I have an 09 A4 that the tpms light has been on since I bought it. I tested the sensors with a scan tool and only one was reading so I replaced all with autel sensors. All of the sensors Id's are being read in vcds but there is no temperature or pressure reading as well as no speed input in vcds. I reset the pressures using the display and waited 20 minutes then drove the car for a little bit but still isn't reading anything but the identification numbers. I loked at the coding and the coding in the abs module has both the tpms 1 and tpms 2 boxex unchecked. I tried to code one both in at separate times and it wont allow it. It says error 31 request out of range. Any help would be appreciated.
Tuesday,28,April,2020,17:39:06:60802
VCDS Version: 20.4.1.0 (x64) HEX-NET CB: 0.4508.4
Dealer/Shop Name: 1234512312345
VIN: WAULF78K59N068768 License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 65 72
77
VIN: WAULF78K59N068768 Mileage: 206830km-128518miles
Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0001
Revision: E1H14---
Coding: 0104010A190F0160
Shop #: WSC 09396 002 1048576
ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 79BACD3FF834D04E4C-802C
Readiness: 0010 0101
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8K0 927 158 C HW: 0B6 927 156
Component: 0B6 20TFSIUSA H04 0050
Revision: --H04---
Coding: 001002
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_TCMAL651 A01004
ROD: EV_TCMAL651.rod
VCID: 3620060389AAFF36E1-8062
Part No SW: 8K0 907 379 AF HW: 8K0 907 379 AF
Component: ESP8 quattro H04 0210
Coding: 150100
VCID: 7DB2D92FE41CEC6E60-8028
Part No SW: 8K0 907 064 F HW: 8K0 907 064 F
Component: BCM2 1.1 H80 0145
Coding: 090100
Shop #: WSC 02399 823 56573
VCID: 33263F1792D8EA1EC6-8066
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000010202006
Component: ELVAUDIB8 H36 0041
Serial number: 0209000012848015
Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
Component: KLIMA 1 ZONE H06 0150
Revision: A1000000 Serial number: 01130320090031
Coding: 64002000
Shop #: WSC 02391 823 56573
VCID: 70ACF01BA34E9106FB-8024
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H24 0253
Revision: 05024001 Serial number: 00000000225447
Coding: 690000B1063C00010000080300007F5F0F14520800000001000000
VCID: 302C301B63CED106BB-8064
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 180309 H06 0070
Serial number: SWF09030185532
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 T HW: 8K0 941 531 T
Component: E1 - LDS H07 0090
Serial number: 00000000001203091159
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 F HW: 8K0 959 655 F
Component: AirbagVW-AU10 H27 0410
Serial number: 0039KD14XSN5
Coding: 303836354230303030304A55304C384B3053
Shop #: WSC 02135 785 00200
VCID: 40CC60DBDB6E41864B-8014
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0900003JA6
Serial number: 6334MSME46340C1BE
Serial number: 6344MSME4463086EJ
Serial number: 6352QSME621E520EL
Serial number: 6362QSME461F0922H
Serial number: 63732SME7C21043C/
Serial number: 63832SME36213C14W
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304ICD0004X
Coding: 000034
VCID: 3D32192FA49C2C6E20-8068
Component: E221 - MFL H02 0003
Part No SW: 8K0 920 950 A HW: 8K0 920 950 A
Component: KOMBIINSTR. H18 0224
Revision: 00000000 Serial number: 9DR1EGC39
Coding: 8B1209000300D705020200
VCID: 2D12296F74FCBCEE90-8078
Part No SW: 8T0 907 468 M HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0095
Revision: GB300043 Serial number: 4300G0930686F2
Coding: 000303
VCID: 4BD647F7EA2892DEAE-801E
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Serial number: 19068C5E110209
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 HW: 8T0 035 785
Component: SG ext.Player H06 0210
Revision: 00000000
Coding: 020302
VCID: 78BCC83BCB3EC94633-802C
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000008591368
Coding: 011C03204000410001
VCID: 41CA65DFD864488E44-8014
Revision: 00002001 Serial number: 0117171294
Coding: 0106023A007A000400B001
Component: LIN BACKUP HO H03 1301
Subsystem 2 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS034 H06 0037
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S2100000
Coding: 0203010102
VCID: 6E90EE63B97A87F6E9-803A
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000008606952
VCID: 40CC60DBD36E41864B-8014
Part No SW: 8K0 907 801 G HW: 8K0 907 801 G
Component: EPB Audi B8 H08 0080
Revision: 00000003 Serial number: 10000000194622
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H01 0301
Revision: 00000003 Serial number: AUZ5Z6I1188533
Coding: 04020002010185034119070800
VCID: 46C076C3F14A6FB671-8012
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
Reset counter: 20
Mileage: 206833 km
Date: 2020.04.28
Time: 15:12:49
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 N HW: 8K0 959 795 C
Component: TSG HL H10 0251
Revision: Serial number: 0000100819785
Coding: 010C03204000210001
VCID: 44C46CCBC7765DA66F-8010
Address 65: Tire Pressure (J502) Labels: 8K0-907-273.clb
Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
Component: J502-RDK H03 0250
Revision: 00001001 Serial number: 13374790243434
Coding: 0CD154
Fault Status: 11100100
Reset counter: 20
Mileage: 206833 km
Date: 2020.04.28
Time: 15:12:40
Bin. Bits: 00000000 00010000
Voltage: 12.00 V
Text: 12,5°C;n.erkannt;3390855811;--h;---°C
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000100819719
Part No SW: 8T0 862 336 C HW: 8T0 862 336 C
Component: FSE_256x BT H33 0550
Revision: 00000000 Serial number: 00000005034728
Coding: 0010370
Shop #: WSC 02335 785 00200
VCID: 3B3617377A88225E1E-806E
End----------(Elapsed Time: 01:30, VBatt start/end: 13.6V/13.7V)-----------
