05 Audi A8 A/c Problems
jgrijalva1
C?ID=366192
I have an 05 Audi A8 Trying to get a/c to work after about 8 mnth absence after engine swap, system had pressure but no cold air . so I vaccumed the system and changed the Orifice tube and then tried to re add freon and said system over pressure and started getting 00819 code lower limit exceeded. after I was able to get about a can of freon in the system .. and my ECON would stay on even after trying to shut it down . Bought the G65 switch for the a/c and same thing with new switch . In the morning I went at it again and clear code and retried , but this time no more 00819 and I am now able to select and leave the ECON option turned off and still no cold air after second can of freon .. So no more 00819 and my VCDS says Auto HVAC OK .SO I wanted to know how I can check if my compressor is turning on or not using VCDS since I am not an electronic wizard on making a plug. I was going to post a clean auto scan report , but I dont get the advance option in the bottom before posting the thread. My a/c pressure gauges seems are the same aroung 70-75psi on both low and high side of the system with the vehicle on or off . Any help would be greatlty appreciated
Hi and welcome.
Please post you scan. It's just text. Ideally, you'll put it between CODE tags as explained here, but if not, don't worry, I'll fix it for you. :cool:
jgrijalva1
C?ID=366192
Tuesday,12,May,2020,12:27:39:64823
VIN: WAULL44E15N011405   License Plate: 512 2020
Mileage: 273120km-169708mi   Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
          46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAULL44E15N011405   Mileage: 273120km-169708miles
Address 01: Engine        Labels: 077-910-560-BFM.clb
   Part No SW: 4E0 910 560 J    HW: 4E0 907 560
   Component: 4.2L V8/5V      G   0010
   Revision: --------    Serial number: AUX3Z0DN753913
   Coding: 0007773
   Shop #: WSC 02313 785 00200
   VCID: 2809F9FE3EFCC83B3B2-807C
7 Faults Found:
17476 - Intake Air Switch-Over Valve (N335)
            P1068 - 004 - Open Circuit
18010 - Power Supply Terminal 30
18061 - Please check DTC Memory of ABS Controller
            P1653 - 008 -  - Intermittent
17538 - Fuel Trim; Bank 2 (Mult)
            P1130 - 001 - System too Lean - Intermittent
16558 - Fuel Trim; Bank 2
            P0174 - 001 - System Too Lean - Intermittent - MIL ON
17536 - Fuel Trim; Bank 1 (Mult)
            P1128 - 001 - System too Lean - Intermittent
16555 - Fuel Trim; Bank 1
            P0171 - 001 - System Too Lean - Intermittent
   Part No SW: 4E0 910 156 S    HW: 09E 927 156 A
   Component: AG6 09E 4,2L5V USA  0020
   Revision: --H01---    Serial number:        0048413
   VCID: 323D1B960820B2EB956-8066
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
   Component: ESP 5.7 allrad  H44 0510
   Coding: 0008597
   Shop #: WSC 02313 000 00000
   VCID: 221DEBD658C0226B656-8076
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 D
   Component:     FBS AUDID3  H04 0140
   Revision: 01404004    Serial number: AUX3Z0DN753913
   Coding: 0410624
   Shop #: WSC 02311 785 00200
   VCID: 58E9893E4E1CB8BB4B2-800C
   Part No SW: 4E0 910 760 C    HW: 4E0 959 760
   Component: Sitzmemory BFS H08  0060
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 3940448
   VCID: 2313EED247DA2B636E0-8076
Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
   Part No SW: 4E0 910 730 G    HW: 4E0 035 729
   Component: Interfacebox    H43 1070
   Revision: 00000000    Serial number: 346KW047518254
   Coding: 0000003
   VCID: 2411EDCE42D42C5B17A-8070
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH03 0040
   Subsystem 2 - Serial number: 00000000006872
   Subsystem 3 - Serial number: 0121.04.060000000100010001ÿ
   Subsystem 4 - Serial number: 010001ÿ
   Part No SW: 4E0 910 043 A    HW: 4E0 820 043 A
   Component: KLIMAAUTOMAT    016 0340
   Revision: 00000029    Serial number: 00000000056507
   Coding: 1052993
   VCID: 1B63D6327FAA13A3A60-804E
Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
   Part No SW: 4E0 910 279 L    HW: 4E0 907 279 L
   Component: ILM Fahrer      H12 0210
   Coding: 0123123
   VCID: 313F149A0D2689F3ECC-8064
   Subsystem 1 - Part No: 4E1 910 113 B
   Component: Wischer WWS D3  H50 0400
   Coding: 00000037
   Shop #: WSC 02313
   Coding: 00139548
   Shop #: WSC 02313
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 141
                    Mileage: 273125 km
                    Date: 2020.05.12
                    Time: 12:22:03
                    Reset counter: 141
                    Mileage: 273125 km
                    Date: 2020.05.12
                    Time: 12:22:03
   Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0430
   Revision: 00000000    Serial number: AUZ5ZBD7100643
Address 0F: Digital Radio        Labels: None
   VCID: 55F7800A5D0E85D3504-8000
No Faults Found
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
   Component: Airbag 8.4E+    H10 0920
   Coding: 0530707
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549 A
   Coding: 0012241
   VCID: 6597B0CA096E1553C04-8030
   Component: Lenkradmodul    H04 0080
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 950 G    HW: 4E0 920 950 G
   Component: KOMBIINSTR. VDO H49 0210
   Revision: D04         Serial number: AUDID3DN002832
   Coding: 0016233
   Shop #: WSC 20112 444 83955
01704 - Terminal 58 (Dimming)
            007 - Short to Ground
                    Fault Status: 00000011
                    Reset counter: 138
                    Mileage: 273125 km
                    Date: 2020.05.11
                    Time: 13:13:03
Address 19: CAN Gateway        Labels:. 4E0-910-468.clb
   Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
   Component: Gateway         H07 0040
   Revision: 07          Serial number: 050050491323ED
   Coding: FCFE7BDD1B7904
   VCID: 2615F7C634E8DE4B09E-8072
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0410624
   XXXXXXXXXXX ELV                 XXXX
Address 34: Level Control        Labels: 4E0-910-553.clb
   Part No SW: 4E0 910 553 H    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 4480
   Coding: 0015510
6 Faults Found:
01583 - Leak in System Detected
                    Fault Status: 11100000
                    Reset counter: 141
                    Mileage: 273125 km
                    Date: 2020.05.12
                    Time: 12:22:03
01400 - Suspension Level Control
            002 - Lower Limit Exceeded
                    Fault Status: 11100010
                    Reset counter: 141
                    Mileage: 273125 km
                    Date: 2020.05.11
                    Time: 13:14:44
00142 - Left Front Dampening Adjustment Valve (N336)
                    Fault Status: 11101100
                    Reset counter: 141
                    Mileage: 273125 km
                    Date: 2020.05.11
                    Time: 18:58:25
00143 - Front Right Dampening Adjustment Valve (N337)
                    Reset counter: 141
                    Mileage: 273125 km
                    Date: 2020.05.11
                    Time: 18:58:26
00144 - Rear Left Dampening Adjustment Valve (N338)
                    Reset counter: 141
                    Mileage: 273125 km
                    Date: 2020.05.11
                    Time: 18:58:26
00145 - Rear Right Dampening Adjustment Valve (N339)
                    Reset counter: 141
                    Mileage: 273125 km
                    Date: 2020.05.11
                    Time: 18:58:27
   Component: Sitzmemory FS  H08  0060
   Coding: 4071530
   Part No SW: 4E0 910 887 N    HW: 4E0 919 887 C
   Component: MNS US          H43 0740
   Revision: 00000000    Serial number: 378K3047506698
   VCID: 382929BEEE5C58BBAB2-806C
Address 38: Roof Electronics        Labels: None
No Faults Found
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 801 B
   Component: Türsteuer.FS BRM002 0060
   Coding: 0028204
   VCID: 2019E1DE56CC307B732-8074
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H04 0040
   Revision: 00400004    Serial number:  W040411090130
   Coding: 0065086
   VCID: 270BFAC233E2C743328-8072
   Component: Heckdeckel      H06 0060
   Component: Neigungssensor  H03 0020
01134 - Alarm Horn (H12)
                    Reset counter: 139
                    Mileage: 266145 km
                    Date: 2017.10.17
                    Time: 18:42:47
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 K    HW: 4E0 035 223 A
   Component: DSP-Amp.-High   H13 0440
   Revision: PROD_01     Serial number: 00000000201267
   Coding: 0000016
   VCID: 2517F0CA49EED553004-8070
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H09 0040
   Revision:             Serial number: 00000000051329
   Coding: 0010111
   VCID: 1E65DF266CB8068B41E-804A
   Subsystem 1 - Part No: 4E0 910 511 A
   Component: UGDO HL US      H02 0030
   Subsystem 2 - Serial number: VK4978T0H2PE
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 802 B
   Component: Türsteuer.BF BRM002 0060
   Coding: 0028204
                    Fault Frequency: 0
                    Reset counter: 160
                    Mileage: 272752 km
                    Date: 2004.05.04
                    Time: 07:21:48
01482 - Motors for Central Locking
                    Fault Status: 00100110
                    Fault Frequency: 0
                    Reset counter: 160
                    Mileage: 272752 km
                    Date: 2004.05.05
                    Time: 09:23:28
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 A    HW: 4E0 907 801
   Component: EPB  AV1C1010   H01 1010
   Revision: AV1C1010
   Coding: 0000532
   Shop #: WSC 29621 002 1048576
   VCID: 1D67D82A61BE1D93584-8048
02596 - Rear Brake Pads Worn
                    Fault Status: 01111000
                    Reset counter: 97
                    Voltage: 9.73 V
                    Count: 61
Address 55: Headlight Range        Labels: 4E0-910-357.lbl
   Part No SW: 4E0 910 357     HW: 4E0 907 357
   Component: Pre-AFS         H01 0040
   VCID: 629DABD61840626B256-8036
   Part No SW: 4E0 910 541 F    HW: 4E0 035 541 E
   Component: TUNER EU/US/RDW H42 0480
   Revision: 00000000    Serial number: 396KU047501354
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H11 0510
   Revision: 00000000    Serial number: 00000000012979
   Shop #: WSC 52639 001 1048576
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  1411080044
   Coding: 344530393135313035412056413031343131303830303434
   Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
   Component: Türsteuer.HL BRM002 0060
   Coding: 0028204
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273     HW: 4E0 907 273
   Component: Reifendruck 2   H01
   Revision: 00010027    Serial number: 00000700027427
   Coding: 0212127
   Shop #: WSC 20112 444 00362
   VCID: 5F9BA2222B324F830A8-800A
                    Reset counter: 138
                    Mileage: 272774 km
                    Date: 2020.04.23
                    Time: 22:40:30
                    Speed: 51.0 km/h
                    Temperature: 11.0°C
                    Error Code: 0
                    Pressure: 2.97 bar
                    Pressure: 1.77 bar
                    Pressure: 1.90 bar
                    Pressure: 2.32 bar
02214 - Tire Pressure Warning
                    Reset counter: 178
                    Mileage: 273121 km
                    Date: 2020.05.09
                    Time: 13:27:32
                    Temperature: 16.0°C
                    Error Code: 2048
                    Pressure: 2.85 bar
                    Pressure: 2.30 bar
                    Pressure: 2.67 bar
                    Pressure: 1.40 bar
   Part No SW: 4E0 910 753 S    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0550
   Revision: 00000000    Serial number: 00000411050013
   Shop #: WSC 12336 024 394758
   VCID: 3537208AF94EA5D3B04-8060
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 C
   Component: Türsteuer.HR BRM002 0060
   Coding: 0028204
                    Fault Frequency: 0
                    Reset counter: 161
                    Mileage: 272928 km
                    Date: 2020.04.25
                    Time: 19:53:12
                    Reset counter: 163
                    Mileage: 272928 km
                    Date: 2020.04.25
                    Time: 19:53:22
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
   Component: Parkhilfe 8-Kan H12 0020
   Revision: --.--.--    Serial number: 08720430200703
   Coding: 0001208
   VCID: 211FE4DA5DC639737CC-8074
   Part No SW: 4F0 910 336 A    HW: 4E0 862 335
   Component: Handyvorb2      H10 0120
   Revision: 00000000    Serial number: 00000007507733
   Coding: 0010900
End----------(Elapsed Time: 04:18, VBatt start/end: 14.0V/14.4V)-----------
Show us what you have in MVB 001 and 002, please.
Jef
HQ
Some general HVAC info we have here on the forum:
https://forums.ross-tech.com/showthread.php?633-Tis%92-the-HVAC-Season
Mainly we are looking to see what the shut down code is. One of the ways you can ID the correct data for this is by turning off the AC compressor:
  • 6 = Compressor OFF: ECON Mode active
  • 7 = Compressor OFF: A/C System / FAN OFF
So while looking at groups 001 and 002, as you turn off the HVAC blower motor, you should get a value of 7, or 7.0. If you have the blower motor on and enable the ECON mode, it should change to 6 or 6.0. Then of course, what number do you get when you try to run the AC? A value of 0 or 0.0 means the system is trying to run the compressor... and if this is the case and your pressure gauges are matching, you most likely have a bad compressor. :(
jgrijalva1
C?ID=366192
Ok so this is what I got
ECON off air running :
Tuesday,12,May,2020,19:50:03:64823
                Address 08: Auto HVAC  (4E0 910 043 A)
19:49:45 Group 001
  0.745 A  Current
  71.5 %  Load
  23.0 %  Load
  6.2 bar  Absolute Pres.
19:49:45 Group 002
  0.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
#2 ECON ON air running :
Tuesday,12,May,2020,19:48:56:64823
19:48:17 Group 001
  0.000 A  Current
  0.0 %  Load
  22.0 %  Load
  5.8 bar  Absolute Pres.
19:48:17 Group 002
  6.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
19:49:18 Group 001
  0.745 A  Current
  70.0 %  Load
  26.0 %  Load
  7.4 bar  Absolute Pres.
19:49:18 Group 002
  0.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
19:49:22 Group 001
  0.745 A  Current
  70.0 %  Load
  25.5 %  Load
  7.2 bar  Absolute Pres.
19:49:22 Group 002
  0.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
19:49:27 Group 001
  0.745 A  Current
  70.0 %  Load
  25.0 %  Load
  7.0 bar  Absolute Pres.
19:49:27 Group 002
  0.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
19:49:30 Group 001
  0.745 A  Current
  70.0 %  Load
  24.5 %  Load
  6.8 bar  Absolute Pres.
19:49:30 Group 002
  0.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
19:49:30 Group 001
  0.745 A  Current
  70.5 %  Load
  24.5 %  Load
19:49:30 Group 002
  0.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
19:49:32 Group 001
  0.745 A  Current
  70.5 %  Load
  24.5 %  Load
19:49:32 Group 002
  0.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
19:49:32 Group 001
  0.745 A  Current
  70.5 %  Load
  24.5 %  Load
19:49:32 Group 002
  0.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
This is GROUP 6 and 7
Tuesday,12,May,2020,19:55:44:64823
19:55:30 Group 006
  85.0  (no units)
  84.0  (no units)
  20.0  (no units)
  236.0  (no units)
19:55:30 Group 007
  84.0  (no units)
  83.0  (no units)
  19.0  (no units)
  233.0  (no units)
Jef
HQ
OK, so it looks like when you turned the ECON on, MVB 002.1 went to a value of 6.0. Otherwise, trying to run the A/C you get 0.0 there, and the high side pressure only went as high as 7.2 Bar (104 PSI), so this isn't looking good for the compressor.
jgrijalva1
C?ID=366192
I Thank you for confirming that , I kinda figured when I saw the 0.0 there . I will order the compressor and keep you guys posted . Thank you very much ,
jgrijalva1
C?ID=366192
Ok SO I received my new compressor and installed and added freon same thing not working . Now While I was waiting for the new one I took a trip to the junkyard and bought me another compressor so now I have 3 A/C compressors doing the same thing . Anything else I can do ?
This is with econ ON :
Monday,18,May,2020,21:45:19:64823
21:44:55 Group 002
  6.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
21:44:55 Group 001
  0.000 A  Current
  0.0 %  Load
  22.0 %  Load
21:44:55 Group 003
  143.0  (no units)
  141.0  (no units)
  67.0  (no units)
  197.0  (no units)
This is with Econ OFF :
Monday,18,May,2020,21:44:26:64823
21:43:44 Group 002
  0.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
21:43:44 Group 001
  0.745 A  Current
  87.5 %  Load
  25.0 %  Load
21:43:44 Group 003
  196.0  (no units)
  202.0  (no units)
  67.0  (no units)
  197.0  (no units)
21:44:40 Group 002
  6.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
21:44:40 Group 001
  0.000 A  Current
  0.0 %  Load
  21.5 %  Load
  5.6 bar  Absolute Pres.
21:44:40 Group 003
  194.0  (no units)
  190.0  (no units)
  67.0  (no units)
  197.0  (no units)
21:44:45 Group 002
  6.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
21:44:45 Group 001
  0.000 A  Current
  0.0 %  Load
  21.5 %  Load
21:44:45 Group 003
  192.0  (no units)
  185.0  (no units)
  67.0  (no units)
  197.0  (no units)
Jef
HQ
:confused: 08-08-002.1 showing 0.0, that means the compressor should be on. What are your low and high side readings?
The other fields show past shut downs. 11.0 is for coolant temp too high and 12.0 is for request from ECM. Any returning codes in the ECM? Does the engine coolant temp seem to be a valid reading?
Did you pull a vacuum on it before charging the AC system for 30 minutes? :rolleyes:
jgrijalva1
C?ID=366192
I have not check on my temperature sensor . Let me check on that then since I had not noticed any return codes from the temp sensor . I will aslo re check the low and high side pressure. and post it ..
jgrijalva1
C?ID=366192
Yes , I pulled vacuum for about 1 hr . on it every time the compressor has being swapped out
jgrijalva1
C?ID=366192
ok so this is what I can see today .
This is Econ ON:
Thursday,21,May,2020,20:15:17:64823
20:14:48 Group 001
  0.750 A  Current
  84.0 %  Load
  25.5 %  Load
20:14:48 Group 002
  0.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
20:14:48 Group 011
  81.0  (no units)
  76.0  (no units)
  81.0  (no units)
  183.0  (no units)
Econ OFF :
Thursday,21,May,2020,20:13:54:64823
20:13:30 Group 001
  0.745 A  Current
  81.0 %  Load
  24.5 %  Load
20:13:30 Group 002
  0.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
20:13:30 Group 012
  203.0  (no units)
  207.0  (no units)
  56.0  (no units)
  202.0  (no units)
Econ off with group 11
20:14:48 Group 001
  0.750 A  Current
  84.0 %  Load
  25.5 %  Load
20:14:48 Group 002
  0.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
20:14:48 Group 011
  81.0  (no units)
  76.0  (no units)
  81.0  (no units)
  183.0  (no units)
jgrijalva1
C?ID=366192
I finally got another compressor . Misunderstanding and they were sending me the wrong one . So I am still getting the same thing , no cold air . No fault codes for HVAC system and dont know where else to look . Same thing with a total of 4 compressors.
What I did notice is when I switch it from Econ on to OFF it 7.0 then goes to show 12. and then 0.0 right away .
Tuesday,09,June,2020,10:43:35:64823
VIN: WAULL44E15N011405   License Plate: 4TH
Mileage: 273290km-169814mi   Repair Order:
VIN: WAULL44E15N011405   Mileage: 273290km-169814miles
   Coding: 0007773
   Coding: 0008597
   Coding: 0410624
   Coding: 3940448
   Coding: 0000003
   Coding: 1052993
   Part No SW: 4E0 910 279 L    HW: 4E1 955 113 B
   Coding: 0123123
   Coding: 00000037
   Shop #: WSC 02313
   Coding: 00139548
   Shop #: WSC 02313
                    Reset counter: 153
                    Mileage: 273299 km
                    Date: 2020.06.09
                    Time: 10:13:04
                    Reset counter: 153
                    Mileage: 273299 km
                    Date: 2020.06.09
                    Time: 10:13:04
No Faults Found
   Coding: 0530707
   Coding: 0012241
   Coding: 0016233
                    Reset counter: 154
                    Mileage: 273299 km
                    Date: 2020.06.09
                    Time: 10:41:04
   Coding: 0410624
   Coding: 0015510
                    Reset counter: 154
                    Mileage: 273299 km
                    Date: 2020.06.09
                    Time: 10:41:04
                    Reset counter: 154
                    Mileage: 273299 km
                    Date: 2020.06.09
                    Time: 10:42:45
   Coding: 4071530
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135
   Component: Dachknoten D3   H02 0090
   Serial number: 00000429600079
   Coding: 0003477
   Shop #: WSC 20205 444 53401
   Coding: 0028204
   Coding: 0065086
                    Reset counter: 151
                    Mileage: 266145 km
                    Date: 2017.10.17
                    Time: 18:42:47
   Coding: 0000016
   Coding: 0010111
   Coding: 0028204
                    Fault Frequency: 0
                    Reset counter: 160
                    Mileage: 272752 km
                    Date: 2004.05.04
                    Time: 07:21:48
                    Fault Frequency: 0
                    Reset counter: 160
                    Mileage: 272752 km
                    Date: 2004.05.05
                    Time: 09:23:28
   Revision: AV1C1010
   Coding: 0000532
                    Reset counter: 97
                    Voltage: 9.73 V
                    Count: 61
   Coding: 0028204
   Coding: 0212127
                    Reset counter: 190
                    Mileage: 272774 km
                    Date: 2020.04.23
                    Time: 22:40:30
                    Speed: 51.0 km/h
                    Temperature: 11.0°C
                    Error Code: 0
                    Pressure: 2.97 bar
                    Pressure: 1.77 bar
                    Pressure: 1.90 bar
                    Pressure: 2.32 bar
                    Reset counter: 153
                    Mileage: 273299 km
                    Date: 2020.06.04
                    Time: 12:35:39
                    Temperature: 29.0°C
                    Error Code: 1536
                    Pressure: 2.87 bar
                    Pressure: 1.67 bar
                    Pressure: 2.07 bar
                    Pressure: 3.05 bar
   Coding: 0028204
                    Fault Frequency: 0
                    Reset counter: 161
                    Mileage: 272928 km
                    Date: 2020.04.25
                    Time: 19:53:12
                    Reset counter: 163
                    Mileage: 272928 km
                    Date: 2020.04.25
                    Time: 19:53:22
   Coding: 0001208
   Coding: 0010900
End----------(Elapsed Time: 03:22, VBatt start/end: 14.2V/14.1V)-----------
Econ off :
Tuesday,09,June,2020,10:46:30:64823
10:46:06 Group 001
  0.745 A  Current
  82.5 %  Load
  22.5 %  Load
  6.0 bar  Absolute Pres.
10:46:06 Group 002
  0.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
10:46:06 Group 003
  198.0  (no units)
  202.0  (no units)
  67.0  (no units)
  197.0  (no units)
Econ On :
Tuesday,09,June,2020,10:47:07:64823
10:46:42 Group 001
  0.000 A  Current
  0.0 %  Load
  21.5 %  Load
10:46:42 Group 002
  7.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
10:46:42 Group 003
  198.0  (no units)
  202.0  (no units)
  67.0  (no units)
  197.0  (no units)
Value 11 and 12 Econ off :
Tuesday,09,June,2020,10:56:23:64823
10:55:56 Group 011
81.0 (no units)
76.0 (no units)
81.0 (no units)
183.0 (no units)
10:55:56 Group 012
202.0 (no units)
207.0 (no units)
56.0 (no units)
202.0 (no units)
10:55:56 Group 002
0.0 (no units)
11.0 (no units)
12.0 (no units)
11.0 (no units)
Jef
HQ
  • Have you let the engine idle for +20 minutes with the A/C on?
  • What are your pressure gauges showing for low and high?
  • Where are you buying parts from?
MartinsX
Riga, Latvia
C?ID=268515
What about readings of several internal T sensors? And ambient T sensor?
Easiest way is to make a MVB maps from engine (0x01) and Climate Control (0x08) and post it here. It's preferred to make reference maps when car is not touched/started for at least 8 hours.
jgrijalva1
C?ID=366192
When I say 4 compressors I meant the one the vehicle had , another I picked up at my local u pull yard . The other about through a company in FL which I returned because pulley was smaller and more grooves and I ordered another through Stockwise Auto . Yes I have left vehicle idle for more than 20 minutes cycling Econ mode couple times . My High and low pressure both show 115psi on both and when I turn on econ mode it just goes down maybe 5lbs of psi on both . ..Those are the 2 temp I took I hope I did get them right . .... I also replaced the outside ambient sensor with a spare I had and didnt seem to see any change .. Hope this helps and in advance thank you everybody for your help .
Tuesday,09,June,2020,22:09:51:64823
22:09:12 Group 001
  0.745 A  Current
  90.0 %  Load
  26.5 %  Load
  7.6 bar  Absolute Pres.
22:09:12 Group 002
  0.0  (no units)
  11.0  (no units)
  12.0  (no units)
  11.0  (no units)
22:09:12 Group 008
  17.0  (no units)
  12.0  (no units)
  17.0  (no units)
  236.0  (no units)
Tuesday,09,June,2020,22:11:17:64823
                Address 01: Engine  (4E0 910 560 J)
22:10:57 Group 001: General
  640 /min  Engine Speed (G28)
  95.0°C  Coolant Temperature (G62)
  1.6 %  Lambda Control Bank 1
  -3.1 %  Lambda Control Bank 2
I like what X says but I'll add....:rolleyes:
Is ambient temp in cluster for MFA reporting right too because if not you are going no where!
jgrijalva1
C?ID=366192
Yes, it is its reporting correctly ..
Just to add when I do the output test everything works and shows ok , fans run and ac valve runs
