hi, 2016 VW jetta need ABS coding,thank you.
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 10 15 16 17 19 25 2B 3C 42 44 46 47 4F 52 55
5F 62 72 75
VIN: 3VW5T7AJXGM401170 Mileage: 52640km-32708miles
Address 01: Engine (J623-CPPA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 906 071 AT HW: 06K 907 425 C
Component: R4 2.0l TFS H13 4876
Revision: --H13---
Coding: 00190012242400171000
Shop #: WSC 00066 790 00014
ASAM Dataset: EV_ECM20TFS02006K906071AT 001005
ROD: EV_ECM20TFS02006K906071AT.rod
VCID: 7DF11E1AEC0AE0A2B6-8028
17178 - Databus
Mileage: 52641 km
Date: 2020.04.13
Time: 00:06:46
Coolant temperature: 41 °C
Intake air temperature: 29 °C
Voltage terminal 30: 11.855 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Readiness: 1110 1101
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: 0000000000000000000000000000000000000000
Shop #: WSC 00066 000 00000
VCID: 75E1063ADC3AB8E2FE-8020
Reset counter: 187
Mileage: 52641 km
Date: 2020.04.13
Time: 00:06:47
Count: 7
Count: 2
Count: 20480
Count: 195
Count: 41984
Count: 57856
Count: 510
Fault Status: 01100101
Reset counter: 187
Mileage: 52641 km
Date: 2020.04.13
Time: 00:06:47
Count: 2
Count: 2
Count: 20480
Count: 212
Count: 42240
Count: 57856
Count: 256
Reset counter: 187
Mileage: 52641 km
Date: 2020.04.13
Time: 00:06:47
Count: 2
Count: 2
Count: 20480
Count: 279
Count: 42240
Count: 57856
Count: 256
Reset counter: 187
Mileage: 52641 km
Date: 2020.04.13
Time: 00:06:47
Count: 2
Count: 2
Count: 20480
Count: 295
Count: 42240
Count: 57856
Count: 256
Reset counter: 187
Mileage: 52641 km
Date: 2020.04.13
Time: 00:06:47
Count: 2
Count: 2
Count: 20480
Count: 270
Count: 42240
Count: 57856
Count: 256
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Revision: 00092000 Serial number: 0400168742
Coding: 030C0C
Shop #: WSC 00066 000 00293
ROD: EV_KESSYPQ35G_A02_VW36.rod
VCID: 377DCC328EB60AF22C-8062
Part No SW: 1K8 907 044 BS HW: 1K8 907 044 BS
Component: Climatronic H07 0405
Revision: 00001K04
Coding: 0050019002
Shop #: WSC 00066 790 00320
VCID: 010962EA90F28442D2-8054
B10AB F0 [009] - Too Low
Reset counter: 187
Mileage: 52641 km
Date: 2020.04.13
Time: 00:06:46
9672448 - Function limitation due to crash signal
B1397 00 [009] - -
Reset counter: 187
Mileage: 52641 km
Date: 2020.04.13
Time: 00:06:46
Part No SW: 5K0 937 087 AJ HW: 5K0 937 087 AJ
Component: BCM PQ35 H+ 122 0183
Revision: BL122001
Coding: EF200A1A902F06D40188008124000D4C0074000845A08DB2E4842000A040
VCID: 7DF11E1AE40AE0A2B6-8028
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 130416 05 54 0403
Coding: 02300A
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0479
Revision: -------- Serial number: 39331610303361
Coding: 0071155001
ASAM Dataset: EV_EPHVA18VW364GP00 001006
VCID: 3663C13689BCF3FA37-8062
Address 15: Airbags (J234) Labels:* 561-959-655.clb
Part No SW: 561 959 655 HW: 561 959 655
Component: AirbagVW11 001 0207
Serial number: 003RXM05VJW0
Coding: 8CCCF000000000005000001AC20800000065
ASAM Dataset: EV_AirbaVW11SMEVW411 001002
ROD: EV_AirbaVW11SMEVW411_VW32.rod
VCID: 63C548626AAE3652A0-8036
Component: BF-Gewichtss. H12 0021
Serial number: IBH0000000000053HY7Q
Coding: 30314C
Subsystem 2 - Part No SW: ----------- HW: 480 000 404 16
Serial number: 35700000000F0C4C8A1Y
Subsystem 3 - Part No SW: ----------- HW: 480 000 404 16
Serial number: 35800000000554345A1A
Subsystem 4 - Part No SW: ----------- HW: 480 022 303 16
Component: SideSensor_Dr 000 0148
Serial number: 3510001AB2050EF4344$
Subsystem 5 - Part No SW: ----------- HW: 480 022 303 16
Component: SideSensor_Pr 000 0148
Serial number: 3520001B12050EF6066Y
Subsystem 6 - Part No SW: ----------- HW: 480 021 204 16
Component: FrontSensor_D 000 0189
Serial number: 3550001C91ECD9D1D36Y
Subsystem 7 - Part No SW: ----------- HW: 480 021 204 16
Component: FrontSensor_P 000 0189
Serial number: 3560001C51ECD9D447E.
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [137] - Open or Short to Ground
Mileage: 52641 km
Date: 2020.04.13
Time: 00:06:53
Part No SW: 1K5 953 521 CR HW: 5K0 953 569 BF
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20160419201595
Coding: 0002440008
ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 7F0DE412E606F2B2A4-802A
Subsystem 1 - Part No SW: 6C0 959 442 C HW: 6C0 959 442 C Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H04 0103
Serial number: 29160000564710056114
Coding: B0FFFF
Part No SW: 5C6 920 985 C HW: 5C6 920 985 C
Component: KOMBI H04 1009
Coding: 271E010000
VCID: 326BFD2665D4EFDA1B-8066
U1101 00 [009] - Active
Reset counter: 187
Mileage: 52641 km
Date: 2020.04.13
Time: 00:06:45
Part No SW: 7N0 907 530 BG HW: 7N0 907 530 AN
Component: J533 Gateway H56 1673
Revision: H56 Serial number: 19051603010498
Coding: 351032
VCID: 76E30136C13CB3FAF7-8022
Component: IMMO H04 1009
Coding: 000007
VCID: 6ADB25468D84671A63-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 D HW: 5K0 905 861 D
Component: ELV-PQ35 H22 0240
Revision: 00000000 Serial number: 16000067381006
Coding: 4100000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 3169F22A60D2D4C262-8064
Component: HRE_Master H12 0071
Serial number: 0398560436
Coding: 02011102
Shop #: WSC 01383 790 50316
ROD: EV_HREntryHella_VW32.rod
VCID: 3C77D31EB79029AAC1-8068
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0397669924
Coding: 020111
Part No SW: 561 959 701 B HW: 3C0 959 793 H
Component: TUER-SG FT 002 0631
Revision: 13100010 Serial number: 0010473042
Coding: 0404BD
Shop #: WSC 00066 790 00083
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
VCID: 1D313E9A0C4A40A2D6-8048
Slave Driver:
Subsystem 1 - Part No SW: 6R0 959 811 T HW: 6R0 959 811 T
Component: J388__TSG_HL 022 1467
Serial number: 14202745160510162322
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 306 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3979CA0A70A21C82DA-806C
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H09 6831
Revision: -------- Serial number: EAA098C0089455
VCID: 285F1F4E5308950AB5-807C
9637138 - Loudspeaker 2 in Double-Subwoofer
B130D 12 [009] - Short to Plus
Reset counter: 187
Mileage: 52667 km
Date: 2022.02.21
Time: 04:43:35
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1673
Coding: 01030100
VCID: 6FED3452BE66823234-803A
Subsystem 1 - Part No SW: 5K0 959 591 A HW: 6R0 959 591 D
Component: J245 PS41.402 H03 0004
Serial number: 0000FST000WAC3L00000
Coding: 180000
Part No SW: 561 959 702 B HW: 3C0 959 792 H
Component: TUER-SG BT 002 0631
Revision: 15100010 Serial number: 0010499644
Coding: 0404BC
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
VCID: 1E333996014C5BBACF-804A
Slave Passenger:
Subsystem 1 - Part No SW: 6R0 959 812 T HW: 6R0 959 812 T
Component: J389__TSG_HR 022 1467
Serial number: 14102744160509004957
B11EE 54 [009] - Missing Calibration / Basic Setting
Reset counter: 187
Mileage: 52641 km
Date: 2020.04.13
Time: 00:06:46
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H05 0111
Coding: 081200010B000200
Subsystem 1 - Part No: 5N0 941 329 Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 5N0 941 329 Labels: 3D0-941-329.CLB
Part No SW: 5C0 035 684 HW: 5C0 035 684
Component: MU-S-NS-US H22 0247
Serial number: VWZAZ2S0178521
Coding: 02630102AA00000051220003001808001F0100D400200105C6
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 62CB4D6675B43F5AAB-8036
Reset counter: 187
Mileage: 52641 km
Date: 2020.04.13
Time: 00:06:45
Voltage terminal 30: 11.8 V
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0158
Serial number: 000003554140549
Coding: 02630102C24232107F1606000000
ASAM Dataset: EV_OCULow 002010
ROD: EV_OCULow_002.rod
VCID: 14275BBEFF8001EA69-8040
End-------------------------(Elapsed Time: 03:23)--------------------------
