hello colleagues
I want to activate developer mode on my audi but I can't.
I have an error "request aut of range".
I searched the forum but I couldn't understand.
I would also like to increase the speed for self-lowering from 50km0h to 100km / h
thanks.
thanks.
Wednesday,20,May,2020,18:38:51:33100
VCDS Version: 20.4.1.0 HEX-NET CB: 0.4508.4
VIN: WAUZZZ4G3GN104663 License Plate:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 18 19 20 28 34 36 3B 3C 42 44
46 52 53 55 5F 62 6C 6D 72 85 8B 8E 8F 90 AC
VIN: WAUZZZ4G3GN104663 Mileage: 159625km-99186miles
Address 01: Engine (J623-CRTD) Labels:. 059-907-401-V2.clb
Part No SW: 4G2 907 401 B HW: 4G2 907 401
Component: 3.0TDI EDC17 X34 0007
Revision: 92X34---
Coding: 0A25401A046601030000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM30TDI0114G2907401B 001007
ROD: EV_ECM30TDI011_AU57.rod
VCID: 2404C71B2F5AB3A64F-8070
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G0 927 166 C HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0007
Revision: --H03---
Coding: 100001
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 2D12223F7C9072EE90-8078
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 17A6DE49E8657B929B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41CA6E8FD008868E44-8014
Part No SW: 4H0 907 064 GN HW: 4H0 907 064 GN
Component: BCM2 2.0 H37 0572
Coding: 01A8700E000000000000
VCID: 7BB6DC67FA642C5E5E-802E
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Component: KLIMA 4 ZONEN H14 0112
Serial number: 27101500041430
Coding: 361111782D0000
VCID: 638684076AD4F49E76-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001197529301
Coding: 0105001440349FE2C9014083A0001800CF9CC3082E08020100000894E10117020040003D030000
VCID: 71AAFE4FA828560EF4-8024
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 150724 H38 0080
Serial number: 150827080205
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 20832182
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 AL HW: 4G0 941 531 AL
Component: E1 - LDS H07 0044
Serial number: 23 10 2015 00001067
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: DAE844D7000000000001
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 B HW: 4G0 907 561
Component: ACC3 H21 0055
Coding: 7E04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002015
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 291AD62F48786ECE7C-807C
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P100733VU
Coding: 30333130313730323535554A304C34473053
VCID: 3B361C67B2E4EC5E1E-806E
Serial number: 3575HRB405J3LHKEDH3$
Serial number: 3585HRB40653LHKI7GCX
Serial number: 3515JRB405L3JK62EGV/
Serial number: 3525JRB405F3JRS29HM8
Serial number: 3554VRB4014553HEF8PF
Serial number: 3564VRB401C553HEEA66
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372OJQ0001Z
Coding: 0000FC
VCID: 373E005786CCC83EFA-8062
Serial number: 11 09 2015 A0028007
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 934 H HW: 4G8 920 934 H
Component: TDieRdwAcc H11 0106
Revision: 08001098 Serial number: 658211015596021
Coding: 13860A001F550008000000
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K_AU57.rod
VCID: 36200D5389C63136E1-8062
Address 18: Aux. Heat (J364) Labels:. 8R0-265-105.clb
Part No SW: 4H0 265 105 J HW: 4H0 265 105 J
Component: Standheizung H26 0270
Revision: 77007007 Serial number: 20151013232122
Coding: 5D3F01
VCID: 291AD62F40786ECE7C-807C
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000002026189
Coding: C0CD078118
ASAM Dataset: EV_GatewPkoUDS 001028
Serial number: 1860608103
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 150810000000000001EF
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
VCID: 679E901796EC98BEAA-8032
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 26101500040990
Coding: 21
VCID: 3D32127FACF0E26E20-8068
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H19 0783
Coding: 008002
ASAM Dataset: EV_AirSuspe 003025
ROD: EV_AirSuspe_VW51.rod
VCID: 2F2E3837769C00FEA2-807A
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000169760875
Coding: 0058130000006001000001010101102030303232203232
VCID: 77BEC057C64C083E3A-8022
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA820AE53-
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 4G0 907 566 M HW: 4H0 907 566 F
Component: SWA Master H07 0060
Serial number: 0384442133
Coding: 040311
VCID: 393A066FB8D8DE4E0C-806C
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 4G0 907 568 M HW: 4H0 907 568 F
Component: SWA Slave H07 0060
Serial number: 0384590216
Coding: 040311
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0511
Coding: 011F16015E00628002080013
VCID: 45C27A9FCC20AAAE78-8010
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H53 0202
Revision: 00000002 Serial number: 0000329158
Coding: 101001010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A381963BDDED55605-806E
Revision: 00002001 Serial number: 0384080595
Coding: 011A062080B93084C32008840E010E470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 A
Component: Sensor, DWA 005 0002
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H03 0004
Serial number: 0000FST000LRXLU00000
Coding: 901F02
Subsystem 4 - Part No SW: 4G0 947 135 F HW: 4G0 947 135
Serial number: 0000000AP00016038501
Component: TSG BF H03 0511
Coding: 011F16015E00628002080002
VCID: 46C07D93F126A1B671-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001638040
ROD: EV_ParkiBrake_VW51.rod
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 04FA02102A630200
VCID: 3424375B9FBA2326DF-8060
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01E00
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01E00
Part No SW: 4G1 035 043 S HW: 4G1 035 043 D
Component: MU-H-N-EU 051 0389
Serial number: A736J0FB000892
Coding: 01750101FF0A000013110001000A00032F0006E5F17001009F
VCID: 2E102533719609F6A9-807A
Subsystem 1 - Part No SW: V03 959 801 FA HW: -----------
Component: ECE 2016 --- 0134
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0006
Serial number: AUZ8Z9FY803677
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G1 919 610 F HW: 4G1 919 610 F
Serial number: 90349OJN000U1
Component: Gracenote2 --- 1012
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Component: TSG HL H03 0511
Coding: 010F14004000628002080002
VCID: 49DA76AFE0384ECE9C-801C
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0140
Coding: 0275000102002003000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
ROD: EV_CamSysRVRVCPANAAU57X_001.rod
VCID: 78BCC36BC352074633-802C
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G5 959 107 C HW: 4G5 959 107 A
Component: HDSG-Modul H02 0049
Revision: 13002001 Serial number: 277500969
Coding: 111104C000
ASAM Dataset: EV_HDSGAu571 001022
ROD: EV_HDSGAu571.rod
VCID: 3228314365AE2D16CD-8066
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0511
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H27 0081
Revision: -------- Serial number: 262130025421000
Coding: EA060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C142F3B478A7BE687-8078
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 B HW: 4G0 907 541
Coding: 7E04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
ROD: EV_AdaptCruisContr2AU57X_002.rod
VCID: 271ED0175E6C58BE6A-8072
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4H0 907 107 H HW: 4H0 907 107
Component: BV-SG H33 0090
Serial number: 005000623010157
Coding: 04C0BB181111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H14 0080
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
VCID: 312A3E4F60A8160EB4-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H14 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 152750670
ROD: EV_RDCMA00100.rod
End----------(Elapsed Time: 02:49, VBatt start/end: 12.4V/12.3V)-----------
