Auto upshift
BB tt
TX, USA
C?ID=281085
Previously disabled auto upshift with an older version of VCDS, got a new computer loaded vcds and now when i select adaptation channel IDE06873 (automatic Upshift) is no longer in the drop down menu.
https://imgur.com/fZ1tRi5
when i go to long coding under byte 1 it is there but selecting it does nothing, it wont let me change the long coding. disabled should be 000002 and enabled should be 000102
https://imgur.com/VMHrORs
https://imgur.com/AajatJS
edit added autoscan:
 Sunday,03,May,2020,11:54:28:51129
VCDS Version: 20.4.1.0 (x64)
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 47 52 53 55
          56 5F 62 6C 6D 72
VIN: WAU4FAFL0BA143516   Mileage: 132020km-82033miles
Address 01: Engine (0-----CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AG    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H19 0002
   Revision: E1H19---
   Coding: 010C010A290F0260
   Shop #: WSC 82976 802 690857
   ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
   ROD: EV_ECM20TFS0118K2907115AG.rod
   VCID: 74E7A39EDF7C96261F-8020
Readiness: 1110 0100
   Part No SW: 8K0 927 158 S    HW: 0BK 927 156 R
   Component: 0BK 20TFSIUSA H08 1005
   Revision: --H08---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 46832956F96054B671-8012
   Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
   Component: ESP8 quattro  H04 0060
   Coding: 1D0D18
   Shop #: WSC 06334 000 00000
   VCID: 020BF5469DC8A8961D-8056
   Part No SW: 8K0 907 064 CH    HW: 8K0 907 064 CH
   Component: BCM2 2.0      H05 0435
   Coding: 0D0200
   Shop #: WSC 06335 000 00000
   VCID: 78FF97AECB14F24633-802C
   Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Serial number: 2311000036059006
   Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
   Component: KLIMA 3 ZONEN H08 0180
   Revision: C1000000    Serial number: 01170320110384
   Coding: 64102000
   VCID: 000FFF4E93C4BA860B-8054
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000000987968
   Coding: 26001011003CAF211400080300003D0D4F9C460802010161000000
   Shop #: WSC 06335 123 12345
   VCID: 3C774BBEBFAC1E6617-8068
   Component: WWS 150311  H07 0070
   Serial number: SWF11030155090
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11328707
   Coding: 025028
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000803111272
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
03207 - Charisma Switch Module
                    Reset counter: 26
                    Mileage: 132029 km
                    Date: 2020.05.03
                    Time: 10:49:00
   Part No SW: 8K0 919 475 T    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H01 0080
   Revision: 11001001    Serial number: 36891106754845
   Coding: 300103
   VCID: 4A9B1D66E578B0D695-801E
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561     HW: 8K0 907 561
   Component: ACC2          H09 0080
   Coding: 00C7AE
   VCID: 6FEDACF2BE5AB5FEE2-803A
   Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003GLD0NA8CK
   Coding: 303837354230303030304A55304C384B3053
   VCID: 45812E5AC4665FAE78-8010
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1000002FFU
   Serial number: 6334MSME5C7512229
   Serial number: 6344MSME5C356F32P
   Serial number: 6352QSME61082D76K
   Serial number: 6362QSME5B0A4650J
   Serial number: 63732SME28062672W
   Serial number: 63832SME2D062850-
   Part No SW: 8R0 953 568 M    HW: 8R0 953 568 M
   Component: Lenks.Modul   H07 0156
   Revision: 00000000    Serial number: 20110317000482
   Coding: 00003F
   VCID: 4B951862EA02A9DEAE-801E
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 981 H    HW: 8K0 920 981 H
   Component: KOMBIINSTR.   H24 0258
   Revision: 00000000    Serial number: EJJ73E13C
   Coding: 835F11000700D704020000
   VCID: 387F57AE8B943246F3-806C
   Part No SW: 8T0 907 468 AE    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0117
   Revision: FC100058    Serial number: 5800F1122800F9
   Coding: 00C303
   VCID: 0407F35E87DCA6A62F-8050
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H07 0170
   Serial number: 1100DFA2010311
   Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00001002352920
   Coding: 00581B00000000000000
   VCID: 3B7548A2BAA2195E1E-806E
   Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0030
   Revision: 00H01000    Serial number: 6PZ 009 014-82
   Shop #: WSC 23181 002 1048576
   VCID: 3C774BBE7FAC1E6617-8068
   Subsystem 1 - Part No: 8K0 907 568 H
   Component: J0770_SWA_Slave_H01 0030
   Subsystem 2 - Serial number: 6PZ 009 014-92
   Subsystem 3 - Serial number: 5F03.03.1100H010003C321420ÿ
   Subsystem 4 - Serial number: 321420ÿ
   Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
   Component: TSG FA        H12 0357
   Revision:             Serial number: 0004100038559
   Coding: 011C13204E00410001
   Revision: 00002001    Serial number: 0142789328
   Coding: 013E0E3A20BA741583B0023204000000
   Component: GTO BF  H01 0070
   Serial number: 00000000000000375074
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS136  H07 0041
   Subsystem 4 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J394 PS229  H07 0041
03156 - Sensor for Anti-Theft System (G578)
                    Reset counter: 26
                    Mileage: 132029 km
                    Date: 2020.05.03
                    Time: 10:49:36
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34804004322301
   VCID: 7AFB8DA6F518E05645-802E
   Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0004100036673
   Coding: 011C13205E00410001
   VCID: 4999226AE07EBBCE9C-801C
   Revision: 00000003    Serial number: 10000000747799
   VCID: 3467639E97FCD626DF-8060
   Part No: 8K5 907 357 B
   Coding: 0000004
   VCID: 397952AA709E2B4E0C-806C
   Part No SW: 4G0 035 082     HW: 4G0 035 082
   Component: Radio U SIRIU H51 0052
   Revision: AB001007    Serial number: 471C50B7565987
   Coding: 020007010000000001
   VCID: 5DB1E63A44F6376E40-8008
   Part No SW: 8T1 035 664 C    HW: 8T1 035 664 B
   Component: H-BN-NA       H51 0116
   Revision: --------    Serial number: 490C60B7609889
   Coding: 010200010106E9EF75001F0E000000030000
   Subsystem 1 - Part No: 8R0 060 884 P
   Component: NAR 2010  0407
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Serial number: 9466C-0B0538276
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Component: E0380 Bedient  H08 0100
   Serial number: 00000000770413
   Component: CD-Database  1886
   Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000114049023
   Coding: 010C13204000210001
   VCID: 45812E5ACC665FAE78-8010
   Revision: --H05---    Serial number: 525PA8-J0Z93QF
   Coding: 1000007
   VCID: 387F57AE4B943246F3-806C
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Component: J605  Master  H51 0330
   Revision: --------    Serial number: 8K9827851A
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
   Component: J756  Slave  H51 0330
   Serial number: 8K9827852A
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000114049024
End-------------------------(Elapsed Time: 04:08)--------------------------
Mari
C?ID=150535
No photos available, host them somewhere else not on Google Drive...
PetrolDave
Westbury, UK
C?ID=1423
Previously disabled auto upshift with an older version of VCDS, got a new computer loaded vcds and now when i select adaptation channel IDE06873 is no longer in the drop down menu.
What was the text after IDE06873?
The text description of adaptation channels remains the same but several versions ago the numeric 'tag' was changed - so if you search for the text descriptor it will still be there.
BB tt
TX, USA
C?ID=281085
Automatic upshift (updated original post to show)
Do you have an old Auto-Scan back from when you made this change originally?
Why do you say you can't change the coding? What error message do you get when you do so?
BB tt
TX, USA
C?ID=281085
Get adaptation error
here is an original scan from when i bought the car before i changed anything on car.
Sunday,25,March,2018,19:09:51:51129
VCDS Version: 17.8.1.0 (x64)
VIN: WAU4FAFL0BA143516   License Plate: IKJ
Mileage: 101600km-63131mi   Repair Order:
          56 5F 62 6C 6D 72
VIN: WAU4FAFL0BA143516   Mileage: 101600km-63131miles
   Revision: E1H19---
   Shop #: WSC 41877 001 1048576
   VCID: 74E7A39EDF7C96E685-8020
4063 - Cylinder 4
          P0304 00 [032] - Misfire Detected
4057 - Cylinder 2
          P0302 00 [032] - Misfire Detected
4051 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [032] - -
   Revision: --H08---
   Coding: 000002
   VCID: 46832956F9605476EB-8012
   Coding: 1D0D18
   VCID: 020BF5469DC8A85687-8056
   Coding: 0D0200
   VCID: 78FF97AECB14F286A9-802C
   Coding: 64102000
   VCID: 000FFF4E93C4BA4691-8054
   Coding: 26001091063CAF010000080300003D0D0F1C460802010161000000
   VCID: 3C774BBEBFAC1EA68D-8068
   Coding: 00FD11
   Coding: 025028
   Coding: 200103
   VCID: 4A9B1D66E578B0160F-801E
   Coding: 00C7AE
   VCID: 6FEDACF2BE5AB53E78-803A
   VCID: 45812E5AC4665F6EE2-8010
   Coding: 00003F
   VCID: 4B951862EA02A91E34-801E
   Coding: 8B1611000700D705020000
   VCID: 387F57AE8B94328669-806C
   Coding: 00C303
   VCID: 0407F35E87DCA666B5-8050
   VCID: 3B7548A2BAA2199E84-806E
   VCID: 3C774BBE7FAC1EA68D-8068
   Coding: 0126023A20BA741580B0023200000000
   VCID: 7AFB8DA6F518E096DF-802E
   VCID: 4999226AE07EBB0E06-801C
   VCID: 3467639E97FCD6E645-8060
   Coding: 0000004
   VCID: 397952AA709E2B8E96-806C
   VCID: 5DB1E63A44F637AEDA-8008
   Coding: 010200010006A9EF71000B0E000000030000
   VCID: 45812E5ACC665F6EE2-8010
   Coding: 1000007
   VCID: 387F57AE4B94328669-806C
End-------------------------(Elapsed Time: 04:06)--------------------------
BB tt
TX, USA
C?ID=281085
Is there a reason it doesn't show up in the drop down menu like it used to? I have previously turned it on and off several times, usually use it for pulling 3rd gear logs.
Interesting. It was indeed present in EV_TCMAL551211_002_AU48.ROD in DS276, but is missing from EV_TCMAL551211_002_AU48.ROD in DS317. I do not know why that channel has gone missing from the definitions.
Stand by while I check some of the versions in between to see when it went away.
OK, I found the boundary. It's present in DS296 and went missing in DS308.
This is mostly for Yanping's benefit, so she can investigate why it went missing.
Meanwhile, you have a PM with a link to an older version that should have the channel in question.
BB tt
TX, USA
C?ID=281085
Thanks UWE!!!! you are awesome!
jay f.
St. Petersburg, FL, USA
C?ID=420015
Wasn't sure if I should start a new thread or continue with this one.
Very similar issue with my 2013 A6 3.0t, but unlike the op I just bought my scanner, so I have only used the newest version of VCDS. However, just like the op I do not have Auto upshift disable available to me in my drop down menu. I have attached my scan below. It's a tad wonky, being that I had to convert the PDF that I saved. I can reload when I get home if need be. Thanks for any help you guys can provide
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 20.4.2(x64) Data version: 20200730 DS317.0 www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log Monday,26,October,2020,15:06:42:46482
VIN: WAUHGAFC5DN130111   License Plate: Mileage:    Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 47 52           53 55 56 5F 62 6C 72 8F 90
VIN: WAUHGAFC5DN130111   Mileage: 202312km-125710miles
Address 01: Engine (J623-CTUA)       Labels: None
   Part No SW: 4G0 907 551 D    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0006
   Revision: --H07---
   Coding: 0A2A0034052601060000
   ASAM Dataset: EV_ECM30TFS0214G0907551D 001007
   ROD: EV_ECM30TFS0214G0907551D.rod    VCID: 2A0D0672FC74707B2C7-807E
6506 - MIL Request Signal Active (Check TCM for errors too!)
          P1624 00 [109] - -
          Confirmed - Tested Since Memory Clear          Freeze Frame:
                Mileage: 200734 km
                Date: 2020.10.01
                Time: 12:04:29
                Engine speed: 670.00 /min
                Normed load value: 15.7 %
                Coolant temperature: 52 °C
                Intake air temperature: 54 °C
                Voltage terminal 30: 12.390 V
                Engine speed: actual: 1280 /min
                MAF_ENVD: 283.24705 mg/stroke
                Coolant temperature (unfiltered): 42.00 °C
                Engine: operating status: IS                 Engine load: 20.312500 %
                Vehicle speed: actual: 0 km/h
20136 - PCV Valve Malfunction
          P052E 00 [104] - -
          Intermittent - Confirmed - Tested Since Memory Clear          Freeze Frame:
                Fault Frequency: 33
                Mileage: 192341 km                 Date: 2020.06.10
                Time: 12:51:20
                Engine speed: 707.00 /min
                Normed load value: 13.7 %
Page 3
                Intake air temperature: 59 °C
                Voltage terminal 30: 13.507 V
                Unlearning counter according OBD: 36
                Engine speed: actual: 672 /min
                MAF_ENVD: 163.41176 mg/stroke
                Coolant temperature (unfiltered): 99.75 °C
                Engine load: 17.187500 %
   Part No SW: 4G1 927 158 A    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H16 1006
   Revision: --H16---       Coding: 000002
   ROD: EV_TCMAL551211_002_AU48.rod    VCID: 2D070D6ECD9A6743C95-8078
12446 - Valve for Transmission Fluid Cooler
          P2753 00 [175] - Open Circuit
          MIL ON - Confirmed - Tested Since Memory Clear          Freeze Frame:
                Fault Frequency: 10
                Mileage: 200112 km
                Date: 2020.09.28
                Time: 15:33:10
                Voltage terminal 30: 12.983 V
                Voltage supply of regulator valves: 12.925 V
                Current N215 Pressure control valve 1: 850.0 mA
                Current N218 pressure reg.valve 4: 50.0 mA
                Current N216 pressure reg.valve 2: 277.6 mA
                Current N233 pressure reg.valve 5: 50.0 mA
                Current N217 pressure reg.valve 3: 50.0 mA
                Current N371 pressure reg. valve 6 lock-up clutch: 50.0 mA
                Current N443 pressure reg.valve 7 main pressure: 706.9 mA
                Current solenoid: 1000.0 mA
                Engine speed: 703 /min
                Transmission fluid temperature: 54 °C                 Control Module temperature: 54 °C                 selected gear: without traction
                M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
                M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
                M015_Time Normal Mode: 17 s
                M019_Time Since Reset: 7650 ms
12448 - Valve for Transmission Fluid Cooler
                Fault Status: 00000001                 Fault Priority: 2
                Fault Frequency: 54
                Mileage: 200616 km
                Time: 12:36:29
                Voltage terminal 30: 12.918 V
                Voltage supply of regulator valves: 12.857 V
                Current N216 pressure reg.valve 2: 276.2 mA
                Current N443 pressure reg.valve 7 main pressure: 704.8 mA
                Engine speed: 706 /min
                Transmission fluid temperature: 72 °C                 Control Module temperature: 74 °C                 selected gear: without traction
                M015_Time Normal Mode: 10 s
   Coding: 44A78F0122E5F1804B00
   ROD: EV_ESPPremiAU57X_004_AU57.rod    VCID: 3635220238CC249BB8F-8062
   Part No SW: 4H0 907 064 CR    HW: 4H0 907 064 CR
   Component: BCM2 2.0      H33 0433
   Coding: 0DA82046000000000000
   VCID: 7BA3F33643EE39F3071-802E
   Component: J764 ELV MLB  H40 0046    Serial number: 2313000035236008
   Part No SW: 4G0 820 043 AF    HW: 4G0 820 043 AF
   Component: KLIMA 4 ZONEN H13 0086
   Serial number: 07031300041434
   Coding: 668120BA49
   ASAM Dataset: EV_AirCondiComfoUDS 002040
   ROD: EV_AirCondiComfoUDS_002.rod    VCID: 6393AB56DBDEE1332F1-8036
   Revision: 11012002    Serial number: 00000001528932
   Coding: 09072091073C9FE081000884A0003800CF9CD208A60802258001085C7B00
   VCID: 6FBBD76607965553BB9-803A
   Component: WWS57X 130301  H36 0080
   Serial number:         130305002034
   Coding: 0045F7
   Serial number: 21076967
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 08 03 2013  00001158
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R571J02
   Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0051785389
   Coding: 853000
   Serial number: 00000008031300010872
   Coding: 110000
   Subsystem 7 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Serial number: 00000005031300010968
   Coding: 110000
   Subsystem 8 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA104972000002988293
   Coding: 020300
   Subsystem 9 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0003    Serial number: 4269C996000000000001
   Revision: 11001001    Serial number: 61061307503935
   Coding: A8C306
   ROD: EV_EPHVA18AU57X0000_004.rod    VCID: 71BFD11E112243A3ADD-8024
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D8002V63N
   Coding: 303234373131303030314A55304C34473053
   ROD: EV_AirbaAU10BPAAU64X_VW51.rod    VCID: 33331B162BBE31B39F1-8066
   Serial number: 6940000Y130000RU9E08
   Serial number: 3575HRB400850F5M615H
   Crash sensor for side airbag: front passenger side:    Serial number: 3585HRB40511TEI42P3A
   Crash sensor for side airbag: rear: driver side:    Serial number: 3515JRB401E50FFIR1CB
   Crash sensor for side airbag: rear: passenger side:    Serial number: 3525JRB401I50FFIRP6Y
   Serial number: 3554VRB400K50DLUI9G7
   Crash sensor for front airbag: front passenger side:    Serial number: 3564VRB400K50DLU9PFE
   Revision: --------    Serial number: 90372MC8000YB
   Coding: 000434
   VCID: 38292C3A3258D2EBAA3-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Component: E221 - MFL  H08 0010    Serial number: 16 01 2013  A0145910
   Part No SW: 4G8 920 983 E    HW: 4G8 920 983 E
   Component: TBenUsa       H79 0515
   Revision: 28460208    Serial number: 658080313596054
   Coding: 0BE609040B41D705020000
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod    VCID: 372B2F063FC6DD93A39-8062
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000860147
   Coding: 00CD073000
   ASAM Dataset: EV_GatewPkoUDS 001018
   ROD: EV_GatewPkoUDS_001_AU57.rod    VCID: 71BFD11E112243A3ADD-8024
   Component: J367-BDMHella  H03 8041    Serial number: 9151060203
   Voltage stabilizer:
   Component: J532_DCDCStab  H23 0021    Serial number: 130109000000000004B1
   Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
   Component: KLIMA FOND    H07 0086
   Serial number: 04031300040520
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
   ROD: EV_ClimaContrUnitRearUDS_002.rod    VCID: 372B2F063FC6DD93A39-8062
0025 - Motor for Rear Left Upper Body Vent
          B10D3 22 [008] - Signal Amplitude Too High           Intermittent - Confirmed - Tested Since Memory Clear          Freeze Frame:
                Fault Frequency: 25
                Reset counter: 143
                Mileage: 201842 km
                Date: 2020.10.17
                Time: 16:14:35
                Voltage terminal 30: 13.47 V
                Outside air temperature: 32.0 °C
                Left Rear Upper Body Vent Motor-Act.val.: 12005
                Left Rear Upper Body Vent Motor-Specified value: 12005
                Left Rear Upper Body Vent Motor-Stop open: 11404
                Left Rear Upper Body Vent Motor-Stop closed: 10000
0033 - Motor for Rear Right Upper Body Vent
          B10D4 22 [009] - Signal Amplitude Too High           Confirmed - Tested Since Memory Clear          Freeze Frame:
                Fault Frequency: 34                 Reset counter: 107
                Mileage: 201842 km                 Date: 2020.10.17
                Time: 16:14:35
                Voltage terminal 30: 13.49 V
                Right Rear Upper Body Vent Motor-Act.val.: 12002
                Right Rear Upper Body Vent Motor-Specified value: 12002
                Right Rear Upper Body Vent Motor-Stop open: 11401
                Right Rear Upper Body Vent Motor-Stop closed: 10000
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Revision: AA000000    Serial number: 00000053866793
   Coding: C0581B008F006001000001010101102030303232203232
   Shop #: WSC 02391 785 00200    VCID: 38292C3A3258D2EBAA3-806C
   Component: SARA 6D       H02 0056
   Revision: --------    Serial number: EJ1BPA8202V7CD
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod    VCID: 3635220238CC249BB8F-8062
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH03 0050
   Revision: 00H03000    Serial number: 6PZ 010 287-03
   VCID: 3039141AD6280AABE23-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H03 0050
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F15.03.1300H03000AMS15796ÿ
   Subsystem 4 - Serial number: S15796ÿ
   Coding: 011F17005E00628002000012    Shop #: WSC 02391 785 00200    VCID: 47CB5FC64FA6AD13D39-8012
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0028306398
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod    VCID: 323D1E12D4A438BB947-8066
   Revision: 00002001    Serial number: 0302599378
   Coding: 0106023A00FA408580B0088402050E070000000000000000000000000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000136687
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO2066521$
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00003093835    Coding: 010000
   Revision: CJ007001    Serial number: 00000000040157
   Coding: 030000
   Shop #: WSC 02391 785 00200    VCID: 1D67DDAEBDBA97C3595-8048
   Coding: 011F17005E00628002000002
   Shop #: WSC 02391 785 00200    VCID: 46D552C248ACB41B28F-8012
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)         012 - Electrical Fault in Circuit          Freeze Frame:
                Reset counter: 53
                Mileage: 200566 km
                Date: 2020.09.30
                Time: 07:38:40
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000623382
   ROD: EV_ParkiBrake_VW51.rod    VCID: 2B030376F38E6973D71-807E
   Serial number: 130314-0002-053
   Coding: 1221A6601002A500
   ROD: EV_HeadlRegulBasic.rod    VCID: 2D070D6ECD9A6743C95-8078
------------------------------------------------------------------------------Address 56: Radio (R)       Labels: Redir Fail!
   Part No SW: 4G0 035 082 E    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0121
   Revision: AB001007    Serial number: 156CU0D7704602
   Shop #: WSC 02391 785 00200    VCID: 221DEE5284C4A83B647-8076
   Part No SW: 4G0 035 746 D    HW: 4G0 035 746 B
   Component: H-BNT-NA      H50 0622
   Revision: --------    Serial number: 194C00D7526827
   Coding: 050200000003E1EF55128B1E00000003100001000000000000
   VCID: 2809FC7AE2F8426B3A3-807C
   Subsystem 1 - Part No: 8R0 060 884 BA
   Component: NAR 2013  0703
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDDD000WV27
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204    Serial number: 90349MCE0006H
   Subsystem 4 - Part No: 8R0 060 961 E    Component: CD-Database  4949
   Shop #: WSC 02391 785 00200    VCID: 49CF59FE59B25B63C5D-801C
   Revision: --H06---    Serial number: 525 PA8J32G29H
   Coding: 1080004
   Shop #: WSC 02391 785 00200    VCID: 2615F242E4EC541B08F-8072
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod    VCID: 313F111ED1A203A3EDD-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod    VCID: 323D1E12D4A438BB947-8066
End----(Elapsed Time: 02:33, VBatt start/end: 12.1V/12.1V. VIgn 11.9V)-----
Same TCM, presumably the same issue?
With the 2020 insanity, I'm not sure @Yanping ever saw this thread.
PetrolDave
Westbury, UK
C?ID=1423
How long have you had the "Valve for Transmission Fluid Cooler - Open Circuit" errors?
It might be an idea to fix those errors before trying to make any changes to the transmission settings.
jay f.
C?ID=420015
I agree & actually replaced that valve last Wed. Check engine light is gone.
PetrolDave
Westbury, UK
C?ID=1423
Could you post a new Auto-Scan please - direct from the saved text file this time would be better :thumbs:
jay f.
C?ID=420015
Will do. I should've done that already after replacing the valve, but didn't even think of it with the Holiday. I'll post this evening, as I left my personal laptop at home. Thanks for the help :)
jay f.
C?ID=420015
Took an extra couple of nights, but here is my updated scan
On a side note, I've had a bunch of "Function Restricted due to Missing Message(s)" malfunctions pop up since my original scan? Seems fishy
Thursday,03,December,2020,18:07:16:46482
VCDS Version: 20.12.0.0 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
Mileage: 204988km-127373mi   Repair Order:
VIN: WAUHGAFC5DN130111   Mileage: 204988km-127373miles
   Revision: --H07---
   VCID: 2A0D0672FC74707B0D7-807E
Readiness: 1110 1101
   Revision: --H16---
   Coding: 000002
   VCID: 2D070D6ECD9A6743E85-8078
   VCID: 3635220238CC249B99F-8062
0058 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ComScl_PDU_Getriebe_01_Timeout]
                    Reset counter: 195
                    Mileage: 203671 km
                    Date: 2020.11.18
                    Time: 11:44:36
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: BE
                    Uz: 9A
0060 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ComScl_PDU_Getriebe_03_Timeout]
                    Reset counter: 195
                    Mileage: 203671 km
                    Date: 2020.11.18
                    Time: 11:44:36
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: C1
                    Uz: 9A
0061 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ComScl_PDU_Getriebe_04_Timeout]
                    Reset counter: 195
                    Mileage: 203671 km
                    Date: 2020.11.18
                    Time: 11:44:36
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: CB
                    Uz: 9A
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Ldm_ApbFailureState]
                    Reset counter: 195
                    Mileage: 203671 km
                    Date: 2020.11.18
                    Time: 11:44:37
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 04
                    Uz: 9A
0629 - Tire Pressure Warning
          C102D 00 [008] - -
                    Fault Frequency: 7
                    Reset counter: 187
                    Mileage: 203254 km
                    Date: 2020.11.12
                    Time: 17:16:13
                    VzRef: 4B
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2C
                    Uz: B7
   VCID: 7BA3F33643EE39F3261-802E
                    Fault Status: 00101101
                    Reset counter: 195
                    Mileage: 203671 km
                    Date: 2020.11.18
                    Time: 11:44:37
   Coding: 668120BA49
   VCID: 6393AB56DBDEE1330E1-8036
   VCID: 6FBBD766079655539A9-803A
   Coding: 0045F7
   Coding: 02006D
   Coding: 853000
   Coding: 110000
   Coding: 110000
   Coding: 020300
                    Reset counter: 195
                    Mileage: 203671 km
                    Date: 2020.11.18
                    Time: 11:44:00
   Coding: A8C306
   VCID: 71BFD11E112243A38CD-8024
12648720 - Databus
          [Getriebesteuergerät - Getriebe_03 - kein Signal/keine Kommunikation]
                    Reset counter: 195
                    Mileage: 203671 km
                    Date: 2020.11.18
                    Time: 11:44:36
   VCID: 33331B162BBE31B3BE1-8066
   Coding: 000434
   VCID: 38292C3A3258D2EB8B3-806C
   VCID: 372B2F063FC6DD93829-8062
   Coding: 00CD073000
   Voltage stabilizer:
4226 - No Communication with Transmission Control Module
          U0101 00 [008] - -
                    Reset counter: 195
                    Mileage: 203671 km
                    Date: 2020.11.18
                    Time: 11:44:36
                    Voltage terminal 30: 11.9 V
                    Voltage terminal 15: 12.0 V
                    Control Module temperature: 33 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Coding: 20
          B10D3 22 [009] - Signal Amplitude Too High
                    Fault Frequency: 161
                    Reset counter: 186
                    Mileage: 201842 km
                    Date: 2020.10.17
                    Time: 16:14:35
                    Outside temperature: 32.0 °C
                    Left Rear Upper Body Vent Motor-Target value: 12005
                    Fault Frequency: 189
                    Reset counter: 186
                    Mileage: 201842 km
                    Date: 2020.10.17
                    Time: 16:14:35
                    Right Rear Upper Body Vent Motor-Target value: 12002
   ROD: EV_SARA2.rod
   VCID: 3039141AD6280AABC33-8064
   VCID: 47CB5FC64FA6AD13F29-8012
   VCID: 323D1E12D4A438BBB57-8066
   Coding: 101F00
                    Reset counter: 195
                    Mileage: 203671 km
                    Date: 2020.11.18
                    Time: 11:44:37
   Coding: 030000
   VCID: 1D67DDAEBDBA97C3785-8048
   VCID: 46D552C248ACB41B09F-8012
                    Reset counter: 157
                    Mileage: 200566 km
                    Date: 2020.09.30
                    Time: 07:38:40
   VCID: 2B030376F38E6973F61-807E
329728 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_GETRIEBE_03_MESSAGE_TIMEOUT]
                    Reset counter: 195
                    Mileage: 203671 km
                    Date: 2020.11.18
                    Time: 11:44:36
                    Voltage terminal 30: 12.0 V
                    Internal Fault ID: 94
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Auto Adjust: not active
329984 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_GETRIEBE_04_MESSAGE_TIMEOUT]
                    Reset counter: 195
                    Mileage: 203671 km
                    Date: 2020.11.18
                    Time: 11:44:36
                    Internal Fault ID: 95
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   VCID: 221DEE5284C4A83B457-8076
   VCID: 2809FC7AE2F8426B1B3-807C
   VCID: 49CF59FE59B25B63E4D-801C
   Coding: 1080004
   VCID: 2615F242E4EC541B29F-8072
   ROD: EV_RGS_L.rod
   VCID: 313F111ED1A203A3CCD-8064
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:33, VBatt start/end: 12.2V/12.1V)-----------
