- Joined
- Apr 17, 2015
- Messages
- 275
- Reaction score
- 86
- Location
- South Africa
- VCDS Serial number
- C?ID=133909
Vehicle towed to our w/shop, for suspension not working. Found 2 front wheel air pipes disconnected. Refitted the pipes and started the vehicle for the air to build up, only rear lifted. Ran full scan and found no air press related fault codes. 1 Fault code: Control module not coded? Could this be the reason? When running compressor the press will build up to 4.2 bar without the front end lifting up.
Friday,15,May,2020,14:43:15:48706
VCDS Version: 20.4.0.1 (x64) HEX-NET CB: 0.4508.4
Dealer/Shop Name: WMRAUTO
VIN: WAUZZZ4H5AN003513 License Plate: ML19PZGP
Mileage: 96252km Repair Order:
Address 34: Level Control Labels: 4G0-907-553.clb
Control Module Part Number: 4H0 907 553 B HW: 4H0 907 553
Component and/or Version: LUFE-DAEMPFER H16 0095
Software Coding: 008007
Work Shop Code: WSC 12345 123 12345
ASAM Dataset: EV_AirSuspe 003017 (AU64)
ROD: EV_AirSuspe_VW51.rod
VCID: 2B16E24142BB72DE87-807E
0001 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 113
Mileage: 96252 km
Date: 2020.05.02
Time: 18:30:39
C10C8 00 [009] - -
Reset counter: 113
Mileage: 96252 km
Date: 2020.05.02
Time: 18:32:01
367877 - Ride Height Not Learned
C1044 00 [009] - -
Reset counter: 113
Mileage: 96252 km
Date: 2020.05.02
Time: 18:30:39
266752 - Control module not coded
U1013 00 [009] - -
Reset counter: 113
Mileage: 96252 km
Date: 2020.05.02
Time: 18:30:39
38144 - No End-of-Line Programming
B2013 00 [009] - -
[keine Bandendeprogrammierung erfolgt (Auslieferungszustand)]
Reset counter: 113
Mileage: 96252 km
Date: 2020.05.02
Time: 18:30:39
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 1B 28 34 36 3B 42
46 47 48 52 53 55 56 5B 5F 62 6C 6D 6F 72 81 84 85 88 89 8A
8B 8D 8E 8F 90
VIN: WAUZZZ4H5AN003513 Mileage: 96252km-59808miles
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
84-Night Vision -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Address 01: Engine (------CDRA) Labels:* None
Part No SW: 4H0 907 560 HW: 4H0 907 560
Component: 4.2l V8/4V H06 0004
Revision: N5H06---
Coding: 0106000C290F0268
Shop #: WSC 02313 785 00200
ASAM Dataset: EV_ECM42FSI0114H0907560 001006
ROD: EV_ECM42FSI0114H0907560.rod
VCID: 679E5E719ED396BEA3-8032
Readiness: 1010 0001
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4H1 927 158 E HW: 0BK 927 156 K
Component: 0BK 42 FSIRdW H07 0006
Revision: --H07---
Coding: 001111
ASAM Dataset: EV_TCMALX51011 001011
ROD: EV_TCMALX51011_001.rod
VCID: 3228FF2565912316C4-8066
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 A HW: 4H0 907 379 A
Component: ESP PREMIUM H08 0151
Coding: 44F6A200226F4500E300
ASAM Dataset: EV_ESPPremi 004012
ROD: EV_ESPPremi_004_AU64.rod
VCID: 302CF52D6B9D1106B2-8064
0677 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Net_Fahrwerk_03_FA_Niveau_Druck_VL_Error]
Reset counter: 153
Mileage: 96252 km
Date: 2020.05.02
Time: 18:06:58
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: A2
Bit Info 4: 00
F-Path: 39
F-Type: 22
Uz: B1
Part No SW: 4H0 907 064 DB HW: 4H0 907 064 L
Component: BCM2 2.0 H13 0510
Coding: 05170001000000000000
Shop #: WSC 55958 000 1048576
VCID: 6C94215D8F35B5E6CE-8038
Subsystem 1 - Part No SW: 4H0 905 852 A HW: 4H0 905 852 A
Component: J764 ELV MLB H37 0042
Serial number: 0210000032117006
03285 - Sensor for Contact with Door Handle; Front Left
Reset counter: 112
Mileage: 96252 km
Date: 2020.03.20
Time: 10:46:20
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H07 0115
Revision: AA000000 Serial number: 00001010122745
Coding: C038B60085043201000001010101112131313333283333
VCID: 3522C4399CFF342EE1-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 E HW: 4H0 820 043 E
Component: Klima 4 Zonen H12 0040
Coding: 48A100BE8C
ASAM Dataset: EV_AirCondiFront 001048
VCID: 22080F653571B39634-8076
0129 - Motor for Left Side Window Defrost Flap
B10D7 22 [009] - Signal Amplitude Too High
Reset counter: 113
Mileage: 96252 km
Date: 2020.03.17
Time: 18:06:25
0133 - Motor for Left Side Window Defrost Flap
B10D7 29 [008] - Signal Implausible
Reset counter: 153
Mileage: 96252 km
Date: 2020.05.02
Time: 18:06:35
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 D HW: 4H0 907 063 D
Component: BCM1 2.0 H09 0083
Revision: 15009001 Serial number: 00000000621614
Coding: 2600E010C034AFF19B810004A0001D0C009DC30803010101800008402000
VCID: 291A1849404760CE75-807C
Subsystem 1 - Part No SW: 4H2 955 119 C HW: 4H2 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 100218 H32 0040
Serial number: 100223002039
Coding: 0045F7
Component: RLS H04 0003
Serial number: 10864601
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 A HW: 4H0 941 531 A
Component: E1 - LDS H07 0044
Serial number: 01 04 2010 00000028
Subsystem 4 - Part No SW: 4H0 907 705 H HW: 4H0 907 705 C
Component: EVLS-SG H08 0275
Serial number: WA091313000000025077
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 5808C815000000000001
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 A HW: 4H0 035 108
Component: DVDCAlpine H42 0120
Revision: AA001001
VCID: 1E703B950909977610-804A
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 C HW: 4H0 919 475 C
Component: PARKHILFE ACC H05 0011
Revision: 11001001 Serial number: 44831003304954
Coding: 300902
ASAM Dataset: EV_AU64XParkiAssis2 005003
ROD: EV_AU64XParkiAssis2.rod
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4H0 907 561 A HW: 4H0 907 561
Component: ACC3 H15 0160
Coding: 3404010201
ASAM Dataset: EV_AdaptCruisContrAU64X 001012
ROD: EV_AdaptCruisContrAU64X_001.rod
VCID: 291A1849484760CE75-807C
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_VIDEO_FAIL]
Reset counter: 153
Mileage: 96252 km
Date: 2020.05.02
Time: 18:06:57
Control Module temperature: 25 °C
Voltage terminal 15: 14.041 V
Velocity_vehicle_reference: -0.01 m/s
Part No SW: 4H0 959 655 B HW: 4H0 959 655 B
Component: Airbag10.43 H22 0026
Revision: -------- Serial number: 003G1001132R
Coding: 30314246304230303037554A305234483053
Shop #: WSC 02311 785 00200
VCID: 3522C43994FF342EE1-8060
Serial number: 3575HRB40616O2OU3GDW
Serial number: 3585HRB40636O2OU88R3
Serial number: 3515JRB40576094IC90G
Serial number: 3525JRB405R6CSQ8A06W
Serial number: 3554VRB405H6NG4E48P/
Serial number: 3564VRB405H6NG4EI1M2
Part No SW: 4H0 953 568 B HW: 4H0 953 568 B
Component: Lenks.Modul H07 0007
Revision: -------- Serial number: 90815JCA00006
Coding: 00043C
VCID: 3228FF256D912316C4-8066
Subsystem 1 - Part No SW: 4H0 951 528 H HW: 4H0 951 528 H
Component: E221 - MFL H04 0009
Serial number: 15 03 2010 33006448
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4H0 920 830 E HW: 4H0 920 830 E
Component: TBenRDWACCNV- H29 0185
Revision: 19409111 Serial number: 658090410593241
Coding: 330608003F000008010000
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K_AU64.rod
VCID: 271E1E715E5356BE63-8072
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 F HW: 4H0 919 204 F
Component: Analoguhr D4 H04 0210
Serial number: 1100312022328
Part No SW: 4H0 907 468 C HW: 4H0 907 468 C
Component: J533--Gateway H07 0175
Revision: -------- Serial number: 00000000012348
Coding: 00C1034A00
ASAM Dataset: EV_GatewUDS 001021
ROD: EV_GatewUDS_AU57.rod
VCID: 312AF0296097180EBD-8064
Subsystem 1 - Part No SW: 4H0 915 181 HW: 4H0 915 181
Component: J367-BDM H07 0130
Serial number: 00000000005640101612
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4H0 907 144 C HW: 4H0 907 144 C
Component: DYNAMIKLENK. H06 0100
Revision: 51001005 Serial number: --------------
Coding: 8B0000
Shop #: WSC 28290 001 1048576
VCID: 281C1D4D5B4D59C66A-807C
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 D HW: 4H0 919 158 D
Component: Klima Fond H11 0040
Coding: 0800000000
ASAM Dataset: EV_AirCondiHeck 001038
ROD: EV_AirCondiHeck.rod
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4H0 907 553 B HW: 4H0 907 553
Component: LUFE-DAEMPFER H16 0095
Coding: 008007
U1111 00 [009] - -
Reset counter: 113
Mileage: 96252 km
Date: 2020.05.02
Time: 18:30:39
C10C8 00 [009] - -
Reset counter: 113
Mileage: 96252 km
Date: 2020.05.02
Time: 18:32:01
C1044 00 [009] - -
Reset counter: 113
Mileage: 96252 km
Date: 2020.05.02
Time: 18:30:39
U1013 00 [009] - -
Reset counter: 113
Mileage: 96252 km
Date: 2020.05.02
Time: 18:30:39
B2013 00 [009] - -
Reset counter: 113
Mileage: 96252 km
Date: 2020.05.02
Time: 18:30:39
Component: MEM-FS H07 0115
Revision: AA000000 Serial number: 00001010122731
Coding: C038BF8085853201020001010101112131313333203333
Shop #: WSC 01661 996 98713
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 A HW: 4H0 907 637 A
Component: SARA 6D red H02 0011
Revision: -------- Serial number: EJ13700036AK000
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D12EC597CAF7CEE99-8078
Part No SW: 4H0 959 793 E HW: 4H0 959 793 E
Component: TSG FA H02 0158
Revision: -------- Serial number: 0000103409619
Coding: 011F1E205E0162C202000007
VCID: 3B36D201BADBE25E17-806E
Revision: 00002001 Serial number: 0128479438
Coding: 011A0E2200393585B03007F2820000000000000000000000000000000000
Subsystem 1 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4H0 959 591 HW: 4H0 959 591
Component: J245 PS50.028 H06 0006
Serial number: WOO1002775$
Coding: 001F00
Subsystem 4 - Part No SW: 4H0 947 135 G HW: 4H0 947 135 G
Component: Dachelektroni H11 0070
Serial number: A2010000000000070437
Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS009 H05 0004
Serial number: WOO10002ARE
Part No SW: 4H0 035 223 HW: 4H0 035 223
Component: BOSE G3 D4 H07 0050
Revision: CI007500 Serial number: 00000000000867
VCID: 5BF672815A9BC25E37-800E
Address 48: Seat, Rear, DS (J876) Labels: None
Part No SW: 4H0 959 860 HW: 4H0 959 860
Component: MEM-FS-Fond H05 0114
Revision: AA000000 Serial number: 00001001326487
Coding: 003892800000300D0A00392038193A2039203B3B202020
VCID: 71AA3029A817580EFD-8024
Part No SW: 4H0 959 792 E HW: 4H0 959 792 E
Component: TSG BF H02 0158
Revision: -------- Serial number: 0000103406234
VCID: 3A38D705B5E1DB560C-806E
Part No SW: 4H0 907 801 C HW: 4H0 907 801 A
Component: EPB-4 H03 0009
Revision: -------- Serial number: 00000000001022
ASAM Dataset: EV_ParkiBrake 001015
ROD: EV_ParkiBrake_VW51.rod
VCID: 281C1D4D534D59C66A-807C
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 HW: 4H0 907 357
Component: ....LWR12.... H02 0070
Serial number: 100311-0004-040
Coding: 11116F101000B200
ROD: EV_HeadlRegulBasic.rod
VCID: 6B962241823BB2DEC7-803E
120589 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[Fehlerhaftes Signal in CAN-Message Fahrwerk_01_FR (0x108)]
Reset counter: 113
Mileage: 96252 km
Date: 2020.03.17
Time: 18:06:27
764928 - Left/Right Driving Switch-Over Active
C1080 00 [009] - -
Reset counter: 113
Mileage: 96252 km
Date: 2020.05.02
Time: 18:22:12
Part No SW: 4E0 035 053 H HW: 4E0 035 053
Component: Radio U Basic H45 0048
Revision: AB001007 Serial number: 010DE0A7505033
Coding: 060003010000000001
VCID: 210A00693877A88E2D-8074
Address 5B: Seat,Rear,PS (J877) Labels: None
Component: MEM-BFS-Fond H05 0114
Revision: AA000000 Serial number: 00001001338926
Coding: 003896800000300D0A00392038193A2039203B3B382020
Part No SW: 4H0 035 754 D HW: 4H0 035 754
Component: H-BN-RW H48 0078
Revision: -------- Serial number: 412DF0A7505011
Coding: 010901000001F9EF65140B0E00000003FC000100
Subsystem 1 - Part No: 8R0 919 884 Q
Component: ROW 2010 0205
Subsystem 2 - Part No SW: 4H0 919 604 B HW: 4H0 919 604 B
Component: DU8 D4 SV NB H44 0021
Serial number: AUZ8ZDA11004CL8
Subsystem 3 - Part No SW: 4H2 919 600 C HW: 4H2 919 600
Component: E380 BDT D4 H09 0062
Serial number: 00000000007033
Component: CD-Database 1886
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 A HW: 4H0 959 795 A
Component: TSG HL H04 0158
Revision: -------- Serial number: 0000103314562
Coding: 010F1E20420162C202000007
VCID: 393AC809B0E7D04E05-806C
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4H0 907 441 HW: 4H0 907 441
Component: SG Rueckfahrkamera 0030
Revision: --H03--- Serial number: 525PA8-J03D01W
Coding: 1023002
VCID: 65825479ACDF84AE91-8030
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 F HW: 4H0 959 107 F
Component: HDSG-Modul H11 0632
Revision: 09145325 Serial number: 067000152
Coding: 0200044000
ASAM Dataset: EV_DeckLidContrUnit 001023
ROD: EV_DeckLidContrUnit.rod
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000004663
Coding: 020000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 63864A616AEBFA9E7F-8036
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H04 0158
Revision: -------- Serial number: 0000103314592
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H2 927 731 HW: 4H2 927 731
Component: GSM-RL H04 0081
Revision: 0R0D4011 Serial number: SN100317 0120
ASAM Dataset: EV_GSM2x3Mono 001014
ROD: EV_GSM2x3Mono_AU64.rod
Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
Part No SW: 4H0 907 547 D HW: 4H0 907 547
Component: NV-ECU-Gen1 H08 0022
Serial number: 0K84AE40003418
Coding: 1101
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H07 0006
Serial number: 00000000001005619775
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4H0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H20 0014
Revision: -------- Serial number: 262130025421000
Coding: E8040000
ROD: EV_OnBoardCamerDPC.rod
0001 - Front Heater for Lane-Holding Assist
C1101 15 [008] - Open or Short to Plus
Fault Frequency: 7
Reset counter: 153
Mileage: 96252 km
Date: 2020.03.20
Time: 10:45:06
Outside air temperature: -39.5 °C
Voltage terminal 15: 12.3 V
Control Module temperature: 24.0 °C
0708 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[EGD_Fahrwerk_01_Signal_Error]
Reset counter: 153
Mileage: 96252 km
Date: 2020.05.02
Time: 18:06:55
Outside air temperature: -38.5 °C
Voltage terminal 15: 13.7 V
Control Module temperature: 27.0 °C
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 A HW: 4H0 907 182 A
Component: IVB H03 0027
Serial number: 00448453074501
Coding: 670FF2
ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00448453074301
Coding: 270FF2
Address 8A: Multicont. Seat Rear,DS (J875) Labels:* None
Part No SW: 4H0 907 182 HW: 4H0 907 182
Serial number: 00448453031601
Coding: 210F00
ASAM Dataset: EV_IVBDriveSideRear 001003
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4H0 907 541 A HW: 4H0 907 541
Coding: 3404010201
ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
ROD: EV_AdaptCruisContr2AU64X_001.rod
Address 8D: Multicont. Seat Rear,PS (J874) Labels:* None
Serial number: 00448453040001
Coding: 210F00
ASAM Dataset: EV_IVBPasseSideRear 001003
Address 8E: Image Processing (J851) Labels:* Redir Fail!
Part No SW: 4H0 907 107 HW: 4H0 907 107
Component: BV-SG H25 0008
Serial number: 000040050503107
Coding: 01A08201
ASAM Dataset: EV_BVS 001007
ROD: EV_BVS.rod
VCID: 6484497D6FE5FDA686-8030
0091 - Function Limitation due to Missing Video Data
C1108 00 [008] - -
[DPC_SystemError]
Reset counter: 153
Mileage: 96252 km
Date: 2020.05.02
Time: 18:24:01
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H04 0060
Coding: 00660600031F037E000308004248D0000000
ASAM Dataset: EV_RGS_L 002006
ROD: EV_RGS_L_VW51.rod
VCID: 6FAE3651B6234EFEEB-803A
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H04 0060
ASAM Dataset: EV_RGS_R 002006
ROD: EV_RGS_R_VW51.rod
VCID: 70AC352DAB1D5106F2-8024
End----(Elapsed Time: 02:59, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
