Results 1 to 9 of 9
Thread: 2006 passat abs not coded
    May 2020
    Las Vegas
    Bought a 2006 passat with abs issues bought ross-tech did scan see below. any help would be appreciated.
    Thursday,14,May,2020,10:26:44:14419
    VIN: WVWAK73C16P143472   License Plate:
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
              72
    VIN: WVWAK73C16P143472   Mileage: 104610km-65001miles
       Part No SW: 3C0 907 115 F    HW: 3C0 907 115 F
       Component: 2.0l R4/4V TFSI     0030
       Revision: --H10---    Serial number: VWZCZ000000000
       Coding: 0404010A19070160
       Shop #: WSC 22811 444 89524
       VCID: 2313EAC417D67D236E9-8076
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 004 -
                        Mileage: 104613 km
                        Date: 2020.05.09
                        Time: 00:22:59
                        Temperature: 24.0C
                        Temperature: 27.0C
                        Absolute Pres.: 930.0 mbar
                        Voltage: 11.557 V
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 004 - Supply Voltage
                        Mileage: 104613 km
                        Date: 2020.05.09
                        Time: 00:22:59
                        Temperature: 43.0C
                        Temperature: 33.0C
                        Voltage: 11.049 V
    001672 - ECM Power Relay Load Circuit
                   P0688 - 004 - Open Circuit - Intermittent
                        Temperature: 23.0C
                        Temperature: 25.0C
                        Voltage: 0.000 V
    Readiness: 0110 0101
       Part No SW: 09G 927 750 CJ    HW: 09G 927 750 CJ
       Component: AQ 250 6F           0841
       Revision: 00H38000    Serial number:
       Coding: 0000072
       Shop #: WSC 00028 028 00001
       VCID: 7BA3F2A4CFE6E5E3069-802E
                013 - Check DTC Memory
                        Fault Status: 00101101
                        Fault Frequency: 9
                        Reset counter: 201
    Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 Q    HW: 3C0 614 095 Q
       Component: ESP 440 C2     H015 0003
       Revision:  H015       Serial number: 0658241360
       Coding: 0010000
       VCID: 303915885620D6BBE3B-8064
    7 Faults Found:
    00532 - Supply Voltage B+
                        Mileage: 104613 km
                        Date: 2020.05.09
                        Time: 00:39:06
                        Mileage: 104613 km
                        Date: 2020.05.09
                        Time: 00:39:06
    01542 - Yaw Rate Sensor (G202)
                        Mileage: 104613 km
                        Date: 2020.05.09
                        Time: 00:39:06
                        Mileage: 104613 km
                        Date: 2020.05.09
                        Time: 00:39:06
                        Mileage: 104613 km
                        Date: 2020.05.09
                        Time: 00:39:06
    00810 - Sensor 1/2 for Brake Pressure
                        Mileage: 104613 km
                        Date: 2020.05.09
                        Time: 00:39:06
       Part No: 1K0 820 047 EB
       Component: Climatic PQ35   090 0505
       VCID: 6889BDE8AE705E7BFBB-803C
       Revision: 00H46000    Serial number: 00000002296500
       Coding: 14840F0340041A00400A00000F00000000285D435C0000
       VCID: 372B2E94B34E0183A21-8062
       Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer VW461  012  0503
       Coding: 00063445
       Shop #: WSC 00028
                        Reset counter: 4
                        Mileage: 104613 km
                        Date: 2020.05.09
                        Time: 00:37:00
                        Voltage: 8.20 V
                        Reset counter: 4
                        Mileage: 104613 km
                        Date: 2020.05.09
                        Time: 00:39:00
                        Voltage: 6.95 V
       Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
       Component: SDAR SIRIUS     H03 0060
       Revision: 00000000    Serial number: AUZ4Z7E7015504
       VCID: 2A0D07E070FCAC6B2DF-807E
                        Reset counter: 219
                        Mileage: 104613 km
                        Date: 2020.05.12
                        Time: 00:00:47
       Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
       Component: 0N AIRBAG VW8R  029 2521
       Revision: 10029000    Serial number: 003A3PRJVKQZ
       Coding: 0012366
       VCID: 2E050BF04C14C04BF17-807A
       Subsystem 1 - Part No: 3C0 959 339 A
       Component: BF-Gewichtsens. 006 0002
       Subsystem 2 - Serial number: 00000000032V6R
       Subsystem 3 - Serial number: 0001.01.000000600000000000†63
       Subsystem 4 - Serial number: 000000†6332MSME0D3C6722G†63
       Subsystem 5 - Serial number: C6722G†6342MSME0D2F0A51I†63
       Subsystem 6 - Serial number: F0A51I†6351HTS69SDAUA33T†63
       Subsystem 7 - Serial number: AUA33T†6361HTS604F64NM20†63
       Subsystem 8 - Serial number: 64NM20†63727TS6I2IIAMM2S†63
       Subsystem 9 - Serial number: IAMM2S†63827TS6I2II6ME2H
       Subsystem 10 - Serial number: I6ME2H
    03032 - Supply Voltage for Seat Occupied Recognition Control Module
       Part No SW: 3C0 953 549 H    HW: 3C0 953 549 H
       Revision: 00005000    Serial number: 3C5953507R
       Coding: 0002013
       VCID: 313F108C5D2ADFB3EC5-8064
       Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
       Revision: X0033000    Serial number: 00000000000000
       Coding: 0007205
       Shop #: WSC 22599 444 53828
       VCID: 33331A84A736EDA39E9-8066
                        Fault Frequency: 10
                        Reset counter: 4
                        Mileage: 104613 km
                        Date: 2020.05.09
                        Time: 00:38:10
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C05C050232
       Coding: 3FFD0E04D31002
       VCID: 211FE0CC0DCA6F337C5-8074
                        Reset counter: 3
                        Mileage: 104613 km
                        Date: 2020.05.09
                        Time: 00:38:28
       Part No SW: 3C0 919 965     HW: 3C0 919 965
       Component: Kompass         005 0002
       Revision: 00005000    Serial number: 1166279TQ0Y404
       VCID: 6D87CCFC81927B5388D-8038
                        Reset counter: 4
                        Mileage: 104613 km
                        Date: 2020.05.09
                        Time: 00:38:19
       Part No SW: 3C0 959 433 Q    HW: 3C0 959 433 Q
       Component:    IMMO         051 0383
       Revision: 00051000    Serial number: VWZCZ000000000
       VCID: 38292DA8BE500EFBABB-806C
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                        Reset counter: 4
                        Mileage: 104613 km
                        Date: 2020.05.12
                        Time: 00:00:04
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2365
       Coding: 0001205
       VCID: 36352390B444F88BB97-8062
       Part No: 1K1 909 144 K
                        Temperature: 20.0C
                        Voltage: 4.50 V
                        Voltage: 5.40 V
       Component:    KSG PQ46 RDK 051 0218
       Coding: 13910F8801862E521804141FF00A0F0E081800
                        Reset counter: 4
                        Mileage: 104613 km
                        Date: 2020.05.09
                        Time: 00:38:29
       Part No: 1K0 959 702 K
       Coding: 0001204
       Revision:   013
       Coding: 0010000
                        Fault Status: 11101101
                        Fault Frequency: 178
                        Reset counter: 219
                        Mileage: 104608 km
                        Date: 2020.05.12
                        Time: 00:09:51
                        Voltage: 12.42 V
                        Count: 236
                000 - - - MIL ON
                        Fault Status: 11100000
                        Reset counter: 219
                        Voltage: 12.42 V
                        Count: 171
                000 - - - MIL ON
                        Reset counter: 219
                        Voltage: 12.42 V
                        Count: 170
       Part No SW: 1K0 035 180 C    HW: 1K0 035 180 C
       Component: Radio PM6       016 0017
       Revision: 00016000    Serial number: VWZ5Z7E2047344
       Coding: 0040400
       VCID: 2019E5C806C0663B73B-8074
                        Reset counter: 3
                        Mileage: 104613 km
                        Date: 2020.05.09
                        Time: 00:36:44
                        Fault Status: 00111011
                        Reset counter: 3
                        Mileage: 104539 km
                        Date: 2020.05.01
                        Time: 14:31:55
       Part No: 1K0 959 703 D
       Component: Tuer-SG         021 2432
       Coding: 0000144
    01813 - Supply Voltage for Door Controller; Rear Left (J388)
       Component:    RDK              0420
       Coding: 0100100
    00667 - Ambient Temperature Signal
                        Reset counter: 4
    00625 - Vehicle Speed Signal
                        Reset counter: 4
       Part No: 1K0 959 704 D
       Coding: 0000144
       VCID: 323D1F80582CE4AB95F-8066
    01814 - Supply Voltage for Door Controller; Rear Right (J389)
    End----------(Elapsed Time: 01:23, VBatt start/end: 12.1V/12.3V)-----------
    Jan 2020
    Poland
    Try 0013605 or 0029986 or 0029989 or 0013602
  3. Likes Dana liked this post
    May 2020
    Las Vegas
    Thank you will try those
  5. Likes Dana liked this post
  6. #4
    United States
    I came up with: 0013755
    This page should help after you get it coded:
    http://wiki.ross-tech.com/wiki/index...ke_Electronics
  7. Likes Stopro92, Jack@European_Parts, Uwe liked this post
  8. #5
    May 2020
    Las Vegas
    is there step by step instructions to code it? I am having a hard time figuring it out....
  9. #6
    Jan 2020
    Poland
    You enter abs 03,select coding, write coding, confirm and check whether the controller has accepted the coding.
  10. Likes Dana, Jack@European_Parts liked this post
  11. #7
    May 2020
    Las Vegas
    THAT WORKED AWSEOME THANK YOU ALL!
  12. Likes Stopro92, Uwe liked this post
  13. #8
    Jan 2020
    Poland
    Which code worked?
  14. Likes Uwe, Fredrick Awuor liked this post
  15. #9
    May 2020
    Las Vegas
    0013755 worked first time
  16. Likes Uwe, Stopro92 liked this post
