Issue with the Suspension Level Control Calibration - Stored Value = 0 (Audi A6 4F)
RobertJB
New Zealand
C?ID=199529
The front air struts in my Audi A6 (4F) Allroad were recently replaced. Once the repair was done I tried to follow the calibration instruction on: https://www.ross-tech.com/vag-com/cars/levelcontrol.html, however it seems like this doesn't nothing, the car is still not levelled. The system works correctly, I can lower or lift the car via MMI. Each corner goes up or down as it should, however each is on different height.
The adaptation process doesn't give me any errors, everything is as per the instructions with the exception that in my case in all channels 01-04, the Stored Value is 0. Should I see a value there, perhaps the factory default or previously stored? This perhaps means that the reference value (or default) which is used to be compared with the new values once measured and entered is somehow lost, how can I reenter/recode it? Am I on the right track here?
Really would appreciate some help here, thank you.
Here are the values from Measuring Blocks channels 004, 005.
Full scan as follows (there was another code before the repair as follows, it is not showing up now)
01437 - Control Position not Learned
Fault Status: 11100101
Reset counter: 105
Mileage: 206050 km
Date: 2020.02.27
Time: 09:04:16
Friday,13,December,2019,14:44:39:28799
VCDS Version: 19.6.2.0 (x64)
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 4F9 910 401 J    HW: 4F0 907 401 C
   Component: 3.0L V6TDI  G000AG  0020
   Revision: --H05---    Serial number:
   Coding: 0011372
   Shop #: WSC 02145 785 00200
   VCID: 2C57FE4B8F7B482F2B-8078
005715 - Please check DTC Memory of ABS Controller
               P1653 - 002 -  - Intermittent
                    Fault Frequency: 26
                    Mileage: 201787 km
                    Date: 2019.11.05
                    Time: 08:27:36
                    RPM: 1533 /min
                    Speed: 17.9 km/h
                    Duty Cycle: 24.9 %
                    Voltage: 13.76 V
                    Bin. Bits: 00101000
                    Torque: 284.7 Nm
                    Bin. Bits: 00000100
   Part No SW: 4F5 910 156 C    HW: 09L 927 156 C
   Component: AG6 09L 3,0 TDI RdW 0020
   Revision: --H04---    Serial number:        4425735
   Shop #: WSC 02325 785 00200
   VCID: 285F025B9B83640FCF-807C
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 AB    HW: 4F0 614 517 R
   Component: ESP 8.0 quattro H05 0040
   Coding: 0016776
   VCID: 64C7566BA72BC06F23-8030
                    Fault Frequency: 22
                    Reset counter: 7
                    Mileage: 202260 km
                    Date: 2019.11.22
                    Time: 12:12:52
                    Hex Value: 0x0000
                    Hex Value: 0x43A2
                    Hex Value: 0x001C
                    Hex Value: 0xB1A9
                    Hex Value: 0x00FF
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601501015927
   Coding: 0000147
   Shop #: WSC 05050 824 59716
   VCID: 63C55577A225C757DA-8036
   Subsystem 1 - Part No: 4F0 910 131 A
   Component: FBSAUDIC6 EZS   H46 0080
   Subsystem 2 - Part No: 4F0 910 220 F
   Component: FBSAUDIC6 IDG   H01 0053
00956 - Key 2
                    Fault Frequency: 27
                    Reset counter: 8
   Part No SW: 4F0 910 732 K    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5140
   Revision: 00000000    Serial number: 351BS087558534
   Coding: 0003002
   Shop #: WSC 02335 785 00200
   VCID: 2B55FD578A754F1722-807E
   Subsystem 2 - Serial number: 00000000987804
   Subsystem 3 - Serial number: 0104.02.080000000100010907ˇ
   Subsystem 4 - Serial number: 010907ˇ
   Part No SW: 4F0 910 043 A    HW: 4F2 820 043 Q
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000052    Serial number: 00000030327912
   Coding: 0001366
   VCID: 1C372E8BDFDBB8AF5B-8048
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H18 0250
   Coding: 0001101
   VCID: 3169EF3FA85925C718-8064
   Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H04 0190
   Coding: 00064784
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0100
   Coding: 00146221
   Shop #: WSC 02335
                    Fault Status: 00101011
                    Reset counter: 9
                    Mileage: 202392 km
                    Date: 2019.11.28
                    Time: 07:47:00
Address 0E: Media Player 1 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 D    HW: 4E0 035 785
   Component: SG ext.Player H15 0830
   Revision: 00000000
   Shop #: WSC 02399 823 56573
   VCID: 2959075F40895D07D0-807C
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 4F AIRBAG AUDI8RH30 0280
   Revision: 09H30000    Serial number: 0037LD0WMZY
   Coding: 0013382
   VCID: 2959075F80895D07D0-807C
   Subsystem 1 - Serial number: 6332CSME3C7315541
   Subsystem 2 - Serial number: 6342CSME3A00407C+
   Subsystem 3 - Serial number: 6352QSME532D3D77U
   Subsystem 4 - Serial number: 6362QSME57591457L
   Subsystem 5 - Serial number: 63734SME533B467FC
   Subsystem 6 - Serial number: 63834SME54563E79C
   Revision: 00H03000    Serial number: 90055080320055
   Coding: 0102142
   Shop #: WSC 02323 785 00200
   VCID: 275D0167969D6B77C6-8072
   Part No SW: 4F0 910 900 C    HW: 4F0 920 901 G
   Component: KOMBIINSTR. M73 H16 0240
   Revision: 00200000    Serial number: 64577TA28
   Coding: 7209858
   Shop #: WSC 05050 824 86492
   VCID: 204F1A7BF3B39C4F87-8074
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B082088046
   Coding: F5D1DE5F70160600
   VCID: 2D51F34FB46141273C-8078
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 E    HW: 4E0 035 110 A
   Component: MP3-Changer     H46 0390
   Revision: 00046002    Serial number: AUZ5ZBH4082725
   VCID: 1A3B2893D5EFC69F49-804E
Address 34: Level Control        Labels: 4F0-910-553.clb
   Part No SW: 4F0 910 553 A    HW: 4F0 907 553 A
   Component: J197 LUFTFEDER  H17 0060
   Serial number: 00619004434100
   Coding: 0000210
   VCID: 224B1073FDBF8E5F91-8076
                    Fault Status: 00101101
                    Fault Frequency: 31
                    Reset counter: 8
                    Mileage: 201787 km
                    Date: 2019.11.05
                    Time: 08:27:37
   Coding: 0091138
   VCID: 61C95F7FB839D547C8-8034
   Part No SW: 4F0 910 793 P    HW: 4F0 959 793 P
   Component: TSG FA          H12 0230
   Revision: 00-00000
   Coding: 0003738
   Shop #: WSC 02327 785 00200
   VCID: 377DD127463DFBF756-8062
   Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
   Component: Komfortgeraet   H27 0220
   Revision: 02200027    Serial number: 01096978920000
   Coding: 0000753
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 910 223 M    HW: 4F0 035 223 N
   Component: Amp.-ASK-RD   H07 0270
   Revision: S1400000
   Coding: 030001
   VCID: 285F025B5B83640FCF-807C
                    Fault Frequency: 26
                    Reset counter: 149
                    Mileage: 191261 km
                    Date: 2018.12.23
                    Time: 10:06:00
                    Voltage: 12.10 V
                    Temperature: 16.0∞C
                    Bin. Bits: 00000011
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Reset counter: 10
                    Mileage: 194050 km
                    Date: 2019.02.27
                    Time: 12:05:34
                    Voltage: 12.20 V
                    Temperature: 20.0∞C
                    Bin. Bits: 00000011
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000520297
   Coding: 0001103
   VCID: 5EB364838947EABFF5-800A
   Part No SW: 4F0 910 793 P    HW: 4F0 959 792 P
   Component: TSG BF          H12 0230
   Revision: 00-00000
   Coding: 0003738
   Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
   Component: EPB  CDEC0080   H04 0080
   Revision: --H04---
   Coding: 0000321
                    Fault Frequency: 70
                    Reset counter: 7
                    Mileage: 202256 km
                    Date: 2019.11.22
                    Time: 12:13:10
                    Voltage: 12.84 V
                    Count: 236
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Revision: 00000000    Serial number: 394B3087866849
   VCID: 2E53F443B9673A3F05-807A
                    Reset counter: 9
                    Mileage: 178920 km
                    Date: 2018.04.13
                    Time: 09:45:51
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 D    HW: 4E0 919 148
   Component: R78 TVHybridDVB     0440
   Revision: R0H06000    Serial number: 76300801232002
   Coding: 0000310
   VCID: 2447166BE7AB806FE3-8070
   Part No SW: 4F0 910 181 F    HW: 4F0 915 181 B
   Component: J0644 BEM       H12 0760
   Revision: 00000000    Serial number: 00000000026804
   Shop #: WSC 00420 824 89071
   Component: von VA0  2802141350
   Coding: 344630393135313035442056413032383032313431333530
   Shop #: WSC 00000 384 00290
02272 - Quiescent Current Stage 1
                    Fault Frequency: 39
                    Mileage: 183988 km
                    Date: 2018.08.14
                    Time: 10:35:23
                    Fault Frequency: 25
                    Date: 2018.08.14
                    Time: 10:39:46
02276 - Quiescent Current Stage 5
                    Mileage: 183988 km
                    Date: 2007.05.16
                    Time: 12:00:07
02274 - Quiescent Current Stage 3
                    Mileage: 183988 km
                    Date: 2007.05.16
                    Time: 12:00:17
                    Mileage: 183988 km
                    Date: 2007.05.16
                    Time: 12:00:27
   Component: TSG HL          H21 0210
   Coding: 0003074
   Part No SW: 4F0 910 441 A    HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J823076
   Coding: 1020505
   VCID: 1E332483C9C7AABFB5-804A
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0210
   Coding: 0003074
   Part No SW: 4F0 910 283 H    HW: 4F0 919 283 H
   Component: Parkhilfe 8-Kan H12 0080
   Revision: 00H12000    Serial number: 06340804908807
   Coding: 0221416
   Part No SW: 4E0 910 336 K    HW: 4E0 862 335
   Component: Handyvorb2      H18 0950
   Revision: 00000000    Serial number: 00000005096863
   Coding: 0010990
   VCID: 2A5BF853858F561FD9-807E
End-------------------------(Elapsed Time: 02:56)--------------------------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Hi RobertJB,
Welcome aboard!
On older cars such as the 7L Touareg that the screen shots are from, yes, there was a Stored Value there, and I believe it was the default height that the respective corner should have. However, I am not sure on the 4F module; I've never done one of those. Hopefully someone else has and can answer this question.
RobertJB
New Zealand
C?ID=199529
Thank you, I will keep looking. In the meantime I have tried to redo the process a few times, however the result is still the same, the car is not levelled. I started to think the maybe I should bleed the system first and then try it again - however I am totally guessing here, so perhaps that is not a good idea.
