Results 1 to 10 of 19
Thread: RNS510 bluetooth
    Jan 2020
    RNS510 bluetooth
    Hello everyone can someone please help i have rosstech, my caravelle has rns510 just fitted bluetooth module, bluetooth works and i can stream music but i cant get the phone to work just mutes the music, I've been trying all day, can someone please help me get this sorted..
    james
    Jul 2014
    Tallinn, Estonia
    What specific part number of BT module and what phone?
    Jan 2020
    1K8 035 730 D iphone 5 s even with the module disconnected i still get a mute with the phone button
    James,
    Jan 2020
    Friday,15,May,2020,20:13:33:47653
    VIN: WV2ZZZ7HZGH070781   License Plate: LOU10W
    Mileage: 39080km-24283mi   Repair Order:
    Chassis Type: 7H-VN75 (7E0)
    Scan: 01 03 04 08 09 0D 15 17 18 19 22 25 37 56 5F 61 77 78 0B
    VIN: WV2ZZZ7HZGH070781   Mileage: 39080km-24283miles
    0D-Slide Door, Left -- Status: OK 0000
    37-Navigation -- Status: Not registered 0011
    5F-Information Electr. -- Status: Cannot be reached 1100
    78-Slide Door, Right -- Status: OK 0000
    Address 01: Engine (2D2D2-CXEB)       Labels:. 04L-907-309-V2.clb
       Part No SW: 04L 906 056 KT    HW: 04L 907 445 A
       Component: R4 2.0l BTD   H03 6176
       Revision: 23101001
       Coding: 0019401C432601080000
       Shop #: WSC 02737 790 50316
       ASAM Dataset: EV_ECM20BTD03004L906056KT 004008
       ROD: EV_ECM20BTD03004L906056KT.rod
       VCID: 094E66CC89B2E01F9EB-805C
    15560 - EGR Sensor 1
              P046C 00 [108] - Implausible Signal
                        Mileage: 38603 km
                        Date: 2020.02.22
                        Time: 11:03:24
                        Coolant temperature: 25 °C
                        Intake air temperature: 18 °C
                        Voltage terminal 30: 12.882 V
                        Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                        Exhaust recirc.valve 1 bank 1: posit.feedback - Spec.value: 2.89 %
                        Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 3.02 %
                        Exhaust recirc.valve 1 bank 1: posit.feedback -Offset closed.: 0.00 %
                        Exhaust recirc.valve 1 bank 1: posit.feedback - Uncnd vlt: 2.501 V
                        EGR vacuum regulator solenoid valve 1 bank 1: res. Cooling mode stop: 2.346 V
                        EGR vacuum regulator solenoid valve 1 bank 1: res. Bypass operation stop: 2.560 V
    Readiness: N/A
    Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H05 0132
       Revision: 00000000    Serial number: 43145000001250
       Coding: 307E80986569847E0C7C017EA6832193790000
       Shop #: WSC 02739 790 50316
       ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
       VCID: 3FDAB81487F61EAFF0F-806A
    0397 - TPMS Warning
              C102D F0 [008] - Pressure Loss
                        Reset counter: 179
                        Mileage: 38995 km
                        Date: 2020.04.18
                        Time: 10:31:04
       Component: LENKW.SENSOR  H07 0070
       Serial number: 09111513471326
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EA40510C07CD7A7BB9-802A
    Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
       Part No SW: 7E0 907 040 D    HW: 7E0 907 040 D
       Component: ClimatronicT5 H02 0508
       Revision: 00001K03
       Coding: 0004000103
       ASAM Dataset: EV_ClimatronicT5 A01003
       ROD: EV_ClimaAutoT5Basis.rod
       VCID: 241017780E505D778DD-8070
       Slave 1:
       Subsystem 1 - Part No SW: 7E5 907 049 C    HW: 7E5 907 049 C
       Component: Heckbedienung  H11 0303
       Serial number: BHB-0010611150015133
    Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 090     HW: 7E0 937 090
       Component: BCM PQ25 Max4 H80 0736
       Revision: B9080001    Serial number: 0771 323150967
       Coding: A0F6793A0A61349393288F446CEB8EF48DA4698960CC6960320403BF0840
       Shop #: WSC 01362 002 1048576
       VCID: 68884348B2787917615-803C
       Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
       Component: RLS 231115 03  37  0059
       Coding: 0228EE
       Subsystem 2 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
       Component: J386__TSG_FT  003 8654
       Serial number: KU0KU004111553087846
       Coding: 1400B0
       Subsystem 3 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
       Component: J387__TSG_BT  003 8654
       Serial number: KU0KU005111553090140
       Coding: 0400A0
       Subsystem 4 - Part No: 7E1 951 171
       Subsystem 5 - Part No: 1K0 951 605 C
       Subsystem 6 - Part No: 7E1 951 171
       Subsystem 7 - Part No SW: 7E0 959 442     HW: 7E0 959 442   Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H02 0103
       Serial number: 29150002280080015464
       Coding: B0FFFF
    Address 0D: Slide Door, Left        Labels: Redir Fail!
       Part No: 7E0 959 243 D
       Component: Schiebetuer-SG  407 0328
       Shop #: WSC 02737 790 00000
       VCID: 3038EB284628F1D7795-8064
       Part No SW: 7E0 959 655 E    HW: 7E0 959 655 E
       Component: VW10Airbag00C 008 0016
       Revision: --------    Serial number: 003PJ000UN5J
       Coding: 000000000000000000000000000000003043
       Shop #: WSC 02734 790 50316
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       VCID: 3828D308A2D82997315-806C
       Serial number: 3495ZRB405T3FSTQJ082
       Serial number: 3505ZRB40693FGI6I9FX
       Part No SW: 7E0 920 980 L    HW: 7E0 920 980 L
       Component: KOMBI         H05 1008
       Coding: 170F010300
       VCID: 3430E738BEB0CDF71DD-8060
    13654544 - Databus
              [Steuergerät für Telefon keine Kommunikation]
                        Reset counter: 182
                        Mileage: 39084 km
                        Date: 2020.05.15
                        Time: 16:35:14
    Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
       Part No SW: 7E0 963 273     HW: 7E0 963 273
       Component: STH-T5GP2     002 0007
       Coding: 4101
       ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001010
       ROD: EV_AuxilParkiHeateWOST5G2.rod
       VCID: 6A8C3940ACF44B07771-803E
    Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
       Part No SW: 7E0 909 901     HW: 7E0 937 090
       Component: GW-K-CAN TP20 H80 0736
       Revision: B9080001
       Coding: 042305
                        Mileage: 39084 km
                        Date: 2020.05.15
                        Time: 16:53:00
    03158 - Control Module for Information Electronics 1 (J794)
                        Reset counter: 142
                        Mileage: 39084 km
                        Date: 2020.05.15
                        Time: 16:53:04
       Part No SW: 0AY 907 554 L    HW: 0CQ 525 130 A
       Component: Haldex4Motion H53 7620
       Serial number: HA1-00018.09.15
       Coding: 0501
       VCID: 54F087B81E70EDF73DD-8000
       Component: IMMO          H05 1008
       Part No SW: 1T0 035 680 Q    HW: 1T0 035 680 Q
       Component: RNS-MID       H30 5274
       Revision: AB001001    Serial number: VWZ6ZZK9254026
       Coding: 06010402040000A10000
       VCID: 3C20CF18966005B7D5D-8068
       Subsystem 1 - Part No: 1T0 919 859 B
       Component: EU West V16  8536
    00857 - CD Changer Unit (R41)
                        Reset counter: 142
                        Mileage: 39080 km
    03138 - Input AUX IN
                        Reset counter: 142
                        Mileage: 39084 km
                        Date: 2020.05.15
                        Time: 17:39:31
                        Reset counter: 142
                        Mileage: 39084 km
                        Date: 2020.05.15
                        Time: 17:39:31
                        Reset counter: 142
                        Mileage: 39080 km
    Address 5F: Information Electr. (J0506)       Labels:. 1T0-035-680.clb
                        Reset counter: 142
                        Mileage: 39080 km
                        Reset counter: 142
                        Mileage: 39084 km
                        Date: 2020.05.15
                        Time: 17:39:31
       Part No SW: 7E0 907 534     HW: 7E0 937 090
       Component: Batt.regelung H80 0736
       Coding: 030B1A73
       Shop #: WSC 02739 790 00000
       Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
       Component: J367-BDM  H08 0223
       Serial number: 62301H19431261914344
    Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
       Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
       Component: Telefon       H08 6900
       Revision: 00008000    Serial number: 00000A10636886
       Coding: 312210
       Shop #: WSC 00078 790 00133
       VCID: 2A0CF9406CF48B07B71-807E
    01524 - Antenna for Telephone
                        Reset counter: 142
                        Mileage: 39084 km
                        Date: 2020.05.15
                        Time: 17:47:32
    01526 - Emergency Call Button (E276)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 142
                        Mileage: 39084 km
                        Date: 2020.05.15
                        Time: 17:47:32
    Address 78: Slide Door, Right        Labels: Redir Fail!
    End----------(Elapsed Time: 02:10, VBatt start/end: 12.1V/12.0V)-----------
  6. Likes Uwe liked this post
    Jul 2014
    Tallinn, Estonia
    A 2016 model and still came with a RNS510? Retrofit a unlocked Discover Media PQ and you will be way better off than the ancient RNS510 and this old BT module.
    Since there's address 5F in the installation list, the vehicle came with a proper newer radio but this was replaced with old tech for some reason?
  8. Likes Uwe, Mari liked this post
    Jan 2020
    can i get this to work?
  10. #8
    Quote Originally Posted by goldenbrown View Post
    Unclear.
    I would start by fixing the Gateway Installation List:
    [Select]
    [19-CAN Gateway]
    [Installation List]
    - Scroll down to 37-Navigation and put a tick-mark next to it.
    - Scroll down to 5F-Information Electr. and remove the tick-mark next to it.
    [Save Coding]
  11. #9
    Jan 2020
    thanks for your help I've done what you suggested
  12. #10
    Then please try to clear any residual fault codes and post a fresh scan afterward.
