2013 Q5 Hybrid Retrofit factory trailer hitch
george.papa
C?ID=342328
Hi All!
I've been working on adding a factory trailer hitch and control module to my 2013 Q5 hybrid. I've been using this discussion as a guide (https://forums.ross-tech.com/showthread.php?330-2013-Q5-Trailer-Hitch-Retrofit).
So far I've been able to:
  • Plug in the trailer comnection/detection module
  • Add "trailer" (item 69) to the Installation list of the CAN Gateway module 19
  • Recode the Central Electronics module 09 to include the "Trailer Hitch Installed" bit.
  • Recode Backup Camera coding module 6C by adding 1 to the appropriate digit in the data word.
  • Recode the trailer module 69 to suit country (in my case USA)
I still have TPMS and ECS warning lights on an I'm struggling with a couple things. Any help or advice would be extremely appreciated!!!
I THINK I need help with the following:
  • I need to recode the Engine module 01 to include the "Trailer Installed" bit.
  • I need to recode the ABS module 03 to include the "Trailer Hitch Installed" bit. Security is needed for this activity.
Auto-scan:
aTuesday,05,May,2020,22:55:23:50542
VIN: WA1C8AFP4DA017006   License Plate:
Mileage: 134480km-83561mi   Repair Order: 2
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 40 42 44 46 47 51 52 53
          56 5F 62 69 6C 6D 72 8C
VIN: WA1C8AFP4DA017006   Mileage: 134480km-83561miles
40-AC Compressor -- Status: Malfunction 0010
51-Electric Drive -- Status: Malfunction 0010
8C-Hybrid Battery -- Status: Malfunction 0010
Address 01: Engine (0-MA--CHJA)       Labels: None
   Part No SW: 8R1 907 115 D    HW: 8R0 907 115 G
   Component: 2.0l R4/4V TF H56 0002
   Revision: NDH56---
   Coding: 6A2A0013442600062000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TFS0118R1907115D 001003
   ROD: EV_ECM20TFS0118R1907115D_001.rod
   VCID: 3635DA25B8CB2B5BB97-8062
10 Faults Found:
          U1113 00 [047] - -
                    Fault Frequency: 15
                    Mileage: 134453 km
                    Date: 2020.05.03
                    Time: 16:48:00
                    Coolant temperature: 12 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 10.342 V
                    Engine operating condition-Channel 87: Idling
                    Relative load value: 81.00 %
                    Engine torque: 0.0 Nm
          U1113 00 [047] - -
                    Fault Frequency: 15
                    Mileage: 134453 km
                    Date: 2020.05.03
                    Time: 16:48:00
18178 - Implausible Data Received from Diagnostic Gateway Module
          U0447 00 [032] - -
                    Mileage: 134441 km
                    Date: 2020.05.02
                    Time: 14:48:29
                    Engine speed: 1170.00 /min
                    Normed load value: 26.7 %
                    Coolant temperature: 15 °C
                    Voltage terminal 30: 13.923 V
                    Unlearning counter according OBD: 36
                    CAN status - engine control module-Bits 0-7: 00000000
                    CAN status - transmission control module-Bits 0-7: 00000000
                    CAN status - brake control module 1-Bits 0-7: 00000000
                    CAN status - brake control module 2-Bits 0-7: 00000000
                    Cruise control switch actuation-Bits 0-7: 00000000
17403 - Implausible Data Received from Parking Brake Control Module
          U0417 00 [032] - -
                    Mileage: 134441 km
                    Date: 2020.04.26
                    Time: 17:08:00
                    Coolant temperature: 39 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 10.790 V
                    Cruise control switch actuation-Bits 0-7: 00000001
17427 - Implausible Data Received from Transmission Control Module
          U0402 00 [032] - -
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:43:03
                    Coolant temperature: 16 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 8.976 V
                    CAN status - engine control module-Bits 0-7: 01000000
                    CAN status - transmission control module-Bits 0-7: 01000000
                    CAN status - brake control module 1-Bits 0-7: 01000000
                    CAN status - brake control module 2-Bits 0-7: 01000000
17433 - Battery Disconnect
          P16C5 00 [096] - Does Not Open
10530 - EVAP System
          P0456 00 [096] - Very Small Leak Detected
12584 - HV Components
          P0AB9 00 [032] - System Failure
12591 - HV Components
          P0AB9 00 [096] - System Failure
4261 - System Voltage
          P0562 00 [096] - Too Low
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 22:00:30
                    Voltage terminal 30: 8.811 V
                    Relative load value: 78.82 %
   Part No SW: 8R1 927 158 K    HW: 0BW 927 156 P
   Component: 0BW 20TFSIUSA H16 1001
   Revision: --H16---
   Coding: 000001
   ASAM Dataset: EV_TCMAL551111 002022
   ROD: EV_TCMAL551111.rod
   VCID: 46D5AAE5C82BBBDB297-8012
12483 - System Voltage
          P0562 00 [044] - Too Low
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:43:03
                    Voltage terminal 30: 8.946 V
                    Voltage supply of regulator valves: 8.913 V
                    Voltage terminal 15: 9.1 V
                    Engine speed: 0 /min
                    Transmission input speed: 0.00 /min
                    Driving position: P
                    Control Module temperature: 17 °C
                    selected gear: without traction
                    Starting clutch status: Kupplung geoeffnet
                    E-machine cut-out clutch status: geoeffnet
                    M015_Time Normal Mode: 608 s
                    M019_Time Since Reset: 7650 ms
                    M018_Time In Afterrun: 0 s
                    Transmission fluid temperature: 17 °C
   Part No SW: 8R0 907 379 T    HW: 8R0 907 379 T
   Component: ESP8 quattro  H09 0060
   Coding: 2D1D1C
   Shop #: WSC 06335 000 00000
   VCID: 51FF89B931E56C638C5-8004
                    Fault Status: 00101101
                    Reset counter: 12
                    Mileage: 134441 km
                    Date: 2020.04.26
                    Time: 16:18:11
                    Hex Value: 0x0000
                    Hex Value: 0x0280
                    Hex Value: 0x0015
                    Hex Value: 0x0293
                    Hex Value: 0x0000
                    Reset counter: 233
                    Mileage: 134453 km
                    Date: 2020.05.03
                    Time: 16:48:00
                    Hex Value: 0x00C0
                    Hex Value: 0x0782
                    Hex Value: 0x003C
                    Hex Value: 0x0382
                    Hex Value: 0x0000
01119 - Gear Recognition Signal
                    Reset counter: 16
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:43:11
                    Hex Value: 0x00C0
                    Hex Value: 0x4282
                    Hex Value: 0x000B
                    Hex Value: 0x27A2
                    Hex Value: 0x0000
                    Reset counter: 16
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:59:13
                    Hex Value: 0x0000
                    Hex Value: 0x1282
                    Hex Value: 0x0029
                    Hex Value: 0x245C
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
   Component: BCM2 2.0      H11 0621
   Coding: 0DC54040000000000000
   VCID: 045170EDBE1749CB773-8050
   Serial number: 2312000198135009
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 16
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:42:59
                    Reset counter: 16
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:58:48
                    Reset counter: 16
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:59:47
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01100920120050
   Coding: 64C120C000
   VCID: 392FD1198955C423545-806C
00532 - Supply Voltage B+
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:58:17
                    Voltage: 8.40 V
                    Temperature: 17.0°C
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 22:00:56
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000474925202
   Coding: 26008091803CAFE00000480300003D0D4F9C6608E0090221000008004000010200020034000000
   Shop #: WSC 65150 001 104857
   VCID: 7AAD0E15CCD30F3B1DF-802E
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 120802  H11 0050
   Serial number: 90243014120726031429
   Coding: 01DD13
   Serial number: 20552939
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000609120315
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R2SAE02
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: F2C80E36000000000001
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:58:20
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:59:48
02236 - Stationary Right Cornering Lamp (Right) (M52)
                    Fault Frequency: 100
                    Reset counter: 240
                    Mileage: 93798 km
                    Date: 2017.12.27
                    Time: 16:15:31
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Serial number: 003GPD90SA3L
   Coding: 303634313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 47CBA7E1CF21A2D3D21-8012
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R120000AEPW
   Serial number: 6334MSME70434A55B
   Serial number: 6344MSME74553845F
   Serial number: 6352QSME2F220C66M
   Serial number: 6362QSME06224C48G
   Serial number: 63732SME19224D54$
   Serial number: 63832SME7E1F00701
13635840 - Supply voltage
          [Powersupply  lower threshold fall short of]
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:58:33
9483264 - Seat Occupied Recognition
          B10B4 00 [008] - Function Restriction due to Undervoltage
          [Bladder Mat: functional restriction because of low voltage]
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:42:47
   Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
   Revision: --------    Serial number: 90372LI30019X
   Coding: 000017
   VCID: 43D3B3F1FB998EF30E9-8016
                    Reset counter: 16
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:58:48
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 981 D    HW: 8R0 920 981 D
   Component: KOMBIINSTR.   H35 0553
   Revision: 00000000    Serial number: RFE23GL8D
   Coding: 8BBF23000B01D705020000
   VCID: 3B23CB118369F633469-806E
                    Reset counter: 16
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:58:35
   Part No SW: 8R0 907 468 E    HW: 8R0 907 468 E
   Component: GW-BEM 5CAN-M H11 0051
   Revision: 2A110020    Serial number: 2042A128100006
   Coding: 80D00AFF00
   VCID: 41DFB9F9E1859CE31C5-8014
   Subsystem 1 - Part No SW: 8R0 915 181 A    HW: 8R0 915 181 A
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900843730
   Subsystem 2 - Part No SW: 8R0 915 181 B    HW: 8R0 915 181 B
   Component: J367-BDMLear2  H07 5040
   Serial number: 00000000000020851982
                    Fault Frequency: 66
                    Reset counter: 17
                    Mileage: 132605 km
                    Date: 2020.03.03
                    Time: 18:31:14
                    Bin. Bits:    10000
                    Voltage: 12.00 V
                    Count: 10
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:59:43
                    Bin. Bits:    10111
                    Voltage: 6.80 V
                    Count: 6
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000036758696
   Coding: 00581B00000000000000
   VCID: 42DDB6F5E48387FB05F-8016
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:59:19
   Part No SW: 8T0 907 566 A    HW: 8T0 907 566
   Component: SWA Master    H17 0040
   Serial number: 0181823987
   Coding: 010211
   Shop #: WSC 06342 000 00000
   VCID: 3E25C20590FBE31B617-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 A    HW: 8T0 907 568
   Component: SWA Slave  H17 0040
   Serial number: 0183666711
   Coding: 010211
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Reduction of function in consequence of undervoltage ECU 1 --> functional reduction by reason of temporary undervoltage]
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:42:25
136194 - Supply voltage
          [Supply voltage - lower limit is exceeded--> supply voltage permanent undervalued]
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:57:28
731394 - Control Module 2 for Lane-Change Assist
          C1115 F2 [008] - Function Restricted due to Under-Voltage
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:42:45
733696 - Control Module 2 for Lane-Change Assist
          C1115 F5 [008] - Limited Visibility
                    Mileage: 123420 km
                    Date: 2019.08.29
                    Time: 10:54:11
Address 40: AC Compressor (J842)       Labels: 8R0-260-797.clb
   Part No SW: 8R0 260 797 C    HW: 8R0 260 797 C
   Component: ES34          H01 0001
   ASAM Dataset: EV_AirCondiCompr_ES34 S03001
   ROD: EV_AirCondiCompr_ES34_AU48.rod
   VCID: 3C21C80D86E7F10B4F3-8068
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:58:45
                    Voltage terminal 15: 8.4 V
                    Compressor speed: 0 /min
                    Compressor current: 0.0 A
                    Compressor temperature: 0 °C
                    Compressor main status: Not available
                    Compressor enabling: Not available
                    Compressor speed specified value: 0 /min
                    Availability of high voltage: Not available
                    Hybrid battery voltage: 100.0 V
                    Compressor motor current: 0.0 A
          U1400 00 [008] - -
          [Funktionseinschraenkung durch Unterspannung]
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:43:05
                    Voltage terminal 15: 8.9 V
   Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000038505089
   Coding: 011D13205E00440004
   VCID: 4DC795C92DDD4883E8D-8018
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:58:46
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:59:40
   Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
   Revision: 00001000    Serial number: 0002848340
   Coding: 000000000100
   Shop #: WSC 65150 001 1048576
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3B23CB1183E9F633469-806E
16387 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Keine Freigabe der Lenkunterstützung aufgrund Unterspannung der Versorgungsspannung]
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:59:12
                    Write only channel
   Revision: 00002001    Serial number: 0183057644
   Coding: 01260E3A20FA709587B005321004000D
   Component: GTO BF  H01 0080
   Serial number: 00000000000000563535
   Component: J245EE20SKB13  H03 0220
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H03 0220
02914 - Sensor 1 for Trunk/Hatch Closed (G525)
                    Fault Status: 00101010
                    Reset counter: 14
                    Mileage: 134453 km
                    Date: 2020.05.03
                    Time: 11:37:34
02915 - Sensor 2 for Trunk/Hatch Closed (G526)
                    Reset counter: 14
                    Mileage: 134453 km
                    Date: 2020.05.03
                    Time: 11:37:34
                    Reset counter: 16
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:59:46
   Revision: 00005001    Serial number: 94813005987002
   VCID: 2D07F5494D1D6883C8D-8078
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Fault Status: 00101011
                    Reset counter: 17
                    Voltage: 11.80 V
                    Temperature: 6.0°C
                    Temperature: 6.0°C
                    Bin. Bits: 00000100
Address 51: Electric Drive (J841)       Labels: 06F-907-080.clb
   Part No SW: 06F 907 080 H    HW: 06F 907 080 H
   Component: MLB HYBRID    H18 0001
   Revision: --------
   ASAM Dataset: EV_DMCM030202106F907080H 001003
   ROD: EV_DMCM030202106F907080H.rod
   VCID: 2C01F84D7687618BDF3-8078
5751 - 14V Power System Voltage
          P0A8D 00 [032] - too Low
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 22:00:17
                    Voltage terminal 30-Battery voltage: 7.845735 V
                    RPM of electric machine-N_EM: 0.00 /min
                    Drive control condition-STATE_EM_MOD_CAN: Standby
                    Torque: current value-TQI_EM_CAN_MVB: 0.0 Nm
                    Power electronics heat sink temperature-PIT_S16TEMPERATURE_DCBLP: 22.13 °C
                    Voltage of intermediate circuit-S16DCLINKVOLTAGE_MVB: 264.94 V
   Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000038517094
   VCID: 4CC198CDD6C7418BFF3-8018
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:58:51
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:59:44
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 10000000094222
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3829D41DB2DFDD2BABB-806C
70912 - Left Parking Brake Motor Voltage Supply
          C100D 13 [008] - Electrical Malfunction
                    Fault Frequency: 11
                    Reset counter: 228
                    Mileage: 134441 km
                    Date: 2020.04.26
                    Time: 16:18:11
                    Voltage terminal 30: 11.9 V
                    Internal Fault ID: 26
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: OFF
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: No enabling
131840 - Switch for Electric Parking Brake
          C100C 13 [000] - Open Circuit
10554390 - Supply voltage
          [FC_LOW_V_BATT]
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:58:14
                    Voltage terminal 30: 9.0 V
                    Internal Fault ID: 40
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156I00C7633465
   Coding: 020007010000000001
   VCID: 211F197901C5BCE37C5-8074
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 22:01:02
                    Voltage: 8.40 V
   Part No SW: 8R1 035 746 B    HW: 8R1 035 746 B
   Component: H-BNT-NA      H43 0552
   Revision: --------    Serial number: 204I$0C7521579
   Coding: 170200060005E1EF57038B4E00000403140000000000000002
   VCID: 3635DA25B84B2B5BB97-8062
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Component: DU7 High  H41 0104
   Serial number: A130IW0C2534971
   Subsystem 3 - Part No SW: 8T0 919 611 C    HW: 8T0 919 611 C
   Component: E0380 Bedient  H02 0020
   Serial number: 00000001264567
   Subsystem 4 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
   Revision:             Serial number: 0000038727299
   Coding: 010C13204000240004
   VCID: 46D5AAE5C8ABBBDB297-8012
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:58:47
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:59:41
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: Anhaenger     H12 0100
   Revision: 1A001001    Serial number: 00000411093958
   Coding: 0200000000000000
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H07---    Serial number: 525PA8-J26A2JF
   Coding: 1010010
   Shop #: WSC 51059 001 104857
   VCID: 3431E02DA237394B873-8060
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Revision: --------    Serial number: 8R0827851B
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Serial number: 8R0827852B
                    Reset counter: 16
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:59:24
   Revision:             Serial number: 0000038722867
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:58:53
                    Reset counter: 17
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:59:46
Address 8C: Hybrid Battery (J840)       Labels: None
   Part No SW: 8R0 915 591     HW: 8R0 915 591
   Component: BMS           H08 0543
   Coding: 0A0200
   Shop #: WSC 40308 001 1048576
   ASAM Dataset: EV_BECM0722011 004016
   ROD: EV_BECM0722011_004_AU48.rod
   VCID: 78A9141DF25F1D2B6BB-802C
8402 - 14V Power System Voltage
          P0A8D 00 [036] - too Low
                    Reset counter: 28
                    Mileage: 134488 km
                    Date: 2020.05.05
                    Time: 21:59:48
                    Pack Voltage: 264.2 V
                    Pack Current: -0.03 A
                    Isolation Resistance: 1016 kOhm
                    Maximum discharge current limit: 164 A
                    BMS_MaxDyn_EntladeStorm: 180 A
                    Contactor Voltage: 264 V
                    Crash status: 00
                    FAN status: 00
                    Pilot Line Status: 00
                    Fuse Status: 00
                    (Minus) Contactor Status: 01
                    (Plus) Contactor Status: 01
                    Terminal 15 status: 01
                    DFCC: 8402
                    Max Cell Temperature: 16 °C
                    Min Cell Temperature: 16 °C
                    Air inlet temperature: 16 °C
                    Air outlet temperature: 18 °C
                    LV Battery Voltage: 6.8 V
                    Min.cell voltage: 3.664 V
                    Max.cell Voltage: 3.677 V
                    Max.cell SOC: 46 %
                    Min.cell SOC: 43 %
                    Max Charge Pack Current(10s duration): 0 A
                    Max Discharge Pack Current(10s duration): 0 A
                    Max Pack Voltage: 264 V
                    Min Pack Voltage(10s duration): 264 V
                    Max.cell Voltage(10s duration): 3.678 V
                    Min.cell Voltage(10s duration): 3.662 V
                    Accelerator Pedal Position D: 14.9 %
                    Calculated LOAD Value: 0.0 %
                    Engine coolant temperature: 16 °C
                    Engine RPM: 0.00 /min
                    Vehicle Speed Sensor: 255 km/h
                    Absolute Throtle Position: 16.9 %
                    distance traveld since fault memory last cleared: 40698 km
                    control module system voltage: 6.810 V
                    absolute load: 0.0 %
                    Time After Engine Start: 0 /min
End----------(Elapsed Time: 02:24, VBatt start/end: 14.3V/14.3V)-----------
george.papa
C?ID=342328
Here is a cleaner auto-scan. It says coding doesn't exist for 01-Engine module. Is this because it's the hybrid? I'm really hoping to do more with my VCDS here. Also still need to figure out how to adjust 03-ABS. PLEASE HELP!
hursday,07,May,2020,11:59:07:50542
Mileage: 134490km-83568mi   Repair Order: 7
VIN: WA1C8AFP4DA017006   Mileage: 134490km-83568miles
40-AC Compressor -- Status: OK 0000
   Revision: NDH56---
          U1113 00 [047] - -
                    Mileage: 134488 km
                    Date: 2020.05.06
                    Time: 22:02:25
                    Engine speed: 701.00 /min
                    Normed load value: 13.7 %
                    Coolant temperature: 96 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 14.324 V
                    Median injection timing: 1.101 ms
                    Relative load value: 16.99 %
                    Engine torque: 36.5 Nm
          U1113 00 [047] - -
                    Mileage: 134488 km
                    Date: 2020.05.06
                    Time: 22:02:25
Readiness: 0110 0101
   Revision: --H16---
   Coding: 000001
   Coding: 2D1D1C
                    Reset counter: 235
                    Mileage: 134494 km
                    Date: 2020.05.07
                    Time: 11:54:06
                    Hex Value: 0x00C0
                    Hex Value: 0x4082
                    Hex Value: 0x003C
                    Hex Value: 0x03AF
                    Hex Value: 0x0000
   Coding: 64C120C000
   Coding: 26008091803CAFE07F00488300003D0DCF9CE608E0090221000008004000010200020034000000
   Coding: 01DD13
   Coding: 02005C
H05 0012
H05 0012
01771 - Control Module for Headlight Range (J431)
                    Reset counter: 235
                    Mileage: 134488 km
                    Date: 2020.05.06
                    Time: 22:02:23
00471 - Control Module for Elect. Regulated Dampers (J250)
                    Reset counter: 235
                    Mileage: 134488 km
                    Date: 2020.05.06
                    Time: 22:02:24
                    Reset counter: 235
                    Mileage: 134488 km
                    Date: 2020.05.06
                    Time: 22:02:27
   Coding: 000017
   Coding: 8BFF23000B00D705020201
                    Reset counter: 235
                    Mileage: 134488 km
                    Date: 2020.05.06
                    Time: 22:02:23
   Coding: 80D00AFF00
   Coding: 010221
   Coding: 010221
   Coding: 01260E3A20FA709787B005323004000D
                    Reset counter: 20
                    Voltage: 12.30 V
                    Temperature: 8.0°C
                    Temperature: 9.0°C
                    Bin. Bits: 00000100
   Revision: --------
   Coding: 170200060005E1FF57038F4E00000403140000000000000002
   Coding: 1031010
03110 - Active Steering Control Module (J792)
                    Reset counter: 235
                    Mileage: 134488 km
                    Date: 2020.05.06
                    Time: 22:02:22
                        Reverse OFF
                    Count: 3
   Coding: 0A0200
End----------(Elapsed Time: 02:14, VBatt start/end: 14.5V/14.5V)-----------
NEtech
C?ID=56995
First:
[Options]
[User Interface and Identification]
write numbers for wsc, importer, device no.
For example 12345 123 23456
[Save]
[Close VCDS]
Start VCDS
Disable start/stop on button or what is available for that on this model.
Explanation: Copy the change coding and insert as new coding:
[Controller No.] > ”New coding”
[01] > 6A2A0013443600062000
[03] > 2D9D1C (First Security Access 61378)
[3C] > 010221
- Ignition OFF 1 minute
- Ignition ON
- Delete all fault codes
- Ignition OFF 10 sec.
- Check fault codes
george.papa
C?ID=342328
thank you so much that worked. Is there mapping that exists for my 01-Engine? i get nothing in the long coding helper.
Dana
Western PA, USA
We don't have a file for that CHJA Hybrid engine controller.
The good news, because it uses the UDS protocol the only documentation you are missing is Coding. Basic Settings, Advanced measuring values and similar would function properly.
The bad news, the Long Coding Helper requires a label file so it wouldn't have been possible to enable that trailer installed bit without assistance.
We don't appear to have any Control module maps from that engine module so it would be helpful if you could email Support a complete Auto-Scan in addition to Measuring value and Adaptation function maps from address 01. Alternatively, there's a section of our forum dedicated to Reference Scans and Maps of Non-Broken Cars that you could post the information in however sending an email to Support would still be helpful as a reminder so we can add it to the to-do list.
