2007 1.9TDI Transporter, Label file issue
Baggy
England
C?ID=397151
Hi, I`m new on here and have just purchased one of your HEX-V2 could you please look at my auto scan its saying None in the label file box, can this be fixed?
Also when im using measuring blocks i can see numbers in the boxes but when i hoover over the boxes with the pointer its not showing me a balloon with specific value information?
I would appreciate any help on this, thank you.
Tuesday,28,April,2020,21:40:40:60788
VCDS Version: 20.4.0.1  HEX-V2 CB: 0.4508.4
Data version: Unknown DS317.0
VIN: WV1ZZZ7HZ7H095555   License Plate:
Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ7H095555   Mileage: 151070km-93870miles
Address 01: Engine        Labels: None
   Part No SW: 038 906 016 AH    HW: 038 906 016 AH
   Component: R4 1,9L EDC  000SG  9712
   Revision: --H05---    Serial number: VWZ7Z0F4836346
   Coding: 0000031
   Shop #: WSC 02736 790 00000
   VCID: 5AED94E89001AE9B7D6-513C
Address 03: ABS Brakes        Labels: None
   Part No SW: 7H0 907 379 P    HW: 7H0 907 379 P
   Component: (M)ABS MK25E        0103
   Revision: 00H12001
   Coding: 0000552
   VCID: 42DD4C881891065B056-5118
Address 09: Cent. Elect.        Labels: None
   Part No: 7H0 937 049 N
   Component: BORDNETZ SGVER 1.0  1001
   Coding: 0000004
   VCID: 3D273F74616F79A3784-5118
Address 15: Airbags        Labels: None
   Part No: 1C0 909 605 A
   Component: 3B AIRBAG VW51      0010
   Coding: 13122
   Shop #: WSC 02736
   VCID: 221DEC08FDD1265B656-5118
Address 17: Instruments        Labels: None
   Part No: 7H0 920 952 B
   Component: KOMBI+WEGFAHRSP VDO V02
   Coding: 00413
   Shop #: WSC 00001
   VCID: 2C0102308F15E02BDFA-5118
   WV1ZZZ7HZ7H095555     VWZ7Z0F4836346
Address 19: CAN Gateway        Labels: None
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02736
   VCID: 70B9D64063BDC4CBA32-5118
Address 45: Inter. Monitor        Labels: None
   Part No: 7H0 951 171 B
   Component: Innenraumueberw.    2920
   Coding: 0000021
   Shop #: WSC 02737 790 00000
   VCID: 290FFB2485E7F50324C-5160
Address 46: Central Conv.        Labels: None
   Part No: 7H0 959 433 B
   Component: CXL Komfortgerát     0004
   Coding: 00020
   Shop #: WSC 02736
   VCID: 323D1C48AD31B6DB956-4AE0
Address 56: Radio        Labels: None
   Part No SW: 7H0 035 152 C    HW: 7H0 035 152 C
   Component: Radio DE2           0004
   Revision: 00004000    Serial number: VWZ4Z4FN090804
   Coding: 0020200
   VCID: 221DEC08F8D1265B656-5118
Address 76: Park Assist        Labels: None
   Part No: 7H0 919 283
   Component: Parkingsyst. T5 T5N 401
   Coding: 00137
   Shop #: WSC 02736
   VCID: 6FBBD53C7E83DB33BA8-513C
End----------(Elapsed Time: 05:51, VBatt start/end: 12.3V/12.3V)-----------
Zenerdiode
Newcastle, England
C?ID=24330
How did you install the VCDS software? It looks like the \Labels folder isn'twhere VCDS expects it to be. Would you try a re-install?
Baggy
England
C?ID=397151
I downloaded the VCDS software 20.4 from your website, I will re-install and see if anything happens. Thank you for your speedy response!!
Baggy
England
C?ID=397151
Ok, so ive re-installed VCDS software and now got all labels apart from engine labels, says Redir Fail now? Please see new auto scan below, thanks again.
Wednesday,29,April,2020,16:42:14:60788
          57 6E 76 77 78 7D
   Coding: 0000031
   VCID: 5AED94E89001AE9B7DF-513C
Address 03: ABS Brakes        Labels:. 7H0-907-37x-ABS.clb
   Revision: 00H12001
   Coding: 0000552
   VCID: 42DD4C881891065B05F-5118
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Coding: 0000004
   VCID: 3D273F74616F79A378D-5118
01598 - Drive Battery Voltage
            002 - Lower Limit Exceeded
   Coding: 13122
   Shop #: WSC 02736
   VCID: 221DEC08FDD1265B65F-5118
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Coding: 00413
   Shop #: WSC 00001
   VCID: 2C0102308F15E02BDF3-5118
   Coding: 00006
   Shop #: WSC 02736
   VCID: 70B9D64063BDC4CBA3B-5118
Address 45: Inter. Monitor        Labels: 7Hx-951-171.lbl
   Coding: 0000021
   VCID: 290FFB2485E7F503245-5160
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Coding: 00020
   Shop #: WSC 02736
   VCID: 323D1C48AD31B6DB95F-4AE0
   Coding: 0020200
   VCID: 221DEC08F8D1265B65F-5118
Address 76: Park Assist        Labels: 7H0-919-283.lbl
   Coding: 00137
   Shop #: WSC 02736
   VCID: 6FBBD53C7E83DB33BA1-513C
End----------(Elapsed Time: 05:47, VBatt start/end: 12.1V/12.1V)-----------
Dana
Western PA, USA
That scan looks a lot better.
If you are just looking for information we have a 038-906-016-BRS label in German that I can send you via Support e-mail. However, if you were looking to diagnose something specific please post the details and we can point you to the group(s) in question instead.
Baggy
England
C?ID=397151
Thank you for your time on this. Yes please could you send it. Will the specific values be in this as I mentioned in my previous post.
Thank you
Dana
Western PA, USA
Yes, although the file is in German it will have the pop-up balloons for specified values. I sent it to the Hotmail address we have on file.
MartinsX
Riga, Latvia
C?ID=268515
I'd like to have 038-906-016-BRS label in German, too.
P.S. Maybe its not a bad idea to include all existing label files in standard English version? If there is no English translation, then include German label file instead of nothing.
Dana
Western PA, USA
Hi Martins,
We discussed that at one point and I believe it would be helpful to most users. Perhaps via an optional tickbox in the installer .. but that's something we still need to decide on.
In the meanwhile I'll send you the same file.
PetrolDave
Westbury, UK
C?ID=1423
That sounds a very good idea to me, Google translate can always be used if necessary by us non-German speakers to get an idea of the meaning.
IgorUK
Paignton, UK
C?ID=558839
Hi, I recently purchased one of RT HEX-V2 tools and this is my first post on this forum. It seems that I am missing the label file for my BRS engine (VW Transporter T5 1.9tdi) as system displays 'none' in the label window of the app interface.
I understand that there is no English version of 038-906-016-BRS file and wanted to ask if it would be possible to get the German version of it so that I can translate it myself. It would also help if you could include any instruction on how to make the new label file work as when I tried to experiment with a similar AXB engine lbl file by putting it into 'User' folder the system gave me 'Redir Fail!' message. Thank you
Zenerdiode
Newcastle, England
C?ID=24330
If you’re having a go at making your own label file for your \User folder, stay away from redirects.
Name the label file you create with the name of the SW part number with extension .lbl
Also have a look here and in the sub-links on the page.
Please post an Auto-Scan too.
