Results 1 to 6 of 6
Thread: 2006 A6 Steering Angle Sensor won't calibrate - 01826 Fault
    May 2020
    Hello everyone. newbeard here. First post. My daughter complained her 2006 A6 quattro 4.2 steering column adjust buttons stopped working (no up/down or telescoping function). Played around with my VAG401 knockoff unit which initially found NO ENG or ABS Faults, and when i was done steering column still wouldn't adjust and now have a persistent ESP Fault with the G85 steering sensor. Upgraded to Ross-Tech and still unable to get rid of the fault. Engine running, drive slow, turn wheel, steering centered, and following the Steering Angle Sensor (G85) Calibration procedure numerous times I get the same result - a "Not Available" response from the sensor. Is it time to try a new sensor? Auto Scan attached. Appreciate this forum and any suggestions/response. Thanks.
    Saturday,02,May,2020,13:28:55:29907
    VIN: WAUDL74F66N097231   License Plate: AYTXXX
    Mileage: 275740km-171336mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
              53 55 56 61 62 65 67 72 76 77
    VIN: WAUDL74F66N097231   Mileage: 275740km-171336miles
       Part No SW: 4F0 910 560 E    HW: 4F0 907 559
       Component: 4.2L V8/5V      G   0020
       Revision: --H01---    Serial number:
       Coding: 0007772
       Shop #: WSC 02325 785 00200
       VCID: 2411EA1552DCB21B173-8070
    18061 - Please check DTC Memory of ABS Controller
                P1653 - 008 -
                        Fault Frequency: 27
                        Mileage: 275739 km
                        Date: 2020.05.02
                        Time: 10:02:40
                        RPM: 721 /min
                        Load: 22.3 %
                        Temperature: 93.0°C
                        Temperature: 45.0°C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.589 V
    Readiness: 0010 1100
       Part No SW: 4F1 910 156 Q    HW: 09L 927 156 A
       Component: AG6 09L 4,2 MPI USA 0040
       Revision: --H01---    Serial number:        4092221
       VCID: 323D1C4D18282CAB95F-8066
    Address 03: ABS Brakes        Labels: 4F0-910-517.clb
       Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
       Component: ESP 8.0 quattro H04 0090
       Coding: 0021352
       VCID: 2D070F3101167353C8D-8078
                        Reset counter: 1
                        Mileage: 275743 km
                        Date: 2020.05.02
                        Time: 12:14:59
                        Hex Value: 0x0900
                        Hex Value: 0x4002
                        Hex Value: 0x0024
                        Hex Value: 0x01AC
                        Hex Value: 0x00FF
       Component: FBSAUDIC6 ELV   H31 0180
       Revision: 30070501    Serial number: 10600600254754
       Coding: 0000015
       Shop #: WSC 23347 444 84359
       VCID: 6393A9091752F5232E9-8036
       Subsystem 1 - Part No: 4F0 910 131 L
       Component: FBSAUDIC6 EZS   H45 0070
       Component: FBSAUDIC6 KSG   H27 0080
       Subsystem 3 - Part No: 4F0 910 220 G
       Component: FBSAUDIC6 IDG   H01 0053
       Part No SW: 4F0 910 731 T    HW: 4E0 035 729
       Component: Interfacebox    H43 3360
       Revision: 00000000    Serial number: 303J/057508999
       Coding: 0000003
       Shop #: WSC 02323 785 00200
       VCID: 33331949E73225A39E9-8066
       Component: Bedienteil MMIC6H08 0050
       Subsystem 2 - Serial number: 00000000253426
       Subsystem 3 - Serial number: 0113.10.050000000100011187ÿ
       Subsystem 4 - Serial number: 011187ÿ
                        Reset counter: 40
                        Mileage: 275739 km
                        Date: 2020.05.02
                        Time: 11:30:01
                        Bin. Bits: 00000000
                        Bin. Bits:  0000000
                        Bin. Bits:      001
       Part No SW: 4F0 910 043     HW: 4F1 820 043 S
       Component: KLIMABETAETIGUNGH12 0160
       Revision: 00000027    Serial number: 00000030063770
       Coding: 0000040
       VCID: 5BE391E92F22CDE3669-800E
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 53
                        Reset counter: 252
                        Mileage: 273238 km
                        Date: 2020.02.11
                        Time: 09:27:07
                        Temperature: 16.0°C
    01856 - Temperature Sensor for Heated Seat; Front Right (G345)
                        Fault Status: 00100111
                        Fault Frequency: 133
                        Reset counter: 38
                        Mileage: 274561 km
                        Date: 2020.04.01
                        Time: 17:02:05
                        Temperature: 22.0°C
       Part No SW: 4F0 910 279 C    HW: 4F0 907 279 A
       Component: ILM Fahrer      H15 0190
       Coding: 0114123
       Shop #: WSC 02335 785 00200
       VCID: 290FFB2135FE6F73245-807C
       Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0150
       Coding: 00062736
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
       Revision: 00000000    Serial number: AUZ5ZBE7257185
       VCID: 1C61D2F56AAC8ADBAF3-8048
    Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
       Part No SW: 4E0 910 593 G    HW: 4E0 035 593 C
       Component: SDAR XM         H04 0670
       Revision: 00000000    Serial number: AUZ4Z7E4037388
       VCID: 2B0301293F027D63D69-807E
                        Reset counter: 173
                        Mileage: 273238 km
                        Date: 2020.02.11
                        Time: 09:27:10
       Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
       Component: 66 AIRBAG AUDI8RH29 0270
       Revision: 12H29000    Serial number: 00359D0A5NE$
       Coding: 0013878
       VCID: 2A0D042D30F8646B2DF-807E
       Subsystem 1 - Part No: 4F0 910 339 A
       Component: BF-Gewichtsens. H02 0050
       Subsystem 2 - Serial number: 6332CSME0C17421B%
       Subsystem 3 - Serial number: 6342CSME0C28243C5
       Subsystem 4 - Serial number: 6352QSME06703F31C
       Subsystem 5 - Serial number: 6362QSME06661E47M
       Subsystem 6 - Serial number: 63734SME061B174F3
       Subsystem 7 - Serial number: 63834SME054F460B4
       Component: Lenksäulenmodul H07 0230
       Revision: 00H07000    Serial number: 90025052860119
       Coding: 0012041
       VCID: 6695B01DE460800BC97-8032
       Component: Lenkradmodul    H07 0080
       Part No SW: 4F0 910 930 A    HW: 4F0 920 980 N
       Component: KOMBIINSTR. M73 H16 0630
       Revision: 00200000    Serial number: 4PY59YDA5
       Coding: 2129263
       Shop #: WSC 04310 758 67144
       VCID: 211FE3014DCEA7337C5-8074
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Component: Gateway         H11 0070
       Revision: 11          Serial number: 1300805A2181A4
       Coding: ECFE73CD1B7904
       Shop #: WSC 02334 785 00200
       VCID: 270BFD1923EA5903321-8072
       Coding: 0082954
       VCID: 619FA3010D4EE7333C5-8034
                        Reset counter: 36
                        Mileage: 13556 km
                        Date: 2020.04.26
                        Time: 13:33:06
       Part No SW: 4E0 910 887 N    HW: 4E0 919 887 C
       Component: MNS US          H45 0740
       Revision: 00000000    Serial number: 355DM067565220
       Shop #: WSC 22197 444 67464
       VCID: 38292E65FE54C6FBABB-806C
       Component: TSG FA          H12 0080
       Revision: 00-00000
       Coding: 0051947
       Shop #: WSC 02327 785 00200
       VCID: 2C0102353A0C7A5BDF3-8078
       Component: Komfortgeraet   H19 0140
       Revision: 01400019    Serial number: 01007982610000
       Coding: 4618301
       Shop #: WSC 00999 444 64523
       VCID: 2E05083D0C10084BF17-807A
    01502 - Bulb for Rear Fog; Left (L46)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 172
                        Mileage: 273238 km
                        Date: 2020.02.04
                        Time: 12:30:54
       Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
       Component: DSP-High C6     H09 0240
       Revision: PROD_01     Serial number: 00000000811287
       Coding: 0000026
       VCID: 2517F71159E64B1300D-8070
       Part No SW: 4F0 910 280     HW: 4F0 907 280 B
       Revision:             Serial number: 00000000008689
       Coding: 0012114
       VCID: 5EE598FD3C30D8CB017-800A
       Component: TSG BF          H12 0080
       Revision: 00-00000
       Coding: 0051947
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0006022
       VCID: 5DE79FF13136C3D318D-8008
       Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
       Component: AFS 1           H01 0030
       Coding: 0000016
       VCID: 2615F01D24E0400B097-8072
       Subsystem 1 - Part No: 4F0 941 329 B
       Component: AFS-Modul links H02 0020
       Subsystem 2 - Part No: 4F0 941 329 B
       Component: AFS-Modul rechtsH02 0020
       Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 B
       Revision: 00000000    Serial number: 394J2057625877
       Revision: 00000000    Serial number: 00000000137846
       Shop #: WSC 22186 444 01407
       VCID: 2313E90957D2B5236E9-8076
       Component: von VA0  0510073027
       Coding: 344630393135313035442056413030353130303733303237
       Shop #: WSC 00000 384 00290
    02272 - Quiescent Current Stage 1
                        Fault Frequency: 9
                        Mileage: 273238 km
                        Date: 2020.02.11
                        Time: 11:05:24
                        Mileage: 273238 km
                        Date: 2020.02.11
                        Time: 11:09:35
    02276 - Quiescent Current Stage 5
                        Mileage: 273238 km
                        Date: 2020.02.11
                        Time: 11:09:45
    02274 - Quiescent Current Stage 3
                        Mileage: 273238 km
                        Date: 2020.02.11
                        Time: 11:09:55
                        Mileage: 273238 km
                        Date: 2020.02.11
                        Time: 11:10:05
       Coding: 0051754
       Part No SW: 4F0 910 273     HW: 4F0 907 273
       Component: Reifendruck 3   H04 0080
       Revision: 00040080    Serial number: 00000700011410
       Coding: 0062422
       VCID: 6099A6050644EE3B33B-8034
       Component: SDS 3501 US     H45 0630
       Revision: 00000000    Serial number: 00000510050137
       Shop #: WSC 12336 024 394758
       VCID: 34311A55E23C229B873-8060
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Coding: 0051754
    02111 - Motor for Window Regulator
                        Fault Status: 00100101
                        Reset counter: 21
                        Mileage: 273306 km
                        Date: 2020.02.15
                        Time: 13:20:08
       Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
       Component: Parkhilfe 4-Kan H09 0030
       Revision: 00H09000    Serial number: 11720528302393
       Coding: 0001206
                        Fault Status: 00101001
                        Fault Frequency: 9
                        Reset counter: 14
                        Mileage: 273701 km
                        Date: 2020.03.10
                        Time: 17:16:51
    01549 - Supply Voltage for Parking-Aid Sensor
                        Fault Frequency: 173
                        Reset counter: 8
                        Mileage: 273238 km
                        Date: 2020.02.11
                        Time: 09:29:08
                        Fault Frequency: 13
                        Reset counter: 14
                        Mileage: 273745 km
                        Date: 2020.03.13
                        Time: 13:00:34
                        Fault Frequency: 41
                        Reset counter: 8
                        Mileage: 273238 km
                        Date: 2020.02.11
                        Time: 09:29:08
       Part No SW: 4F0 910 336 D    HW: 4E0 862 335
       Component: Handyvorb2      H11 0700
       Revision: 00000000    Serial number: 00000007520059
       Coding: 0010900
    End----------(Elapsed Time: 02:05, VBatt start/end: 11.9V/12.0V)-----------
    Hi and welcome.
    Been here?
    http://wiki.ross-tech.com/wiki/index.php/01826
    Have you verified that this isn't a power problem of some sort?
    May 2020
    Thanks for the reply Uwe. I was focused on the Steering issue but did notice the Quiescent Current faults. Battery is an uncoded replacement from daughters local college town shop installed Feb 2019... which might explain some of the power anomalies. Still finding my way around the new analyzer and the wiki/forums. Checked the wiki as you suggested and it looks like the Steering Column Control Module (J527) was the most common fault for the 2006's according to the special notes. Auto scan does not show fault for this though. Still frustrated that my cheap analyzer is now costing me $$ and more time than expected. Thanks again and will post updates when i get a chance since car is not always available to troubleshoot.
    I don't think the Quiescent Current faults in the Battery Management module are related. I mean you should check physically that the steering angle sensor is getting power as it should.
    May 2020
    Update: tried to sort out any power issues as suggested. Installed proper agm battery (Quiescent Current faults now gone), downloaded erwin manuals, checked fuses (all good). Still trying to understand DIN system... Everything else connected to the J527 was working (except column adj switch) so bought a used clockspring from local wrecking yard for backup, ground down T8 torx to get access, and swapped out the G85 sensor since the wrecking yard clockspring had a different older airbag connector receptacle. Temped everything back together and tested good with the wiki Calibration procedure.
    Noticed that the T25 torx screw which secures the clockspring and J527 module to the steering column can be loosened to help remove and restore the plastic covers (explains the hole in the middle of the lower cover). Wondering if that can cause issues if over-torqued.
    Anyway now back to the original issue of no steering column power adjustment. Probably a new post for that one. Thanks for the help on this!
    Quote Originally Posted by newbeard View Post
    Since you've mentioned the problem in this thread there's no need to start a new one IMHO.
