Hello all and thank you before hand for any help; much appreciated.
Son has a GTI, 2008 with the dual clutch transmission. It stalled and the flashing PRNDS thing happened.
Took it to a shop and they told my son it needs a new transmission.
I've come to this place for great help in the past; perhaps not as a registered user but it did help me fix my old 1.8T Golf.
I have an eBay scanner and I borrowed from a friend a VCDS so I could save the report on the vehicle.
I changed the Mechatronic and programming was the same. Before swapping the unit, I tested all solenoids; they were all good on both units, according to a multi-meter readings. I thought the issue with the original was internal electronics and I didn't want to mess with it so I placed back the replacement unit into the DSG. New oil and filter went in and assembled everything back. This is where I learned the GTI does not have a traditional hydraulic power steering, I missed to fasten a ground cable and steering was really hard plus the light on the dashboard; fixed that issue quickly.
I did the testing indicated while the car was with the engine running and my foot on the brake pedal. went to the trans tolerance 061 then 060. Then trying the 062 Clutch adaptation, it would not do anything and report an error; it suggested to take the car for a drive so I did but then again, after 1st gear going into 2nd, PRNDS flashes, loose engagement of the transmission's gear/s and car won't move. Restart the engine and engage 1st and went around the block to bring the car back into the garage.
Second suggestion was a worn clutch so I ordered the full assembly from ECS and had a mechanic swap it. When he was done, he took it for a test drive and said it was good but at the moment of picking up the car and going for a drive to test it, same issue. 19143, 17115, 19143
Since the mechanic could not figure the problem, I took the car home.
Next thing, according to the VCDS scan, is to check the Output Shaft Speed Sensor 1/2 (G501 G502)
I cannot find any info on a part number nor the location of it so I can pull it out and grab the part number.
The full scan shows other issues such as aftermarket LED fog lights, which work but the computer reports as being out.
Please, I just need to have the car back running again.
Thanks in advance!!
Thanks in advance!!
Sunday,12,April,2020,17:07:10:59058
VCDS Version: 20.4.0.1 (x64) HEX-NET CB: 0.4508.4
VIN: License Plate: 7RLP094
Mileage: 192730km-119756mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWFV71K78W188819 Mileage: 192730km-119756miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0GN3NL84A
Coding: 0403010A1C070160
Shop #: WSC 01279 785 00200
VCID: 3620E1CC41A1CF36E8-8062
Readiness: 0010 0101
Part No SW: 02E 300 043 F HW: 02E 927 770 AE
Component: GSG DSG 070 1157
Revision: 04507000 Serial number: 00000607111057
Shop #: WSC 44551 111 44551
VCID: 177E0C48266B163ED3-8042
19143 - Unexpected / Implausible Mechanical Gear Disengagement
P2711 - 004 - - Intermittent
Fault Frequency: 255
Reset counter: 40
Mileage: 192739 km
P2711 - 005 - - Intermittent
Fault Status: 00100101
Reset counter: 40
Mileage: 192739 km
Revision: 00H11001
Coding: 0021122
VCID: 73A618D812539A1E0F-8026
Part No SW: 1K0 820 047 HJ HW: 1K0 820 047 HJ
Component: Climatic PQ35 141 1010
Revision: 00141028 Serial number: 00000000000000
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Revision: 00H54000 Serial number: 00000007836535
Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
Shop #: WSC 23320 444 57348
VCID: 71AA12D0684FA80EFD-8024
Component: Wischer 231107 021 0501
Coding: 00038805
Shop #: WSC 23320
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 21
Mileage: 192738 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.80 V
Reset counter: 21
Mileage: 192738 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.80 V
Revision: 00000000 Serial number: AUZ4Z7G0202537
Coding: 0000000
VCID: 3326D8D852D3DA1ECF-8066
Reset counter: 20
Mileage: 192738 km
Time: 16:12:58
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0A0V0V
Coding: 0013899
Shop #: WSC 01269 785 00200
VCID: 6C9403A44F6D45E6CE-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME2A3534749
Subsystem 3 - Serial number: 6342MSME2B6161368
Subsystem 4 - Serial number: 6352QSME45193559I
Subsystem 5 - Serial number: 6362QSME4572503BF
Subsystem 6 - Serial number: 63727SME1210264FY
Subsystem 7 - Serial number: 63827SME122B137D1
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 051 0100
Coding: 0012122
VCID: 78BC2FF40B35F9463A-802C
Component: E0221 002 0010
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
Part No SW: 1K6 920 974 A HW: 1K6 920 974 A
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0GN3NL84A
Coding: 0007203
Shop #: WSC 23320 067 57207
VCID: 3228DDDCADC9D316C4-8066
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 121107F2000576
Coding: ED811F070013020000
VCID: 302CD7D4A3C5E106B2-8064
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T29SB03
VCID: 7DB23EE02417DC6E69-8028
Component: IMMO VDD 1216
Component: Tuer-SG 006 1207
Coding: 0001077
VCID: 383CEFF44BB53946FA-806C
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Shop #: WSC 00000 028 00001
VCID: 3522E6C05CA7C42EE1-8060
00003 - Control Module
Coding: 139006885103281B0904058FB0080A04889C00
Shop #: WSC 00000 785 00200
VCID: 04444B0447FDADA626-8050
Coding: 0001076
VCID: 393AEAF070BF204E05-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74A41BC4175D9D2616-8020
Component: Radio PM6 019 0035
Revision: 00019000 Serial number: VWZ5Z7G2191537
Coding: 0040401
VCID: 291A3AB0801F90CE75-807C
Component: RDK 0450
Coding: 0100101
End----------(Elapsed Time: 01:14, VBatt start/end: 13.9V/13.8V)-----------
Control Module Part Number: 02E 300 043 F HW: 02E 927 770 AE
Component and/or Version: GSG DSG 070 1157
Software Coding: 0000020
Work Shop Code: WSC 44551 111 44551
Reset counter: 40
Mileage: 192739 km
Reset counter: 40
Mileage: 192739 km
Address 02,02E 300 043 F,recoded (Short coding),from,0000020,to,0000020,(44551/111/44551),
VCID: 177E0C48366B163ED3-8042
Advanced Identification
Identification: TFK-030
Revision: 04507000
Date: 11.07.06
Test stand number: 8501
Manufacturer number: 1057
Flash Status
Programming Attempts: 2
Successful Attempts: 2
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 147676 000 02069
Flash Date: 00.00.00
Software
0007
Misc.
Hardware number: 02E 927 770 AE
Lot Number: C30
Type Lock: 0001
VCDS Info:
Address 09: DTCs cleared
Address 16: DTCs cleared
VCDS Release 20.4.0: SRI Reset
Control Module Part Number: 1K6 920 974 A Labels: 1K0-920-xxx-17.lbl
Component:KOMBIINSTRUMENT VDD 1216, Coding:0007203
Channel Description Unit Current val. New val.
02 Service Reminder Status 0 ---
40 Distance since Service miles x100 0 ---
41 Time since Service Days 1 ---
42 Minimum Distance to Service --- --- ---
43 Maximum Distance to Service --- --- ---
44 Maximum Time to Service --- --- ---
45 Oil Quality 1 ---
47 Soot Quantity km x100 0 ---
48 Thermal Load km x100 3 ---
49 Minimum Time to Service --- --- ---
50 Basic Distance Value for Oil Change miles x100 75 ---
51 Basic Time Value for Oil Change Days 180 ---
Address 0F: DTCs cleared
