Results 1 to 10 of 13
Thread: VW Transporter 2007 2.5tdi bpc
    May 2018
    Australia
    Using vcds and trying to test turbo....software freezing up everytime i hit turbo button.any idea why?
    Near Philadelphia, PA, USA
    Quote Originally Posted by Gapel3 View Post
    As you are not a new poster here on our forum, what might we need to help you? That's right... every time we go to work on a different vehicle, those on the forum willing to help need a point of reference. An Autoscan please.
  3. Likes PetrolDave, Uwe, NZDubNurd liked this post
    The [Turbo] button does not test the turbo.
    The [Turbo] button is there to speed up sample rates using various techniques that are not 100% kosher and may not work on every control module.
  5. Likes dnoermann, NZDubNurd liked this post
  6. #4
    May 2018
    Australia
    thx uwe.....can i change value of egr flow between air mass sensor?i cannot see egr valve adaptation in it.should have it if is equipped isnt it?
    Do we have an Auto-Scan from this vehicle somewhere? Because without seeing exactly what ECU it has, I can't even begin to check what functionality said ECU supports.
    May 2018
    Australia
    TRANSPORTER
    Thursday,14,May,2020,16:11:38:39620
    VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
    VIN: WV1ZZZ7HZ8H047706   License Plate: HAKK
    Mileage: 285180km-177202mi   Repair Order:
    Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
    Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
              57 6E 76 77 78 7D
    VIN: WV1ZZZ7HZ8H047706   Mileage: 285180km-177202miles
    Address 01: Engine        Labels: 070-906-016-BPC.clb
       Part No SW: 070 906 016 DQ    HW: 070 906 016 DQ
       Component: R5 2,5L EDC G000SG  1583
       Revision: --H05---    Serial number: VWZ7Z0G5746272
       Coding: 0051172
       Shop #: WSC 02736 790 00000
       VCID: E288F0DD3CD5F596FD-5160
    008214 - Intake Manifold Flap Position Sensor (Bank 1)
                   P2016 - 000 - Short to Ground - Intermittent
                        Mileage: 285183 km
                        RPM: 777 /min
                        Voltage: 14.44 V
                        Duty Cycle: 100.2 %
                        Lambda: 0.0 %
                        Lambda: -0.2 %
                        (no units): 4.0
    Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP.lbl
       Part No SW: 7H0 907 379 R    HW: 7H0 907 379 R
       Component: ESP MK25E1          0104
       Revision: 00H31001
       Coding: 0001634
       VCID: C4C4164586019BA6EF-5118
    Address 08: Auto HVAC        Labels: Redir Fail!
       Part No: 7H0 820 045 R
       Component: CLIMA/AC            0202
       VCID: B4244685D6A12B265F-5118
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
       Part No: 7H0 937 049 AD
       Component: BORDNETZ SGVER 1.0  2101
       Coding: 0000101
       VCID: F4A4868596216B269F-5118
    00968 - Right Turn Signals
       Part No: 1C0 909 605 F
       Component: 0T AIRBAG VW61 0R   0004
       Coding: 12372
       Shop #: WSC 02736
       VCID: A71EA1C9477750BEEA-5118
    Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
       Part No: 7H0 920 851 R
       Component: KOMBI+WEGFAHRSP VDO V02
       Coding: 00722
       Shop #: WSC 00001
       VCID: BA3868BDA4C5DD5685-5118
       WV1ZZZ7HZ8H047706     VWZ7Z0G5746272
                30-00 - Open or Short to Plus
       Part No: 6N0 909 901
       Coding: 00022
       Shop #: WSC 02736
       VCID: F0AC8A95B23957067B-5118
    Address 22: AWD        Labels: 7H0-907-554.clb
       Part No: 7H0 907 554 F
       Component: HALDEX 4Motion      2110
       VCID: B3264599D3AF2C1E46-5118
    Address 46: Central Conv.        Labels: 7H0-959-433.lbl
       Part No: 7H0 959 433 B
       Component: C11 KomfortgerŠt     0004
       Coding: 00031
       Shop #: WSC 02736
       VCID: B228409D7CB525164D-4B00
    Address 76: Park Assist        Labels: 7H0-919-283.lbl
       Part No: 7H0 919 283
       Component: Parkingsyst. T5 T5N 401
       Coding: 00137
       Shop #: WSC 02736
       VCID: EFAE89E9AF0748FE62-513C
                37-00 - Faulty
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
    End----------(Elapsed Time: 05:56, VBatt start/end: 14.3V/14.3V)-----------
    Address 01: DTCs cleared
  9. Likes Uwe liked this post
  10. #7
    EGR valve "adaptation" is done in Basic Settings, Group 003 on this engine.
    ; Ignition ON, Engine ON (Idling)
    ; Activate Basic Setting
    ; Press and Hold both Brake Pedal and Gas Pedal
    ; Exhaust Gas Recirculation (EGR) is alternately switched on and off
    ; The Deviation between "EGR ON" and "EGR OFF" must at least be 100.0 mg/Str.
  11. #8
    May 2018
    Australia
    Yes done it but doesnt seems to be doing as explained.....just wondering what should be right value for injector on idle and deviation on idle too?
    I got one code which is terminal 30. not sure if tat can cause power lost.
    Tuesday,19,May,2020,14:46:43:39620
    VIN: WV1ZZZ7HZ8H047706   License Plate: HAKO
    Mileage: 285220km-177227mi   Repair Order:
              57 6E 76 77 78 7D
    VIN: WV1ZZZ7HZ8H047706   Mileage: 285220km-177227miles
       Coding: 0051172
       VCID: E288F0DD3CD5F596FD-513C
       Revision: 00H31001
       Coding: 0001634
                        Reset counter: 38
                        Mileage: 285189 km
                        Count: 128
                        Count: 6401
                        Count: 128
                        Count: 255
       Coding: 0000101
                014 - Defective
       Coding: 12372
       Shop #: WSC 02736
       Coding: 00722
       Shop #: WSC 00001
       Coding: 00022
       Shop #: WSC 02736
       Coding: 00031
       Shop #: WSC 02736
       Coding: 00137
       Shop #: WSC 02736
                37-00 - Faulty
    End----(Elapsed Time: 06:05, VBatt start/end: 12.1V/11.9V. VIgn 11.9V)-----
    Address 03: DTCs cleared
    Address 08: DTCs cleared
    Address 09: DTCs cleared
    Address 15: DTCs cleared
    Address 17: DTCs cleared
    Address 19: DTCs cleared
    Address 22: DTCs cleared
    Address 46: DTCs cleared
    Address 76: DTCs cleared
  12. #9
    May 2018
    Australia
    VW TRANSPORTER 2008 T5 2.5TDI
    no power oil level reses,good start ,no power under load gutless
  13. #10
    May 2018
    Australia
    uwe...also what i relised is after engine is runing get egr read 475mg/str duty cycle 0.0%...rev up bit and is back to 275 mg/str and aroun 21.4% duty cycle
