I took my car to a shop to have my lower control bushings replaced and while there the mechanic stated that my dash panel lite up like a Christmas tree and he "shut off" my ABS module. I am trying to undo what this mechanic did.
Log below:
Log below:
Friday,13,March,2020,11:08:25:14114
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWAA71K88W055654 License Plate:
Mileage: 165590km-102892mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 08 09 15 16 17 19 25 42 44 46 52 56 65
VIN: WVWAA71K88W055654 Mileage: 165590km-102892miles
16-Steering wheel -- Status: Not registered 0001
44-Steering Assist -- Status: Not registered 0011
Address 01: Engine (CBT) Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 BK HW: 07K 906 032 Q
Component: 2,5l R5/4V G 1568
Revision: 1NH01--- Serial number: VWX7Z0G63N384C
Coding: 0000001
Shop #: WSC 01279 785 00200
VCID: 73B3D98397B65ABFC47-8026
049441 - No Communication with ABS Brake Control Module
U0121 - 008 -
Fault Status: 01101000
Mileage: 165597 km
Time: 20:14:24
Load: 0.0 %
Temperature: 22.0°C
Temperature: 29.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.192 V
Readiness: 0010 1101
Part No SW: 1K0 820 047 GF HW: 1K0 820 047 GF
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
VCID: 6E85C8F7FC9477572B9-803A
01316 - ABS Control Module
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Revision: 00H54000 Serial number: 01000007211396
Coding: 108D0F214004150047140000001400000008730B5C000100000000000000
Shop #: WSC 03207 444 00944
VCID: 6FBBD5F3FB9E7E5F20F-803A
Component: Wischer 040707 021 0501
Coding: 00038805
Shop #: WSC 03207
00927 - Terminal 30 (Right)
Fault Status: 00101011
Reset counter: 163
Mileage: 165597 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.15 V
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D090AMV
Coding: 0013899
Shop #: WSC 01269 785 00200
VCID: 6C81C2FFCA88854705D-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME193466257
Subsystem 3 - Serial number: 6342MSME19767C51K
Subsystem 4 - Serial number: 6352QSME2E0B392DV
Subsystem 5 - Serial number: 6362QSME335620030
Subsystem 6 - Serial number: 63727SME0D4748512
Subsystem 7 - Serial number: 63827SME0D470F202
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000022
VCID: 74B1DA9F92B85D87DDD-8020
Part No SW: 1K0 920 954 F HW: 1K0 920 954 F
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0G63N384C
Coding: 0007203
Shop #: WSC 03170 444 84404
VCID: 2F3B15F33B1E3E5F60F-807A
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 020707F2000573
Coding: 198F024007000000
Fault Status: 01110100
Reset counter: 122
Mileage: 165597 km
Time: 23:46:15
Fault Frequency: 227
Reset counter: 126
Mileage: 165597 km
Time: 23:46:16
Fault Frequency: 192
Mileage: 165597 km
Time: 22:37:17
Component: IMMO VDD 1212
Component: Tuer-SG 006 120A
Coding: 0001077
VCID: 38292EAFCE50F9E7315-806C
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 00000 028 00001
VCID: 3537279BD942048F2A3-8060
00625 - Vehicle Speed Signal
Mileage: 165580 km
Temperature: 29.0°C
Voltage: 12.20 V
Voltage: 12.00 V
00750 - Warning Lamp
Mileage: 165580 km
Temperature: 26.0°C
Voltage: 11.60 V
Voltage: 11.40 V
Coding: 139006885103281B0904058FB0080A04889C80
Shop #: WSC 01287 785 00200
VCID: 04518A5FC2186D07EDD-8050
Coding: 0001076
VCID: 392F2BABF55AE0EFCEB-806C
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 56: Radio
Component: RDK 0450
Coding: 0100101
Fault Status: 00111000
Reset counter: 162
Mileage: 165597 km
Time: 00:18:24
End----------(Elapsed Time: 00:55, VBatt start/end: 14.1V/14.2V)-----------
Sunday,03,May,2020,18:25:39:14114
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Coding: 0000001
VCID: 73B3D98397B65AB35E9-8026
U0121 - 008 -
Fault Frequency: 15
Mileage: 165597 km
Time: 20:14:24
Load: 0.0 %
Temperature: 22.0°C
Temperature: 29.0°C
Voltage: 12.192 V
001281 - Vehicle Speed Sensor
P0501 - 002 - Implausible Signal
Fault Status: 01100010
Mileage: 165597 km
Time: 22:54:12
RPM: 2268 /min
Load: 16.1 %
Temperature: 85.0°C
Temperature: 33.0°C
Voltage: 14.097 V
VCID: 6E85C8F7FC94775BB17-803A
VCID: 6FBBD5F3FB9E7E53BA1-803A
Coding: 00038805
Shop #: WSC 03207
00926 - Terminal 30
Reset counter: 167
Mileage: 165597 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 5.00 V
Reset counter: 163
Mileage: 165597 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.15 V
Coding: 0013899
VCID: 6C81C2FFCA88854B9F3-8038
Coding: 0000022
VCID: 74B1DA9F92B85D8B473-8020
Coding: 0007203
VCID: 2F3B15F33B1E3E53FA1-807A
Reset counter: 122
Mileage: 165597 km
Time: 23:46:15
Reset counter: 127
Mileage: 165597 km
Time: 23:46:16
Fault Frequency: 240
Mileage: 165597 km
Time: 22:37:17
Coding: 0001077
VCID: 38292EAFCE50F9EBABB-806C
VCID: 3537279BD9420483B0D-8060
Mileage: 165580 km
Temperature: 29.0°C
Voltage: 12.20 V
Voltage: 12.00 V
Mileage: 165580 km
Temperature: 26.0°C
Voltage: 11.60 V
Voltage: 11.40 V
VCID: 04518A5FC2186D0B773-8050
Coding: 0001076
VCID: 392F2BABF55AE0E3545-806C
Address 56: Radio
Component: RDK 0450
Coding: 0100101
Reset counter: 162
Mileage: 165597 km
Time: 00:18:24
End----------(Elapsed Time: 00:54, VBatt start/end: 14.3V/14.3V)-----------
