DSG Oil Temp.- 2015 Audi S3
morris39
Canada
C?ID=395084
I cannot find this value on Block Map. My VCDS version:Release 20.4.0 (x64) Data version: 20200331 DS317.0
On some threads here and Wiki Group 24 is suggested but does appear on my Block Map. Earlier models say Group 19 but on mine that refers to battery volts.
Ideas?
PetrolDave
Westbury, UK
C?ID=1423
Would be helpful to see an Auto-Scan, the software version in the TCU may be important.
morris39
Canada
C?ID=395084
I posted my auto scan May 14, on Reference Scans and ... for non broken cars... titled "Launch Control" There is not much of interest there as there are no DTCs.
BTW you suggested moving that post to general repairs.
Cheers
morris39
Canada
C?ID=395084
HelloDave
TCU scan below. I suspect that the DSG temp. has not been read before as the maintenance milestone hasn't been reached.
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4521
Revision: 05853104 Serial number: TFK01504143668
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1F1BE53447365B034A8-804A
This is not an auto-scan please post one.
You may find it helpful to read through blocks and look for a temp ref or find temp sender in WD and connect a decade box to respective track and look for block changes.
This TCM uses the newer UDS protocol, so there are no traditional Measuring Block Group Numbers.
Instead, use Advanced Measuring Values and look for:
IDE00024-ENG98981 -- Transmission fluid temperature
It should be roughly the fifth thing in the list, but you can narrow the list down by typing "temp" in the search/filter box.
morris39
Canada
C?ID=395084
Thank you. My mistake, I should have remembered that exclusion. I had asked how to see groups while not connected to the car and Block Map was suggested. That map seems to have most of the same group numbers as AM Blocks from a casual scan but obviously not all.
