I have a Seat Alhambra 2019 that has 19,000 miles on the clock. I was looking to alter the settings on the power fold mirrors for them to operate on locking and starting the engine but that is another story? However, before doing anything, I ran a full Auto Scan as attached. As something of a surprise it showed up 2 faults,
1) 0852 Indicator Lamp in Auto Hold Switch, C1156 14 [008] Open or Short to Ground
2) 03789 Terminal 75 Limp Mode Active, 000 Intermittent
I have not been aware of any issues with the vehicle since I got it new, no MIL on or problems with driving the car.
I have not, as yet, cleared the faults off to see if they return as the vehicle is still under warranty and is about due for it's first service & inspection so will leave them to see what the dealer has to say? But, in the mean time, wondered if anybody had any ideas as to the possible causes?
Also showing up on the scan was;
Address 4C Tire Pressure II, Cannot Be Reached (This may be because it does not have a Tire Monitoring System but relies on the ABS / Speed Sensor to detect any differences in the Tire Pressures?
Address 53 Parking Brake, Cannot Be Reached, which is a bit of a concern given it is an Electronic Parking Brake with Hill Hold?
Checked for previous posts but they do seem wide and varied? As for the mirror issue think I have found the security code to access the system to alter the current settings or a method which is valid for an Audi in altering the Long Coding but will leave that for another day.
Sunday,10,May,2020,14:40:31:08428
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
VIN: VSSZZZ7NZLV502802 License Plate: K80EXC
Mileage: 30580km-19001mi Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 03 08 09 10 13 15 16 17 18 19 25 36 3C 42 44 46 4C 52 53
5F 61 62 69 6C 6D 72 A5 BE BF
VIN: VSSZZZ7NZLV502802 Mileage: 30580km-19001miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-DLTA) Labels: None
Part No SW: 04L 906 016 PR HW: 04L 907 309 AB
Component: R4 2.0l TDI H20 7034
Revision: 8EH20---
Coding: 0119001A043511082000
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01104L906016PR 004001
ROD: EV_ECM20TDI01104L906016PA_VW36.rod
VCID: 08499FE5B2B1358B1B2-805C
Part No SW: 5N0 614 109 CT HW: 5N0 614 109 CT
Component: ESC-EBC460iV1 H16 0050
Serial number: A020S78
Coding: 11F0449A8920C26E287F880022C59143143117F0F0014094
ASAM Dataset: EV_Brake1ESCEPBTRW 006353
ROD: EV_Brake1ESCEPBTRW_006.rod
VCID: 7F5B0439E77F72332A8-802A
0852 - Indicator Lamp in Auto-Hold Switch
C1156 14 [008] - Open or Short to Ground
Reset counter: 21
Mileage: 28901 km
Date: 2020.03.04
Time: 08:15:21
Additional_Codes: 00 00 00 0E C0 7F 40 48 00
DTC: 00 03 54
Additional2: 04 02 01 0D 1B 00 66 00 66 00
Part No SW: 7N0 907 044 BE HW: 7N0 907 044 BE
Component: Clima-Sharan H04 0707
Revision: 00001K06
Coding: 021000C549
ASAM Dataset: EV_ClimatronicSharan A01724
VCID: 74B1DB15DE39216B47A-8020
Slave 1:
Subsystem 1 - Part No SW: 7N0 907 049 C HW: 7N0 907 049 C
Component: KBT-H 004 0103
Serial number: 20190822000000216536
Part No SW: 5K0 937 086 AC HW: 5K0 937 086 AC
Component: BCM PQ35 M 122 0193
Revision: BC122001
Coding: 40590A3F8925E1C0508800C8B400817403D10008636D2D226480C72000C1
Shop #: WSC 00020 790 00000
VCID: 75B7E611D5C33863704-8020
Subsystem 1 - Part No SW: 7N2 955 119 C HW: 7N2 955 119 C Labels: 1KX-955-119.CLB
Component: WWS428 190708 024 0646
Serial number: 19070303044961
Coding: 004DBD
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: SAY19M08D30H14M46S12
Coding: 0228BB
Subsystem 3 - Part No: 7N0 951 172
Component: Sensor, DWA 0 005 0502
Subsystem 4 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0009
03789 - Terminal 75 Limp Mode Active
Reset counter: 13
Mileage: 29964 km
Date: 2020.03.13
Time: 16:07:00
Voltage: 10.40 V
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39331925901539
Coding: 0071155201
ASAM Dataset: EV_EPHVA18VW364GP00 001007
VCID: 372B2C198FCF8A73A28-8062
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7N0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 2808190438AEC2
Coding: 00000900FE0739
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 3635211D88C5737BB9E-8062
Part No SW: 7N0 959 655 D HW: 7N0 959 655 D
Component: VW10Airbag11B H16 0016
Serial number: 003PWPE237AZ
Coding: 003142
ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 40D947C5DA01CDCB132-8014
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS609104491E9DV
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS609405491EDDV
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60EFA1481EDDA
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS60EEA3481EDDC
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS60ABB94A1E9D0
Part No SW: 5K0 953 521 FP HW: 5K0 953 569 BD
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20181219200573
Coding: 3082240000
ROD: EV_SMLSNGVOLWSR8C.rod
Subsystem 1 - Part No SW: 6JA 919 719 D HW: 6JA 919 719 D
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000G1663130719
Coding: 001000
Part No SW: 7N5 920 980 G HW: 7N5 920 980 G
Component: KOMBI H03 3030
Coding: 410F010800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
VCID: 3D273E31ADF3A023784-8068
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 G
Component: Zuheizer 051 3041
Revision: 00051000 Serial number: 09028242000000
Coding: 0000041
VCID: 38292F258E51850BAB2-806C
Part No SW: 7N0 907 530 BR HW: 7N0 907 530 AN
Component: J533 Gateway H56 1708
Revision: H56 Serial number: 130919F1001396
Coding: 468233
VCID: 015F82C1910B04C35CC-8054
Component: IMMO H03 3030
Coding: 000002
VCID: 6A8DC56D8CFDE79BED6-803E
Address 36: Seat Mem. Drvr (J810) Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 E HW: 3C8 959 760 E
Component: Sitzmemory H06 3101
Revision: 00H06000
Coding: 000018
Shop #: WSC 12336 024 394758
VCID: 372B2C198F4F8A73A28-8062
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0149
Serial number: 00000525665645
Coding: A29544A0
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: 392F2A21B9DB9C0354C-806C
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 J HW: 7N0 959 793 G
Component: TSG FA H05 0561
Revision: Serial number: 0000388592878
Coding: 01112E209E01411001
VCID: 49CF5AE1E9BB0C83C4C-801C
Part No: 7N0 909 144 R
Component: EPS_ZFLS Kl. 275 3501
Revision: 00H21000
VCID: 42DD4DCDD88DDFDB056-8016
Address 4C: Tire Pressure II
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 J HW: 7N0 959 792 G
Component: TSG BF H05 0561
Revision: Serial number: 0000388596756
Coding: 01112C209E01411001
VCID: 48C95FE5F2B1F58BDB2-801C
Address 53: Parking Brake
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 7N5 035 680 E HW: 7N5 035 680 E
Component: MU-S-ND-ER H41 0475
Serial number: SEZAZ2W0415635
Coding: 04240801FF0000000111110100880A001F0103C60020010086
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 3537261195C37863B04-8060
Subsystem 1 - Part No SW: 5F0 060 884 BT HW: -----------
Component: ECE AS 2020 --- 1310
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1708
Coding: 330F7873
VCID: 71BFD201A1AB1443ACC-8024
Subsystem 1 - Part No SW: 1K0 915 181 L HW: 1K0 915 181 L
Component: J367-BDM H07 0270
Serial number: 56249C04165831253126
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
Part No SW: 7N0 959 794 L HW: 7N0 959 794 H
Component: TSG HL H03 0561
Revision: Serial number: 0000388580574
Coding: 01006C200001411001
VCID: 4CC163F5E6C919ABFFA-8018
Address 69: Trailer (J345) Labels:. 7N0-907-383.clb
Part No SW: 7N0 907 383 A HW: 7N0 907 383
Component: Anhaenger H12 0130
Revision: 3I001001 Serial number: 00000527515598
Coding: 410C040003000000
VCID: 34311B159E39616B87A-8060
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 7N0 907 441 B HW: 7N0 907 441 B
Component: VW428 RVC Mid H04 0040
Coding: 012408010301000700
Shop #: WSC 00020 999 39850
ASAM Dataset: EV_CamSysRearPANAVW428 002002
ROD: EV_CamSysRearPANAVW428.rod
VCID: 303917056AA15D4BE32-8064
Address 6D: Trunk Elect. (J605) Labels:| 7N0-959-107.clb
Part No SW: 7N0 959 107 G HW: 7N0 959 107 A
Component: HDSG-Modul H12 0250
Revision: 41012002 Serial number: 245900872
Coding: 0733334003
ASAM Dataset: EV_HDSGVW428 201138
ROD: EV_HDSGVW428_VW36.rod
VCID: 3B233029B3E7AE13460-806E
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
Component: TSG HR H03 0561
Revision: Serial number: 0000388572988
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 Q HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0881
Serial number: 26081912K13983
Coding: 0304020800000401000613078080400090000E00002000
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002.rod
VCID: 45D756D1C523E8E3204-8010
Address BE: Slid. Door Rear Left (J558) Labels: 7N0-959-244.clb
Part No SW: 7N0 959 244 B HW: 7N0 959 244 B
Component: Schiebetuer_l 005 2414
Serial number: 19351211
ASAM Dataset: EV_AST A03704
ROD: EV_AST.rod
VCID: 38292F2582D1850BAB2-806C
Address BF: Slid. Door Rear Right (J731) Labels: 7N0-959-244.clb
Component: Schiebetuer_r 005 2414
Serial number: 19351233
ROD: EV_AST.rod
End----------(Elapsed Time: 01:54, VBatt start/end: 12.1V/12.1V)-----------
