Results 1 to 4 of 4
Thread: Throttle Body Adaptation Failed due to "Aborted-Saftey reasons"
    New User
    Sep 2019
    Texas, USA
    I tried to do throttle body adaptation on a 2013 Audi A8. The reason is that the throttle body has been recently cleaned. I followed the proper procedure documented on VCDS website: 01-Engine-->Basic setting-->Test of throttle valve adaptation-->Go.
    However, as soon as I hit Go a message "Aborted-Safety reasons ERROR" poped up and the adaptation was unsuccessful. I tried several times after recycling the engine and ignition but still didn't work. There were no fault codes regarding the engine.
    Please help and advise what to do.
    Thanks in advance!
    Monday,04,May,2020,13:17:40:36290
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
    VCDS Version 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
    VIN: WAUR2AFD9DN008993   License Plate:
    Mileage: 157636km-97950mi   Repair Order:
    Chassis Type: FD-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 20 28 34 36 3B 3C 42
              46 47 52 53 56 5F 62 6C 6D 6F 72 81 85 88 89 8B 8E 8F 90 BA
    VIN: WAUR2AFD9DN008993   Mileage: 157636km-97950miles
    BA-Motor Mounts -- Status: OK 0000
    Address 01: Engine (------CEUA)       Labels: Redir Fail!
       Part No SW: 4H0 906 014 L    HW: 4H0 906 014
       Component: 4.0l V8TFSI / H56 0005
       Revision: NCH56---
       Coding: 022A00326546010E1000
       Shop #: WSC 30909 002 1048576
       ASAM Dataset: EV_ECM40TFS0114H0906014L 001005
       ROD: EV_ECM40TFS0114H0906014L.rod
       VCID: 2C01FA48F683EB4BDF3-8079
    Readiness: 1110 1101
       Part No SW: 4H1 927 158 EE    HW: 0BK 927 156 AG
       Component: 0BK 40TFSIUSA H16 1002
       Revision: --H16---
       Coding: 000001
       Shop #: WSC 03200 002 104857
       ASAM Dataset: EV_TCMALX51011 002022
       ROD: EV_TCMALX51011_002_AU64.rod
       VCID: 77AB15247F459893621-8023
       Part No SW: 4H0 907 379 E    HW: 4H0 907 379 E
       Component: ESP PREMIUM   H10 0352
       Coding: C4E5F30023A7CF00E200
       ASAM Dataset: EV_ESPPremi 005013
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 3431E2282EB3B38B873-8061
       Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 CD
       Component: BCM2 2.0      H32 0510
       Coding: 0DA72046000000000000
       Shop #: WSC 05141 444 105578
       VCID: 6E853040009FD95BB17-803B
       Serial number: 2312000152884004
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Revision: AA000000    Serial number: 00000033390141
       Coding: C018320085047201010001010101112131313333283333
       Shop #: WSC 02313 785 00200
       VCID: 3537DF2C2549AA83B0D-8061
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 H    HW: 4H0 820 043 H
       Component: Klima 4 Zonen H20 0120
       Coding: 688122B87C
       VCID: 25170F6C9569DA0300D-8071
    0137 - Motor for  Right Side Window Defrost Flap
              B10D8 22 [009] - Signal Amplitude Too High
                        Reset counter: 237
                        Mileage: 157636 km
                        Date: 2020.05.04
                        Time: 13:13:31
    0194 - Position Sensor in Left Center Vent
              B10E1 15 [009] - Open or Short to Plus
                        Reset counter: 237
                        Mileage: 157636 km
                        Date: 2020.05.04
                        Time: 13:13:36
       Revision: 11012002    Serial number: 00000001558924
       Coding: 09072091077C9FE38B000804A0003800009CD3088E0001218001085C7B00
       VCID: 6FBB2D440795D053BA1-803B
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 120419  H35 0080
       Serial number:         120618091241
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 10267873
       Coding: 025523
       Component: E1 - LDS  H07 0044
       Serial number: 04 07 2012  00000597
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R2A4002
       Serial number: 00000016071200010282
       Coding: 100000
       Serial number: 00000010071200010778
       Coding: 100000
       Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA103815000001585313
       Coding: 020300
       Serial number: 32F8CA36000000000001
       Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
       Component: PARKHILFE ACC H01 0072
       Revision: 11001001    Serial number: 61061219800162
       Coding: A80B02
       ASAM Dataset: EV_EPHVA18AU57X0000 003008
       Part No SW: 4H0 907 561 B    HW: 4H0 907 561
       Component: ACC3          H17 0400
       Coding: 7E01020201
       ASAM Dataset: EV_AdaptCruisContrAU64X 002021
       ROD: EV_AdaptCruisContrAU64X_002.rod
       VCID: 2A0DFC50FC77F57B2DF-807F
       Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
       Component: Airbag10.43   H44 0041
       Revision: --------    Serial number: 003JS001BP9A
       Coding: 303143303230303030314A55304C34483053
       VCID: 372BD5243FC55893A21-8063
       Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
       Component: BF-Gewichtss.  H03 0040
       Serial number: 5850000R12710052N7
       Serial number: 3575HRB405R1F0BC5O9G
       Serial number: 3585HRB405B1F0BABGMA
       Serial number: 3515JRB40184UIV8KHRO
       Serial number: 3525JRB40184UIV8C97W
       Serial number: 3554VRB40084UIV8KGMW
       Serial number: 3564VRB40084UIV8CI8D
       Revision: --------    Serial number: 90815LGB0001Q
       Coding: 0004BC
       VCID: 3829D618325B57EBABB-806D
       Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
       Component: E221 - MFL  H09 0009
       Serial number: 09 05 2012  B1049429
       Part No SW: 4H0 920 980 K    HW: 4H0 920 980 K
       Component: TBenUSAACC--- H71 0515
       Revision: 35081077    Serial number: 658140712592033
       Coding: 0B4F08015744D705020000
       ASAM Dataset: EV_RBD4K 004046
       ROD: EV_RBD4K_AU64.rod
       VCID: 3333E1342BBDB4B39E9-8067
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
       Component: Analoguhr D4  H05 0224
       Serial number: 1120622000830
       Part No SW: 4H0 907 468 AB    HW: 4H0 907 468 AA
       Component: J533--Gateway H10 0028
       Revision: --------    Serial number: 00000000607915
       Coding: 00ED074800
       ASAM Dataset: EV_GatewPkoUDS 001013
       VCID: 71BF2B3C1121C6A3AC5-8025
       Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
       Component: J367-BDM  H08 0181
       Serial number: 00000000004970639415
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
       Serial number: 12186003312011200410
       Part No SW: 8K0 857 511 G    HW: 8K0 857 511 G
       Component: FLA           H04 0020
       Revision: AB001001
       Coding: 04018B6B74745D545420363E00
    Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
       Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
       Component: Klima Fond    H16 0120
       Coding: 2000000000
       ROD: EV_AirCondiHeck.rod
       VCID: 313FEB3CD1A186A3EC5-8065
       Part No SW: 4H0 907 553 E    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H17 0099
       Coding: 008002
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2E05F040C09F995BF17-807B
       Revision: AA000000    Serial number: 00000033390275
       Coding: C0183B0085057201010001010101112131313333203333
       Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
       Component: SARA 6D       H02 0053
       Revision: --------    Serial number: EJ1BPA77004GN8
       ASAM Dataset: EV_SARA2 005011
       ROD: EV_SARA2.rod
       Part No SW: 4H0 907 566 A    HW: 4G0 907 566
       Component: J769  SWA MasterH02 0040
       Revision: 00H02000    Serial number: 6PZ 010 287-07
       VCID: 2E05F040CC1F995BF17-807B
       Subsystem 1 - Part No: 4H0 907 568 A
       Component: J770  SWA Slave H02 0040
       Subsystem 2 - Serial number: 6PZ 010 287-27
       Subsystem 3 - Serial number: 5F23.07.1200H02000AMS14483
       Subsystem 4 - Serial number: S14483
       Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
       Component: TSG FA        H06 0263
       Revision: --------    Serial number: 0000128992246
       Coding: 011F1F005E0062C202003017
       Shop #: WSC 02312 785 00200
       VCID: 48C9A6D842BB276BDBB-801D
       Revision: 00002001    Serial number: 0180520372
       Coding: 0106063A00FA759FB3B0C7840603010F0000000000000000000000000000
       Shop #: WSC 02311 785 00200
       Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
       Component: GTO BF  H01 0080
       Serial number: 00000000000000092513
       Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J245  007C  H06 0005
       Serial number: 225400086790
       Coding: 020200
       Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
       Component: Dachelektroni  H11 0080
       Serial number: A2012000000000598116
       Coding: 070000
       Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J394  0014  H06 0005
       Serial number: 225400086658
       Coding: 020200
       Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J392  006A  H06 0005
       Serial number: 225400086789
       Coding: 020200
       Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J867  00E0  H06 0005
       Serial number: 225400086409
       Coding: 020200
       Subsystem 8 - Part No SW: 3AA 962 243     HW: 3AA 962 243
       Component: GEB.F.Heckoef  H12 0719
       Serial number: 84281041
       Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
       Component: BOSE-G3C7-ANC H02 0540
       Revision: CJ002700    Serial number: 00000000002291
       Coding: 030000
       VCID: 1C612A88A6A31BCBAF3-8049
       Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
       Component: TSG BF        H06 0261
       Revision: --------    Serial number: 0000129133230
       Coding: 011F1F005E0062C202003007
       VCID: 3C21CA0806637BCB4F3-8069
       Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
       Component: EPB-4         H03 0013
       Revision: --------    Serial number: 00000000407756
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2B03F954F38DEC73D69-807F
       Part No SW: 4H0 035 082 H    HW: 4H0 035 082
       Component: Radio U SIRIU H60 0138
       Revision: AB001007    Serial number: 155G%0C7522929
       Coding: 020007010000000001
       VCID: 26150860E8EFD11B097-8073
       Part No SW: 4H0 035 746 M    HW: 4H0 035 746 C
       Component: H-BNT-NA      H49 1038
       Revision: --------    Serial number: 183GP0C7502220
       Coding: 020200000001F9EF7D328F1E000000031C0001000000000000
       VCID: 323DE430D427BDBB95F-8067
       Subsystem 1 - Part No: 8R0 060 884 EN
       Component: NAR 2017/2018  1602
       Subsystem 2 - Part No SW: 4H0 919 604 F    HW: 4H0 919 604 F
       Component: DU8 D4 SV NB  H47 0021
       Serial number: AUZ8ZDC9300PUA5
       Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
       Component: E380 BDT D4  H09 0065
       Serial number: 00000000088003
       Subsystem 4 - Part No: 8R0 060 961 D
       Component: CD-Database  4353
       Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
       Component: TSG HL        H06 0262
       Revision: --------    Serial number: 0000129122986
       Coding: 010F1F00400062C202003007
       Part No SW: 4H0 907 428 A    HW: 7P6 907 441 D
       Component: TopView       H05 0111
       Revision: 11001001    Serial number: 82330JF0049393
       Coding: 020A000001010000000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 005022
       ROD: EV_CamerSysteTopViewAUDI_005.rod
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 R    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0039
       Revision: 10011001    Serial number: 176200162
       Coding: 0210044100
       ROD: EV_DeckLidContrUnit.rod
       VCID: 3D27C70C1DF972C378D-8069
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Revision: --------    Serial number: 000000080656
       Coding: 200000
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 63935174DBDD64332E9-8037
       Component: TSG HR        H06 0262
       Revision: --------    Serial number: 0000129122948
    Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
       Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
       Component: GSM-LL        H08 0083
       Revision: 0L0D5014    Serial number: SN120529  0295
       ROD: EV_GSM2x3Mono_AU64.rod
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H25 0038
       Coding: E9060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 26150860E86FD11B097-8073
       Serial number: 00006525099902
       Coding: 766FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 2F3BED44C7959053FA1-807B
       Serial number: 00006523254802
       Coding: 366FF2
       Part No SW: 4H0 907 541 B    HW: 4H0 907 541
       Coding: 7E01020101
       ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
       ROD: EV_AdaptCruisContr2AU64X_002.rod
       VCID: 28090658E27BC76B3BB-807D
       Part No SW: 4G0 907 107 D    HW: 4H0 907 107
       Component: BV-SG         H30 0038
       Serial number: 005000051507127
       Coding: 02A19B000111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       VCID: 270B0564EF65C813321-8073
       Coding: 0066F609031F037E070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L_VW51.rod
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R_VW51.rod
       VCID: 323DE430D4A7BDBB95F-8067
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145     HW: 4H0 907 145
       Component: AEM - LEAR    H05 0006
       Revision: 00001001    Serial number: 97804000474204
       ASAM Dataset: EV_AEMLearAU64X 002014
       ROD: EV_AEMLearAU64X.rod
       VCID: 6695486028EF111BC97-8033
    End----(Elapsed Time: 03:06, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
    All prerequisites met?
    Battery voltage looks a bit marginal in your scan. I realize it's a above the documented level, but the first thing I'd try is charging that battery.
    New User
    Sep 2019
    Texas, USA
    Hi Uwe, thanks for your help. And sorry for my late response. I made sure all prerequisites were met and also battery was charged. Still same error.
    I’m thinking if it’s because I didn’t enter security access code. VCDS didn’t generate one for me so I didn’t enter any. Do you think that could the cause of the issue?
    I've never heard of an ECU that required a security access code to do a TBA.
