain.
If i remove the Fuse 42 In one of the dash fuse panels, which i think is the 05 acc/start module it drops to 0.05
Im going to locate the module which I believe is under the carpet in front of the drivers seat. I'll disconnect the module to then see if the drain clears. Although it could save time if i knew if its location changes depending on LHD or RHD?
If disconnecting the 05 module causes the drain to disappear. What would make the module drain the battery? Is it just faulty or are there things that will keep it awake? A key at a close range i would have thought? I've had the keys well away when testing. The door buttons and the start button have never worked as long as the owner has had the car.
Of course he may i suspect have had a 0.2 off an amp drain all that time and only gained the higher drain issue after regular jump starts that then possably damaged the MMI.
He had replaced the battery and someone told him to replace the 61 battery regulation module previously before bringing it to me. But at that time he says the display screen was still trying to pop up.
The battery is a good make but has no code to enter so i added a digit to the coding. I'v read that should reset the learned values. Is that correct?
Also some times a code appearing in the 05 module. 00003 - Control Module 012 - Electrical Fault in Circuit. But that also appears in other modules as well sometimes.
I have cleared codes many times and captured a few log files but I'm not sure how accurate they are due to me having fuses out and having to manually go through every module to clear all codes. If any one thinks it would help I'll clear all codes and do a fresh scan.
The MMI modules that can not be reached are all ok now I did not alter any coding in the replacement control head and it seems to work fine.
thanks
Alan
Background:
VIN: WAUZZZ4E04N002263 License Plate: OU03 FYZ
Mileage: 174290km-108298mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 1E 25 28 34 36
37 38 42 46 47 4F 52 53 55 56 57 61 62 72 76
VIN: WAUZZZ4E04N002263 Mileage: 174290km-108298miles
07-Control Head -- Status: Cannot be reached 1100
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Cannot be reached 1100
57-TV Tuner -- Status: Cannot be reached 1100
Part No SW: 4E0 910 409 B HW: 4E0 907 409 B
Component: 4,0L 4V/TDI G000AGMª0020
Revision: <> Serial number: AUX3Z0C3314070
Coding: 0010773
Shop #: WSC 02313 785 00200
VCID: 224FB26CFDDB6E5412-8076
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 000 - Open Circuit
RPM: 651 /min
Torque: 85.8 Nm
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
Temperature: 30.6°C
19591 - Intake Manifold Runner Control
P3135 - 000 - Lower Stop not Reached
RPM: 651 /min
Torque: 85.8 Nm
Duty Cycle: 88.3 %
Duty Cycle: 88.3 %
Duty Cycle: 0.4 %
Temperature: 30.6°C
Readiness: 0 0 X X X
Part No SW: 4E0 910 156 B HW: 09E 927 156 A
Component: AG6 09E 4,0LTDI RdW 0050
VCID: 214DBD60F8DD754C0B-8074
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
RPM: 32 /min
(no units): 30.0
(no units): 25.0
Temperature: 12.0°C
T.B. Angle: 0.0°
Voltage: 6.40 V
Part No SW: 4E0 910 517 A HW: 4E0 614 517 A
Component: ESP 5.7 allrad H29 0420
Coding: 0008557
Shop #: WSC 01218 000 00000
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H02 0120
Revision: 01203502 Serial number: AUX3Z0C3314070
Coding: 0395264
Shop #: WSC 00954 002 1048576
VCID: 58BBD084EB07F4843C-800C
Component: ELV XXXX
Fault Frequency: 0
Reset counter: 63
Mileage: 174288 km
Date: 2003.02.27
Time: 03:16:54
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Shop #: WSC 00861 210 09583
VCID: 2341B768E2C1675C19-8076
Address 07: Control Head
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 015 0240
Revision: 00000014 Serial number: 00000000016106
Coding: 0088209
VCID: 5ABFCA8C950BE6940A-800E
14 Faults Found:
003 - Mechanical Failure
Fault Status: 01100011
Reset counter: 63
Mileage: 171576 km
Date: 2003.02.27
Time: 00:33:20
Voltage: 11.60 V
Temperature: 18.0°C
(no units): 194.0
(no units): 91.0
Temperature: -84.0°C
014 - Defective
Fault Status: 01101110
Reset counter: 63
Mileage: 171576 km
Date: 2003.02.27
Time: 00:33:21
Temperature: 18.0°C
00065 - Rear Left Footwell Heater (Z42)
Fault Frequency: 221
Reset counter: 63
Mileage: 171576 km
Date: 2003.02.27
Time: 00:33:22
Voltage: 11.60 V
00713 - Centre Left Vent Positioning Motor (V110)
Fault Status: 00100011
Fault Frequency: 7
Reset counter: 98
Mileage: 173789 km
Date: 2003.02.28
Time: 23:47:27
Voltage: 14.20 V
Temperature: 11.0°C
(no units): 137.0
(no units): 144.0
Temperature: -78.0°C
00729 - Potentiometer in Positioning Motor for Right-Hand Central Vent (G137)
Fault Status: 00101010
Reset counter: 102
Mileage: 173909 km
Date: 2003.03.05
Time: 08:46:46
Voltage: 14.30 V
(no units): 207.0
(no units): 255.0
Fault Frequency: 83
Reset counter: 101
Mileage: 171578 km
Date: 2003.02.28
Time: 00:55:43
00066 - Rear Right Footwell Heater (Z43)
Fault Status: 00101100
Reset counter: 102
Mileage: 171578 km
Date: 2003.02.28
Time: 00:55:48
Voltage: 13.00 V
01844 - Control Module for Fresh Air Blower (J126)
Reset counter: 76
Mileage: 173910 km
Date: 2003.03.05
Time: 09:36:14
Temperature: 28.0°C
(no units): 84.0
(no units): 118.0
00020 - Motor for Blocking Flap; Defrost and Body Vents; Right (V199)
Fault Frequency: 195
Reset counter: 102
Mileage: 171602 km
Date: 2003.02.28
Time: 03:54:12
Voltage: 13.50 V
Temperature: 28.0°C
(no units): 194.0
(no units): 101.0
Temperature: -81.0°C
01868 - Rear Right Warm/Cold Flap Air Outlet Motor (V221)
Fault Frequency: 146
Reset counter: 100
Mileage: 171602 km
Date: 2003.02.28
Time: 03:54:24
Voltage: 13.70 V
Temperature: 27.0°C
(no units): 194.0
(no units): 101.0
Reset counter: 98
Mileage: 174234 km
Date: 2003.02.27
Time: 00:03:03
Voltage: 13.90 V
Temperature: 2.0°C
(no units): 135.0
(no units): 93.0
Temperature: -97.0°C
00711 - Left Footwell Flap Positioning Motor (V108)
Fault Frequency: 13
Reset counter: 102
Mileage: 174234 km
Date: 2003.02.27
Time: 00:12:08
Voltage: 14.50 V
Temperature: 4.0°C
(no units): 62.0
(no units): 90.0
00714 - Centre Right Vent Positioning Motor (V111)
Reset counter: 98
Mileage: 174234 km
Date: 2003.02.27
Time: 00:12:46
Voltage: 14.50 V
Temperature: 5.0°C
(no units): 62.0
(no units): 92.0
00021 - Motor for Blocking Flap; Defrost and Body Vents; Left (V200)
Fault Frequency: 10
Reset counter: 63
Mileage: 174236 km
Date: 2003.02.27
Time: 00:46:00
Voltage: 14.60 V
Temperature: 7.0°C
(no units): 194.0
(no units): 99.0
Temperature: -95.0°C
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 C HW: 4E0 907 279 C
Component: ILM Fahrer H11 0090
Coding: 0110001
VCID: 285BA0449BE784044C-807C
Subsystem 1 - Part No: 4E2 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 00861
Address 11: Engine II Labels: Redir Fail!
Component: 4,0L 4V/TDI G000AGSª0020
Coding: 0010773
17426 - Intake Manifold Runner (Bank 2)
P1018 - 000 - Lower limit not reached
RPM: 651 /min
Torque: 85.8 Nm
Duty Cycle: 88.3 %
Duty Cycle: 88.3 %
Duty Cycle: 0.4 %
Temperature: 30.6°C
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H08 0940
Coding: 0431707
VCID: 63C1F768A241275C59-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H09 0030
Coding: 0112041
VCID: 65C5E970AC75596CB7-8030
Component: Lenkradmodul H02 0050
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 A
Component: KOMBIINSTR. VDO H42 0060
Revision: D07 Serial number: AUDID3C3000062
Coding: 0001411
Shop #: WSC 01234 444 64523
VCID: 5CB3CC949F3F18A418-8008
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 HW: 4E0 815 069 C
Component: Heizgeraet H06 0280
Revision: 0000000E Serial number: 00000009001484
VCID: 59BDD580900DED8C03-800C
02251 - Heater Unit Locked
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H06 0050
Revision: 06 Serial number: 10003034110506
Coding: FCFEFFDE2B2504
Shop #: WSC 00861 210 61278
Address 1E: Media Player 2
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0395264
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Fault Frequency: 0
Reset counter: 63
Mileage: 174288 km
Date: 2003.02.27
Time: 03:16:54
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0200
Revision: 00000010 Serial number: 00000000006713
Coding: 0000000
VCID: 61CDFD60B85D354C4B-8034
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
Shop #: WSC 00957 210 10282
VCID: 2545A970ECF5996C77-8070
Fault Status: 11101000
Reset counter: 63
Mileage: 174290 km
Date: 2003.02.27
Time: 00:50:08
Reset counter: 103
Mileage: 174290 km
Date: 2003.02.28
Time: 00:32:26
Component: Sitzmemory FS H07 0060
Coding: 4063338
Shop #: WSC 00947 210 81015
01882 - Lumbar Support Fore / Aft Adjustment Button (E336); Forward
Reset counter: 63
Mileage: 174288 km
Date: 2012.04.08
Time: 01:02:58
01883 - Lumbar Support Fore / Aft Adjustment Button (E336); Backward
Reset counter: 63
Mileage: 174288 km
Date: 2012.04.08
Time: 01:02:58
Address 37: Navigation
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0080
Serial number: 00000307900025
Coding: 0035974
VCID: 1D358190C4A551AC2F-8048
02139 - Control Circuit for Left Front Interior Lights
Reset counter: 63
Mileage: 174288 km
Date: 2003.02.27
Time: 00:03:00
02138 - Control Circuit for Front Right Interior Lights
Reset counter: 63
Mileage: 174288 km
Date: 2003.02.27
Time: 00:03:00
00211 - Control Circuit for Rear Illumination Lights
Reset counter: 63
Mileage: 174288 km
Date: 2003.02.27
Time: 00:03:00
01370 - Alarm triggered by Interior Monitoring
Reset counter: 103
Date: 2003.02.27
Time: 01:03:00
Bin. Bits: 10000000
Reset counter: 103
Mileage: 174288 km
Date: 2003.02.27
Time: 04:53:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 802
Component: Türsteuer.FS BRM004 0080
Coding: 0028454
VCID: 5EB7C69C89230AB476-800A
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040304230060
Coding: 0004345
VCID: 2759A37896F98B7C45-8072
Component: Heckdeckel H06 0060
Component: Neigungssensor H02 0020
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 63
Mileage: 167448 km
Date: 2003.03.09
Time: 19:34:00
Fault Status: 00101001
Fault Frequency: 19
Reset counter: 103
Mileage: 174234 km
Date: 2003.02.27
Time: 00:20:00
Address 47: Sound System
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H06 0060
Revision: Serial number: 00000000013919
Coding: 0010101
VCID: 5DB5C190842511AC6F-8008
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 801
Component: Türsteuer.BF BRM004 0080
Coding: 0028454
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000431
Shop #: WSC 01218 210 182178
02596 - Rear Brake Pads Worn
Fault Status: 01111000
Reset counter: 57
Voltage: 5.80 V
Count: 61
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
Shop #: WSC 02311 785 00200
VCID: 62CFF26CBD5B2E5452-8036
Address 56: Radio
Address 57: TV Tuner
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000002574
Shop #: WSC 43354 133 80440
VCID: 204BB864F3D77C4404-8074
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2703301613
Coding: 344530393135313035412056413032373033333031363133
Shop #: WSC 00000 128 00289
02256 - Quiescent Current
Fault Status: 00100001
Reset counter: 103
Mileage: 174290 km
Date: 2003.02.27
Time: 07:28:03
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0080
Coding: 0028454
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0080
Coding: 0028454
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0001008
VCID: 60CBF864B3573C4444-8034
End-------------------------(Elapsed Time: 03:58)--------------------------
Tuesday,19,May,2020,18:55:39:05279
VCDS Version: 19.6.2.2
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 25 28 34 36 37
00-Steering Angle Sensor -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
11-Engine II -- Status: Cannot be reached 1100
31-Engine other -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
34-Level Control -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
Address 01: Engine
Coding: 0395264
VCID: 58BBD084EB07F48FBD-800C
Subsystem 1 - Part No: 4E0 905 852 C
Component: ELV 1734
Fault Frequency: 0
Reset counter: 64
Mileage: 174288 km
Date: 2003.06.06
Time: 03:05:04
Coding: 4063328
VCID: 2341B768E2C1675798-8076
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 729 H HW: 4E0 035 729 A
Component: Interfacebox H43 0770
Revision: 00000000 Serial number: 300LG027513722
VCID: 2D555150B405A1273E-8078
Subsystem 1 - Part No: 4E0 910 609
Component: Bedienteil MMI H41 0010
Subsystem 2 - Serial number: 318AM037503766
Subsystem 3 - Serial number: ÿÿ21.01.03ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Subsystem 4 - Serial number: ÿÿÿÿÿÿÿ
Coding: 0088209
VCID: 5ABFCA8C950BE69F8B-800E
6 Faults Found:
Reset counter: 103
Mileage: 174290 km
Date: 2003.06.06
Time: 02:57:50
Voltage: 11.90 V
Temperature: 16.0°C
(no units): 62.0
(no units): 87.0
Temperature: -85.0°C
01867 - Rear Left Warm/Cold Flap Air Outlet Motor (V220)
Reset counter: 103
Mileage: 174290 km
Date: 2003.06.06
Time: 02:57:50
Voltage: 11.90 V
Temperature: 16.0°C
(no units): 62.0
(no units): 87.0
Fault Status: 00101110
Reset counter: 103
Mileage: 174290 km
Date: 2003.06.06
Time: 02:57:52
Temperature: 16.0°C
Reset counter: 103
Mileage: 174290 km
Date: 2003.06.06
Time: 02:57:53
Voltage: 11.90 V
Reset counter: 103
Mileage: 174290 km
Date: 2003.06.06
Time: 03:05:46
Voltage: 13.80 V
Temperature: 16.0°C
(no units): 174.0
(no units): 86.0
Reset counter: 103
Mileage: 174290 km
Date: 2003.06.06
Time: 03:09:33
Voltage: 14.50 V
Address 15: Airbags
Coding: 0112041
VCID: 65C5E970AC75596736-8030
Coding: 0001411
VCID: 5CB3CC949F3F18AF99-8008
VCID: 59BDD580900DED8782-800C
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
02757 - Learning Tire Pressures
Coding: FCFEFFDE0B2504
Reset counter: 104
Mileage: 174290 km
Date: 2003.06.06
Time: 03:11:50
Reset counter: 104
Mileage: 174290 km
Date: 2003.06.06
Time: 03:11:51
Reset counter: 104
Mileage: 174290 km
Date: 2003.06.06
Time: 03:11:51
Coding: 0395264
Component: ELV 1734
4E0905852C ELV 1734
Fault Frequency: 0
Reset counter: 64
Mileage: 174288 km
Date: 2003.06.06
Time: 03:05:04
Coding: 0000000
VCID: 61CDFD60B85D3547CA-8034
01863 - Air Outlet Motor; Rear Left (V218)
Coding: 4063338
Reset counter: 64
Mileage: 174288 km
Date: 2012.04.08
Time: 01:02:58
Reset counter: 64
Mileage: 174288 km
Date: 2012.04.08
Time: 01:02:58
Part No SW: 4E0 910 887 D HW: 4E0 919 887 C
Component: MNS ECE H41 0550
Revision: 00000000 Serial number: 305D6037533001
VCID: 2E57565CB903DA3F07-807A
Coding: 0028454
VCID: 5EB7C69C89230ABFF7-800A
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 G HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0360
Revision: PROD_01 Serial number: 00000000138953
Coding: 0000013
VCID: 214DBD60F8DD75478A-8074
Coding: 0010101
VCID: 5DB5C190842511A7EE-8008
Reset counter: 104
Mileage: 174288 km
Date: 2003.06.06
Time: 03:11:00
Reset counter: 104
Mileage: 174288 km
Date: 2003.06.06
Time: 03:12:00
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
Reset counter: 64
Mileage: 174288 km
Date: 2003.06.06
Time: 03:04:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
Reset counter: 64
Mileage: 174288 km
Date: 2003.06.06
Time: 03:04:00
Coding: 0028454
Part No SW: 4E0 910 541 C HW: 4E0 035 541 B
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 304AS047558496
VCID: 204BB864F3D77C4F85-8074
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 C HW: 4E0 919 146
Component: TV analog TUNER H11 0210
Revision: 00000008 Serial number: 00000000000000
Coding: 0001003
Shop #: WSC 00000 785 00200
Component: von VA0 2703301614
Coding: 344530393135313035412056413032373033333031363134
Shop #: WSC 12345 128 00289
Coding: 0028454
Coding: 0028454
End-------------------------(Elapsed Time: 03:49)--------------------------
