Results 1 to 10 of 11
Thread: Passat B8 enable Android Auto?
    May 2020
    Hi all, new to the forum, VCDS and VW. I have a decent background of retrofits on Fords (focus & fiesta) and realised I couldn't stay away from mods on my new (used) Passat...
    I started by adding Passenger Mirror Down on Reverse with the instructions found here and I'm currently looking into Android Auto in more detail.
    I've read it can be done by the dealer as my car already has the car-net option on the screen. I think I saw some companies that can help with that, but I'm hoping it's now also available from VCDS? I'm currently struggling with the various terminologies, and have not seen a recent post around this, so decided to start a new thread.
    Here's my Auto Scan
    Friday,08,May,2020,10:47:54:24548
    VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
    VIN: WVWZZZ3CZGE026196   License Plate:
    Chassis Type: 3C-VW48 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
    VIN: WVWZZZ3CZGE026196   Mileage: 139765km-86845miles
    Address 01: Engine (J623-DCXA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 GK    HW: 04L 907 309 R
       Component: R4 1,6L EDC   H21 1369
       Revision: B5H21---
       Coding: 0125001203651D093000
       Shop #: WSC 05311 115 00310
       ASAM Dataset: EV_ECM16TDI01104L906026GK 002001
       ROD: EV_ECM16TDI01104L906026GJ_VW48.rod
       VCID: 79AFEB3CE95CAC83145-802C
    5523 - Engine Start Blocked by Immobilizer
              P1570 00 [040] - -
                        Mileage: 139497 km
                        Date: 2020.04.30
                        Time: 08:53:32
                        Engine speed: 764.00 /min
                        Normed load value: 22.0 %
                        Coolant temperature: 68 °C
                        Intake air temperature: 45 °C
                        Voltage terminal 30: 11.660 V
                        Unlearning counter according OBD: 25
                        Immobilizer snapshot A-Sia Error Snap A: 00 00 00
                        Immobilizer snapshot B-Sia Error Snap B: 00 00 00
       Part No SW: 0CW 300 048 N    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 0611
       Revision: 00005005    Serial number: CU501505305308
       Shop #: WSC 05311 115 00094
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 47CB5DC4EF280A73D21-8012
       Revision: 00000000    Serial number: 61565000003099
       Coding: 0FEC928F34220B720778060941C949F0492CD0E0608292F11842F078C202
       Shop #: WSC 00015 115 00001
       ROD: EV_Brake1UDSContiMK100IPB_034.rod
       VCID: 7AADF430EC5AA79B1DF-802E
       Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
       Component: VWKESSYMQB    026 0709
       Revision: 00026000    Serial number: 0372006385
       Coding: 000F0F0703
       ROD: EV_KessyHellaMQBAB.rod
       VCID: 392F2B3CA9DC6C83545-806C
       Part No SW: 5G0 907 426 AF    HW: 5G0 907 426 AF
       Component: AC Manuell    H03 1202
       Revision: 00001K06
       Coding: 12120104202100001000400000000002
       ASAM Dataset: EV_ACManueBHBVW37X 003129
       ROD: EV_ACManueBHBVW37X_003.rod
       VCID: 6FBBD564A718F233BA1-803A
       Part No SW: 5Q0 937 086 AH    HW: 5Q0 937 086 AH
       Revision: --------    Serial number: 86582005152183
       Coding: 03011842C2C1027F0FA44094B10407281880000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 005986D88A86FD4B53B-8054
       Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    150508  043 0607
       Serial number:         150515234400
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S2Y15M06D10H11M01S59
       Coding: 90A8DD
       Subsystem 3 - Part No SW: 3G0 941 633     HW: 3G0 941 633
       Serial number: 18 04 2015  00000784
       Component: Sensor, DWA  006 0326
       Serial number: 000000000ZY151271H7P
       Serial number: 00000000000062752149
       Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0056
       Revision: --------    Serial number: 39391516001196
       Coding: 0071051811
       VCID: 44D14AC8DE1E216B373-8010
       Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
       Component: ACC BOSCH MQB H04 0192
       Coding: 3200678251FFC428949C804D
       ASAM Dataset: EV_ACCBOSCHVW48X 001008
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 34311A088EBE91EB873-8060
    0836 - Databus
              [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                        Reset counter: 112
                        Mileage: 139421 km
                        Date: 2020.04.27
                        Time: 08:24:40
                        Control Module temperature: 14 °C
                        Voltage terminal 15: 14.4 V
       Part No SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
       Component: Airbag VW20   013 0195
       Revision: --------    Serial number: 003SSPBBG5CA
       Coding: 98FCC0C0000000005C5400CC008800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7EA5F820F0728BBB217-802A
       Belt Pretensioner left:
       Serial number: 3G2857705E0159P01016
       Coding: 80000D
       Belt Pretensioner right:
       Serial number: 3G2857706E0163P00158
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 454 003 005 15
       Serial number: 3576U000000DA4215415
       Subsystem 4 - Part No SW: -----------    HW: 454 003 005 15
       Serial number: 3586U000000AA4215413
       Subsystem 5 - Part No SW: -----------    HW: 454 800 706 15
       Serial number: 3516R69C72C07000000B
       Subsystem 6 - Part No SW: -----------    HW: 454 800 606 15
       Serial number: 3526R86662E070000006
       Subsystem 7 - Part No SW: -----------    HW: 454 802 605 15
       Serial number: 3556V148BC706000000D
       Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20150612401057
       Coding: 0410
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3D273F2CBDF450A378D-8068
       Part No SW: 3G0 920 941 A    HW: 3G0 920 941 A
       Component: KOMBI         201 6421
       Coding: 27A40A182780260001886B011000000000000000
       VCID: 2411EA483E5E016B173-8070
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2227
       Revision: --------    Serial number: 09061510800237
       Coding: 030300045F085900FB00005C1C0F00010001070000000000000000000000
       ROD: EV_GatewConti_013.rod
       VCID: 75B7E70CC544C8E370D-8020
       Component: E221__MFL-DC1  H16 0040
       Serial number: 29150001211140035242
       Coding: 2CFFFF
       Serial number: 3328766803
       Analog clock:
       Component: Analoguhr  111 1004
       Serial number: 2605201500010137
       Serial number: 15000034511013
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BFD31CB12CE4C3AC5-8024
       Serial number: 180515BEH08471
       Coding: 00350A20D001028000001000
       VCID: 43D349D4DB1026530E9-8016
       Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000001568343
       Coding: 0D0000
       Component: EPS_MQB_ZFLS  125 1061
       Coding: 8103
       Shop #: WSC 00015 115 00310
       Serial number: 270515BER00443
       Coding: 00350020D001028000001000
       VCID: 42DD4CD0C40A2F5B05F-8016
       Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000001573936
       Coding: 050000
       Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
       Component: MU-S-ND-ER    820 0627
       Coding: 02840201FF00000051111101008808001F0100C601200100CF
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 303916187AA6ADCBE3B-8064
       Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
       Component: ABT_Std-2_Nav  H43 4064
       Serial number: VWZ6Z9R1680166
       Subsystem 2 - Part No SW: 5NA 919 866 AR    HW: -----------
       Component: ECE AS 20/21  --- 1430
    End----------(Elapsed Time: 01:39, VBatt start/end: 12.1V/12.1V)-----------
    Dec 2016
    Amsterdam
    Not sure if its SWAP/FEC related since you already have carplay enabled, but the next step would be to see an adaptation channel map of module 5F.
    Current:
  3. Likes Uwe, Dana liked this post
    May 2020
    I think I've done it correctly. See below
    ;SW:3Q0-035-874-A   HW:3Q0-035-874-A ---  Information Electr.
    ;Component:MU-S-ND-ER    820 0627, Coding:02840201FF00000051111101008808001F0100C601200100CF
    ;EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW37.rod
    ;Friday,08,May,2020,17:34:36:24548
    ;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
    ;VCID: 303916187AA6ADCBE3B-8064
    IDE00346-Summertime-automatic,manual ,1
    IDE00758-Base volume of telephone,50 %,1
    IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00845-Wheel circ.,0 mm,2
    IDE02121-CD eject button,Enabled ,1
    IDE02122-Developer mode,not activated ,1
    IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,49
    IDE02502-Confirmation of installation change,FF 63 ,2
    IDE02607-Wheel pulse,0 ,2
    IDE02699-Number 1 for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE03471-ENG117847-Vehicle configuration-advanced_range_display,OFF ,30
    IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
    IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
    IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
    IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
    IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
    IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
    IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
    IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
    IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
    IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
    IDE03471-ENG263540-Vehicle configuration-correction_e_mileage,0 ,30
    IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,On ,30
    IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
    IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
    IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
    IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
    IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30
    IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,OFF ,30
    IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,OFF ,30
    IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,OFF ,30
    IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
    IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
    IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting,OFF ,30
    IDE03471-ENG125049-Vehicle configuration-Joker_button_1,Not Present ,30
    IDE03471-ENG125050-Vehicle configuration-Joker_button_2,Not Present ,30
    IDE03471-ENG127492-Vehicle configuration-LGI,OFF ,30
    IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated ,30
    IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
    IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
    IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
    IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
    IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
    IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
    IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
    IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
    IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
    IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF ,30
    IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
    IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
    IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
    IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
    IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
    IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
    IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
    IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,OFF ,30
    IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
    IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
    IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
    IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active ,30
    IDE03471-ENG117844-Vehicle configuration-picture_navi,On ,30
    IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
    IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
    IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
    IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,OFF ,30
    IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo,OFF ,30
    IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
    IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
    IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
    IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
    IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
    IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
    IDE03471-ENG126143-Vehicle configuration-RVC_video_input,FBAS ,30
    IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
    IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation,no restriction ,30
    IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
    IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
    IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,Not Present ,30
    IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
    IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi,activated ,30
    IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,1 ,30
    IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF ,30
    IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
    IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
    IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
    IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF ,30
    IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30
    IDE03471-ENG137647-Vehicle configuration-UOTA,OFF ,30
    IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
    IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
    IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
    IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
    IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
    IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF ,30
    IDE03471-ENG127494-Vehicle configuration-VZO,OFF ,30
    IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
    IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
    IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
    IDE03902-Automatic ring break diagnostic,No automatic start ,1
    IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP ,1
    IDE04521-Sporadic ring break detection,Visual ,1
    IDE04550-Bluetooth: Sniff mode,OFF ,1
    IDE05111-Fee-based traffic information (TMC),32771 ,2
    IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,OFF ,1
    IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
    IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,OFF ,1
    IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,OFF ,1
    IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1
    IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
    IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
    IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 ,40
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
    IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128 ,40
    IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128 ,40
    IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128 ,40
    IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128 ,40
    IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128 ,40
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-3 ,40
    IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128 ,40
    IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128 ,40
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128 ,40
    IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 ,40
    IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
    IDE10604-Menu entries for mobile online services,activated ,1
    IDE11122-Country identification: country of sale HMI,GB ,2
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
    IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21
    IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21
    IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21
    IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21
    IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21
    IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
    IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21
    IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21
    IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21
    IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21
    IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21
    IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21
    IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21
    IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21
    IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21
    IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
    IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,21
    IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,21
    IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,21
    IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,21
    IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,21
    IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,21
    IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,21
    IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,21
    IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,21
    IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,21
    IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,21
    IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,21
    IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,21
    IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,21
    IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,21
    IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,21
    IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,21
    IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,21
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
    IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,21
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
    IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,21
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
    IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,21
    IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,21
    IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,21
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
    IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,21
    IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,21
    IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,21
    IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,21
    IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,21
    IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,21
    IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,21
    IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,21
    IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,21
    MAS00951-Bluetooth,On ,1
    MAS01968-Fan,normal ,1
    MAS03782-WLAN,On ,1
    ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
    ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
    ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
    ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
    ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
    ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
    ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
    ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
    ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
    ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
    ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
    ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated ,60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
    ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
    ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
    ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
    ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
    ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,activated ,60
    ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated ,60
    ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated ,60
    ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated ,60
    ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
    ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60
    ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60
    ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
    ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
    ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
    ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated ,60
    ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated ,60
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated ,60
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not activated ,60
    ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ,60
    ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated ,60
    ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
    ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
    ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,activated ,60
    ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
    ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
    ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,activated ,60
    ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,60
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
    ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
    ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated ,60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
    ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated ,64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64
    ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ,64
    ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
    ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ,64
    ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated ,64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus ,64
    ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated ,64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
    ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,activated ,64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
    ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated ,64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
    ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ,64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
    ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated ,64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
    ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64
    ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
    ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated ,64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
    ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated ,64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus ,64
    ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated ,64
    ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated ,64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
    ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64
    ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
    ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated ,64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
    ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
    ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated ,64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
    ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated ,64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
    ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated ,64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
    ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
    ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64
    ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64
    ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
    ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,activated ,64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
    ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
    ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
    ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
    ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
    ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated ,64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
    ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated ,64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
    ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated ,64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated ,64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
    ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated ,64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
    ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated ,64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated ,64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated ,64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
    ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available ,8
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
    ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ,8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Databus Infotainment ,8
    ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available ,8
    ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment ,8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
    ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available ,8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
    ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available ,8
    ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
    ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
    ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8
    ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available ,8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
    ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1,0 ,6
    ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2,50 ,6
    ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3,100 ,6
    ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1,0 ,6
    ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2,50 ,6
    ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3,100 ,6
    ENG117915-ENG101574-Dimming_Functional_Illumination_for_Operating_Unit-X1,255 ,12
    ENG117915-ENG99557-Dimming_Functional_Illumination_for_Operating_Unit-X2,255 ,12
    ENG117915-ENG102140-Dimming_Functional_Illumination_for_Operating_Unit-X3,255 ,12
    ENG117915-ENG102936-Dimming_Functional_Illumination_for_Operating_Unit-X4,255 ,12
    ENG117915-ENG103548-Dimming_Functional_Illumination_for_Operating_Unit-X5,255 ,12
    ENG117915-ENG113992-Dimming_Functional_Illumination_for_Operating_Unit-X6,255 ,12
    ENG117915-ENG99777-Dimming_Functional_Illumination_for_Operating_Unit-Y1,255 %,12
    ENG117915-ENG100480-Dimming_Functional_Illumination_for_Operating_Unit-Y2,255 %,12
    ENG117915-ENG100773-Dimming_Functional_Illumination_for_Operating_Unit-Y3,255 %,12
    ENG117915-ENG100631-Dimming_Functional_Illumination_for_Operating_Unit-Y4,255 %,12
    ENG117915-ENG102174-Dimming_Functional_Illumination_for_Operating_Unit-Y5,255 %,12
    ENG117915-ENG113993-Dimming_Functional_Illumination_for_Operating_Unit-Y6,255 %,12
    ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0 ,12
    ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10 ,12
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100 ,12
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150 ,12
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
    ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253 ,12
    ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1 %,12
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,8 %,12
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,20 %,12
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,60 %,12
    ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100 %,12
    ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 3C 00 C8 00 B4 00 A0 00 9B 00 23 00 23 00 19 00 19 00 FF FF FF FF FF FF FF FF 00 00 36 ,40
    ENG117809-p_damping_Display,5 ms,1
    ENG117808-p_HMI_Display,10 %,1
    ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
    Elapsed Time: 00:34
  5. Likes Dana liked this post
    United States
    I could be way off here but I think this general section applies to those options:
    IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
    IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
    IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
    IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
    IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
    IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
    IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
    IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
    IDE03471-ENG263540-Vehicle configuration-correction_e_mileage,0 ,30
    IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,On ,30
    IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
    IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
    IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
    IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
    IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30
    IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,OFF ,30
    IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,OFF ,30
    IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,OFF ,30
    IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
    IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
    IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting,OFF ,30
    IDE03471-ENG125049-Vehicle configuration-Joker_button_1,Not Present ,30
    IDE03471-ENG125050-Vehicle configuration-Joker_button_2,Not Present ,30
    IDE03471-ENG127492-Vehicle configuration-LGI,OFF ,30
    IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated ,30
    IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
    IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
    IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
    IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
    IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
    IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
    IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
    IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
    "Mirror_link" appears to be on/enabled in a few of the maps I checked from the NAR market where Android Auto is standard even on low-spec models. I would be tempted to change IDE03471-ENG138662 from off to on.
  7. Likes Uwe liked this post
  8. #5
    May 2020
    Thanks, I'll give it a go.
    I was reading through those options and the fact it's off seemed a bit strange...
    I also noticed the following
    IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF ,30
    IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
    IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
    IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
    IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
    IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
    IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
    IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
    I wonder if those relate to the voice commands?
    Also, I googled the following and most people have it set the same, but i wonder if that's somehow related?
    Finally, I spotted the following and thought they're interesting. Does anyone know if they require the camera to function? Especially the pedestrian assist should work without it and be on for all cars I think?
    IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
    IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
  9. Likes Dana liked this post
  10. #6
    Jul 2014
    Tallinn, Estonia
    Pedestrian Assist/Detection is a function of the 3Q0980653 front camera. Doesn't work without it.
  11. Likes Dana liked this post
  12. #7
    May 2016
    Carplay AA and Mirrorlink are all Swap
  13. Likes Dana liked this post
  14. #8
    Quote Originally Posted by vastechnics View Post
    Three different SwAP codes, or one common one?
  15. #9
    Feb 2017
    00060300 Mirror Link
    00060800 Apple Carplay
    00060900 Google Automotive Link
  16. #10
    May 2020
    Quote Originally Posted by ibis_white View Post
    not sure what those are? Ok, so those are the SWaP Codes. Do I need to give those to the dealer so they can understand what I'm after?
    On Service mode, I don't have the menu "Functioning enabling codes". I hope this can be somehow enabled and doesn't mean that it's impossible to activate? I read somewhere i need to enable developer mode because my firmware is old, so I can try this.
    Looking online, I think I can buy 5g0 054 830A and probably enter the code myself which might be a possibility while the dealers are closed?
