Results 11 to 20 of 28
Thread: HEX-NET Introductory Videos
    I have been playing with the different options for connecting the device directly or to the router.
    I have found that for me the best and reliable connection and with the best range is to using the device directly (Ad-Hoc as it's called?) I have an excellent range without dropping out and managed to connect to a vehicle from 30 metres (only for experimental purposes)
    However, using infrastructure mode, for me it's a waste of time, very unreliable, so until I fix the issue, Direct connection is the only way. Without doubt, I reckon it's an issue with my router. so when I get the issue fixed, I'll report back in the hope it'll help others.
    Or does anyone know of any particular router settings I should use?
    Yesterday I even tried relocating my router from inside the office, to outside of the office to the workshop on a bracket on the wall, it made no difference.
    Am I correct in saying that infrastructure mode Should be better than Direct connection? Or maybe I just go and buy a better router, we'll see.
  2. #12
    Could also be power savings on your laptop. Typically we see them affect AP (ad-hoc) in a worse way, but that just shows they behave differently in those two modes. Try setting your wifi adapter for "maximum performance" or anything similar you can find, and also turn off "let Windows put this device to sleep to save power" (or similar).
  3. #13
    My Laptops are always set for maximum performance, but the main issue is while I'm using my Desktop. My Desktop doesn't have a Wireless card, this Desktop is connected directly to the router, so tried using the device in Infrastructure mode so I can use VCDS on the Desktop. Hope this makes sense. So to enable me to use the Desktop, I have to connect a D-link USB connector and connect the device using Direct access.
  4. #14
    Yep that makes sense. I use a similar setup here at home (wired desktop) and I actually ran CAT6 and a third WiFi router to my garage for this purpose last week. Even without the third router, scans in infrastructure mode were slow but reliable, as long as I left the car door open.
  5. #15
    For sure my router has the issue, because in infrastructure mode, I use VCDS in my office and the car is just outside office in workshop, only 3 metres away. But I have the poor connection in this mode. I'll try changing some settings in the router after I researched what are the best setting for my router, and go from there.
    In the meantime time, I just connect a D-Link WiFi to my Desktop and everything is perfect when connecting using Ad-Hoc direct mode.
  6. #16
    update
    I contacted my service provider who supplied my router and advised what settings to change and try.
    I logged in to the router and simply changed the channel from Automatic to channel 1, I tested this and so far it's made a massive difference and at the moment it works fine in infrastructure mode.
    Hope this helps anyone else who has the same issue.
  7. Likes Uwe, Eric, Boki Ar liked this post
  8. #17
    If you have an Android device, this app can be quite useful:
    https://play.google.com/store/apps/d...analyzer&hl=en
  9. Likes Gary, Boki Ar liked this post
  10. #18
    Thanks for that Uwe, I'll install it on my Samsung phone and try it out if I get any further issues.
  11. Likes Boki Ar, Uwe liked this post
  12. #19
    Verified VCDS User romad's Avatar
    Oroville, California People's Republic
    And there are several similar iOS apps on the iTunes Store for iDevice users.
  13. Likes Boki Ar liked this post
  14. #20
    Quote Originally Posted by romad View Post
    Cool. Are there any in particular that you'd recommend?
