Results 1 to 2 of 2
Thread: 2013 Passat Trendline TDI ABS Coding (MK60EC1)
    May 2020
    CANADA
    Swapped ABS module because of no communication, could someone please help with the procedure for coding in the new one?
    Monday,11,May,2020,16:02:18:57402
    VCDS Version: 20.4.0.1 (x64)
    VIN: 1VWAN7A36DC063189   License Plate:
    Mileage: 113690km-70643mi   Repair Order:
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
    VIN: 1VWAN7A36DC063189   Mileage: 113690km-70643miles
    Address 01: Engine (J623-CKRA)       Labels:. 03L-906-022-CFC.clb
       Part No SW: 03L 997 009 J    HW: 03L 907 309 S
       Component: R4 2.0l TDI   H21 9982
       Revision: 71H21---    Serial number:
       Coding: 001D0012842400000000
       Shop #: WSC 99909 999 00000
       ASAM Dataset: EV_ECM20TDI01103L997009J 004005
       ROD: EV_ECM20TDI01103L997009H.rod
       VCID: 3B7EC825B2859A5E17-806E
       Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 9436
       Revision: 05551213    Serial number: 00001207070035
       Shop #: WSC 09003 957 00200
       VCID: 244C1359E73BC5A646-8070
       Revision: 00H31001
       VCID: 7DFA063DE411546E69-8028
                        Reset counter: 88
                        Date: 2020.05.11
                        Time: 11:22:11
                        Count: 3
                        Count: 12
                        Count: 20992
                        Count: 195
                        Count: 49664
                        Count: 7936
                        Fault Status: 01100101
                        Reset counter: 88
                        Mileage: 113697 km
                        Date: 2020.05.11
                        Time: 11:22:03
                        Count: 3
                        Count: 14
                        Count: 29184
                        Count: 279
                        Count: 49408
                        Count: 7936
                        Reset counter: 88
                        Mileage: 113697 km
                        Date: 2020.05.11
                        Time: 11:22:03
                        Count: 3
                        Count: 14
                        Count: 29184
                        Count: 295
                        Count: 49408
                        Count: 7936
       Part No SW: 561 907 044 M    HW: 561 907 044 M
       Component: Climatronic   H03 0404
       Revision: 00001K01
       Coding: 0030001002
       ROD: EV_ACClimaBHBVW411_VW41.rod
       VCID: 21421A4D3029D08E2D-8074
       Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
       Component: BCM PQ35 H+   121 0168
       Revision: BL121001
       Coding: 6F200E18902B08D408880001160085480071008640801560648060000C70
       VCID: 74EC2319D75B152616-8020
                        Reset counter: 126
                            Term 15 Off
                        Voltage: 8.60 V
    00956 - Key 2
                        Reset counter: 86
                        Mileage: 113697 km
                        Date: 2020.05.07
                        Time: 16:23:06
                        Voltage: 11.75 V
                        Reset counter: 127
                        Mileage: 113697 km
                        Date: 2020.05.07
                        Time: 16:23:06
                        Voltage: 11.70 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 86
                        Mileage: 113697 km
                        Date: 2020.05.07
                        Time: 16:27:24
                        Voltage: 13.65 V
       Part No SW: 5C0 959 655     HW: 5C0 959 655
       Component: AirbagVW10G   013 0809
       Serial number: 003ENM04PS8+
       Coding: 00003548
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 6FE62C75B67D36FEEB-803A
       Serial number: 6940000Y120000KY3K04
       Coding: 303045
       Serial number: 3572MSME716D0275ZZZY
       Serial number: 3582MSME2F645074ZZZ.
       Serial number: 3516KSME0323641FZZZN
       Serial number: 3526KSME6310721FZZZP
       Serial number: 3556LSME6E026E1EZZZ8
       Serial number: 3566LSME44566A1EZZZ2
       Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
       Revision: FF010041    Serial number: 20120912100218
       Coding: 088A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 76E81911C927073628-8022
       Component: E221__MFL-YVJ  H07 0022
       Coding: E20000
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 870 C    HW: 561 920 870 C
       Component: KOMBI         H07 0705
       Coding: 331E01
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
       VCID: 193232AD1879884EE5-804C
       Part No SW: 7N0 907 530 T    HW: 7N0 907 530 K
       Component: J533  Gateway H40 1632
       Revision:   H40       Serial number: 05111101290746
       Coding: 461000
       VCID: 4182BACDD869F08E4D-8014
       Part No SW: 561 919 965     HW: 561 919 965
       Component: Kompass         002 0001
       Revision: 00002000    Serial number: 1829227R2YXB06
       VCID: 63CE5045A2B5829E7F-8036
       Component: IMMO          H07 0705
       VCID: 6AD03D618D9FD3D6BC-803E
       Component: TUER-SG FT    002 0525
       Revision: 13110009    Serial number: 0005649573
       Coding: 0404F5
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 5BBE68A552C5BA5E37-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  004 4472
       Coding: 800000
              B11EC 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 128
                        Mileage: 113697 km
                        Date: 2020.05.11
                        Time: 10:37:25
    67330 - Switch for Central Locking
              B122D 29 [008] - Signal Implausible
                        Reset counter: 127
                        Mileage: 113697 km
                        Date: 2020.05.11
                        Time: 10:54:01
    131584 - Motor for Rear Window Regulator
              B11EE 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 87
                        Mileage: 113697 km
                        Date: 2020.05.11
                        Time: 10:37:25
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 290    3305
       Revision: 00H22000
       VCID: 3776D41546ADBE3EF3-8062
       Part No SW: 7N0 907 532     HW: 7N0 907 530 K
       Component: EZE_2         H40 1632
       Coding: 00000008
       VCID: 6FE62C75BE7D36FEEB-803A
       Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0005
       Component: TUER-SG BT    002 0525
       Revision: 15110009    Serial number: 0005558305
       Coding: 0404F4
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 5CBC6BB957CBBD663E-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  004 4472
       Coding: 800000
                        Reset counter: 87
                        Mileage: 113697 km
                        Date: 2020.05.11
                        Time: 10:37:30
       Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
       Component: LOW NAR       H02 0006
       Revision: -----06S    Serial number: VWZ4Z6M3451118
       Coding: 0500040002000B
       VCID: 234E10452235C29E3F-8076
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Revision: 1B001001    Serial number: 00007663390184
       Coding: 0A10040000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3A70CD21BDBFA3560C-806E
    End-------------------------(Elapsed Time: 02:41)--------------------------
  2. Likes Boki Ar liked this post
  3. #2
    16.4905 S, 151.7375 W
    Just in case you do not have the ABS coding, based on the VIN should it should be as follows:
    C54BC0F5492800FDA30C03EC92220042271000
    We have a Ross-Tech forum post that explains the ABS Coding and the Basic Settings:
    MK60EC1 ABS FAQ - In the "How-To's and Tips".
    Hope this helps,
    drpeter
