B5.5 Passat GLS 4Motion Transmission Coding Question
spaztikgoat
C?ID=389469
**first post, be gentle*
Recently bought a 2004 Passat GLS 4Motion with the 1.8T and I'm running into an issue when I try to re-code the transmission I get an "Error 31: request out of range error message. Currently my code is 0001104 which is tiptronic buttons/paddles installed, new strategy shifting, DSP program active, and front wheel drive (North America). I would like to change to 0001032 which would give me old strategy shifting, "sport" mode", and AWD (North America). What am I doing wrong? Do I need a security access code? If so I cannot find one.
Adding to the confusion my transmission is a 5HP-19 FAL which according to the ZF website is a version of the 5HP19FLA that was used in the 2000 and 2001 Audi A4's with the 1.8T so I'm guessing that the transmission in my car was swapped from an older A4. Could this be why my coding won't work?
Below is my autoscan.
Thursday,14,May,2020,13:05:32:13231
VCDS Version: 20.4.0.1  HEX-V2 CB: 0.4508.4
VIN: WVWPD63B94P252166   License Plate:
Mileage: 124920km-77621mi   Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWPD63B94P252166   Mileage: 124920km-77621miles
Address 01: Engine        Labels: 06B-906-018-AWM.clb
   Part No SW: 4B0 906 018 DQ    HW: 8E0 909 018 A
   Component: 1.8L R4/5VT     G   0060
   Revision: 00000000    Serial number: VWZ7Z0D9339092
   Coding: 0016751
   Shop #: WSC 23071 444 53249
   VCID: 73B3D80A47A612635E0-5160
17884 - EVAP Leak Detection Pump
            P1476 - 002 - Malfunction / Insufficient Vacuum
Readiness: 0000 0100
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 3B0 927 156 AM
   Component: AG5 01V 1.8l5VT USA 1212
   Coding: 0001104
   Shop #: WSC 05311 000 00000
   VCID: 71BFD2023DBA2073ACC-5160
Address 03: ABS Brakes        Labels: None
   VCID: 55F78692AC126C53504-51F2
No Faults Found
   Part No: 1C0 909 605 C
   Component: 09 AIRBAG VW61 04   0003
   Coding: 12345
   Shop #: WSC 00028
   VCID: 2411EB56B7C8C5DB17A-513C
Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
   Part No: 3B0 920 929 B
   Component: KOMBI+WEGFAHRSP VDO V04
   Coding: 13235
   VCID: 2615F15EC1F437CB09E-513C
   WVWPD63B94P252166     VWZ7Z0D9339092
            80-10 - Single-Wire Operation - Intermittent
01304 - Radio
            49-00 - No Communications
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00028
   VCID: 70B9D70633B0297BA32-513C
01304 - Radio
   Part No: 1C0 959 799 C
   Component: 08 Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00028
   VCID: 372B2C1A165EBE43A28-4B1E
   Subsystem 1 - Part No: 1C1959801
   Component: 08 Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C1959802
   Component: 08 Tõrsteuer.BF KLO 0202
   Subsystem 3 - Part No: 1C0959811
   Component: 08 Tõrsteuer.HL KLO 0202
   Subsystem 4 - Part No: 1C0959812
   Component: 08 Tõrsteuer.HR KLO 0202
            80-00 - Single-Wire Operation
            27-00 - Implausible Signal
End----------(Elapsed Time: 04:45, VBatt start/end: 12.3V/12.3V)-----------
Same TCM in some other 2004:
https://forums.vwvortex.com/showthread.php?4978415-b5-vw-passat-tranny-codes
https://www.passatworld.com/threads/tiptronic-5-4-abrupt-downshifting.357490/
https://forums.ross-tech.com/showthread.php?3140
And in fact, I can only find that part number in 2004 model cars. All three are coded the same as yours. Now this doesn't mean the transmission itself wasn't swapped, but it's a pretty clear that the TCM wasn't and that 0001104 is the "correct" factory coding.
I do not think a security access code is required. Make sure you coding changes with key on, engine off. The TCM is almost certain to reject coding changes if the engine is running. Usually "Request out of Range" means your coding is requesting some feature that the module's firmware doesn't support, so try changing just one thing at a time, for example the Tiptronic Shift Strategy, or the DSP selection.
Speaking of the latter, were are you getting the '3' in the second-to-last digit? I don't see that documented as a valid option anywhere.
spaztikgoat
C?ID=389469
Thank you so much for the quick response. Even when I try changing a single digit, say the last digit to a 2, I get the same error 31 message. I would think that since I have a north American 4motion car that it would allow me to code it as such. And I agree with you that 3 is not listed as an option in the coding but I found a thread on passatworld where someone was able to code their b5.5 passat 4motion with a three.
The next thing I would try is a different value for the WSC and non-zero values for the Importer and Equipment Number. You may be able to tweak these on the Coding screen before saving a coding, but if not, set them on the Options screen, User Interface and Identification tab:
Custom recommended values:
WSC: 02628
Importer: 444
Equipment Number: 29584
After setting them there, click [Save], then exit and re-start VCDS for them to take effect.
I can't guarantee this will be effective, but it doesn't cost much to try.
spaztikgoat
C?ID=389469
No such luck. I see that a number of others have the same 1104 coding for their transmission but they are able to change the second to last digit to a 3 giving them a 1134 code. I can't imagine that changing from 1104 to 1102 will make much difference but the fact that I cannot change anything is frustrating. Are there any ways to force coding or any tricks to get around the error 31 message?
MasterTommy
Amsterdam
C?ID=295586
I don't know if this will apply to an older car such as this, but changing stuff that effects emissions (which a gearbox shifting strategy change will probably do) is also usually harder to change. Again, I don't know if this applies to this generation.
spaztikgoat
C?ID=389469
Thank you for your input. I tried 1134 and 1034 and both worked. The only thing I cant change is the last digit which still seems odd since I do in fact have a north American 4motion car and not a fwd.
