Results 1 to 8 of 8
Thread: Immobilizer Issues fault 00474 (8E A4)
    May 2020
    Galway, Ireland
    hi all hoping someone can help,
    Background:
    Completing a scan to turn off a fault light (engine management) my laptop malfunctioned... and somehow managed to throw up the immobilizer.. dont ask me how or what happened.. long story short we could get it fixed apart from a local guy was able bypass the EEprom in the ECM. (hence fault in scan below)
    how ever now we still have the issue of the IMMO light being on on the dash and when i go to adapt the keys, as you enter the test value it come up with an error. i have the the pin for the cluster too. i cant communicate with the IMMO module.
    Can someone point me in the right direction? or at least what to check next? or who to call!
    final note car is running with IMMO Light on dash.
    see full scan below.
    Wednesday,06,May,2020,20:56:39:15909
    Dealer/Shop Name: Oatfield Lodge
    VIN: WAUZZZ8E44A062094   License Plate:
              67 69 75 76 77
    VIN: WAUZZZ8E44A062094   Mileage: 512000km-318142miles
    Address 01: Engine        Labels: 038-906-019-AVF.lbl
       Part No: 038 906 019 LJ
       Component: 1,9l R4 EDC 0000SG  4910
       Coding: 00003
       Shop #: WSC 63351
       VCID: 6A8DC46AD56C0B0BEDF-4B1E
    17994 - Engine Mount Solenoid Valves (N144/N145)
                P1586 - 35-10 - Short to Plus - Intermittent
       Part No: 8E0 614 517 A
       Component: ABS/ESP allrad      3429
       Coding: 04255
       Shop #: WSC 06435
       VCID: 2615F05A01F4EF6B097-51F2
       Part No: 8E0 820 043 AC
       Component:   A4 Klimaautomat   1219
       Coding: 00000
       Shop #: WSC 63351
       VCID: 629DAC4A2D5C534B25F-5160
                49-00 - No Communications
       Part No: 8E0 907 279 C
       Component: int. Lastmodul  RDW 0606
       Coding: 00001
       Shop #: WSC 63351
       VCID: 323D1C0A3D3C83CB95F-4B00
    Address 15: Airbags        Labels: 8E0-959-655-84.lbl
       Part No: 8E0 959 655 B
       Component: Airbag 8.4EP        3002
       Coding: 0010602
       Shop #: WSC 63351 000 00000
       VCID: 3635201AD4549FEBB97-5184
       Part No: 8E0 953 549 F
       Component: Lenksáulenmodul     0308
       Coding: 01001
       Shop #: WSC 63351
       VCID: 3635201AD1549FEBB97-4B1E
       Part No: 8E0 920 950 J
       Component: KOMBI+WEGFAHRS. RB4 D37
       Coding: 01400
       VCID: 303916023330B1DBE3B-5184
       WAUZZZ8E44A062094     AUZ6Z0C0191650
    01177 - Engine Control Unit
                65-10 - Unauthorized - Intermittent
    Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
       Part No: 8E0 951 177
       Component: Innenraumueberw.   0604
       Coding: 00001
       VCID: 6B83C16EDA961203969-513C
    01463 - Alarm triggered by Sensor for anti-theft alarm System
                43-00 - Closed
       Part No: 8E0 959 433 BC
       Component: Komfortgerát T3B    1311
       Coding: 06859
       Shop #: WSC 63351
       VCID: 73B3D90E82A6CAC35E9-4B1E
       Subsystem 1 - Part No: 8E2959802B
       Component: Tőrsteuer.FS BRM 0003
       Subsystem 2 - Part No: 8E2959801B
       Component: Tőrsteuer.BF BRM 0003
       Subsystem 3 - Part No: 8E0959801A
       Component: Tőrsteuer.HL BRM 0003
       Subsystem 4 - Part No: 8E0959802A
       Component: Tőrsteuer.HR BRM 0003
    7 Faults Found:
    01134 - Alarm Horn (H12)
    01370 - Alarm triggered by Interior Monitoring
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
    00956 - Key 2
                35-00 - -
    01561 - Rear left door
    End----------(Elapsed Time: 05:39, VBatt start/end: 12.2V/14.5V)-----------
    Quote Originally Posted by L walker View Post
    There is no separate Immobilizer module in this car; all Immo functionality is in 17-Instruments.
  3. Likes Jetta ,97 liked this post
    May 2020
    Galway, Ireland
    why would the adaption 21 come up with an error when matching ? as soon as i put in the new key value?
    Check Immo and key status in MVBs 022, 023, and 024.
    Dallas (McKinney) ,TX ,USA
    Because you have Immo off in ECU .
    Immobilizer/ECU
    /Cluster Programing (Used or NEW)
    email: marinmm2001@gmail.com , info@advancedcarelectronics.com
    https://www.advancedcarelectronics.com/
    May 2020
    Galway, Ireland
    Quote Originally Posted by Jetta ,97 View Post
    do i have to code the light off then?
    what are my options? re- enable IMMO in ecu? then try reconfig what ever went wrong?
    Yes , you have to have Immo On to program Immobilizer or keys.
    Immobilizer/ECU
  9. #8
    May 2020
    Galway, Ireland
    Ok thank you. I will get in touch with the guy who turned it off.
    I will post findings then
