Results 1 to 3 of 3
Thread: 2004 golf tdi - readiness test failing
    May 2020
    Hi Guys,
    I need some help with my 2004 golf tdi. It is failing in "comprehensive components" test. After few trips to shop, 3 smog tests and drivng it for hundred of miles, I decided to get a VCDS system and take the help of you experts. Unfortunately VCDS does not have any "set readiness" scripts for my model of tdi. So, I ran an all-scan. What I am suspecting is the Control Module for Fuel Pump (J538) is the culprit. Clearing the codes did not help. They came back in the next scan.
    If I replace the Control Module for Fuel Pump (J538) and the code does not come back, will it pass smog? Do I need to have all the errors fixed? Most look like electrical errors which should not matter for smog test. At this point, all I care is, it passing the smog. It is already past due and this is my daily driver. I am in California.
    Thanks for the help. I am sharing the all-scan log file here.
    all-scan code:
     Monday,11,May,2020,18:54:46:24978[/COLOR]
    VIN: 9BWFR61J144018764   License Plate: 2004TDI-11MAY20-7PM
    Mileage: 241050km-149781mi   Repair Order:
    Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
              76
    VIN: 9BWFR61J144018764   Mileage: 241050km-149781miles
    Address 01: Engine        Labels: 038-906-016-BEW.lbl
       Part No SW: 038 997 016 R    HW: 028 101 114 6
       Component: R4 1,9L EDC G000AG  0282
       Revision: 12345678    Serial number: VWZ7Z0C7100757
       Coding: 0150034
       Shop #: WSC 02103 003 1048576
       VCID: 2D070CAAC1072743C8D-5184
    Readiness: 0 0 1 0 0
    Address 02: Auto Trans        Labels: 09A-927-750.lbl
       Part No: 09A 927 750 AM
       Component: AG5 Getriebe 09A   0251
       VCID: 76B5E3C671D1249B797-50AE
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
       Part No: 1C0 907 379 L
       Component: ABS FRONT MK60      0101
       Coding: 0004097
       Shop #: WSC 00001 785 00200
       VCID: 33331AD2272371B39E9-5184
       Part No: 1C0 909 605 F
       Component: 08 AIRBAG VW61 0202 0003
       Coding: 12344
       Shop #: WSC 00001
       VCID: 270BFE82E6FB0D13321-513C
       Part No: 1J0 920 907 F
       Component: KOMBI+WEGFAHRSP VDO V02
       Coding: 15234
       Shop #: WSC 00001
       VCID: 2C0101AEFF1D2E4BDF3-513C
       9BWFR61J144018764     VWZ7Z0C7100757
    01335 - Drivers Seat/Mirror Position Control Module (J543)
                49-00 - No Communications
    00476 - Control Module for Fuel Pump (J538)
    01304 - Radio
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00001
       VCID: 70B9D5DE13B50AABA3B-513C
    8 Faults Found:
    01304 - Radio
       Part No: 1C0 959 799 C
       Component: 8C Komfortgerát HLO 0003
       Coding: 00258
       Shop #: WSC 00001
       VCID: 372B2EC2365B9D93A21-4B1E
       Component: 8C Tőrsteuer.FS KLO 0202
       Subsystem 2 - Part No: Steuerger
       Component: t Beif. antwortet nicht
       Component: 8C Tőrsteuer.HL KLO 0202
       Component: 8C Tőrsteuer.HR KLO 0202
    12 Faults Found:
                53-10 - Supply Voltage Too Low - Intermittent
                37-10 - Faulty - Intermittent
                54-10 - Incorrectly Equipped - Intermittent
    00953 - Interior Light Time limit
                25-10 - Unknown Switch Condition - Intermittent
    End----------(Elapsed Time: 05:18, VBatt start/end: 14.3V/14.2V)-----------
    Jan 2020
    Poland
    Check the fuel pump relay first, I had a case with this error and the relay was the culprit.
  3. Likes Uwe liked this post
    HQ
    This car is looking for stuff that doesn't exist as it came from factory.... this car didn't come with power seat and there isn't a fuel pump control module, just a simple J17 relay. I don't know how the CAN Gateway got to that point. Connect to address 19 CAN Gateway, go into coding and just reapply the same 00006 coding value it already has. Exit out and then lock the car up for a few minutes. Then go back into the car and see if you can clear codes out of the control modules.
    Also, if it has an aftermarket radio that ties into the CAN system, unplug it for now. If various codes clear out, mainly in address 17 and 19, then go for an extended test drive and see if the readiness finally flips for the engine.
    Jef
  5. Likes Uwe liked this post
