Audi A8 2003, Battery drain.
Pinpointdiag
Scotland
C?ID=90374
Hi all,
I have a few questions that i'm hoping you can help me with:
1. What can cause the 05 module to stay awake (other than the keys)?
2. Is it under the carpet on LHS regardless of LHD or RHD?
3. Has anyone seen this module cause a 0.15 amp drain?
Background and details below - hope someone can give me a few pointers.
thanks
Alan
Background:
I have this A8 thats been with me for a few months. It has lots of problems. But the customer only really wanted to find the cause of the battery drain. Other people had been trying to fix it over a long period of time before me.
I found a constant battery drain present of well over 2amp after allowing time for everything to shut down.
Some obvious faults i thought could be relevant were, The mmi system was not operational.
The central locking works but the keyless entry and start functions don't. It starts OK with the key in the ignition though.
The air bag suspension drops after a couple of days.
The battery had been replaced but not coded. And the 61 battery regulation module I'm told had been replaced wihout any coding anyway.
After some testing of fuses i found no blown fuses but three fuses that when removed dropped the
current drain down to 0.05amp.
Two of the fuses were 5 amp for the MMI system and one 25amp for the keyless start module.
I have (I think) found the problem with the MMI. Both the control head and the cd changer are faulty.
Now with a second hand control head and the changer disconnected and a bypass loop inplace everything else
switches on. If ether one is returned to original it will not work again. The display however has striped the teeth off its gear wheels. I can fix that with a repair kit. And most of the drain is gone.
However I'm left with a much better but still I think too high 0.2amps drain.
If i remove the Fuse 42 In one of the dash fuse panels, which i think is the 05 acc/start module it drops to 0.05
Im going to locate the module which I believe is under the carpet in front of the drivers seat. I'll disconnect the module to then see if the drain clears. Although it could save time if i knew if its location changes depending on LHD or RHD?
If disconnecting the 05 module causes the drain to disappear. What would make the module drain the battery? Is it just faulty or are there things that will keep it awake? A key at a close range i would have thought? I've had the keys well away when testing. The door buttons and the start button have never worked as long as the owner has had the car.
Of course he may i suspect have had a 0.2 off an amp drain all that time and only gained the higher drain issue after regular jump starts that then possably damaged the MMI.
He had replaced the battery and someone told him to replace the 61 battery regulation module previously before bringing it to me. But at that time he says the display screen was still trying to pop up.
The battery is a good make but has no code to enter so i added a digit to the coding. I'v read that should reset the learned values. Is that correct?
Also some times a code appearing in the 05 module. 00003 - Control Module 012 - Electrical Fault in Circuit. But that also appears in other modules as well sometimes.
I have cleared codes many times and captured a few log files but I'm not sure how accurate they are due to me having fuses out and having to manually go through every module to clear all codes. If any one thinks it would help I'll clear all codes and do a fresh scan.
The MMI modules that can not be reached are all ok now I did not alter any coding in the replacement control head and it seems to work fine.
VIN: WAUZZZ4E04N002263   License Plate: OU03 FYZ
Mileage: 174290km-108298mi   Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 1E 25 28 34 36
          37 38 42 46 47 4F 52 53 55 56 57 61 62 72 76
VIN: WAUZZZ4E04N002263   Mileage: 174290km-108298miles
07-Control Head -- Status: Cannot be reached 1100
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
57-TV Tuner -- Status: Cannot be reached 1100
   Part No SW: 4E0 910 409 B    HW: 4E0 907 409 B
   Component: 4,0L 4V/TDI G000AGMª0020
   Revision:    <>       Serial number: AUX3Z0C3314070
   Coding: 0010773
   Shop #: WSC 02313 785 00200
   VCID: 224FB26CFDDB6E5412-8076
17985 - Right Engine Mount Solenoid Valve (N145)
            P1577 - 000 - Open Circuit
                    RPM: 651 /min
                    Torque: 85.8 Nm
                    Bin. Bits:        0
                    Bin. Bits:        0
                    Bin. Bits:        0
                    Temperature: 30.6°C
19591 - Intake Manifold Runner Control
            P3135 - 000 - Lower Stop not Reached
                    RPM: 651 /min
                    Torque: 85.8 Nm
                    Duty Cycle: 88.3 %
                    Duty Cycle: 88.3 %
                    Duty Cycle: 0.4 %
                    Temperature: 30.6°C
Readiness: 0 0 X X X
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E0 910 156 B    HW: 09E 927 156 A
   Component: AG6 09E 4,0LTDI RdW 0050
   Coding: 0000001
   VCID: 214DBD60F8DD754C0B-8074
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -  - Intermittent
                    RPM: 32 /min
                    (no units): 30.0
                    (no units): 25.0
                    Temperature: 12.0°C
                    T.B. Angle: 0.0°
                    Voltage: 6.40 V
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 A    HW: 4E0 614 517 A
   Component: ESP 5.7 allrad  H29 0420
   Coding: 0008557
   Shop #: WSC 01218 000 00000
            000 -  -
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 C
   Component:     FBS AUDID3  H02 0120
   Revision: 01203502    Serial number: AUX3Z0C3314070
   Coding: 0395264
   Shop #: WSC 00954 002 1048576
   VCID: 58BBD084EB07F4843C-800C
                    Fault Status: 01101100
                    Fault Frequency: 0
                    Reset counter: 63
                    Mileage: 174288 km
                    Date: 2003.02.27
                    Time: 03:16:54
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 C    HW: 4E0 959 760
   Component: Sitzmemory BFS H06  0060
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4063328
   Shop #: WSC 00861 210 09583
   VCID: 2341B768E2C1675C19-8076
Address 07: Control Head
   Part No SW: 4E0 910 043     HW: 4E0 820 043 A
   Component: KLIMAAUTOMAT    015 0240
   Revision: 00000014    Serial number: 00000000016106
   Coding: 0088209
   VCID: 5ABFCA8C950BE6940A-800E
14 Faults Found:
00716 - Air recirculation Flap Positioning Motor (V113)
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 63
                    Mileage: 171576 km
                    Date: 2003.02.27
                    Time: 00:33:20
                    Voltage: 11.60 V
                    Temperature: 18.0°C
                    (no units): 194.0
                    (no units): 91.0
                    Temperature: -84.0°C
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 63
                    Mileage: 171576 km
                    Date: 2003.02.27
                    Time: 00:33:21
                    Temperature: 18.0°C
00065 - Rear Left Footwell Heater (Z42)
                    Fault Frequency: 221
                    Reset counter: 63
                    Mileage: 171576 km
                    Date: 2003.02.27
                    Time: 00:33:22
                    Voltage: 11.60 V
00713 - Centre Left Vent Positioning Motor (V110)
                    Fault Status: 00100011
                    Fault Frequency: 7
                    Reset counter: 98
                    Mileage: 173789 km
                    Date: 2003.02.28
                    Time: 23:47:27
                    Voltage: 14.20 V
                    Temperature: 11.0°C
                    (no units): 137.0
                    (no units): 144.0
                    Temperature: -78.0°C
00729 - Potentiometer in Positioning Motor for Right-Hand Central Vent (G137)
                    Fault Status: 00101010
                    Reset counter: 102
                    Mileage: 173909 km
                    Date: 2003.03.05
                    Time: 08:46:46
                    Voltage: 14.30 V
                    (no units): 207.0
                    (no units): 255.0
                    Fault Frequency: 83
                    Reset counter: 101
                    Mileage: 171578 km
                    Date: 2003.02.28
                    Time: 00:55:43
00066 - Rear Right Footwell Heater (Z43)
                    Fault Status: 00101100
                    Reset counter: 102
                    Mileage: 171578 km
                    Date: 2003.02.28
                    Time: 00:55:48
                    Voltage: 13.00 V
01844 - Control Module for Fresh Air Blower (J126)
                    Reset counter: 76
                    Mileage: 173910 km
                    Date: 2003.03.05
                    Time: 09:36:14
                    Temperature: 28.0°C
                    (no units): 84.0
                    (no units): 118.0
00020 - Motor for Blocking Flap; Defrost and Body Vents; Right (V199)
                    Fault Frequency: 195
                    Reset counter: 102
                    Mileage: 171602 km
                    Date: 2003.02.28
                    Time: 03:54:12
                    Voltage: 13.50 V
                    Temperature: 28.0°C
                    (no units): 194.0
                    (no units): 101.0
                    Temperature: -81.0°C
01868 - Rear Right Warm/Cold Flap Air Outlet Motor (V221)
                    Fault Frequency: 146
                    Reset counter: 100
                    Mileage: 171602 km
                    Date: 2003.02.28
                    Time: 03:54:24
                    Voltage: 13.70 V
                    Temperature: 27.0°C
                    (no units): 194.0
                    (no units): 101.0
                    Reset counter: 98
                    Mileage: 174234 km
                    Date: 2003.02.27
                    Time: 00:03:03
                    Voltage: 13.90 V
                    Temperature: 2.0°C
                    (no units): 135.0
                    (no units): 93.0
                    Temperature: -97.0°C
00711 - Left Footwell Flap Positioning Motor (V108)
                    Fault Frequency: 13
                    Reset counter: 102
                    Mileage: 174234 km
                    Date: 2003.02.27
                    Time: 00:12:08
                    Voltage: 14.50 V
                    Temperature: 4.0°C
                    (no units): 62.0
                    (no units): 90.0
00714 - Centre Right Vent Positioning Motor (V111)
                    Reset counter: 98
                    Mileage: 174234 km
                    Date: 2003.02.27
                    Time: 00:12:46
                    Voltage: 14.50 V
                    Temperature: 5.0°C
                    (no units): 62.0
                    (no units): 92.0
00021 - Motor for Blocking Flap; Defrost and Body Vents; Left (V200)
                    Fault Frequency: 10
                    Reset counter: 63
                    Mileage: 174236 km
                    Date: 2003.02.27
                    Time: 00:46:00
                    Voltage: 14.60 V
                    Temperature: 7.0°C
                    (no units): 194.0
                    (no units): 99.0
                    Temperature: -95.0°C
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 C    HW: 4E0 907 279 C
   Component: ILM Fahrer      H11 0090
   Coding: 0110001
   VCID: 285BA0449BE784044C-807C
   Subsystem 1 - Part No: 4E2 910 113
   Component: Wischer WWS D3  H30 0320
   Coding: 00000030
   Shop #: WSC 00861
   Component: 4,0L 4V/TDI G000AGSª0020
   Coding: 0010773
17426 - Intake Manifold Runner (Bank 2)
            P1018 - 000 - Lower limit not reached
                    RPM: 651 /min
                    Torque: 85.8 Nm
                    Duty Cycle: 88.3 %
                    Duty Cycle: 88.3 %
                    Duty Cycle: 0.4 %
                    Temperature: 30.6°C
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655     HW: 4E0 959 655
   Component: Airbag 8.4E+    H08 0940
   Coding: 0431707
   VCID: 63C1F768A241275C59-8036
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549
   Component: Lenksäulenmodul H09 0030
   Coding: 0112041
   VCID: 65C5E970AC75596CB7-8030
   Component: Lenkradmodul    H02 0050
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 900     HW: 4E0 920 950 A
   Component: KOMBIINSTR. VDO H42 0060
   Revision: D07         Serial number: AUDID3C3000062
   Coding: 0001411
   Shop #: WSC 01234 444 64523
   VCID: 5CB3CC949F3F18A418-8008
   Part No SW: 4E0 910 105     HW: 4E0 815 069 C
   Component: Heizgeraet      H06 0280
   Revision: 0000000E    Serial number: 00000009001484
   VCID: 59BDD580900DED8C03-800C
02251 - Heater Unit Locked
            000 -  -
Address 19: CAN Gateway        Labels:. 4E0-910-468.clb
   Part No SW: 4E0 910 468     HW: 4E0 907 468 A
   Component: Gateway         H06 0050
   Revision: 06          Serial number: 10003034110506
   Coding: FCFEFFDE2B2504
   Shop #: WSC 00861 210 61278
Address 1E: Media Player 2
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0395264
   XXXXXXXXXXX ELV                 XXXX
                    Fault Frequency: 0
                    Reset counter: 63
                    Mileage: 174288 km
                    Date: 2003.02.27
                    Time: 03:16:54
Address 28: HVAC, Rear        Labels: None
   Part No SW: 4E0 910 158     HW: 4E0 919 158 A
   Component: KLIMA-STG. FOND 015 0200
   Revision: 00000010    Serial number: 00000000006713
   Coding: 0000000
   VCID: 61CDFD60B85D354C4B-8034
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
   Component: LUFTFDR.-CDC    H05 4290
   Coding: 0015510
   Shop #: WSC 00957 210 10282
   VCID: 2545A970ECF5996C77-8070
            008 - Implausible Signal
                    Fault Status: 11101000
                    Fault Frequency: 6
                    Reset counter: 63
                    Mileage: 174290 km
                    Date: 2003.02.27
                    Time: 00:50:08
01316 - ABS Control Module
                    Reset counter: 103
                    Mileage: 174290 km
                    Date: 2003.02.28
                    Time: 00:32:26
   Component: Sitzmemory FS  H07  0060
   Coding: 4063338
   Shop #: WSC 00947 210 81015
01882 - Lumbar Support Fore / Aft Adjustment Button (E336); Forward
                    Reset counter: 63
                    Mileage: 174288 km
                    Date: 2012.04.08
                    Time: 01:02:58
01883 - Lumbar Support Fore / Aft Adjustment Button (E336); Backward
                    Reset counter: 63
                    Mileage: 174288 km
                    Date: 2012.04.08
                    Time: 01:02:58
Address 37: Navigation
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H01 0080
   Serial number: 00000307900025
   Coding: 0035974
   VCID: 1D358190C4A551AC2F-8048
02139 - Control Circuit for Left Front Interior Lights
                    Reset counter: 63
                    Mileage: 174288 km
                    Date: 2003.02.27
                    Time: 00:03:00
02138 - Control Circuit for Front Right Interior Lights
                    Reset counter: 63
                    Mileage: 174288 km
                    Date: 2003.02.27
                    Time: 00:03:00
00211 - Control Circuit for Rear Illumination Lights
                    Reset counter: 63
                    Mileage: 174288 km
                    Date: 2003.02.27
                    Time: 00:03:00
01370 - Alarm triggered by Interior Monitoring
            000 -  -  - Intermittent
                    Reset counter: 103
                    Date: 2003.02.27
                    Time: 01:03:00
                    Bin. Bits: 10000000
                    Reset counter: 103
                    Mileage: 174288 km
                    Date: 2003.02.27
                    Time: 04:53:00
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802     HW: 4E2 959 802
   Component: Türsteuer.FS BRM004 0080
   Coding: 0028454
   VCID: 5EB7C69C89230AB476-800A
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H03 0030
   Revision: 00300003    Serial number:  W040304230060
   Coding: 0004345
   VCID: 2759A37896F98B7C45-8072
   Component: Heckdeckel      H06 0060
   Component: Neigungssensor  H02 0020
01565 - Luggage Compartment Light (W3)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 63
                    Mileage: 167448 km
                    Date: 2003.03.09
                    Time: 19:34:00
                    Fault Status: 00101001
                    Fault Frequency: 19
                    Reset counter: 103
                    Mileage: 174234 km
                    Date: 2003.02.27
                    Time: 00:20:00
Address 47: Sound System
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280     HW: 4E0 907 280 A
   Component: ILM Beifahrer   H06 0060
   Revision:             Serial number: 00000000013919
   Coding: 0010101
   VCID: 5DB5C190842511AC6F-8008
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802     HW: 4E2 959 801
   Component: Türsteuer.BF BRM004 0080
   Coding: 0028454
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 A    HW: 4E0 907 801
   Component: EPB  AV1C1010   H01 1010
   Revision: AV1C1010
   Coding: 0000431
   Shop #: WSC 01218 210 182178
02596 - Rear Brake Pads Worn
                    Fault Status: 01111000
                    Reset counter: 57
                    Voltage: 5.80 V
                    Count: 61
Address 55: Headlight Range        Labels: 4E0-910-357.lbl
   Part No SW: 4E0 910 357     HW: 4E0 907 357
   Component: Pre-AFS         H01 0030
   Shop #: WSC 02311 785 00200
   VCID: 62CFF26CBD5B2E5452-8036
Address 56: Radio
Address 57: TV Tuner
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H12 0550
   Revision: 00000000    Serial number: 00000000002574
   Shop #: WSC 43354 133 80440
   VCID: 204BB864F3D77C4404-8074
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  2703301613
   Coding: 344530393135313035412056413032373033333031363133
   Shop #: WSC 00000 128 00289
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 103
                    Mileage: 174290 km
                    Date: 2003.02.27
                    Time: 07:28:03
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 801 A
   Component: Türsteuer.HL BRM004 0080
   Coding: 0028454
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 802 A
   Component: Türsteuer.HR BRM004 0080
   Coding: 0028454
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283     HW: 4E0 919 283 A
   Component: Parkhilfe 8-Kan H07 0030
   Coding: 0001008
   VCID: 60CBF864B3573C4444-8034
End-------------------------(Elapsed Time: 03:58)--------------------------
Tuesday,19,May,2020,18:55:39:05279
VCDS Version: 19.6.2.2
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 25 28 34 36 37
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
11-Engine II -- Status: Cannot be reached 1100
31-Engine other -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
34-Level Control -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
Address 01: Engine
   Coding: 0395264
   VCID: 58BBD084EB07F48FBD-800C
   Subsystem 1 - Part No: 4E0 905 852 C
   Component: ELV                 1734
                    Fault Frequency: 0
                    Reset counter: 64
                    Mileage: 174288 km
                    Date: 2003.06.06
                    Time: 03:05:04
   Coding: 4063328
   VCID: 2341B768E2C1675798-8076
Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
   Part No SW: 4E0 910 729 H    HW: 4E0 035 729 A
   Component: Interfacebox    H43 0770
   Revision: 00000000    Serial number: 300LG027513722
   VCID: 2D555150B405A1273E-8078
   Subsystem 1 - Part No: 4E0 910 609
   Component: Bedienteil MMI  H41 0010
   Subsystem 2 - Serial number: 318AM037503766
   Subsystem 3 - Serial number: ÿÿ21.01.03ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
   Subsystem 4 - Serial number: ÿÿÿÿÿÿÿ
   Coding: 0088209
   VCID: 5ABFCA8C950BE69F8B-800E
                    Reset counter: 103
                    Mileage: 174290 km
                    Date: 2003.06.06
                    Time: 02:57:50
                    Voltage: 11.90 V
                    Temperature: 16.0°C
                    (no units): 62.0
                    (no units): 87.0
                    Temperature: -85.0°C
01867 - Rear Left Warm/Cold Flap Air Outlet Motor (V220)
                    Reset counter: 103
                    Mileage: 174290 km
                    Date: 2003.06.06
                    Time: 02:57:50
                    Voltage: 11.90 V
                    Temperature: 16.0°C
                    (no units): 62.0
                    (no units): 87.0
                    Fault Status: 00101110
                    Reset counter: 103
                    Mileage: 174290 km
                    Date: 2003.06.06
                    Time: 02:57:52
                    Temperature: 16.0°C
                    Reset counter: 103
                    Mileage: 174290 km
                    Date: 2003.06.06
                    Time: 02:57:53
                    Voltage: 11.90 V
                    Reset counter: 103
                    Mileage: 174290 km
                    Date: 2003.06.06
                    Time: 03:05:46
                    Voltage: 13.80 V
                    Temperature: 16.0°C
                    (no units): 174.0
                    (no units): 86.0
                    Reset counter: 103
                    Mileage: 174290 km
                    Date: 2003.06.06
                    Time: 03:09:33
                    Voltage: 14.50 V
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 15: Airbags
   Coding: 0112041
   VCID: 65C5E970AC75596736-8030
   Coding: 0001411
   VCID: 5CB3CC949F3F18AF99-8008
   VCID: 59BDD580900DED8782-800C
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
02757 - Learning Tire Pressures
   Coding: FCFEFFDE0B2504
                    Reset counter: 104
                    Mileage: 174290 km
                    Date: 2003.06.06
                    Time: 03:11:50
                    Reset counter: 104
                    Mileage: 174290 km
                    Date: 2003.06.06
                    Time: 03:11:51
                    Reset counter: 104
                    Mileage: 174290 km
                    Date: 2003.06.06
                    Time: 03:11:51
   Coding: 0395264
   Component: ELV                 1734
   4E0905852C  ELV                 1734
                    Fault Frequency: 0
                    Reset counter: 64
                    Mileage: 174288 km
                    Date: 2003.06.06
                    Time: 03:05:04
   Coding: 0000000
   VCID: 61CDFD60B85D3547CA-8034
01863 - Air Outlet Motor; Rear Left (V218)
   Coding: 4063338
                    Reset counter: 64
                    Mileage: 174288 km
                    Date: 2012.04.08
                    Time: 01:02:58
                    Reset counter: 64
                    Mileage: 174288 km
                    Date: 2012.04.08
                    Time: 01:02:58
   Part No SW: 4E0 910 887 D    HW: 4E0 919 887 C
   Component: MNS ECE         H41 0550
   Revision: 00000000    Serial number: 305D6037533001
   VCID: 2E57565CB903DA3F07-807A
   Coding: 0028454
   VCID: 5EB7C69C89230ABFF7-800A
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 G    HW: 4E0 035 223 A
   Component: DSP-Amp.-High   H13 0360
   Revision: PROD_01     Serial number: 00000000138953
   Coding: 0000013
   VCID: 214DBD60F8DD75478A-8074
   Coding: 0010101
   VCID: 5DB5C190842511A7EE-8008
                    Reset counter: 104
                    Mileage: 174288 km
                    Date: 2003.06.06
                    Time: 03:11:00
                    Reset counter: 104
                    Mileage: 174288 km
                    Date: 2003.06.06
                    Time: 03:12:00
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
                    Reset counter: 64
                    Mileage: 174288 km
                    Date: 2003.06.06
                    Time: 03:04:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
                    Reset counter: 64
                    Mileage: 174288 km
                    Date: 2003.06.06
                    Time: 03:04:00
   Coding: 0028454
   Part No SW: 4E0 910 541 C    HW: 4E0 035 541 B
   Component: TUNER EU/US/RDW H41 0290
   Revision: 00000000    Serial number: 304AS047558496
   Coding: 0000001
   VCID: 204BB864F3D77C4F85-8074
Address 57: TV Tuner        Labels: 4E0-910-146.clb
   Part No SW: 4E0 910 146 C    HW: 4E0 919 146
   Component: TV analog TUNER H11 0210
   Revision: 00000008    Serial number: 00000000000000
   Coding: 0001003
   Shop #: WSC 00000 785 00200
   Component: von VA0  2703301614
   Coding: 344530393135313035412056413032373033333031363134
   Shop #: WSC 12345 128 00289
   Coding: 0028454
   Coding: 0028454
End-------------------------(Elapsed Time: 03:49)--------------------------
Interesting that the Kessy module itself thinks it has a problem:
I don't know if its location depends on whether the car is LHD or RHD. But I would find it and inspect it. Water damage seems to be a common issue.
DrPeter
16.4905° S, 151.7375° W
a.) CAN-Bus messages from other controllers
b.) Strong RF signals / interference / EMF / quasar emissions / etc..
c.) Faulty controller
a.) The J518 control unit is located on the vehicle's floor under the driver's seat (LHD) or the passenger seat (RHD)
b.) See the Official Factory Repair Information
- Personally, I do not recall, but anything is possible if it is an Audi or Volkswagen :p
We do not recommend pulling fuses or disconnecting controllers in order to find a parasitic batter draw. We do recommend to use the procedures found in the Volkswagen TSB Parasitic draw testing through fuse panel VW technical bulletin 270711
Hope this helps,
drpeter
Pinpointdiag
Scotland
C?ID=90374
Yes Drpeter that helps. I have only waited maybe an hour before testing. I was expecting every thing to have powered down after 30mins. maybe 45. not two hours. I'll try again
I am testing with a low amps clamp and by drop test over fuses pretty much as the tsb says.
Disconnecting the module would only be further evidence.
c.) Faulty controller.
What about a fault with one of its sensors. ie door buttons or proximity sensors.
Quasar emissions. ?
I have logged in to erwin and it gave a location of in front of drivers seat. But it showed left hand side. This is RHD. I could not find any clarification of that. i probably misread.
Ewe. Hopefully the module will show signs of water damage given its location on the floor.
Thanks for replying
Pinpointdiag
Scotland
C?ID=90374
What exactly does it do besides measuring the voltage drop across a fuse and then using that to estimate the current flowing through that fuse?
Unless I'm missing something, one can accomplish exactly the same thing with a standard digital volt meter and fuse chart..
Yes you can do the same thing with a dmm, This just makes it a lot easier as it gives an audible indication when you make a good connection across the fuse and a different
signal when you hit one with current flowing. You only have to pay attention to probing the fuse terminals. With a dmm, one fuse box with 30 fuses means you have to probe 60 tiny terminals
and then look away to the screen between each fuse often while upside down under a dash.
It then also shows the actual current with out having to look it up.
I think it was worth £30. Not sure I'd pay over £100 that it normally seems to sell for.
