Results 1 to 9 of 9
Thread: MY16 Golf R - fuel gauge issues
    Verified VCDS User dontuan's Avatar
    May 2020
    Hello all,
    Was hoping someone could shed some light on this before I pull what's left of my hair out
    I recently upgraded the LPFP in my car and tried running an "Adaptation of Fuel Pump (FP)" (not sure if related), but afterwards I noticed my fuel gauge showing empty and 0 range left when I know for a fact there's at least 1/4 tank left. I swapped the stock pump/basket back over and it's still showing empty now, so I put the new pump/basket back in and went out to fill up. On my way to the gas station I get "Error: Fuel tank system! Service Vehicle." After filling up the tank my gauge moved to 1/2
    Below is the scan:
    Monday,18,May,2020,17:25:26:58744
    VCDS Version: 20.4.1.0 (x64)
    VIN: WVWLF7AU0GW146427   License Plate: MK7 R_STG 3 FUEL
    Mileage: 78553km-48810mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 52 55 5F 75 A9
    VIN: WVWLF7AU0GW146427   Mileage: 78553km-48810miles
    Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 H    HW: 06K 907 425 E
       Component: 2.0l R4 TFSI  H13 UME1
       Revision: --H13---
       Coding: 091D00122426000E3004
       ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
       ROD: EV_ECM20TFS0208V0906259H.rod
       VCID: 45816251C4449EAE78-8010
    23086 - Fuel Level Sensor Circuit
              P0463 00 [039] - Signal too High
                        Mileage: 78553 km
                        Date: 2020.05.18
                        Time: 17:13:23
                        Coolant temperature: 80 °C
                        Intake air temperature: 43 °C
                        Voltage terminal 30: 12.324 V
                        Engine: operating status: ES
                        STATE_LS_SAE[1]: INI
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 97 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                        FAC_TPS_1_SAE: 16.406250 %
                        FUP_H_SAE: 7800.0 kPa
    22063 - Implausible Data Received from Instrument Panel Control Module
              U0423 00 [039] - -
                        Mileage: 78553 km
                        Date: 2020.05.18
                        Time: 17:13:13
                        Voltage terminal 30: 12.363 V
                        ECU_STATE: ENG_STOP
                        Engine oil temperature: 82.0 °C
                        Time since engine start: 0.0 s
                        T_ES: 10 min
                        Cruise control switch actuation-Main switch hardware: not activated
                        Cruise control switch actuation-Main switch CAN: not activated
                        ECU_STATE: ENG_STOP
    22092 - Implausible Data Received from Instrument Panel Control Module
              U0423 00 [039] - -
                        Mileage: 78553 km
                        Date: 2020.05.18
                        Time: 17:13:13
                        Voltage terminal 30: 12.343 V
                        ECU_STATE: ENG_STOP
                        T_ES: 10 min
                        ECU_STATE: ENG_STOP
    Readiness: 1110 0101
       Part No SW: 0D9 300 014 Q    HW: 02E 927 770 AQ
       Component: DQ250-UM 661s H53 4523
       Revision: 06253104    Serial number: TFK01509211628
       ROD: EV_TCMDQ250021.rod
       VCID: 2643C5DD590275B651-8072
       Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
       Component: ESC           H42 0623
       Revision: 00000000    Serial number: 62665000003949
       Coding: 01FA6BA154240972057B030241CA6980D62A90A0C08296B700400058C208
       ROD: EV_Brake1UDSContiMK100IPB_034.rod
       VCID: 79F9DEA1F83C2A4E4C-802C
    0297 - Steering angle sensor
              B1168 16 [008] - Voltage Too Low
                        Fault Frequency: 12
                        Reset counter: 199
                        Mileage: 78544 km
                        Date: 2020.05.09
                        Time: 00:27:58
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 246
                        Mileage: 67961 km
                        Date: 2019.04.14
                        Time: 16:43:32
    16412 - Display for Tire Pressure Monitoring
                        Reset counter: 198
                        Mileage: 78544 km
                        Date: 2020.05.09
                        Time: 00:28:08
    16413 - Display for Tire Pressure Monitoring
                        Reset counter: 198
                        Mileage: 78544 km
                        Date: 2020.05.09
                        Time: 00:28:08
       Revision: 00021000    Serial number: 0380555746
       Coding: 030C0C
       VCID: 3A7B01ADBDBAE15605-806E
       Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
       Revision: 00001K08
       Coding: 00020004200100000005000012111402
       VCID: 6ADBF1ED8D9A91D6B5-803E
       Part No SW: 5Q0 937 085 AJ    HW: 5Q0 937 085 AF
       Component: BCM MQBAB HNA H24 0175
       Serial number: 01061526800809
       Coding: 00011A46C041A2F169E44000091C07201800000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 0109B64190EC728E04-8054
       Component: WWS    150913  043 0551
       Serial number:         150923103511
       Component: RLHS  037 0059
       Serial number: S5Y15M10D12H15M18S22
       Coding: 06A8DD
       Serial number: 003GCR03K2SP
       VCID: 479D6859FE488CBE8A-8012
       Occupant Detection:
       Component: BF-Gewichtss.  H11 0021
       Serial number: IBH000000000003B8KWY
       Coding: 303058
       Subsystem 2 - Part No SW: -----------    HW: 480 002 809 15
       Serial number: 3570000000006AC0B61I
       Subsystem 3 - Part No SW: -----------    HW: 480 002 809 15
       Serial number: 3580000000096690B61L
       Subsystem 4 - Part No SW: -----------    HW: 480 403 009 15
       Serial number: 3510002A71CCEA01C048
       Subsystem 5 - Part No SW: -----------    HW: 480 403 009 15
       Serial number: 3520002B91CF2DA5D30K
       Subsystem 6 - Part No SW: -----------    HW: 480 403 009 15
       Serial number: 35500029D1CF2D70E20H
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 403 009 15
       Serial number: 3560002B11CF2D7561DH
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0110
       Revision: --------    Serial number: 01101504220458
       Coding: 0410
       ROD: EV_SMLSKLOMQB_009_VW37.rod
       VCID: 071DA859BEC84CBE4A-8052
    No ASAM data for: "EV_SMLSKLOMQB" (VW37)
       Part No SW: 5G1 920 858 A    HW: 5G1 920 858 A
       Component: KOMBI         303 6420
       Coding: 0BAD081A2B80CF0502086A001400000000000000
       VCID: 2E533DFD71F23DF6A9-807A
    9453074 - Fuel Level Sensor 1
              B103E 1B [009] - Resistance Too High
                        Reset counter: 157
                        Mileage: 78544 km
                        Date: 2020.05.07
                        Time: 16:10:30
    9459739 - Fuel Level Sensor 2
              B1058 1B [008] - Resistance Too High
                        Reset counter: 197
                        Mileage: 78544 km
                        Date: 2020.05.07
                        Time: 16:10:30
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1223
       Revision: --------    Serial number: 0004017700
       Coding: 0101000830085900FB00022A1C0F00000001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 75E1D291D4244E2E28-8020
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H10 0101
       Serial number: 29150001859120085386
       Coding: 31FFFF
       Component: Haldex4Motion H52 UM01
       Serial number: HA1-00027.07.15
       Coding: 0001
       VCID: 4A9B516DED5A71D695-801E
       Revision: 00000000    Serial number: 15000217469009
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 34672F959FDE1726DF-8060
       Serial number: 220915BIL04347
       Coding: 001F1320D000040000000000
       VCID: 43857C49CA70A09E56-8016
       Serial number: 00000000000007484243
       Coding: 111000
       Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
       Component: EPS_MQB_ZFLS  505 5063
       Coding: 8102
       VCID: 39791EA1B8BCEA4E0C-806C
       Serial number: 250915BIO17929
       Coding: 001F1320DE00040000800000
       VCID: 428B794DD56AA9965D-8016
       Serial number: 00000000000007592489
       Coding: 091000
              B1487 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 177
                        Mileage: 77982 km
                        Date: 2020.04.19
                        Time: 12:32:29
       Coding: 022A01010B000400
       VCID: 408F7345DB66BB864B-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Part No SW: 3Q0 035 844     HW: 3Q0 035 844
       Component: MU-S-S-US     H25 0245
       Serial number: VWZAZ2R0459001
       Coding: 02730000FF00000051220001001808001F0207D40120010002
       ROD: EV_MUStd4CTSAT_VW37.rod
       VCID: 6CD7F7F5876E8FE6C7-8038
       Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
       Component: ABT_Std-2  H50 8130
       Serial number: VWZ6ZJT1845672
              B201A 00 [009] - -
                        Reset counter: 177
                        Mileage: 64691 km
                        Date: 2019.03.20
                        Time: 18:29:07
                        Voltage terminal 30: 12.1 V
                        Status_Software_Version_Management-module_name: D
       Component: OCULowMQBUS   007 0568
       Coding: 02730002C2821A017F1E06020000
       ROD: EV_OCULowMQB.rod
       Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
       Serial number: 150909200614
       VCID: 2F6D20F976F834FEA2-807A
    End-------------------------(Elapsed Time: 04:36)--------------------------
    Jul 2014
    Hi dontuan,
    I take it the DTC's about fuel sensors in 17 Instruments do not clear? Have you checked the connector for bent pins or damaged wiring, does the connector fit properly?
    Regards HMC
  3. Likes Dana liked this post
    May 2020
    Quote Originally Posted by HMC View Post
    Hi dontuan,
    Regards HMC
    At first they would not clear when the needle was below empty, but after I filled up all the way the needle moved to 1/2 tank I was then able to clear it.
  5. Likes Dana liked this post
  6. #4
    Perhaps there are some clues in the IDE03473 series of measuring values for the fuel tank sensors.
  7. Likes Dana liked this post
  8. #5
    Does the Golf R have 2 fuel level sensors?
  9. Likes Dana liked this post
  10. #6
    May 2020
    That’s what I was hoping it was, but don’t know where to start with that.
    Yes, but the only one I touched was the main pump in the passenger side.
  11. #7
    United States
    Advanced Measuring Values are explained here:
    https://www.ross-tech.com/vcds/tour/adv-meas-blocks.php
    Although we'd want to see data from this car you might find my 17-Instruments control module map from a dual level sender wagon helpful. There's an entire chunk of IDE03473 Adv measuring value groups with sensor 1 and 2 data and the tank was nearly full.
    If you purchased VCDS new (rather than used) I believe you fall into #2 here.
  12. Likes Uwe liked this post
  13. #8
    May 2020
    Dana - appreciate the assistance and yes, I did purchase my cable new and fall into the #2 category. I will start there by registering it and will report back.
  14. Likes Dana liked this post
  15. #9
    don: Hi. I don't have details for your specific NAR model vehicle in my database but based on cobbling together information from other Golf mk7s, perhaps you might consider this:
    The 3 x wires shown as "1" in the upper part of the picture are the fuel gauge sender wires for a transducer in the WD on the lower part of the picture. Now clearly, the WD in my picture is not the same as your car because the arrangement above shows a single integrated unit for both fuel gauge senders - but keep an open mind for a while longer, please!
    Again, I could be trying to join dots that don't exist - but if you needed to re-connect the 3 x wires shown in the top part of the picture as part of the pump replacement exercise - maybe there was an error in positioning the colours (no offence intended in suggesting this - I'm just hypothesizing)? If this happened, the measurement parameters for KX2 in the lower part of the picture would be incorrect - potentially producing the type of measurement errors that you have observed - perhaps?
    If you consider my musings to be worthy of further investigation - I suggest that you grab a copy of the actual WD for your model vehicle and confirm the wire colour/pin positions on the housing connector
  16. Likes NZDubNurd, PetrolDave, Dana, Uwe liked this post
