Results 1 to 10 of 12
Thread: T5 Multi Function Display Enabling
    May 2020
    My 2010 T5.1 van has had cruise and MFD stalks installed. The cruise has been enabled and works fine but we cannot get the MFD to come alive, the rocker switch on the stalk deos nothing and the central display shows outside temperature most of the time.
    Can anyone help with the necessary coding?
    Andy
    Thursday,07,May,2020,19:49:56:27147
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 03 04 08 09 10 15 17 19 25 56 69 0B
    VIN: WV1ZZZ7HZBH001268   Mileage: 107060km-66523miles
    Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 022 CH    HW: 03L 907 309 K
       Component: R4 2,0L EDC   X35 9126
       Revision: 26X35---    Serial number: 00000000000000
       Coding: 01194012233400080000
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM20TDI01103L906022CH 002012
       ROD: EV_ECM20TDI01103L906022CH_002.rod
       VCID: ED9295EA3CFB7527FC-80B8
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 F    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0104
       Revision: 00H43001
       Coding: 708724AD89A40E9624A49177A96610
       Shop #: WSC 02736 790 49152
       VCID: B5227D8A1C2BFDE7C4-80E0
                        Reset counter: 116
                        Mileage: 105585 km
                        Date: 2014.05.10
                        Time: 15:12:53
                        Count: 6161
                        Count: 128
                        Count: 250
    Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
       Part No SW: 7E5 907 047 AA    HW: 7E5 907 047 AA
       Component: Climatic-T5   H10 0101
       Revision: 00004001
       Coding: 0000000002
       Shop #: WSC 02737 790 50316
       ASAM Dataset: EV_ClimaticT5 A01002
       ROD: EV_ClimaT5Basis.rod
       VCID: EE9092E631FD8E3FC5-80BA
       Part No SW: 7H0 937 087 D    HW: 7H0 937 087
       Component: BCM T5GP H+4  H47 0221
       Revision: BO047001    Serial number: 0347 140100528
       Coding: A0A0303A0E612431802040003C2B8C540080430F60060000300000000000
       Shop #: WSC 02736 790 12345
       Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
       Component: J386__TSG_FT  002 3311
       Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
       Component: J387__TSG_BT  002 3311
    Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
       Part No SW: 7E0 919 475     HW: 7E0 919 475
       Component: PARKHILFE 4K  H10 0008
       Revision: --------    Serial number: 33031007900159
       Coding: 100002
       Shop #: WSC 02736 790 50316
       ASAM Dataset: EV_VW75XParkAssis4K A01003
       ROD: EV_VW75XParkAssis4K_A01.rod
       VCID: EFAE8FE236F78737CE-80BA
    1079316 - Center Rear Right Parking Aid Sensor
              B1078 14 [008] - Open or Short to Ground
                        Fault Frequency: 26
                        Reset counter: 118
                        Mileage: 106036 km
                        Date: 2020.03.05
                        Time: 13:57:44
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag009 H05 0013
       Revision: --------    Serial number: 003HL000655E
       Shop #: WSC 02734 790 50316
       VCID: B5227D8A142BFDE7C4-80E0
       Part No SW: 7E0 920 960 C    HW: 7E0 920 960 C
       Component: KOMBI         H04 0204
       Coding: 460A00
       Shop #: WSC 02756 790 50316
       VCID: A91AA1FAC893A90750-80FC
       Part No SW: 6N0 909 901     HW: 7H0 937 087
       Component: GW-K-CAN TP20 0221
       Coding: 042300
       VCID: F0AC8C9E23C998CFD7-80A4
       Component: IMMO          H04 0204
       VCID: EA989EF60D15621F99-80BE
    Address 56: Radio
       Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
       Component: Anhaenger     H12 0130
       Revision: 3B001001    Serial number: 00000402969681
       Coding: 4100000101000000
       VCID: B2284696ED45EADFE1-80E6
    02025 - Supply Voltage for External Components
                        Fault Status: 00101010
                        Fault Frequency: 148
                        Reset counter: 113
                        Mileage: 97989 km
                        Date: 2012.12.21
                        Time: 10:23:21
    End----(Elapsed Time: 01:38, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
    Aug 2016
    Eindhoven, NB, NL
    This is strange, it should work (byte 1 bit 3 is enabled in 0x17).
    Are you sure the wiring/stalks are correctly installed? Can you verify with DVOM that wires short to GND when you press a button?
  3. Likes Uwe liked this post
    May 2020
    Thank you. I will ask the technician who fitted the stalks to check the wiring.
    Regards
    Andy
    Jun 2014
    Poland
    I think 7E0 920 960 C is a lowLine . withount any function
    7E0 920 970 is with MFA
  6. Likes NEtech liked this post
    Looks like it,
    WV1ZZZ7HZBH001268
    PR-Code 9Q0 Without multi-function display/trip computer
  8. Likes Uwe liked this post
  9. #6
    May 2020
    Thanks for your input guys.
    I understand from searching elsewhere that the 960 cluster (Midline?) won't work (easily) with the MFSW but should work fine with the column stalk.
    As standard it shows the outside temperature and, for a while after fuelling) it shows the range so it must be capable of calculating the fuel consumption.
  10. #7
    Jun 2014
    Poland
    Looks like it,
    WV1ZZZ7HZBH001268
    MFA is a High Line cluster (cluster number 7E0920970 for example)
    Quote Originally Posted by Walkingshaw View Post
    you can try add stalk
    I never care about lowLine cluster what options they show as they are LowLine
    is a like a ADD remote control for 2chanell TV receiver ...no point
  11. #8
    Jan 2019
    The lowline cluster is showing some parts of Multifunction-Display, too when Stalk is added.
  12. Likes Robert-VW liked this post
  13. #9
    Jun 2014
    Poland
    Quote Originally Posted by dnoermann View Post
    aha ...so who why they charge soo much money for Highline cluster ...if it show this same ?
  14. #10
    Jan 2019
    Whell it is VW, they charge it because we pay it
    The lowline Cluster does not have more "Pages" to display.
    But with the MFL you can change between those Values, sorry German:
    Temperatur
    Reichweite
    Durchschnittsverbrauch
    Durchschnittsgeschwindigkeit
    Fahrzeit in 2 Ebenen (Kurzzeit- sowie Langzeitspeicher).
    This was validated on a T6.
  15. Likes Uwe, Robert-VW liked this post
