Results 1 to 5 of 5
Thread: 2005 passat b6
    Pirate
    May 2020
    Southampton, UK
    2005 passat b6
    hi guys, i have an issue with a passat. it came in as a non starter with various no comms faults. i traced the fault to a fried steering column control module causing fuse 16 in the engine bay to blow. ive replaced the module with a used part with exactly the same part number but i need some help coding it. ill include autoscans with the old part fitted and the new part fitted.thanks a lot
    Pirate
    May 2020
    Southampton, UK
    new part fitted
    Removed.   Data from a clone/pirate copy of VCDS is not acceptable here
    Pirate
    May 2020
    Southampton, UK
    old part fitted
    Pirate
    May 2020
    Southampton, UK
    im assuming the key fault if due to incorrect vin or no coding. the airbag and radio faults are because thryre not fitted
    Quote Originally Posted by tomb711 View Post
    Getting help in this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php#uk
