I'm a new DIY guy just trying to get my son's 2010 A4 (147K miles) to start after replacing the starter wire harness. After replacing the water pump and reassemble the front bumper and radiator, I had mistakenly ground the alternator causing a small fire. After replacing the whole wiring harness and a new battery, the car wouldn't start. I just heard the clicking noise by the ECU after pushing the remote key in the accessory mode. Also, the radiator fan would come on intermittently and would slowly drain the battery. So, I detached it temporarily and hookup the charger while I did a quick auto scan with Ross-Tech Hex-2 interface. I had also checked all the fuses and relays; they were good except one (F5 by the ECU fuse box area) for engine management. By the way, because there's no communication to the engine or ECU(?), I wasn't able to disengage my e-brake or reprogram it through the long adaption of the new battery as it kept reverting to the old battery info.
I am trying to avoid taking it to the dealership as it gets very expensive. So, any help will be greatly appreciative.
Here is the full auto scan result:
Tuesday,28,April,2020,15:44:18:19449
VIN: WAUAFAFL3AN016981 License Plate:
Mileage: 237230km-147407mi Repair Order: 3B
Chassis Type: 8T0
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 72
Mileage: 237230km-147407miles
Address 01: Engine
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 8K1 927 155 J HW: 0AW 927 156 H
Component: 0AW 20TAVSUSA H02 0004
Revision: --H02--- Serial number: 0000000295
Coding: 000001
Shop #: WSC 22102 444 85875
ASAM Dataset: EV_TCMVL381 A02018
ROD: EV_TCMVL381.rod
VCID: 3B2332E603E11F43469-806E
2264 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [167] - -
[Engine control unit No communication]
Mileage: 237232 km
Date: 2009.04.28
Time: 04:17:37
Engine speed: 100.00 /min
Transmission input speed: 1 /min
Transmission output speed: 1 /min
Engine torque: 0 Nm
Transmission fluid temperature: 26 °C
Accelerator position: 0.0 %
Clutch status: 1
Occurrence_counter_over_length_of_life: 3
7066 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [047] - -
Mileage: 237232 km
Date: 2009.04.28
Time: 04:17:37
Engine torque: 0 Nm
Clutch status: 1
Occurrence_counter_over_length_of_life: 4
Part No SW: 8K0 907 379 BT HW: 8K0 907 379 BT
Component: ESP8 front H04 0010
Coding: 080D10
Shop #: WSC 02391 823 56573
VCID: 0C41A13A164FE8FB3F3-8058
Part No SW: 8K0 907 064 DF HW: 8K0 907 064 DF
Component: BCM2 1.1 H02 0321
Coding: 090100
Shop #: WSC 02399 823 56573
VCID: 77ABEED67FC9FB23621-8022
Subsystem 1 - Part No SW: 8K0 959 754 B HW: 8K0 959 754 B
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0815000083686009
Component: J764 ELV MLB H37 0042
Serial number: 0209000053992014
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 97
Mileage: 237232 km
Date: 2009.04.28
Time: 04:17:33
Part No SW: 8T1 820 043 AM HW: 8T1 820 043 AM
Component: KLIMA 1 ZONE H08 0171
Revision: A0000000 Serial number: 01270720090969
Coding: 64002000
VCID: 7CA1F1FA46EFD87B0F3-8028
Reset counter: 97
Mileage: 237232 km
Date: 2009.04.28
Time: 04:17:33
Reset counter: 97
Mileage: 237232 km
Date: 2009.04.28
Time: 04:17:33
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 97
Mileage: 237232 km
Date: 2009.04.28
Time: 04:17:33
Temperature: 25.0°C
Temperature: 1.0°C
Absolute Pres.: 1.0 bar
RPM: 102 /min
Current: 0.000 A
Temperature: 36.0°C
01297 - Sensor for Vent Temperature; Footwell (G192)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 97
Mileage: 237232 km
Date: 2009.04.28
Time: 04:17:33
Temperature: 25.0°C
Voltage: 4.90 V
Voltage: 12.80 V
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H25 0380
Revision: 09025001 Serial number: 00000000315520
Coding: 690000B1063C00010000080000007F5F0F14520800000001000000
VCID: 3A2D37E20C5B264B5DF-806E
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 220709 H06 0070
Serial number: SWF09070225639
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 AK HW: 8K0 941 531 AK
Component: E1 - LDS H08 0090
Serial number: 00000000002207091480
00576 - Terminal 15
Reset counter: 97
Mileage: 237232 km
Date: 2009.04.28
Time: 04:17:00
Reset counter: 97
Mileage: 237232 km
Date: 2009.04.28
Time: 04:17:00
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
Component: AirbagVW-AU10 H37 0520
Serial number: 003EGD02AVTW
Coding: 303836354230303030304A55304C384B3053
Shop #: WSC 02135 785 00200
VCID: 42DD4F02640B6E8B05F-8016
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0900004NXX
Serial number: 6334MSME4956160BF
Serial number: 6344MSME49555367I
Serial number: 6352QSME0F353E12K
Serial number: 6362QSME0E361D28P
Serial number: 63732SME1E33450C+
Serial number: 63832SME1E331208W
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304IGV000ER
Coding: 000014
VCID: 3D273CFE1D75117378D-8068
Component: E221 - MFL H02 0003
Part No SW: 8K0 920 950 E HW: 8K0 920 950 E
Component: KOMBIINSTR. H19 0253
Revision: 00300000 Serial number: BWX20MP79
Coding: 8B1209000300D705020000
VCID: 313F10CED12DE513EC5-8064
Reset counter: 97
Mileage: 237232 km
Date: 2009.04.28
Time: 00:02:45
00532 - Supply Voltage B+
Reset counter: 137
Mileage: 237232 km
Date: 2020.04.25
Time: 19:20:39
Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0105
Revision: GB600050 Serial number: 5000G0972280D4
Coding: 00C303
VCID: 50F9754ABAE78C1B83B-8004
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Serial number: 19087AC1070709
Reset counter: 97
Mileage: 237232 km
Date: 2009.04.28
Time: 04:17:34
Bin. Bits: 10111
Voltage: 12.70 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009131361
Coding: 011C03204000410001
VCID: 45D7541E75A559B320D-8010
Revision: 00002001 Serial number: 0120294911
Coding: 0106023A007A000400B0010000000000
Component: LIN BACKUP HO H03 1301
Subsystem 2 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS037 H06 0041
Reset counter: 97
Mileage: 237232 km
Date: 2009.04.28
Time: 04:17:33
01134 - Alarm Horn (H12)
014 - Defective
Fault Status: 01101110
Reset counter: 97
Mileage: 237232 km
Date: 2009.04.28
Time: 04:17:37
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AH HW: 8T0 035 223
Component: DSP STD H07 0230
Revision: S2200000
Coding: 0203010101
VCID: 74B1D9DA6EBF903B473-8020
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009136003
VCID: 44D1491A7E9F60BB373-8010
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0090
Revision: 00000003 Serial number: 10000000291566
VCID: 343119DA2E3FD03B873-8060
Fault Status: 11100100
Reset counter: 97
Mileage: 237232 km
Date: 2009.04.28
Time: 04:17:33
Voltage: 12.90 V
Count: 64
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H03 0351
Revision: 00000005 Serial number: AUZ5Z6I1254074
Coding: 05020000010105004119070000
VCID: 46D5531248A352AB297-8012
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
Reset counter: 97
Mileage: 237232 km
Date: 2009.04.28
Time: 04:17:38
Reset counter: 97
Mileage: 237232 km
Date: 2009.04.28
Time: 04:17:42
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000101634578
Coding: 010C03204000210001
VCID: 42DD4F02648B6E8B05F-8016
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000101634575
End----------(Elapsed Time: 01:22, VBatt start/end: 12.9V/12.9V)-----------
