Retrofit Woes instrument cluster b6 passat
MezTech
Trinidad and Tobago
C?ID=380032
Hello all so recently I retrofitted a rcd 510 from a 2009 tig and a instrument cluster from a b7 passat (color mfd with red dials) my car is a b6 passat highline with as much bells and whistles that my region dealer offered at the time (tire pressure warning system, heated seats, white writing mfd etc) anyways the swap went well everything works except that now I have lost certain features I had when I had the white mfd installed they are.
1. Tire pressure system only shows the symbol in the cluster but doesnt show the words on the mfd before when I pressed the button it would say partially loaded on or fully loaded on or tire pressure to low please note the b7 donor car does not have the tire pressure system.
2. My lights and vision menu as well as the convenience menu is gone so I can't set the coming home lights or choose how to adjust the mirror etc.
3. Can't activate needdle sweep I would of thought a b7 passat with a color mfd would of been able to do it.
Was told that to get these features I would need to change the can gateway in my car to the gateway that's in the b7 passat donor car how true is this?
Thanks.
Wednesday,13,May,2020,20:17:58:50820
VCDS Version: 20.4.0.1 (x64)
VIN: WVWZZZ3CZAE059006   License Plate:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 42 44 46 52 53 55 56 62
          65 72
VIN: WVWZZZ3CZAE059006   Mileage: 90620km-56308miles
Address 01: Engine (   )       Labels:. 06J-907-115-BZB.clb
   Part No SW: 06J 906 026 BL    HW: 06J 906 026
   Component: MED17.5             3433
   Revision: A8H11---    Serial number: VWZCZ000000000
   Coding: 0404000324070160
   Shop #: WSC 66565 257 00032
   VCID: 75EBDA181C07B22E21-8020
Readiness: 0000 0001
   Part No SW: 02E 300 057 Q    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3108
   Revision: 05551213    Serial number: 00001201112323
   VCID: 2757C050962B90BE63-8072
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
   Component: J104    C4 440 V2   0015
   Revision: --025---    Serial number: 00000795725514
   Coding: 0001365
   Shop #: WSC 05311 000 00000
   VCID: 62C19144BD89359674-8036
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 EB    HW: 3C0 907 044 EB
   Component: ClimatronicPQ46 133 1010
   Revision: 00133026    Serial number: 00000000000000
   VCID: 65CB8A58ACA742AE91-8030
01810 - Actuating Motor for Temperature Flap; Right (V159)
                    Fault Status: 01110000
                    Fault Frequency: 18
                    Reset counter: 163
                    Mileage: 204063 km
                    Date: 2017.06.07
                    Time: 06:00:00
                    Reset counter: 197
   Revision: 00H54000    Serial number: 00000003395376
   Coding: E7868F0700041A00470A00000F000000000A5D435C000120000000000000
   Shop #: WSC 05124 123 12345
   VCID: 336F240052F3EC1ECF-8066
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 120909 022  0601
   Coding: 00046997
   Shop #: WSC 05124
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     260909 046  0204
   Coding: 00208933
   Shop #: WSC 05124
00061 - Footwell Lights
                    Fault Frequency: 202
                    Reset counter: 163
                    Mileage: 200696 km
                    Voltage: 12.35 V
                    Fault Status: 00101010
                    Fault Frequency: 185
                    Reset counter: 203
                    Mileage: 196411 km
                    Voltage: 13.40 V
                    Fault Frequency: 175
                    Reset counter: 203
                    Mileage: 196411 km
                    Voltage: 13.40 V
01598 - Drive Battery Voltage
                    Fault Frequency: 57
                    Reset counter: 186
                    Mileage: 203130 km
                    Voltage: 13.95 V
   Part No SW: 3C8 919 475 A    HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0009
   Revision: --------    Serial number: 08720926901292
   Coding: 100102
   Shop #: WSC 05314 000 00000
   VCID: 326121046DE9E516C4-8066
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__00J VW10 HI   1916
   Revision: 20013000    Serial number: 003E2PL1MBN-
   Coding: 0012362
   VCID: 448D77DC075D5BA666-8010
   Subsystem 1 - Serial number: 6332MTS628842669
   Subsystem 2 - Serial number: 6342MTS643012449
   Subsystem 3 - Serial number: 6351HTS6J90219KJ
   Subsystem 4 - Serial number: 6361HTS6AS4C56KR
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
   Component: J0527               0030
   Revision: 00035000    Serial number: 3C5953507CN
   Coding: 0001511
   VCID: 74EDE71C177DAB2616-8020
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Part No SW: 3AA 920 880 B    HW: 3AA 920 880 B
   Component: KOMBI         H03 0407
   Coding: 160F01
   Shop #: WSC 00028 028 00311
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
   VCID: 3261210465E9E516C4-8066
10485825 - Internal Control Module Memory Check Sum Error
          B2000 41 [137] - General checksum failure
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P09A090184
   Coding: FDA1FF07000202001003
   Shop #: WSC 05314 123 12345
   VCID: 2A5139648539ADD67C-807E
   Part No SW: 3C0 959 433 AM    HW: 3C0 959 433 AM
   Component:    IMMO         052 0383
   Revision: 00052000    Serial number: VWZCZ000000000
   Shop #: WSC 07737 898 02089
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Component: Sitzverstellung     1101
   Revision: 00005000    Serial number: 00000000000000
   VCID: 2F672870BEDBC8FEAB-807A
   Part No SW: 1K0 959 701 AS    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1502
   Revision: 71009005    Serial number: 00000884298709
   Coding: 0005111
   VCID: 7F0738302E3BF87E7B-802A
                    Fault Status: 00100101
                    Reset counter: 190
00131 - Outside Door Handle Illumination/mirror Light Driver Side
                    Fault Status: 00101100
                    Reset counter: 189
                    Mileage: 193659 km
                    Date: 2016.12.31
                    Time: 00:00:24
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 196    2901
   Revision: 00H17000
   Component:    KSG PQ46 RDK 052 0412
   Coding: 19910A0001860E7630049F1FF008DF0E305801
01134 - Alarm Horn (H12)
                    Fault Frequency: 23
                    Reset counter: 150
                    Mileage: 193461 km
                    Date: 2016.12.29
                    Time: 21:19:48
   Part No SW: 1K0 959 702 AS    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1502
   Revision: 71009005    Serial number: 00000783098703
   Coding: 0005110
   VCID: 0005BBCC53C5878602-8054
                    Reset counter: 192
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
                    Reset counter: 189
                    Mileage: 193659 km
                    Date: 2016.12.31
                    Time: 00:00:24
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   010       Serial number: 00000000041701
   Coding: 0000057
   VCID: 2C5D3F7C8FCDB3E68E-8078
   Component: AFS-Steuergeraet    0142
   Coding: 2311617
   VCID: 346D271C57FDEB26D6-8060
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Part No SW: 5K0 035 190 A    HW: 5K0 035 190 A
   Component: Radio RCD510  051 0213
   Revision: 00000001    Serial number: VWZ1Z3N1798387
   Coding: 0100040004000F
   VCID: 234FD44022137C9E3F-8076
00856 - Radio Antenna
                    Reset counter: 157
                    Mileage: 90497 km
                    Date: 2014.10.04
                    Time: 00:38:17
                    Reset counter: 157
                    Mileage: 90497 km
                    Date: 2014.10.04
                    Time: 00:38:17
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0308
   Revision: 41004101    Serial number: 00000001090569
   Coding: 0000208
   VCID: 70E5EB0C63659706F2-8024
00934 - Electric Window Motor; Rear Left (V26)
                    Reset counter: 190
   Component:    RDK              0453
   Coding: 0161211
01487 - System Function Test
                    Fault Status: 01100101
                    Mileage: 199860 km
                    Date: 2017.04.09
                    Time: 07:21:06
                    Mileage: 90624 km
                    Date: 2014.10.04
                    Time: 20:04:04
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0308
   Revision: 41004101    Serial number: 00000001100073
   Coding: 0000208
   VCID: 71E3EE08686F9E0EFD-8024
                    Reset counter: 203
                    Mileage: 199871 km
                    Date: 2017.04.09
                    Time: 03:32:14
00935 - Electric Window Motor; Rear Right (V27)
                    Reset counter: 190
                    Fault Frequency: 52
                    Reset counter: 203
                    Mileage: 200722 km
                    Date: 2017.04.23
                    Time: 03:32:42
End-------------------------(Elapsed Time: 02:24)--------------------------
kamold
Australia
C?ID=241363
Lights and vision menu needs upgrade from CECM to BCM.
Convenience menu requires CCM upgrade to B7 version (which also has the immobilizer data in it so need to transfer that via eeprom)
Needle sweep should be able to be activated using the 'Staging' or 'Celebration' adaptation channels in the instrument cluster.
TPMS needs upgrade to the B7 high version if you want individual pressures per tyre displayed as well as multiple tyre profiles to select from. TPMS high sits on the extended canbus which would necessitate an canbus upgrade.
Welcome to the world of 'I'll just change this one thing....oh no it means I have to change that other thing. Which then means I have to also change these things....'
Before you know it most of the car is upgraded ;)
MezTech
Trinidad and Tobago
C?ID=380032
Thanks for the information trying to wrap my mind around what you said
1. lights and vision needs upgrade from cecm to bcm so is it just a matter of swapping it out from the donor car?
2. ccm well I know I will have to do without this one because of the immobilizer don't have anything that can read my eeprom and the devices I saw that can are pretty expensive
3. for some reason staging and celebration are saying function not available when I try to activate it.
4. for the tpms to show the words on the display that means I would need a gateway from a highline b7 passat that came with the tpms installed? at least for now once I see the light comes up I know its because the tire pressure is low so its ok for now.
sorry for all the questions thanks in advance.
kamold
Australia
C?ID=241363
BCM upgrade is fairly involved. It's basically a complete rewire of all the car's electrical systems as the plugs for BCM and older CECM are not the same. I'd call it a moderate to advanced level retrofit given the amount of time it takes messing around in the footwell, and then programming the eeprom for the correct lighting configuration.
You can buy an eeprom tool suitable for swapping the CCM for under $100.
If you can't enable staging via adaptation, need to modify the cluster eeprom directly.
TPMS high requires a new TPMS module which is installed behind the rear bumper.
MezTech
Trinidad and Tobago
C?ID=380032
Was reading the forums saw where you was talking about how difficult the bcm upgrade is with regard to room etc on the b6 passat you got any writeups or can you point me in the right direction to get started seems like its not worth it in my opinion but you never know.
Yea I'm seeing some tools on ebay for a decent price (non odb)
Yes was told this by someone else so I will need to get the eeprom tool to read and modify it not a problem.
Tpms high is this the version where it shows individual tire pressures? if yes I don't really need that function would of just liked to see the words that used to come up on the mfd before like tire pressure to low or when I switch between the two monitoring modes.
also will changing the can gateway provide any additional functionality?
kamold
Australia
C?ID=241363
I haven't seen a good writeup on the BCM retrofit there is some info on Russian sites like drive2.ru.
By the time people get to BCM retrofit they're normally pretty experienced retrofitters so get stuck in to wiring diagrams etc
CCM eeprom has to be read directly from the eeprom on the module board itself, not over OBD.
Cluster eeprom can likewise be modified with the same tool.
The issue with the TPMS you have is that the B6 TPMS module (which is a part of the CCM) only talks to the cluster with DDP protocol. Your new cluster uses BAP.
So you either have to manually change the part load/full load via VCDS, or upgrade to the B7 TPMS high version which adds individual tyre pressure display in the cluster also.
MezTech
Trinidad and Tobago
C?ID=380032
Ok seen many of your posts you seem pretty involved in retrofitting your car as well did you bother to rewire to the bcm yourself? and what eeprom tool would you recommend? will look for a tpms module on ebay if you know of any part numbers that will work feel free to post is there no cecm that will support the premium cluster and lights and vision menu?
kamold
Australia
C?ID=241363
No you can't just replace the CECM.
You've installed a B7 cluster, so you need a B7 BCM in order to have those menus back.
There are plenty of eeprom tools around personally I have TL866II just a cheap one.
After saying for years I wouldn't bother with BCM to just get the lights menu back in the MFD I ended up doing it a few months ago to get High Beam Assist seeing as I had retrofitted the front assist camera.
Glad I did the menus coming back is a bonus.
There are some guys who can make you up a harness to go from the CECM to BCM wiring, but it still requires some cutting and soldering etc I believe and you also need to be able to program the eeprom which is easy to do with another tool over OBD.
TPMS is 3AA 907 273 F (there are some other part numbers which will also work)
MezTech
Trinidad and Tobago
C?ID=380032
Ok nice reading on another forum about your earlier run in with the retrofitting for the color cluster in the r36 good stuff but I think I understand everything now well I will order the b7 tpms module and the eeprom reader I will take the ccm from the b7 donor car and the bcm as well I will cut out the bcm jacks with long enough pigtails to cut and join to my oem harness and search for a writeup on how to wire it up that will be the last thing that I do as it seems as a painstaking job also what will changing the can gateway enable me to do?
kamold
Australia
C?ID=241363
Make sure you have all the wiring diagrams to compare.
Hit me up on PM I can share whatever information I have.
You will need to replace the gateway with one that has an extended CAN interface that the TPMS module will connect into.
When you replace the CCM with B7 version you will also need to rewire the steering column ELV wiring.
And also possibly update the ABS software......it's an endless snowball of changes.
downtime
C?ID=280813
I write my 2cents on CECM -> BCM swap as well.
I did that to my wife's previous car (2007 Golf Plus). Although a different platform but it was the same effort needed. Complete rewiring was needed and changing from multiple different plugs to three BCM connectors. Also relays needed to be upgraded and new relay holder needed.
It took about 2 days to do and it was a lot of work but it was not that difficult. Make the preparations well before and it is easy to just repin and check the list. I created a cross matrix excel where I had old pin -> New pin for all connections.
Like Kamold wrote, in addition to get the missing menus back, you will get some new things that are coming with BCM like high beam assist support etc.
MezTech
Trinidad and Tobago
C?ID=380032
:( seems like a mountain of never ending changes really thought this retro fitting was plug and play with some coding etc just doing some reading on the tpms and it seems like the module on the b7 is a direct system and the system I have currently is the indirect system will I need to change my tire sensors as well? thought it was just a matter of locating a b7 indirect tpms module and swap over.
MezTech
Trinidad and Tobago
C?ID=380032
thanks for pitching in seems like its doable but the information on acquiring the diagrams etc is somewhat hard to obtain searching drive.ru as we speak.
downtime
C?ID=280813
Buy some quality time from Erwin and download the wiring diagrams for your car and for a newer Passat with BCM. You can build the information with that.
MezTech
Trinidad and Tobago
C?ID=380032
Gateway 7N0907530AJ
Tpms module 3AA907273F
tpms sensors 3AA907275
If I purchase all these parts will my tpms show on the mfd with no ccm changes abs software updates etc.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Few people confirm it to you that CCM needs to be update to BCM .
As someone mention this is not easy swap , require lot off work, wiring re-pin , immobilizer involved, Specially very good skills to be able read write Eeprom memory , because if you do something wrong you will end up with DEAD car. Form your answers looks like you are really not familiar what is eeprom and how this works.
Some things are not just like that , chnage just cluster and be done with it .
Same thing when I did Mk6 cluster to my mk5 jetta, many other things needed to be change to make it work correct with Mk6 steering and Mk6 Navi.
MezTech
Trinidad and Tobago
C?ID=380032
No I am not familiar with the eeprom I'm reading at the moment but I was solely inquiring about the tpms system read elsewhere bcm and ccm upgrade was not needed just wanted to comfirm.
diskoboy
C?ID=50403
Years ago I've had a Passat B6 where I've changed the CECM to a B7 BCM. There are guides on www.motor-talk.de with diagrams ect. I did it in 4-5 hours. New relays has to be installed as well. In my car I've had to extend the wires, but on another car the wires was long enough.
In order to retrofit the CCM to B7 3AA, your ABS has to have at least revision 21. I've changed ABS to 3C0 614 109 AF and got revision 25. I've ended up changing it to a KESSY one with 2 new keys.
Gateway has to changed as well.
Just found a old log from my car: https://forums.ross-tech.com/showthread.php?1123-Passat-3C-Coding-of-byte-18-with-a-new-3AA-BCM
