DTCs not clearing
technodevotee
Worcester, UK
C?ID=339141
Hi.
I have spent a long time searching the forum for an answer to my question but can't find one. There is a lot of stuff on here though please excuse me if I missed it.
I've got a few DTCs that appear on all my scans and I've tried clearing them but they don't go away.
I read that clear all DTCs doesn't always work so I selected the modules in question and tried that way but they still don't clear.
I noticed that some of the modules don't have label files and wondered if that is connected.
On the day the DTCs were logged the battery was very low and I suspect that was what caused them. The car has been fine since giving the battery a good long charge so I'm not really worried about them but I would rather they weren't there on every scan.
Latest autoscan:
Wednesday,06,May,2020,08:52:17:52412
VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4523.4
VIN: WVGZZZCRZLD003566   License Plate:
Mileage: 6723   Repair Order:
Chassis Type: CR-VW53 (4N2)
Scan: 01 02 03 06 09 13 15 16 17 19 2B 36 42 44 46 52 5F 69 6C 6D
          74 81 A5 AC BB BC CB D6 D7 DE
VIN: WVGZZZCRZLD003566   Mileage: 10820km-6723miles
CB-Rear Axle Steering -- Status: OK 0000
DE-Charger 1 for mobile dev -- Status: OK 0000
Address 01: Engine (J623-DENA)       Labels: None
   Part No SW: 760 907 401 G    HW: 059 907 309 L
   Component: 3.0l V6 TDI   H26 0002
   Revision: CAH26---
   Coding: 292A4032057E050335180000000400000000000000000000
   Shop #: WSC 31414 039 00001
   ASAM Dataset: EV_ECM30TDI011760907401G 001002
   ROD: EV_ECM30TDI011760907401G.rod
   VCID: 197A3B6B18550E4EE5-804C
Address 02: Auto Trans (J217)       Labels:* Redir Fail!
   Part No SW: 760 927 158 B    HW: 0D5 927 156 N
   Component: 0D5  30TDIRdW H05 1003
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002014
   ROD: EV_TCMALX52011_VW53.rod
   VCID: 1F0E15730671607E1B-804A
   Part No SW: 4M6 907 379 AC    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0856
   Coding: 1DA732B730A20B99DEA34897188356EAE93AE1B84C0CD07B12186A57975C87
   ASAM Dataset: EV_ESP9BOSCHCMP 004011
   ROD: EV_ESP9BOSCHCMP_VW53.rod
   VCID: 7EB008F7E13BC97670-802A
200960 - Databus
          [Signal_LWR_Hoehenwert_VL_error_(255)]
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0044
   Serial number: 00000384427733
   Coding: 0138B8000000A88188000101210100008900000707008F8F00000000015000
   Shop #: WSC 31414 043 00001
   ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
   VCID: 3D32CFFBACBD126E29-8068
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ8001250619402580D7
   Coding: BF2F00
   Part No SW: 4N0 907 063 KG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0691
   Coding: 07501143E1790009070D97085BBE8C40000B30100000009301100800FB2476011BC500BB12B6C6170000010000D128181800000044010104000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: 7DB20FFBEC3DD26E69-8028
   Subsystem 1 - Part No SW: 762 955 113     HW: 762 955 113
   Component: WIPER 250719  011 0420
   Serial number: VZ1SKA 1000917250719
   Serial number: 23357623X81A955555A0
   Coding: 02006D
   Light switch:
   Subsystem 3 - Part No SW: 762 941 633     HW: 762 941 633
   Component: E1 - LTM  H06 0054
   Serial number: 13S27.06.1900140204
   Subsystem 4 - Part No SW: 3G0 857 511 AL    HW: 3G0 857 511 AL
   Serial number: GX1CE130041920810040
   Coding: 030000
   Interior Light Module:
   Subsystem 5 - Part No SW: 760 947 105 N    HW: 760 947 105 N
   Component: Dachelektroni  H32 0057
   Serial number: 00000774360000000000
405507 - Functional Limitation due to Energy Management
          B10CD 00 [008] - -
          [Function limitation due to energy management system]
                    Reset counter: 223
                    Mileage: 10801 km
                    Date: 2020.03.27
                    Time: 12:01:12
                    average_Voltage_terminals: 11.40 V
                    Outside air temperature sensor-Resistance: 0.00 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 8.50 °C
                    interior_temperature: 15.50 °C
                    Vehicle speed: 0.00 km/h
   Part No SW: 760 907 561 C    HW: 760 907 561
   Component: LRR4R         H04 0333
   Coding: 32657FCB78000400000020A000000010051246484401009E00
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_VW53.rod
   VCID: 1C74227F17677B66FE-8048
   Part No SW: 4M0 959 655 J    HW: 4M0 959 655 J
   Component: AirbagVW31    H07 2720
   Serial number: 003YQM020RRC
   Coding: 88CCC0C00C800000585400EF308D41A80065
   Shop #: WSC 31414 030 00001
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 42C8BC07D5436D9654-8016
   Subsystem 1 - Part No SW: -----------    HW: 480 002 207 19
   Serial number: 357000000004BC819E3Y
   Subsystem 2 - Part No SW: -----------    HW: 480 002 207 19
   Serial number: 35800000000D0B152E3M
   Subsystem 3 - Part No SW: -----------    HW: 480 032 507 19
   Component: SideSensor_Dr  002 0149
   Serial number: 351001C24B8AC8C07B0L
   Subsystem 4 - Part No SW: -----------    HW: 480 032 507 19
   Component: SideSensor_Pr  002 0149
   Serial number: 352001C1CC740CA03B1A
   Subsystem 5 - Part No SW: -----------    HW: 480 030 606 19
   Component: FrontSensor_D  002 0189
   Serial number: 355001C20FF2EDF0CB95
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 030 606 19
   Component: FrontSensor_P  002 0189
   Serial number: 356001C20FF326A07ABM
   Pedestrian Protection Driver:
   Subsystem 7 - Part No SW: -----------    HW: 480 032 606 19
   Component: PedP_Sensor_D  002 014A
   Serial number: 228001C208FD7590192A
   Subsystem 8 - Part No SW: -----------    HW: 480 031 807 19
   Component: PedP_Sensor_P  002 014A
   Serial number: 229001C2462C0020BC90
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 480 032 506 19
   Component: PedP_Sensor_C  002 014A
   Serial number: 230001C208F57E711D6B
   Subsystem 10 - Part No SW: -----------    HW: 480 001 406 19
   Serial number: I0M00000000B1438CCBG
   Subsystem 11 - Part No SW: -----------    HW: 480 001 406 19
   Serial number: I0N00000000E1438CCBK
   Part No SW: 760 953 507 B    HW: 760 953 507 B
   Component: Lenks.Modul   H03 0006
   ROD: EV_SMLSKLOAU736_VW53.rod
   Part No SW: 762 920 790 A    HW: 762 920 790 A
   Component: FBenRDW       H12 0208
   Coding: A5A631E27F94260001A86322B0E06808E40000A0
   ASAM Dataset: EV_DashBoardAU65X 001017
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 1B76216312697C5EF7-804E
   Operating Unit Drive Mode Selection:
   Subsystem 1 - Part No SW: 760 927 531 G    HW: 760 927 531 G
   Component: E881 BedieFPA  001 0460
   Serial number: 000000091171SG3000M1
   Level control system control head:
   Subsystem 2 - Part No SW: 760 927 135 B    HW: 760 927 135 B
   Component: E281 BedieNiv  001 0110
   Serial number: 000000091171SG3001CH
   Part No SW: 4N2 907 468 BB    HW: 4N2 907 468 AB
   Component: Gateway       H16 0052
   Revision: BD000001    Serial number: 018BD855619725
   Coding: 0301000300008E407F07000000DB0532589E00070C000000037D078E10000100
   ASAM Dataset: EV_CGateCONTIAU491 004190
   ROD: EV_CGateCONTIAU491_004_VW53.rod
   VCID: 7AB804E7FD13E5564C-802E
   Subsystem 1 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H18 0052
   Serial number: 39190001239260049243
   Coding: 2FFFFF
   Serial number: 7379992105
8519683 - Energy Management Active
          U140B 00 [008] - -
                    Reset counter: 223
                    Mileage: 10801 km
                    Date: 2020.03.27
                    Time: 12:01:03
                    EM_vehicle_state: 00 10
                    Static current shutdown level: Deactivation stage 1
                    Auxiliary heater activation restriction request-Parking heater: Permitted
                    Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 19000192483014
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: 3424EADF9FF7D326D6-8060
   Component: MEM-FS        009 0044
   Serial number: 00000384338324
   Coding: 01389A400000A48188000101210100008900000707008F8F00000000015000
   ROD: EV_SCMDriveSideCONTIAU736_VW53.rod
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ8001250619402580CF
   Coding: BF2F00
   Part No SW: 4M1 959 593 J    HW: 4M1 959 593 D
   Component: TSG FS002 0421
   Serial number: YE007SFF28625
   Coding: 003F9A00DE01040000013082
   ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   VCID: 44C4BA1FCF5763A666-8010
   Part No SW: 4N0 909 144 E    HW: 4N0 909 144 C
   Component: EPS_MLBEVO2BS H22 0505
   Coding: B2150101000100
   ASAM Dataset: EV_EPSVWBSAU426 010017
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 3228ECC765E3DD16C4-8066
   Part No SW: 4N0 907 064 DP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H15 0202
   Coding: 01350000AFB000487329A0041C00480203000000004704502F0400000508803F001F31C4010001
   ASAM Dataset: EV_BCM2CONTIAU651 010009
   ROD: EV_BCM2CONTIAU651_010_VW53.rod
   VCID: 004C760F9BCFBF8602-8054
   Ignition key:
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY1916516JJ
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000487902
   Rear Spoiler Adjustment:
   Part No SW: 4M1 959 592 J    HW: 4M1 959 592 D
   Component: TSG BFS002 0421
   Serial number: YE007SFF3060B
   Coding: 003F9A00DE01040000013080
   ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   VCID: 43C6B903CA59649E5F-8016
   Part No SW: 760 035 063 A    HW: 760 035 063 A
   Component: MU-H-LND-EU   049 2648
   Coding: 02350601FF00000043110101C08808301F0206E601A004009F
   Shop #: WSC 31414 152 00001
   ASAM Dataset: EV_MUHigGen2pALPI 001001
   ROD: EV_MUHigGen2pALPI_VW53.rod
   VCID: 0F6E4533D691D0FE8B-805A
   Subsystem 1 - Part No SW: 762 919 618     HW: 762 919 618
   Component: ABT_Prem_R  H40 5211
   Serial number: VWZ6ZGW1710136
   Subsystem 2 - Part No: V03 959 805 HG
   Component: MIB2P_EU_Q119  0360
   Subsystem 3 - Part No: V03 959 800 EG
   Component: Gracenote2  1010
   Volume Control 1:
   Subsystem 4 - Part No SW: 762 927 341     HW: 762 927 341
   Component: VW536LLB  H06 0109
   Serial number: 2019050600000182
   Media socket:
   Subsystem 5 - Part No SW: 5G0 035 953 D    HW: 0
H08 0014
   Part No SW: 4M0 907 383 G    HW: 4M0 907 383 B
   Component: Anhaenger     H33 0273
   Revision: 9A001003    Serial number: 0522821047
   Coding: 0110000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 3620D0D7898BC136E8-8062
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 760 980 568     HW: 760 980 568
   Component: RVC Compact+  H09 0250
   Coding: 0135060123002015000048
   ASAM Dataset: EV_CamSysRVRVCARPANAMLBEv 001001
   ROD: EV_CamSysRVRVCARPANAMLBEv.rod
   VCID: 618A538B7085168E6D-8034
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C737-6252-4
   Coding: 17D8
   ROD: EV_DeckLidCONTIAU736_VW27.rod
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M0 907 777 S    HW: 4M0 907 777 B
   Component: Fahrwerk-SG   H37 1253
   Serial number: 0807190824
   Coding: B0504940F8
   ASAM Dataset: EV_ChassContrContiAU426 001004
   ROD: EV_ChassContrContiAU426.rod
   VCID: 49DAAB2BE875BECE95-801C
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130657889
   Coding: 303030
   Part No SW: 762 713 041 B    HW: 4M2 713 041 G
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 19061753171127
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 116A434BC0A5C60E9D-8044
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AL    HW: 4N0 907 107 G
   Component: zFAS Var B    H09 0293
   Coding: 04C2840000000000000806000090C63C18075300000000000000000000000000000000000000000000000000000000000000000000000000000040000000000000001004000000700000004000000000008040000020
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 095A6B2BA8F5FECE55-805C
2117691 - Ethernet Databus
          U11C4 00 [008] - No Communications
          [Databus_Ethernet_no_communication]
                    Reset counter: 223
                    Mileage: 10801 km
                    Date: 2020.03.28
                    Time: 16:44:31
                    Ethernet signal quality: no link
2117692 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
          [Databus_Ethernet_missing_PDU]
                    Reset counter: 223
                    Mileage: 10801 km
                    Date: 2020.03.28
                    Time: 16:44:28
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H05 0006
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736_VW53.rod
   Part No SW: 4M1 959 595 J    HW: 4M1 959 595 D
   Component: TSG HFS004 0421
   Serial number: YE007SFK23657
   Coding: 003E92000000040000013080
   ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
   VCID: 46C0A017F96B51B678-8012
   Component: TSG HBFS004 0421
   Serial number: YE007SFK23656
   ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4M0 909 145 AA    HW: 4M0 909 145 E
   Component: HAL_MLBevoH08 0698
   Revision: --------    Serial number: CCC_098_B_1122_
   Coding: 42250E00
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010.rod
   VCID: 6FAE25B3B651B0FEEB-803A
   Part No SW: 7P5 941 591 BH    HW: 7P5 941 591 B
   Component: LED1L         H07 0009
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
   VCID: 034679038AD9A49E1F-8056
   Component: LED1R         H07 0009
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 400000
   ASAM Dataset: EV_Charg1MobilDevicAU651 004001
   ROD: EV_Charg1MobilDevicAU651.rod
   VCID: 230619832A19449E3F-8076
End----------(Elapsed Time: 02:14, VBatt start/end: 12.3V/12.2V)-----------
TIA
Label files being absent have no effect on the ability to clear DTCs.
The fault in ABS is "Intermittent, Not Confirmed" and the ABS doesn't consider it significant enough to report the Gateway ("03-ABS Brakes -- Status: OK 0000"). This car is new enough that the ABS DTC may only clear via the generic OBD-II clear command. Give that a try please.
The Energy Management faults in 09 and 19 have me puzzled. Those should clear directly on the respective modules.
Ditto for the Ethernet fault in A5.
Do you get any sort of error message when you do try to clear those directly in the respective modules?
Do you have the hood open when you are clearing them? If not, please try doing it with the hood open.
technodevotee
Worcester, UK
C?ID=339141
Thanks @Uwe, I'll give that a try as soon as my back is better (overdid it in the garden a couple of days ago).
I hope you and your (very) extended family are OK there.
