Hi all!
Tested a little bit my Passat B6, 2.0TDI BMP for DPF measures. No fault codes, but Pressure Difference at idle = 7.65 (in some moments go up to aprox. 10).
Pressure Difference in driving mode:
2000rpm ~50,
3000rpm ~100,
4000rpm ~199.
Pressure Difference Offset stays -12.75 all the time (negative is ok?).
DPF Load Coeff: 0.0%
DPF Carbon Mass: 108.0 (max value 60gr)
Carbon Mass Learned: 0.0%.
The car have 340 000km (212 500miles) on clock.
Is it time to clean/change/remove DPF? Don't want wait till LIMP mode etc.
Thanks for technical help! Cheers!
2000rpm ~50,
3000rpm ~100,
4000rpm ~199.
