Results 1 to 10 of 14
Thread: 2012 Audi A8, 4.2L, Intermittent rough idle, misfire
    May 2020
    **First Post**
    I purchase this car used around 70k miles....first time Audi owner. After a first couple of weeks of honeymoon phase....I noticed a slight hesitation from stop position. Seems like a 1 sec delay then car snaps into acceleration. If I do an agressive start, you cant feel it.....only when you give it gas slowly. I took it to Audi Allentown, they could not find anything with their diagnostics....not sure if they did road test).....so I let it go.....I thought maybe this is just how Audi's are. A few more months after that, I noticed a "whistling noise" coming from engine when it is cold. I took my car in for oil service, and they told me my BREATHER CONTROL VALVE is bad. I orderd the part myself and replaced it (Im not sure if this procedure requires a vacuume or coolant purge, I just simply removed and replaced). The whistling sound was less, but did not go away completely. So, thought maybe something else is causing this pressure in my crankcase, so I replaced the OE air filters with brand new K&N filters, and I changed the spark plugs while at it. The original spark plugs i removed were NGK PN 101905621B, and I Installed NGK PFR6W-TG5547 (OE equivalent)......I still have original plugs. During the spark plug change, this was my first time dealing with the D plugs on the coils.....(I broke clips on #4 and #8).....I installed plugs on. The first start up, was very rough.....I knew sometheing was wrong....so I went and secure the plugs again as best as i can and car ran much better......I actually got a misfire code on #4 cylinder on first start up.....but I got that to clear. Now, air filter, new Breather control valve, and new spark plugs are on my car......but the whistling sound was Still there. I took car back to dealership for diagnostics.....another $170, just for them to tell me that the Breather control valve was bad again. So I got another Breather control valve via warranty....and installed that one. This valve seems to be MUCH better......every now and again, i still hear a faint whistle. My car still runs like it has intermittent misfires.....feels like a vaccume leak or something.
    My autoscan tells me too rich/too lean....but im stuck here. Is there any measure values that I can take a look at with car running?
    IDE01975,76, 77,78....ALL have extreme misfire counts. But the values for Misfires per 1000 revolutions are 0
    Tuesday,05,May,2020,23:15:49:57557
    VIN: WAURVAFD4BN019274   License Plate:
    Chassis Type: FD-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 0E 10 15 16 17 19 34 36 3B 42 46 47 52
              53 55 56 5F 62 6C 6D 6F 72 81 88 89 8F 90
    VIN: WAURVAFD4BN019274   Mileage: 215827km-134108miles
    Address 01: Engine (------CDRA)       Labels:| 079-907-560-CFS.clb
       Part No SW: 4H0 907 560 C    HW: 4H0 907 560
       Component: 4.2l V8/4V    H07 0005
       Revision: N5H07---
       Coding: 0106000A290F0168
       Shop #: WSC 59317 001 1048576
       ASAM Dataset: EV_ECM42FSI0114H0907560C 001006
       ROD: EV_ECM42FSI011_AU64.rod
       VCID: 2A0D07BF9C71240B2DF-807E
    16475 - Fuel Trim; Bank 2
              P0175 00 [096] - System Too Rich
                        Mileage: 214526 km
                        Date: 2020.04.28
                        Time: 13:51:27
                        Engine speed: 706.00 /min
                        Normed load value: 28.6 %
                        Coolant temperature: 100 °C
                        Intake air temperature: 31 °C
                        Voltage terminal 30: 14.041 V
                        Unlearning counter according OBD: 31
                        AFS dm: 25.8 kg/h
                        Median injection timing: 0.729 ms
    16497 - Fuel Trim; Bank 1
              P0172 00 [096] - System Too Rich
                        Mileage: 214526 km
                        Date: 2020.04.28
                        Time: 13:51:18
                        Engine speed: 738.50 /min
                        Normed load value: 31.0 %
                        Coolant temperature: 101 °C
                        Voltage terminal 30: 14.112 V
                        AFS dm: 29.0 kg/h
                        Median injection timing: 0.786 ms
       Part No SW: 4H1 927 158 AD    HW: 0BK 927 156 AF
       Component: 0BK 42 FSIUSA H19 1007
       Revision: --H19---
       Coding: 000002
       ASAM Dataset: EV_TCMALX51011 002018
       ROD: EV_TCMALX51011_002_AU64.rod
       VCID: 72BDDFDF74212CCB55F-8026
       Part No SW: 4H0 907 379 B    HW: 4H0 907 379 B
       Component: ESP PREMIUM   H10 0273
       Coding: 44E6F20022674F00E200
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ESPPremi 005006
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 313F10D3B1A757D3EC5-8064
       Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 AD
       Component: BCM2 2.0      H24 0510
       Coding: 0D872000000000000000
       Shop #: WSC 51988 000 1048576
       VCID: 6E85CBAF6099082BB17-803A
       Serial number: 2311000024780007
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Revision: AA000000    Serial number: 00001002323265
       Coding: C018320085043201010001010101112131313333283333
       Shop #: WSC 02313 785 00200
       VCID: 353724C3454F7BF3B0D-8060
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 E    HW: 4H0 820 043 E
       Component: Klima 3 Zonen H14 0063
       Coding: 4881222E88
       VCID: 221DEF9FE441FC4B65F-8076
    0137 - Motor for  Right Side Window Defrost Flap
              B10D8 22 [008] - Signal Amplitude Too High
                        Reset counter: 253
                        Mileage: 214447 km
                        Date: 2020.04.27
                        Time: 23:45:16
    0378 - Coolant Circulation Pump
              B10D0 04 [008] - Internal System Fault
                        Reset counter: 10
                        Mileage: 214464 km
                        Date: 2020.04.28
                        Time: 13:05:41
       Part No SW: 4H0 907 063 L    HW: 4H0 907 063 D
       Component: BCM1 2.0      H12 0092
       Revision: 15012002    Serial number: 00000000954392
       Coding: 02002091163C9FE1CB008804A0003908009CD30882000121800008402000
       VCID: 313F10D3B12757D3EC5-8064
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 110209  H32 0040
       Serial number:         110220170422
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 10062557
       Coding: 025523
       Subsystem 3 - Part No SW: 4H0 941 531 D    HW: 4H0 941 531 D
       Component: E1 - LDS  H07 0044
       Serial number: 16 02 2011  00000311
       Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
       Component: USHL4.2  H30 0020
       Serial number: 0000001805569R0B2L06
       Subsystem 5 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0280
       Serial number: WA101933000000179814
       Coding: 020300
       Serial number: 8348C095000000000001
    02893 - Valet Parking Lock Button (E536)
                        Reset counter: 1
                        Mileage: 214615 km
                        Date: 2020.04.28
                        Time: 19:20:00
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4H0 035 108 D    HW: 4H0 035 108
       Component: DVDCAlpine    H42 0180
       Revision: AA001001
       VCID: 211FE093E1C7E7537C5-8074
       Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0030
       Revision: 11001001    Serial number: 55901103503100
       Coding: 300102
       ASAM Dataset: EV_EPHVA18AU57X0000 001002
       ROD: EV_EPHVA18AU57X0000_001.rod
       VCID: 372B2ECB5FC389E3A21-8062
       Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
       Component: Airbag10.43   H41 0041
       Revision: --------    Serial number: 003JS0011W42
       Coding: 303143303230303030344A55304C34483053
       Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
       Serial number: 5850000R1112801DNW
       Serial number: 3575HRB405H09RECA034
       Serial number: 3585HRB405H0C15IFGQN
       Serial number: 3515JRB405P0AMH0LGEX
       Serial number: 3525JRB405P0AMH0B04+
       Serial number: 3554VRB404V0BTBEA84/
       Serial number: 3564VRB404V0BTBEI1JE
       Part No SW: 4H0 953 568 B    HW: 4H0 953 568 B
       Component: Lenks.Modul   H08 0007
       Revision: --------    Serial number: 90815KB100003
       Coding: 000434
       VCID: 323D1FDFB4216CCB95F-8066
       Subsystem 1 - Part No SW: 4H0 951 528 H    HW: 4H0 951 528 H
       Component: E221 - MFL  H04 0009
       Serial number: 04 09 2010  33021996
       Part No SW: 4H0 920 920 C    HW: 4H0 920 920
       Component: TBenUSA------ H30 0309
       Revision: 26110011    Serial number: 658030211593005
       Coding: 0B6608011B00D705020000
       ASAM Dataset: EV_RBD4K 004033
       ROD: EV_RBD4K_AU64.rod
       VCID: 2517F483F56F0B7300D-8070
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
       Component: Analoguhr D4  H05 0224
       Serial number: 1110206000573
       Part No SW: 4H0 907 468 E    HW: 4H0 907 468 C
       Component: J533--Gateway H08 0204
       Revision: --------    Serial number: 00000000100973
       Coding: 00C1034A00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 33331ADB4BBB65C39E9-8066
       Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650552908
       Part No SW: 4H0 907 553 C    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H17 0096
       Coding: 008000
       ASAM Dataset: EV_AirSuspe 003022
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2C0101A796853A3BDF3-8078
       Revision: AA000000    Serial number: 00001002323224
       Coding: C0183B0085053201010001010101112131313333203333
       Part No SW: 4H0 907 637     HW: 4H0 907 637
       Component: SARA 6D       H02 0015
       Revision: --------    Serial number: EJ1BPA3100D5EU0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 6C81C1A75605FA3B9F3-8038
       Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
       Component: TSG FA        H02 0162
       Revision: --------    Serial number: 0000113119179
       Coding: 011F1F205E0062C202000006
       Shop #: WSC 02312 785 00200
       VCID: 3B2332FB636BAD83469-806E
       Revision: 00002001    Serial number: 0143176864
       Coding: 0106023A00FA7585B0B0C7C0020100000000000000000000000000000000
       Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
       Component: GTO BF  H01 0070
       Serial number: 00000000000000021323
       Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
       Component: J245 PS50.028  H06 0006
       Serial number:     WOO11367361
       Coding: 020200
       Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
       Component: Dachelektroni  H11 0080
       Serial number: A2011000000000339709
       Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
       Component: V252 PS009  H05 0004
       Serial number:     WOO1000BSO
       Part No SW: 4G0 035 223 A    HW: 4G0 035 223 A
       Component: BOSE G3 C7    H07 0070
       Revision: CJ007000    Serial number: 00000000020232
       VCID: 1B63D27BC3ABCD83A69-804E
       Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
       Component: TSG BF        H02 0162
       Revision: --------    Serial number: 0000113125256
       VCID: 3A2D37FF6C51948B5DF-806E
       Revision: --------    Serial number: 00000000038343
       ROD: EV_ParkiBrake_VW51.rod
    Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
       Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
       Component: ....AFS13.... H01 0011
       Serial number: 110210-0004-027
       Coding: 12116F33701AA400
       ASAM Dataset: EV_AdvanFrontSyste 005001
       ROD: EV_AdvanFrontSyste_AU21.rod
       VCID: 303915D7BAAD5EDBE3B-8064
    H02 0006
       Coding: 1C0000
    H02 0006
       Coding: 1C0000
       Part No SW: 4H0 035 082 A    HW: 4H0 035 082
       Component: Radio U SIRIU H51 0068
       Revision: AB001007    Serial number: 155BX0B7500858
       Coding: 020007010000000001
       VCID: 1F1BE66BD7B3D1A34A1-804A
       Part No SW: 4H0 035 664 B    HW: 4H0 035 664
       Component: H-BN-NA       H48 0294
       Revision: --------    Serial number: 098B.0B7501558
       Coding: 020200000001F1EF45128B0E00000003F400010000000000
       VCID: 2615F38F88E9006B097-8072
       Subsystem 1 - Part No: 8R0 060 884 AC
       Component: NAR 2011  0503
       Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
       Component: DU8 D4 SV NB  H46 0021
       Serial number: AUZ8ZDB1100DVP+
       Subsystem 3 - Part No SW: 4H1 919 600 D    HW: 4H1 919 600
       Component: E380 BDT D4  H09 0063
       Serial number: 00000000029007
       Component: CD-Database  2712
       Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
       Component: TSG HL        H04 0162
       Revision: --------    Serial number: 0000113074909
       Coding: 010F1F20400062C202000006
       VCID: 392F28F369579F93545-806C
       Part No SW: 4H0 907 441     HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0030
       Revision: --H04---    Serial number: 525 PA8J11D1C9
       Coding: 1020003
       VCID: 6597B483B96FCB73C0D-8030
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0036
       Revision: 10011001    Serial number: 039100495
       Coding: 0210044100
       ROD: EV_DeckLidContrUnit.rod
       VCID: 3B2332FB63EBAD83469-806E
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Revision: --------    Serial number: 000000024276
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 6393AA9BBBDBB5432E9-8036
       Component: TSG HR        H04 0162
       Revision: --------    Serial number: 0000113075007
    Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
       Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
       Component: GSM-LL        H07 0083
       Revision: 0L0D5012    Serial number: SN110118  0107
       ROD: EV_GSM2x3Mono_AU64.rod
       VCID: 2B0302BB938B3D03D69-807E
       Serial number: 00000003154701
       Coding: 764FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 2F3B16ABA7934123FA1-807A
       Serial number: 00000003154402
       Coding: 364FF2
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       Coding: 00060000031F000000030801424CDA010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L_VW51.rod
       VCID: 6FBBD6AB67130123BA1-803A
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R_VW51.rod
       VCID: 70B9D5D77A2D1EDBA3B-8024
    End----------(Elapsed Time: 02:44, VBatt start/end: 12.0V/12.0V)-----------
    Could the high crankcase PCV pressures be from blow by and fuel contamination in sump from faulty HPP EVAP and possible leaking injectors?
    Sure sounds like a safety recall campaign waiting to happen no & since passed useful life, did you report to NHTSA yet?
    Did you know you are behind for firmware update level?
    May 2020
    What firmware are you referring to exactly? Are you talking about ECM software version?
    I wasnt aware that my misfires/PCV were NHTSA related. Seems like there are a lot of PCV issues in these cars in the Audiworld forum.....therefore a recall would have been initiated
    United States
    Yes, Engine. I searched our TSB/TPI collection and although there were 12 documents all of them were for SWL 004 and lower. Oddly, there's a level 0006 but I can't locate the TPI associated with it. Jack may be able to add clarity.
    HPFP failure is common so I agree with that suggestion. One of the high pressure fuel pumps could be leaking gas directly into the oil resulting in Rich on both banks. Although it would only mask the problem you could change the oil to see if the problem and reoccurring rich DTCs return within a few days or not but if one of those pumps is blown out it could contaminate new oil in a few hours.
    I suppose the better option might be to get a dipstick (or something you can grab a sample with) and see if the existing oil smells like gas. If it does I wouldn't run the engine like that until the source has been identified and corrected followed by an oil change.
  5. Likes Uwe, ai_Ingo, Jack@European_Parts liked this post
    Jan 2020
    Germany (Auto-Intern)
    I absolutely agree with Dana. I had the problem with a leaky high pressure pump more than once.
  7. Likes Dana, Jack@European_Parts, Uwe liked this post
    Does anyone doubt Dana is indeed correct?
    Does anyone doubt me?
    Let me ask some more questions okay?
    Did you know OP, it is strongly recommended you report your issue's to NHTSA & to possibly protect your ability to seek reimbursement for an obvious need for a Safety recall?
    Hey did you additionally know that due to laziness by ORVR, that EVAP and fuel system related certified components as Zero type & for clear widespread failure of reclamation, indeed are a safety issue and a SMOG related useful life warranty when a carry over is used that was certified for 15 years or 150k, however, additionally since a safety issue by design documented mechanical and electronic AECD failure, this is an unlimited timeline for extension of such coverage?
    Are you prepared to do your part and submit a complaint to NHTSA?
    https://forums.ross-tech.com/showthr...l=1#post156577
    Yup question marks in place check!
    May 2020
    What part of the Autoscan depicts the actual SWL?? is it the "0005"??
    Also, in order to get this updated...will dealer charge me for this? Or should a software update be a complimentary service when I have already paid for 3 diagnostic checks within the past year??
    Im just asking becuase, i like to be armed with information before i go the dealer and claim something. I want to be able to show them my Autoscan depicting the old software version, and what is should be
    Revision: N5H07---
  10. #8
    May 2020
    Thanks for the suggestion about dipstick. Simple nomenclature that I can understand. I know my way around cars.....just new to Audi technology and nomenclature.
  11. #9
    Quote Originally Posted by derekmyoung View Post
    Yes.
    It's an 8 year old car. I wouldn't expect much free from a dealer unless there's some kind of special campaign or recall.
  12. Likes PetrolDave liked this post
  13. #10
    ARE NOT FIRMWARE UPDATES PART OF USEFUL LIFE WARRANTY & SHEAR ADMITTANCE A VEHICLE FAILS OR FAILED TO COMPORT AS CERTIFIED IF NOT MADE AVAILABLE FOR FREE OR BY CAMPAIGN IN ADR?
    IS THE WARRANTY 10/120K OR 15/150K IS THERE AN ORVR, LET'S HAVE A LOOK AT THE SLIPPERINESS?
    OH DEAR?
    Section 17 Pg. 6 California ARB Information Engine Code: R.CH-No.: Revision Date:Part 1 Test Group: BADXV04.23UH CDR 12-27-2010
    https://literature.audiusa.com/calibration_lookup.asp
    https://iaspub.epa.gov/otaqpub/displ...d=23725&flag=1
    https://iaspub.epa.gov/otaqpub/displ...d=23726&flag=1
    https://iaspub.epa.gov/otaqpub/displ...d=24165&flag=1
    https://iaspub.epa.gov/otaqpub/displ...d=23727&flag=1
    Revision: N5H07---
    Revision: --H19---
    Coding: 000002
    Model Audi A8L qu. 4.2
    A8Q
    Date of production 01.03.2011
    Model year 2011
    Sales type 4H85AA
    Engine Code CDRA
    Transmission Code MXR
    Emission standard 7GB Emission standard ULEV 2
