Passat B8 enable Android Auto?
george13
C?ID=400380
Hi all, new to the forum, VCDS and VW. I have a decent background of retrofits on Fords (focus & fiesta) and realised I couldn't stay away from mods on my new (used) Passat...
I started by adding Passenger Mirror Down on Reverse with the instructions found here and I'm currently looking into Android Auto in more detail.
I've read it can be done by the dealer as my car already has the car-net option on the screen. I think I saw some companies that can help with that, but I'm hoping it's now also available from VCDS? I'm currently struggling with the various terminologies, and have not seen a recent post around this, so decided to start a new thread.
Here's my Auto Scan
Friday,08,May,2020,10:47:54:24548
VIN: WVWZZZ3CZGE026196   License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
VIN: WVWZZZ3CZGE026196   Mileage: 139765km-86845miles
Address 01: Engine (J623-DCXA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 GK    HW: 04L 907 309 R
   Component: R4 1,6L EDC   H21 1369
   Revision: B5H21---
   Coding: 0125001203651D093000
   Shop #: WSC 05311 115 00310
   ASAM Dataset: EV_ECM16TDI01104L906026GK 002001
   ROD: EV_ECM16TDI01104L906026GJ_VW48.rod
   VCID: 79AFEB3CE95CAC83145-802C
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [040] - -
                    Mileage: 139497 km
                    Date: 2020.04.30
                    Time: 08:53:32
                    Engine speed: 764.00 /min
                    Normed load value: 22.0 %
                    Coolant temperature: 68 °C
                    Intake air temperature: 45 °C
                    Voltage terminal 30: 11.660 V
                    Unlearning counter according OBD: 25
                    Immobilizer snapshot A-Sia Error Snap A: 00 00 00
                    Immobilizer snapshot B-Sia Error Snap B: 00 00 00
   Part No SW: 0CW 300 048 N    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0611
   Revision: 00005005    Serial number: CU501505305308
   Shop #: WSC 05311 115 00094
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 47CB5DC4EF280A73D21-8012
   Revision: 00000000    Serial number: 61565000003099
   Coding: 0FEC928F34220B720778060941C949F0492CD0E0608292F11842F078C202
   Shop #: WSC 00015 115 00001
   ROD: EV_Brake1UDSContiMK100IPB_034.rod
   VCID: 7AADF430EC5AA79B1DF-802E
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0709
   Revision: 00026000    Serial number: 0372006385
   Coding: 000F0F0703
   ASAM Dataset: EV_KessyHellaMQBAB 004032
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 392F2B3CA9DC6C83545-806C
   Part No SW: 5G0 907 426 AF    HW: 5G0 907 426 AF
   Component: AC Manuell    H03 1202
   Revision: 00001K06
   Coding: 12120104202100001000400000000002
   ASAM Dataset: EV_ACManueBHBVW37X 003129
   VCID: 6FBBD564A718F233BA1-803A
   Part No SW: 5Q0 937 086 AH    HW: 5Q0 937 086 AH
   Revision: --------    Serial number: 86582005152183
   Coding: 03011842C2C1027F0FA44094B10407281880000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 005986D88A86FD4B53B-8054
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    150508  043 0607
   Serial number:         150515234400
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y15M06D10H11M01S59
   Coding: 90A8DD
   Light switch:
   Subsystem 3 - Part No SW: 3G0 941 633     HW: 3G0 941 633
   Serial number: 18 04 2015  00000784
   Component: Sensor, DWA  006 0326
   Serial number: 000000000ZY151271H7P
   Serial number: 00000000000062752149
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39391516001196
   Coding: 0071051811
   VCID: 44D14AC8DE1E216B373-8010
   Component: ACC BOSCH MQB H04 0192
   Coding: 3200678251FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001008
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 34311A088EBE91EB873-8060
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Reset counter: 112
                    Mileage: 139421 km
                    Date: 2020.04.27
                    Time: 08:24:40
                    Control Module temperature: 14 °C
                    Voltage terminal 15: 14.4 V
   Part No SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003SSPBBG5CA
   Coding: 98FCC0C0000000005C5400CC008800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7EA5F820F0728BBB217-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  106 1032
   Serial number: 3G2857705E0159P01016
   Coding: 80000D
   Belt Pretensioner right:
   Component: BeltPretRevFR  106 1032
   Serial number: 3G2857706E0163P00158
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 003 005 15
   Serial number: 3576U000000DA4215415
   Subsystem 4 - Part No SW: -----------    HW: 454 003 005 15
   Serial number: 3586U000000AA4215413
   Subsystem 5 - Part No SW: -----------    HW: 454 800 706 15
   Serial number: 3516R69C72C07000000B
   Subsystem 6 - Part No SW: -----------    HW: 454 800 606 15
   Serial number: 3526R86662E070000006
   Subsystem 7 - Part No SW: -----------    HW: 454 802 605 15
   Serial number: 3556V148BC706000000D
   Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150612401057
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3D273F2CBDF450A378D-8068
   Part No SW: 3G0 920 941 A    HW: 3G0 920 941 A
   Component: KOMBI         201 6421
   Coding: 27A40A182780260001886B011000000000000000
   VCID: 2411EA483E5E016B173-8070
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2227
   Revision: --------    Serial number: 09061510800237
   Coding: 030300045F085900FB00005C1C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 75B7E70CC544C8E370D-8020
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150001211140035242
   Coding: 2CFFFF
   Serial number: 3328766803
   Analog clock:
   Component: Analoguhr  111 1004
   Serial number: 2605201500010137
   Serial number: 15000034511013
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD31CB12CE4C3AC5-8024
   Serial number: 180515BEH08471
   Coding: 00350A20D001028000001000
   VCID: 43D349D4DB1026530E9-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001568343
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 8103
   Shop #: WSC 00015 115 00310
   Serial number: 270515BER00443
   Coding: 00350020D001028000001000
   VCID: 42DD4CD0C40A2F5B05F-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001573936
   Coding: 050000
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    820 0627
   Coding: 02840201FF00000051111101008808001F0100C601200100CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 303916187AA6ADCBE3B-8064
   Component: ABT_Std-2_Nav  H43 4064
   Serial number: VWZ6Z9R1680166
   Subsystem 2 - Part No SW: 5NA 919 866 AR    HW: -----------
   Component: ECE AS 20/21  --- 1430
End----------(Elapsed Time: 01:39, VBatt start/end: 12.1V/12.1V)-----------
MasterTommy
Amsterdam
C?ID=295586
Not sure if its SWAP/FEC related since you already have carplay enabled, but the next step would be to see an adaptation channel map of module 5F.
george13
C?ID=400380
I think I've done it correctly. See below
;SW:3Q0-035-874-A   HW:3Q0-035-874-A ---  Information Electr.
;Component:MU-S-ND-ER    820 0627, Coding:02840201FF00000051111101008808001F0100C601200100CF
;EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW37.rod
;Friday,08,May,2020,17:34:36:24548
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: 303916187AA6ADCBE3B-8064
IDE00346-Summertime-automatic,manual ,1
IDE00758-Base volume of telephone,50 %,1
IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00845-Wheel circ.,0 mm,2
IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,49
IDE02502-Confirmation of installation change,FF 63 ,2
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG263540-Vehicle configuration-correction_e_mileage,0 ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,OFF ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting,OFF ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,On ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,1 ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE05111-Fee-based traffic information (TMC),32771 ,2
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,OFF ,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,OFF ,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,OFF ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-3 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
IDE10604-Menu entries for mobile online services,activated ,1
IDE11122-Country identification: country of sale HMI,GB ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
MAS00951-Bluetooth,On ,1
MAS01968-Fan,normal ,1
MAS03782-WLAN,On ,1
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Databus Infotainment ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG117915-ENG101574-Dimming_Functional_Illumination_for_Operating_Unit-X1,255 ,12
ENG117915-ENG99557-Dimming_Functional_Illumination_for_Operating_Unit-X2,255 ,12
ENG117915-ENG102140-Dimming_Functional_Illumination_for_Operating_Unit-X3,255 ,12
ENG117915-ENG102936-Dimming_Functional_Illumination_for_Operating_Unit-X4,255 ,12
ENG117915-ENG103548-Dimming_Functional_Illumination_for_Operating_Unit-X5,255 ,12
ENG117915-ENG113992-Dimming_Functional_Illumination_for_Operating_Unit-X6,255 ,12
ENG117915-ENG99777-Dimming_Functional_Illumination_for_Operating_Unit-Y1,255 %,12
ENG117915-ENG100480-Dimming_Functional_Illumination_for_Operating_Unit-Y2,255 %,12
ENG117915-ENG100773-Dimming_Functional_Illumination_for_Operating_Unit-Y3,255 %,12
ENG117915-ENG100631-Dimming_Functional_Illumination_for_Operating_Unit-Y4,255 %,12
ENG117915-ENG102174-Dimming_Functional_Illumination_for_Operating_Unit-Y5,255 %,12
ENG117915-ENG113993-Dimming_Functional_Illumination_for_Operating_Unit-Y6,255 %,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,8 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,20 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,60 %,12
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 3C 00 C8 00 B4 00 A0 00 9B 00 23 00 23 00 19 00 19 00 FF FF FF FF FF FF FF FF 00 00 36 ,40
ENG117808-p_HMI_Display,10 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
Elapsed Time: 00:34
Dana
Western PA, USA
I could be way off here but I think this general section applies to those options:
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG263540-Vehicle configuration-correction_e_mileage,0 ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,OFF ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting,OFF ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
"Mirror_link" appears to be on/enabled in a few of the maps I checked from the NAR market where Android Auto is standard even on low-spec models. I would be tempted to change IDE03471-ENG138662 from off to on.
george13
C?ID=400380
Thanks, I'll give it a go.
I was reading through those options and the fact it's off seemed a bit strange...
I also noticed the following
IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
I wonder if those relate to the voice commands?
Also, I googled the following and most people have it set the same, but i wonder if that's somehow related?
Finally, I spotted the following and thought they're interesting. Does anyone know if they require the camera to function? Especially the pedestrian assist should work without it and be on for all cars I think?
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
siLc
Tallinn, Estonia
C?ID=330192
Pedestrian Assist/Detection is a function of the 3Q0980653 front camera. Doesn't work without it.
vastechnics
C?ID=143747
Carplay AA and Mirrorlink are all Swap
ibis_white
C?ID=236086
00060300 Mirror Link
00060800 Apple Carplay
00060900 Google Automotive Link
george13
C?ID=400380
not sure what those are? Ok, so those are the SWaP Codes. Do I need to give those to the dealer so they can understand what I'm after?
On Service mode, I don't have the menu "Functioning enabling codes". I hope this can be somehow enabled and doesn't mean that it's impossible to activate? I read somewhere i need to enable developer mode because my firmware is old, so I can try this.
Looking online, I think I can buy 5g0 054 830A and probably enter the code myself which might be a possibility while the dealers are closed?
PetrolDave
Westbury, UK
C?ID=1423
IIRC the FeC codes required to enable a SwAP feature can be vehicle specific and can only be enabled (once!) by someone with a Fazit connection.
george13
C?ID=400380
I got hold of an activation document, but i'm struggling to get the local dealers to activate because i didn't purchase it from them. An independent specialist didn't want to do it either, saying it's not worth their time.
Any suggestions on how to get hold of someone with a genuine Fazit connection? Is there a list somewhere, or would VW be able to give me that?
Also, what's the difference between Fazit and Odis? Am i right to assume that Odis is a tool similar to used to connect to the Fazit system which is the central database of VAG?
rhinopower
C?ID=58979
Where in the UK are you George?
chr
Romania
C?ID=79671
Your unit is Delphi? Issue is solved?
