Results 1 to 10 of 11
Thread: USB 2.0 Extension Cable
    Mar 2020
    Canada
    Recently bought Hex-V2 scanner and am pleased with its performance but standard connecting cable is short. I would have chosen the 5 m cable if it were an option. If I buy the USB 2.0 extension cable will the power draw increase? I ask b/c with engine off the time to bat. voltage dropping down to 12V and communication loss is marginal as it is with the standard cable.
    Jun 2014
    Poland
    up to 3m is ok
    longer that this is recommend use ACTIVE one with power
    Mar 2020
    Canada
    Quote Originally Posted by Spacewalker View Post
    up to 3m is ok
    ?? What are you talking about? Your answer is not about what I asked.
    Quote Originally Posted by morris39 View Post
    You might want to reconsider that reply....
    Both active and passive USB extension cables are available; if you use a passive cable then there is no reason why power draw will increase, but if the extension is longer than 3m the attenuation of signals could make the connection unreliable.
    If you want to use a USB extension longer than 3m then you should us an active extension, such as https://www.amazon.co.uk/UGREEN-Exte.../dp/B00B2HP3A2, this will slightly increase the power draw but will be more reliable.
  5. Likes Uwe liked this post
    Note that passive extension cables are not permitted by the USB standards. That doesn't mean they can't or won't work, but it does mean that if it doesn't, you can't complain at anyone.
    An "active" cable is basically a cable with a single-port hub on the end.
    If I wanted a longer cable for my HEX-V2, I would buy a passive USB-A to USB-B ("printer") cable in whatever length (up to 5m) to avoid having any connectors somewhere in the middle. It will be lacking the screw-lock on the "B" end of the cable we ship, but that's of little consequence.
    A total length beyond 5m requires an active repeater in any case.
    Mar 2020
    Canada
    Stiil confused. Your site offers a 5m USB 2.0 extension cable which has "active repeater electronics". My original question is about that accessory cable possible additional power draw. You suggest using printer cable. Is that cheaper than your accessory cable? 3 m would suffice for me.
    Original question still stands re your 5m cable.
    Mar 2020
    Canada
  10. #8
    Mar 2020
    Canada
    Cross purposes. Pls. see my response to Uwe below.
  11. #9
    Yes, it will marginally increase power draw from the USB port on the computer. I do not know how much, but I don't think it will be particularly significant. I also do not think it will increase power draw from the car's OBD-II port at all, not that this should really matter much, because unlike the HEX-NET, the HEX-V2 does not have a low-power sleep mode and shouldn't be left plugged into a car's OBD-II port permanently.
    Most likely:
    10': https://www.amazon.com/dp/B00NH13DV2/
    15': https://www.amazon.com/dp/B00BCWALHM/
    But you're in Canada, so YMMV.
  12. #10
    Mar 2020
    Canada
    Most likely:
    Thanks for the clear response.
