Results 21 to 30 of 31
Thread: Retrofit Woes instrument cluster b6 passat
  1. #21
    Aug 2014
    Have a look here: https://www.motor-talk.de/forum/umba...-t4813384.html
    (Use Google Chrome if Deutch is not your favorite language )
  2. Likes iichel liked this post
  3. #22
    Nov 2019
    Trinidad and Tobago
    Thanks for the read up will retrofit the tpms high for now as I do further reading on the cecm to bcm swap as well as the swapping of the ccm and reading of the eeprom data
  4. #23
    Dallas (McKinney) ,TX ,USA
    Quote Originally Posted by MezTech View Post
    Noo I am nt familiar with the eeprom
    I suggest you stay a way from this and let someone who know to do that part for you , otherwise ,like I said before, you can end up with Dead car in your hand.
    Immobilizer/ECU
    /Cluster Programing (Used or NEW)
    email: marinmm2001@gmail.com , info@advancedcarelectronics.com
    https://www.advancedcarelectronics.com/
  5. #24
    Nov 2019
    Trinidad and Tobago
    My goal with that was just to read it and send it to someone to do the coding part not trying to brick anything
  6. #25
    Mar 2015
    Australia
    There is a free tool on dunt.at to assist with transferring the eeprom's immo contents from B6 CCM to B7 CCM.
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist|BCM Retrofit|HBA/FLA
  7. #26
    Nov 2019
    Trinidad and Tobago
    ok will check it out currently looking at the best tool to use think I will go with the one you use
  8. #27
    Nov 2019
    Trinidad and Tobago
    Gateway 7N0907530AJ
    Tpms module 3AA907273F
    tpms sensors 3AA907275
    I already have the b7 passat instrument cluster installed if i buy and configure these parts will the tpms show up in the mfd my car came fitted with the direct tpms system from factory but since the clusters use different protocols I dont get any info on the mfd only get the tpms light on the dash
    need a straight answer on this from anyone have all the parts in my cart just to click buy
  9. #28
    Aug 2014
    Gateway 7N0907530AJ
    All parts should fit, however, for the sensors I've would search for 3AA907275B. Without B it's just a repair set.
    When everything is installed and coded with VCDS, you'll need datasets for 3AA907273F. This can't be done with VCDS, so you'll need another tool starting with V** or El**W**.
    That said, if it was me, with this major project, I would do it in this way:
    1. Cluster
    2. CECM to BCM swap
    3. TEST TEST TEST - make sure that everything is okay. No errors and car is working perfect
    4. Change gateway and CCM module.
    5. TEST TEST TEST - make sure that everything is okay. No errors and car is working perfect
    6 Continue with other projects (TMPS and other)
    I've been there and it's a hell trying to figure out which modules is causing the error when replacing multiple at the same time.
    4 *** - remember one or 2 new wires from the ELV to/from the gateway is either no longer needed or should be added. I've can't remember, but there are some changes.
  10. Likes Jetta ,97, Uwe, PetrolDave, Dana liked this post
  11. #29
    Nov 2019
    Trinidad and Tobago
    Ok thanks going to check back on scarp b7 comfortline which I took the instrument cluster from I will be able to get the bcm with the 3 big connectors(can dismantle and buy the entire harness if need be) and the relay panel from it, as well as the ccm the gateway was already sold, since the car doesn't have the tpms system, electric seats etc should I bother with taking the bcm and ccm from it as it has a limited feature set?
  12. #30
    Aug 2014
    The only reason for buying the entire harness + replay would be to have connectors when doing the conversion. Basically anything 15 centimeters from the 3AA BCM is not needed for this conversion project.... However it's allways nice to have some extra wires
  13. Likes MezTech, Jetta ,97 liked this post
