For information.
The outcome of this story.
Car is received back and issue wit 12V battery seems to be solved.
The whole thing came down to a 12V battery beeing defective/damaged.
This have most likley happend prior to delivery, since this since this was bought off the dealers exhibition.
Cars are often displayed with lights on, with a charger on 12V at dealers exhibition.
Most likley the charger have failed un-noticed, leading to an completley draining of the 12V batt to zero volt, and left it there for a while.
Indeed they now, when digging in details, they find out that car has been exposed to a 12V battery drain issue at exhibition.
Ordinary lead acid batteries are very quickly destroyed if drained to zero capacity, (below approx 11,5V), left in this state, and not recharged immediately.
in this case battery voltage has been down towards zero.
When it happend for me, returning from a holliday, it was 4,8VDC, and has probably been in this state for 4-5 days.
When this happens to a battery, water and acid are separated.
In bottom of cell it becomes more or less concentrated sulphuric acid.
The acid will immediately start "eating" the lead plates in battery.
The damage to plates is permanent, and results in less reserve capacity.
Sometimes they are not able to recharge at all.
In my case it recharged, but the reserve capacity in battery was close to nothing, following the damage.
This effect is also valid for the AGM battery technology, as this happens to be.
I have verified this with my knowledge of batteriers and my other experts on batteries, and they confirm such effects of such deep draining.
For a long lifetime the batteries should normaly be charged when coming to abt 50% capacity, and immediatley, if it runs down towards 0% at abt 11,5V
The most critical is the time the battery is left in a deep cycled state.
In the situation below 11,5V (0%), the damage to battery goes very quickly.
Further to car:
Even though dealer found no immediate high drain from battery when car had gone to sleep, and shifted their focus to the battery itself, they did a thorough investigation of whole car, and logged the car over days to see if any systems waked up un-intenionally creating current drains.
They claim there where no unnormal current drains beeing discovered.
12V battery is changed, and car seems OK now.
I have enclosed an autoscan after car received back.
For some strange reason, I now get in contact with address 46.
The spoiler failure I think occured when I pushed the button, when the car was in an automatic retract event, even thogh it should handle such a combination of events withouth a .
functionality resetted itself neext time car was started.
The other failures: They have appeard after I received car back.
I do nut fully understand what they can be.
I may open new threads for those.
Autoscan:
Wednesday,17,June,2020,10:17:25:14143
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4524.4
VIN: WAUZZZF21LN026072 License Plate: DR-77022
Mileage: 5394km-3351mi Repair Order:
Chassis Type: F2-AU58 (4N1)
Scan: 01 02 03 09 15 16 17 19 22 23 36 42 44 46 51 52 5F 6D 81 8C
A5 BA BB BC C0 C5 C6 D6 D7
VIN: WAUZZZF21LN026072 Mileage: 5394km-3351miles
8C-Hybrid Battery -- Status: Malfunction 0010
BA-Motor Mounts -- Status: OK 0000
C5-Therm. mgt. -- Status: OK 0000
C6-Batt. Chrg. -- Status: Malfunction 0010
Address 01: Engine (J623-DLGA) Labels: None
Part No SW: 4K0 906 259 B HW: 06L 907 425 B
Component: R4 2.0l TFSI H07 0002
Coding: 1A6540320526050B340A0800000000000000000000000000
ASAM Dataset: EV_ECM20TFS0204K0906259B 001004
ROD: EV_ECM20TFS0204K0906259B.rod
VCID: 3039102D3AA0207BE3B-8064
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4K0 927 156 C HW: 0HL 927 156 B
Component: 0DK 20TFSIRdW H01 0002
Revision: --H01--- Serial number: 0000000971
Coding: 000001
ASAM Dataset: EV_TCMDL382021 002034
ROD: EV_TCMDL382021_AU58.rod
Automatic Transmission Fluid Pump:
Subsystem 1 - Part No SW: 80A 927 154 HW: 0DK 315 149 E
Component: V671 ATFP-2 007 0058
Serial number: 75307021190217000232
Subsystem 2 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041190238000361
Part No SW: 4N0 907 379 AN HW: 4N0 907 379 F
Component: ESP9 Premium H06 0856
Coding: 44AA41972AA40A9C119E0898207F52D3F5B9C0228254508810044ACBAF9D03
ASAM Dataset: EV_ESP9BOSCHCMP 004011
ROD: EV_ESP9BOSCHCMP_004_AU65.rod
VCID: 04518CFDDE986CDB773-8050
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 4N0 907 063 FG HW: 4N0 907 063 AG
Component: BCM1 MLBevo H10 0690
Coding: 07000943C13900DD0700070818AD8C68130B3310000600970101080039321C810A4509324256110800000100004918180800400044010000000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 016011
ROD: EV_BCM1BOSCHAU651_016.rod
VCID: 78A9E80D9250383B6BB-802C
Subsystem 1 - Part No SW: 4K1 955 119 HW: 4K1 955 119
Component: J400FRWISCH 063 0740
Serial number: 00000001907050402134
Coding: 7DC727
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 23593883X81A955555A0
Coding: 02006E
Light switch:
Subsystem 3 - Part No SW: 4K1 941 501 A HW: 4K1 941 501 A
Component: E1 - LTM H09 0086
Serial number: 14S20.09.1900691695
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE119061924210325
Interior Light Module:
Subsystem 5 - Part No SW: 4K0 947 135 AE HW: 4K0 947 135 AE
Component: Dachmodul H42 0415
Serial number: C00352780
Coding: 0D0104
Address 15: Airbags (J234) Labels:* None
Part No SW: 4N0 959 655 Q HW: 4N0 959 655 Q
Component: AirbagVW31 H19 2720
Serial number: 003YZM07J5NJ
Coding: AAFCF0C00CA00000985000FFF00D40A000C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
ROD: EV_AirbaVW31SMEAU65x_VW53.rod
VCID: 4ACD62C5BC3C7AABCDF-801E
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2019246088800000
Coding: 04F001
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2019246379200000
Coding: 04F001
Subsystem 3 - Part No SW: ----------- HW: 480 001 109 19
Serial number: 35700000000630098042
Subsystem 4 - Part No SW: ----------- HW: 480 001 109 19
Serial number: 3580000000097D1C204L
Subsystem 5 - Part No SW: ----------- HW: 480 031 309 19
Component: SideSensor_Dr 002 0149
Serial number: 351001C2456919615FDC
Subsystem 6 - Part No SW: ----------- HW: 480 031 309 19
Component: SideSensor_Pr 002 0149
Serial number: 352001C2456112304DDY
Subsystem 7 - Part No SW: ----------- HW: 480 031 809 19
Component: FrontSensor_D 002 0149
Serial number: 355001C247D3A1112AF9
Front Sensor Passenger:
Subsystem 8 - Part No SW: ----------- HW: 480 031 809 19
Component: FrontSensor_P 002 0149
Serial number: 356001C247E42EC0980H
Pedestrian Protection Center:
Subsystem 9 - Part No SW: ----------- HW: 480 030 409 19
Component: PedP_Sensor_C 002 0149
Serial number: 230001C246186520289S
Subsystem 10 - Part No SW: ----------- HW: 480 001 309 19
Component: PedPSensor_D2 001 0887
Serial number: I0M000000008C7D430CD
Subsystem 11 - Part No SW: ----------- HW: 480 001 309 19
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000A201530CV
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4N0 907 129 AE HW: 4N0 907 129 AE
Component: Lenks.Modul H03 0005
ROD: EV_SMLSKLOAU736_AU58.rod
VCID: 74B1DC3D8E385C5B473-8020
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4K0 920 794 B HW: 4K0 920 794 B
Component: FHybRDWACC--- H12 0210
Coding: 852450C2E88000080121E1709384880008002800
ASAM Dataset: EV_DashBoardAU65X 001017
ROD: EV_DashBoardAU65X_VW53.rod
Part No SW: 4N1 907 468 BB HW: 4N1 907 468 AB
Component: Gateway H16 0052
Revision: BC000001 Serial number: 018BC812219912
Coding: 02010005000206C029810100005B0132CC78000710000000097D079E10000000
ASAM Dataset: EV_CGateCONTIAU491 004190
ROD: EV_CGateCONTIAU491_004_VW53.rod
VCID: 79AFED09A95A2133145-802C
Subsystem 1 - Part No SW: 4K0 951 523 H HW: 4K0 951 523 H
Component: E221__MFL H06 0003
Serial number: 00000000000000000000
Subsystem 2 - Part No SW: 4K0 915 181 B HW: 4K0 915 181 B
Component: J367-BDMConti H03 1051
Serial number: 75801303001902080044
Address 22: AWD (J492) Labels:* None
Part No SW: 4K0 927 755 B HW: 0CJ 927 749 A
Component: C8_DLE_N_SD2 H01 0008
Serial number: 19128A6744
Coding: 111C0000
ASAM Dataset: EV_AWDCQUOD31 001052
ROD: EV_AWDCQUOD31.rod
VCID: 34311C3DCEB81C5B873-8060
Address 23: Brake Booster (J539) Labels: None
Part No SW: 4M0 909 059 J HW: 4M0 909 059
Component: J539 EBKV H11 0288
Serial number: 085460012152
ASAM Dataset: EV_BrakeBoostBOSCHCMP 001003
ROD: EV_BrakeBoostBOSCHCMP_AU58.rod
VCID: 3B233701E3E6D323469-806E
Brake Assistance Sub:
Subsystem 1 - Part No SW: 4M0 909 057 B HW: 4M0 909 057
Component: VX70BrakeAssi H04 0154
Serial number: 05802861051218171729
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0044
Serial number: 00000381691693
Coding: 005812400000B4010003010101010000000000000000000000000000004000
ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M1 959 593 D HW: 4M1 959 593 D
Component: TSG FS002 0189
Serial number: YE007SHS2873D
Coding: 001CDF4252000480A001B400
ROD: EV_DCU2DriveSideMAXHKLO.rod
VCID: 3E253E15F0F4C60B617-806A
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 4N0 909 144 E HW: 4N0 909 144 C
Component: EPS_MLBEVO2BS H22 0505
Coding: 94002101010000
ASAM Dataset: EV_EPSVWBSAU426 010017
ROD: EV_EPSVWBSAU426_010.rod
VCID: 323D1A2534AC126B95F-8066
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 4N0 907 064 DD HW: 4N0 907 064 D
Component: BCM2 MLBevo H15 0183
Coding: 01740000002000E26309A0000400080203030001804B06502F04000000040030001F0100000F11
ASAM Dataset: EV_BCM2CONTIAU651 010009
ROD: EV_BCM2CONTIAU651_010_AU58.rod
Ignition key:
Rear Light Left 1:
Subsystem 2 - Part No SW: 4K8 945 069 B HW: 4K8 945 069 B
Component: Slali1AU583 H03 0404
Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Rear Spoiler Adjustment:
Subsystem 3 - Part No SW: 4K8 959 252 HW: 4K8 959 252
Component: J223 HSP 0304 H02 0200
Serial number: WA138947000074241253
Coding: 00FF00
Rear Light Left 2:
Subsystem 4 - Part No SW: 4K8 945 217 B HW: 4K8 945 217 B
Component: Slali2AU583 H03 0404
Rear Light Right 1:
Subsystem 5 - Part No SW: 4K8 945 070 B HW: 4K8 945 070 B
Component: Slare1AU583 H03 0404
Rear Light Right 2:
Subsystem 6 - Part No SW: 4K8 945 218 B HW: 4K8 945 218 B
Component: Slare2AU583 H03 0404
65652 - Rear Spoiler Limit Switch
B1343 29 [008] - Signal Implausible
Reset counter: 139
Mileage: 5216 km
Date: 2020.06.16
Time: 18:08:43
Supply voltages-Supply voltage: Terminal 30: 13.738 V
Supply voltages-Supply voltage Terminal 30 - 2: 13.710 V
Supply voltages-Supply voltage Terminal 30 - 3: 13.668 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
general_additional_freeze_frame-coprocessor_spi_status: 00000000
general_additional_freeze_frame-dataflash_status: 00000000
general_additional_freeze_frame-interior_temperature: -50.0 °C
general_additional_freeze_frame-Operating_Status: 00000000 00000000
general_additional_freeze_frame-production_mode: not active
general_additional_freeze_frame-reset_cause: 00000000
general_additional_freeze_frame-Reset_counter: 0
general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
general_additional_freeze_frame-subnetwork_status: 00000000 00000000
general_additional_freeze_frame-terminal_control_intern_status: 1B 02 2A 16 05 78
general_additional_freeze_frame-Transport_Mode: not active
general_additional_freeze_frame-Vehicle speed: 0.00 km/h
can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
Address 51: Electric Drive (J841) Labels: None
Part No SW: 80A 907 080 A HW: 80A 907 080 A
Component: 50A87696A0HO0 H08 0008
Revision: -------- Serial number: -00105.08.19000
Coding: 03000000000000000000
Shop #: WSC 48165 001 1048576
ASAM Dataset: EV_DMCMHITACAU426 003007
ROD: EV_DMCMHITACAU426_003.rod
VCID: 221DEA65644C82EB65F-8076
Part No SW: 4M1 959 592 D HW: 4M1 959 592 D
Component: TSG BFS002 0189
Serial number: YE007SI106348
Coding: 001CDF025E000480A001B400
ROD: EV_DCU2PasseSideMAXHKLO.rod
VCID: 3D273919FDF2DD1378D-8068
Part No SW: 4K0 035 063 D HW: 4K0 035 063 A
Component: MU-H-LND-EU 054 2711
Coding: 01859301FF0A000043111101C00800102F0001E403F00800CE
ASAM Dataset: EV_MUHigGen2pALPI 001001
ROD: EV_MUHigGen2pALPI_AU27.rod
VCID: 2411EC7D7E588CDB173-8070
Subsystem 1 - Part No: V03 959 804 BK
Component: MIB2P_EU_Q319 0400
Subsystem 2 - Part No SW: 4K0 919 605 C HW: 4K0 919 605 A
Component: DU AU58x High H42 0147
Serial number: INX00101071900060466
Subsystem 3 - Part No: V03 959 800 EG
Component: Gracenote2 1010
Volume Control 1:
Subsystem 4 - Part No SW: 4K1 919 616 B HW: 4K1 919 616 A
Component: LSR-D5/C8 H33 0110
Serial number: 00004419000092193014
Display Unit 5 For Multimedia System:
Subsystem 5 - Part No SW: 4K0 919 603 B HW: 4K0 919 603
Component: DU AU58x Bot H41 0147
Serial number: INX00108071900080525
Media socket:
Subsystem 6 - Part No SW: 4N0 035 736 A HW: 4N0 035 736
Component: MediaConnectH 014 0133
Serial number: 051900508822003
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 8W8 959 107 D HW: 8W8 959 107
Component: HDSG-Modul H13 0171
Revision: -------- Serial number: A2-C744-8781-2
Coding: 1610
ROD: EV_DeckLidCONTIAU736_VW27.rod
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4K1 713 041 H HW: 4K1 713 041 H
Component: GSM-LL H14 0051
Serial number: 19.256 40540
ASAM Dataset: EV_GSMKAMAU581 001005
ROD: EV_GSMKAMAU581.rod
VCID: 2809F84D027068BB3BB-807C
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 4KD 915 233 HW: 4KD 915 233
Component: BMC_PHEV_PL58 H08 0263
ASAM Dataset: EV_BECM0842071 001004
ROD: EV_BECM0842071_AU58.rod
VCID: 7AADF205AC5C2A2B1DF-802E
Battery Junction Box:
Subsystem 1 - Part No SW: 4K0 915 254 C HW: 4K0 915 254 C
Component: SX6 SFT426D0 H23 0205
Cell module: control module 1:
Subsystem 2 - Part No SW: 4N0 915 115 HW: 4N0 915 115
Component: J991 SFT426D1 H08 0105
Cell module: control module 2:
Subsystem 3 - Part No SW: 4N0 915 115 HW: 4N0 915 115
Component: J992 SFT426D2 H08 0105
Cell module: control module 3:
Subsystem 4 - Part No SW: 4N0 915 115 HW: 4N0 915 115
Component: J993 SFT426D3 H08 0105
Cell module: control module 4:
Subsystem 5 - Part No SW: 4N0 915 115 HW: 4N0 915 115
Component: J994 SFT426D4 H08 0105
Cell module: control module 5:
Subsystem 6 - Part No SW: 4N0 915 115 HW: 4N0 915 115
Component: J995 SFT426D5 H08 0105
Cell module: control module 6:
Subsystem 7 - Part No SW: 4N0 915 115 HW: 4N0 915 115
Component: J996 SFT426D6 H08 0105
Cell module: control module 7:
Subsystem 8 - Part No SW: 4N0 915 115 HW: 4N0 915 115
Component: J997 SFT426D7 H08 0105
Cell module: control module 8:
Subsystem 9 - Part No SW: 4N0 915 115 HW: 4N0 915 115
Component: J998 SFT426D8 H08 0105
4122 - No Communication with ABS Brake Control Module
U0121 00 [040] - -
[Diag_C_HCAN_ESP_21_TO]
High-volt. battery mode: spec. value: Standby-mode
Mode HV battery actual value: Initializing
H-V battery voltage: 386.20 V
Voltage in H-V system-Voltage of hybrid battery after protection: 1.50 V
Current of H-V / hybrid battery: -0.00 A
Battery temperature-Capturing statistic data: status: Initializing
Battery charge condition: 58 %
Voltage terminal 30: 12.20 V
Voltage terminal 30C: 12.40 V
Power reduction status: not active
Malfunction Indicator Lamp-Start request: not active
Service Disconnect: Status: connected
Pilot line: closed
Status of voltage freedom: High voltage power off not recognized
Crash signal: not active
Protection of posit. terminal of high voltage / hybrid battery: Open
Protection of neg. terminal of high voltage / hybrid battery: Open
Status pre-loader: Open
HV battery: cool. level requirement: invalid
Pump for HV battery coolant: specified power value: 12.00 %
Pump for HV battery coolant: status: no error
HV battery positive terminal insulation resistance-Status: Initializing
HV battery positive terminal insulation resistance: 5460 kOhm
HV battery minus terminal insulation resistance-Status: Initializing
HV battery minus terminal insulation resistance: 1850 kOhm
Entire HV system positive terminal insulation resistance-Status: Initializing
Entire HV system positive terminal insulation resistance: 20470 kOhm
Entire HV system minus terminal insulation resistance-Status: Initializing
Entire HV system minus terminal insulation resistance: 20470 kOhm
maximum voltage for battery cells-Index 1: 0
maximum voltage for battery cells-Value: 3.715 V
minimum voltage for battery cells-Index 1: 0
minimum voltage for battery cells-Value: 3.712 V
Highest measured temperature-Temperature sensor: 0
Highest measured temperature-Value: 21 °C
Lowest measured temperature-Temperature sensor: 0
Lowest measured temperature-Value: 21 °C
Air temperature of H-V / hybrid battery-Intake: -100 °C
Air temperature of H-V / hybrid battery-Exhaust: 19 °C
Maximum charge level-Index 1: 0
Maximum charge level-Value: 58 %
Minimum charge level-Index 1: 0
Minimum charge level-Value: 58 %
Dynamic limit for charge current-Limit for charge current: Initializing
Predictive limit for charge current-Limit for charge current: Initializing
Dynamic limit for discharge current-Limit for discharge current: Initializing
Predictive limit for discharge current-Limit for discharge current: Initializing
Maximum charging voltage: 431.60 V
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* None
Part No SW: 4KE 907 107 AK HW: 4N0 907 107 F
Component: zFAS Var A H08 0293
Coding: 04118600000000000000060000400C6C189D56000000000000000000000000000019000000000000000000000000000000000000000000000000800000000000000078D00080009000000000000000000080400000B0
ASAM Dataset: EV_ZFASAU516 001003
ROD: EV_ZFASAU516_001.rod
VCID: 084998CDE2B048BB1BB-805C
Address BA: Motor Mounts (J931) Labels: None
Part No SW: 4M0 907 145 E HW: 4M0 907 145 B
Component: AEMevo H10 0132
ASAM Dataset: EV_AEMZFAU736 006014
ROD: EV_AEMZFAU736_006.rod
Part No SW: 4M1 959 595 D HW: 4M1 959 595 D
Component: TSG HFS004 0189
Serial number: YE007SHC04489
Coding: 000CDD0200000480A000B000
VCID: 40D940ED8A00B0FB13B-8014
Component: TSG HBFS004 0189
Serial number: YE007SHU2768D
Address C0: Act. for Ext. Noise (J943) Labels:* None
Part No SW: 4K0 035 335 HW: 3F0 035 335
Component: E_SOUND_SGH05 0113
Serial number: EN193504540000
Coding: 04
ASAM Dataset: EV_ESoundMLBEvoS1NN 003008
ROD: EV_ESoundMLBEvoS1NN.rod
VCID: 629DAA6524CCC2EB25F-8036
Address C5: Therm. mgt. (J1024) Labels:* None
Part No SW: 4M0 965 429 N HW: 4M0 965 429 F
Component: TME-Max H08 0303
Serial number: 0062813
Coding: 00
ASAM Dataset: EV_ThermContrVISAU49X 002033
ROD: EV_ThermContrVISAU49X_AU58.rod
VCID: 42DD4AE5840CA2EB05F-8016
Subsystem 1 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G395 pT-Sens1 H11 0010
Subsystem 2 - Part No SW: 3Q0 963 231 E HW: 3Q0 963 231 E
Component: J848 HV-PTC 200 0204
Serial number: -00103.8W.2A20370246
Subsystem 3 - Part No SW: 4G0 816 797 C HW: 4G0 816 797 C
Component: J842 EKK es33 H03 0015
Serial number: 00000000019051401231
Geber für Kältemitteldruck/Kältemitteltemperatur 2:
Subsystem 4 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G826 pT-Sens2 H11 0010
Refrigerant Expansion Valve 2:
Subsystem 5 - Part No SW: 4M0 816 682 E HW: 4M0 816 682 E
Component: N637 EV2_KaMi H12 0102
Serial number: 00000000000151041509
Refrigerant Shut Off Valve 2:
Subsystem 6 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N640 AV2_KaMi H12 0102
Serial number: 00000000000130922466
Refrigerant Shut Off Valve 3:
Subsystem 7 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N641 AV3_KaMi H12 0102
Serial number: 00000000000130922426
Refrigerant Shut Off Valve 4:
Subsystem 8 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N642 AV4_KaMi H12 0102
Serial number: 00000000000130922418
Refrigerant Shut Off Valve 5:
Subsystem 9 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N643 AV5_KaMi H12 0102
Serial number: 00000000000130922250
Address C6: Batt. Chrg. (AX4) Labels:* 5QE-915-681.clb
Part No SW: 5QE 915 681 S HW: 5QE 915 681 S
Component: OBC Delta-ES H74 2831
Coding: 11508B607000
Shop #: WSC 00150 218 00000
ASAM Dataset: EV_OBCTwoPhaseDT2MLBev14P 001002
ROD: EV_OBCTwoPhaseDT2MLBev14P.rod
VCID: 5CE1949D06A8F41B6F3-8008
13705551 - Databus
[Klima_14_Timeout]
Fault Frequency: 40
Reset counter: 142
Mileage: 4981 km
Date: 2020.06.15
Time: 15:25:14
13705502 - Databus
[Einheiten_01_TimeOut]
Fault Frequency: 22
Reset counter: 141
Mileage: 5042 km
Date: 2020.06.15
Time: 16:36:16
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 4K0 941 592 BC HW: 4K0 941 592 B
Component: LMS_MLBevo H11 0031
ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
ROD: EV_LMSLeftHELLAAU58X_AU27.rod
VCID: 72BDDA25F42C526B55F-8026
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
ASAM Dataset: EV_LMSRightHELLAAU58X 001013
ROD: EV_LMSRightHELLAAU58X_AU27.rod
End----------(Elapsed Time: 02:18, VBatt start/end: 13.0V/13.0V)-----------
