This car has been repaired after front end accident damage. We're left with a heap of issues to resolve but my main question is regarding the crash data stored in 44 steering assist. This has shut done the power steering. From the research I have done so far, it looks like from 2018 onwards, it is not possible to clear crash data and the steering assist ECU will need replacing. Can anyone confirm this?
Tuesday,28,April,2020,15:11:28:54575
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWZZZAWZJU036957 License Plate:
Mileage: 1930km-1199mi Repair Order:
Chassis Type: AW-VW27 (2Q0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F
VIN: WVWZZZAWZJU036957 Mileage: 1930km-1199miles
10-Park/Steer Assist -- Status: Cannot be reached 0100
Address 01: Engine (J623-CHYC) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 057 AP HW: 04C 907 309 BE
Component: R3 1.0l MPI H20 5636
Revision: 33H20000
Coding: 01110032020405080000
Shop #: WSC 31414 790 00200
ASAM Dataset: EV_ECM10MPI01104C906057AP 001004
ROD: EV_ECM10MPI01104C906057AP_VW27.rod
VCID: 73B3DE51DB387A635E0-8026
9803 - No Communications with Parking Assist Control Module A
U0159 00 [047] - -
Mileage: 1916 km
Date: 2020.02.12
Time: 20:07:22
Coolant temperature: 87 °C
Intake air temperature: 36 °C
Voltage terminal 30: 12.345 V
selected gear-Bits 0-7: 0
U0428 00 [047] - -
Mileage: 1916 km
Date: 2020.02.12
Time: 20:07:21
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [032] - -
Mileage: 1920 km
Date: 2020.02.14
Time: 00:07:12
Coolant temperature: 7 °C
Intake air temperature: 7 °C
Voltage terminal 30: 9.612 V
4710 - No Communications with Airbag Control Module
U0151 00 [040] - -
Mileage: 1920 km
Date: 2020.02.14
Time: 00:07:11
Voltage terminal 30: 10.201 V
Readiness: 0100 0000
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 2Q0 614 517 AA HW: 2Q0 614 517 N
Component: ESC_base_vFGS H23 0222
Serial number: 08509092180110
Coding: 09034A64154490B35205A81B24E142A649124926114A242444541254452442659248926488522424222A482AA251D64A3D8A6B52BC
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
ROD: EV_Brake1BOSCHESPMQBA0_004.rod
VCID: 6D87C829BD1CAC93884-8038
1152 - Databus
[ComScl_ACC_10_Timeout]
Reset counter: 94
Mileage: 1916 km
Date: 2020.02.12
Time: 20:07:28
1312 - Databus
[ComScl_PLA_01_Timeout]
Reset counter: 84
Mileage: 1902 km
Date: 2019.07.15
Time: 03:19:15
0922 - No Communications with Airbag Control Module
U0151 00 [008] - -
[ComScl_Airbag_01_Timeout]
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 00:07:12
1171 - Multiple collision brake
B13BC F2 [008] - No function
Fault Frequency: 12
Reset counter: 40
Mileage: 1920 km
Date: 2020.02.14
Time: 00:07:20
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [137] - -
[Scl_LWI_Lenkradwinkel_Error]
Reset counter: 94
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 2G2 820 045 D HW: 2G2 820 045 D
Component: SG_AC_Manuell H50 0301
Coding: 012100000800010011000400020000000000000000000000000000000000
ASAM Dataset: EV_ACManuePrehMQBA0 001011
ROD: EV_ACManuePrehMQBA0_VW27.rod
VCID: 221DEB153442A3EB656-8076
197890 - Temperature Sensor for Evaporator Vent
B108A 15 [008] - Open or Short to Plus
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 03:39:45
Outside air temperature: 13.5 °C
Voltage terminal 30: 11.3 V
Compressor current: specified value: 0.000 A
459009 - Databus
[Airbagsteuergerät - kein Signal/Kommunikation]
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 03:54:29
262914 - Refrigerant Pressure
B10AB F0 [008] - Too Low
Reset counter: 134
Mileage: 1919 km
Date: 2020.02.14
Time: 16:57:46
Refrigerant pressure: 1.0 bar
Outside air temperature: 12.5 °C
Temperature after evaporator: 16.9 °C
System run time-Terminal 15 on: 5 s
Engine speed: 1240 /min
Part No SW: 2Q0 937 089 HW: 2Q0 937 089
Component: BCM A0 Std H97 0916
Serial number: 07001800500836
ASAM Dataset: EV_BCMA0 204001
ROD: EV_BCMA0_204.rod
VCID: 77ABEA41CF401643628-8022
Drivers Door Control Module:
Subsystem 1 - Part No SW: 2Q2 959 881 C HW: 2Q2 959 881 C
Component: FHSG_DRV 001 0002
Serial number: 00000000000018085567
Coding: 1F0000
Subsystem 2 - Part No SW: 2Q2 959 882 HW: 2Q2 959 882
Component: FHSG_PSG 001 0001
Serial number: 00000000000018819834
Coding: 050000
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY173332RF9
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099776340
Subsystem 5 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000019008001
Coding: 1F0000
Subsystem 6 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000018843423
Coding: 070000
12 Faults Found:
6154 - Bulb for Rear Right Turn Signal
B11EB 15 [009] - Open or Short to Plus
Reset counter: 94
Mileage: 1920 km
Date: 2020.02.14
Time: 04:55:03
Zusaetzliche Umgebungsdaten-Terminal 15 status: On
Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
Zusaetzliche Umgebungsdaten-Low beam: not activated
Zusaetzliche Umgebungsdaten-OFF: not activated
Zusaetzliche Umgebungsdaten-Outside air temperature: 0
Zusaetzliche Umgebungsdaten-Automatic high beam assist: not activated
Zusaetzliche Umgebungsdaten-Parking light: not activated
Zusaetzliche Umgebungsdaten-Parking light left: not activated
Zusaetzliche Umgebungsdaten-Parking light right: not activated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
Zusaetzliche Umgebungsdaten-last wakeup: 33
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 13.7 V
8458 - Bulb for Right DRL
B121E 15 [009] - Open or Short to Plus
Reset counter: 94
Mileage: 1916 km
Date: 2020.02.12
Time: 20:07:05
Zusaetzliche Umgebungsdaten-last wakeup: 45
Zusaetzliche Umgebungsdaten-voltage measurement: 12.5 V
9994 - Bulb for Right Parking Lamp
B12E9 15 [009] - Open or Short to Plus
Reset counter: 94
Mileage: 1920 km
Date: 2020.02.14
Time: 18:42:19
Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 11.7 V
10762 - Bulb for Right Tail Light
B12BF 15 [008] - Open or Short to Plus
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 18:42:19
14858 - Bulb for Right Brake Lamp / Tail Lamp
B133C 15 [009] - Open or Short to Plus
Reset counter: 94
Mileage: 1917 km
Date: 2020.02.12
Time: 20:11:30
Zusaetzliche Umgebungsdaten-voltage measurement: 14.9 V
131586 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Funktionseinschränkung durch Unterspannung -unterer Grenzwert unterschritten>]
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 00:07:35
Zusaetzliche Umgebungsdaten-voltage measurement: 8.7 V
227080 - Turn Signal Switch
B1144 29 [008] - Signal Implausible
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 00:04:32
Zusaetzliche Umgebungsdaten-voltage measurement: 10.4 V
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
B131D F7 [008] - No Release by Immobilizer
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 00:07:13
Zusaetzliche Umgebungsdaten-voltage measurement: 10.0 V
528405 - Databus
[Airbag_01 Datenbus fehlende Botschaft]
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 00:07:13
558101 - Databus
[Airbag_02 Datenbus fehlende Botschaft]
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 03:54:33
Zusaetzliche Umgebungsdaten-voltage measurement: 10.7 V
919560 - Light Switch
B126A 29 [008] - Signal Implausible
Reset counter: 134
Date: 2020.02.14
Time: 19:04:26
Zusaetzliche Umgebungsdaten-voltage measurement: 12.1 V
950278 - Light recognition sensor
B13CA 15 [008] - Open or Short to Plus
Reset counter: 134
Date: 2020.02.14
Time: 19:04:26
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 11.4 V
Address 10: Park/Steer Assist
Address 13: Auto Dist. Reg
Address 15: Airbags (J234) Labels:* None
Part No SW: 2Q0 959 655 AG HW: 2Q0 959 655 AG
Component: VW22Airbag 010 0248
Revision: --------
Coding: 88CCC0C0000000005C5400CF008800000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
ROD: EV_AirbaVW22BPAVW27X_VW27.rod
VCID: 025D8B95948243EB456-8056
Subsystem 1 - Part No SW: ----------- HW: 442 060 312 17
Serial number: 3577Y21BF263F3C2F2EU
Subsystem 2 - Part No SW: ----------- HW: 442 060 312 17
Serial number: 3587Y21BF263F3C1C0FQ
Subsystem 3 - Part No SW: ----------- HW: 442 0B0 701 18
Component: SideSensor_Dr 1C7 0148
Serial number: 3517734BD28A7CD4225X
Subsystem 4 - Part No SW: ----------- HW: 442 0B0 701 18
Serial number: 3527734BD28A7CD1E2E9
Subsystem 5 - Part No SW: ----------- HW: 442 130 502 18
Component: FrontSensor_D 290 118A
Serial number: 355AG11BD275C884216Y
22 Faults Found:
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Reset counter: 95
Mileage: 1920 km
Date: 2020.03.20
Time: 31:01:02
B1000 1B [136] - Resistance Too High
9437723 - Igniter for Passenger's Airbag
B1002 1B [136] - Resistance Too High
9438235 - Igniter for Front passenger's Head Curtain Airbag
B1004 1B [136] - Resistance Too High
9438491 - Igniter for Driver head airbag
B1005 1B [136] - Resistance Too High
B1007 1B [137] - Resistance Too High
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
B1008 1B [137] - Resistance Too High
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
B1009 1B [137] - Resistance Too High
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [136] - Resistance Too High
9440027 - Driver's side; side-airbag igniter
B100B 1B [136] - Resistance Too High
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [136] - Open or Short to Ground
9443091 - Driver's Side Airbag Crash Sensor
B1017 13 [136] - Open Circuit
9443347 - Rear Side Airbag Crash Sensor (on driver's side)
B1018 13 [136] - Open Circuit
9443603 - Rear Side Airbag Crash Sensor (on front passenger's side)
B1019 13 [136] - Open Circuit
9443859 - Driver's Front Airbag Crash Sensor
B101A 13 [136] - Open Circuit
9445397 - Key switch for deactivation of passenger-side airbag
B1020 15 [136] - Open or Short to Plus
9446675 - Redundant signal path for airbag shut-off; passenger side
B1025 13 [136] - Open Circuit
9447187 - Seat Occupied Sensor; Passenger's Side
B1027 13 [136] - Open Circuit
9451027 - Crash sensor side airbag; passenger side
B1036 13 [136] - Open Circuit
9629972 - Indicator Lamp for Passenger Airbag Enabled
B12F1 14 [136] - Open or Short to Ground
9682162 - Multiple collision brake
Part No SW: 2G0 920 940 A HW: 2G0 920 940 A
Component: KOMBI 309 0460
Coding: 24A4010021802600018822011001000000000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001020
ROD: EV_DashBoardVDDMQBA0_VW27.rod
8 Faults Found:
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_Audio_0x31 keine Kommunikation]
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 03:54:39
16777020 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_TEL_0x28 keine Kommunikation]
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 03:54:39
16777028 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
[BAP_AWV_0x1B keine Kommunikation]
Reset counter: 94
Mileage: 1916 km
Date: 2020.02.12
Time: 20:07:05
16776960 - Databus
[ACC_02 keine Kommunikation]
Reset counter: 94
Mileage: 1916 km
Date: 2020.02.12
Time: 20:07:02
16776961 - Databus
[ACC_04 keine Kommunikation]
Reset counter: 94
Mileage: 1916 km
Date: 2020.02.12
Time: 20:07:02
16776962 - Databus
[Airbag_01 keine Kommunikation]
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 00:07:11
16776980 - Databus
[PLA_Status keine Kommunikation]
Reset counter: 94
Mileage: 1916 km
Date: 2020.02.12
Time: 20:07:02
9456433 - Key
B104B 31 [008] - No Signal
Mileage: 1920 km
Part No SW: 2Q0 909 901 HW: 2Q0 937 089
Component: GW MQB A0 H97 0916
Coding: 030100046F085600F8000048080F00010001070000000000000000000000
ASAM Dataset: EV_GatewA0 013020
ROD: EV_GatewA0_VW27.rod
VCID: 6FBBD221B7105E83BA8-803A
Subsystem 2 - Part No SW: 2Q0 915 181 HW: 2Q0 915 181
Component: J367-BDMBOSCH H02 2011
Serial number: 100403C1
8 Faults Found:
131594 - Parallel Parking Assistance Control Module
U104E 00 [009] - No communication
[Timeout Knoten 0x0A / 76 - Steuergerät für Parklenkassistent]
Reset counter: 94
Mileage: 1916 km
Date: 2020.02.12
Time: 20:07:03
Supply voltage: Terminal 30: 12.5 V
Terminal 15: On
131604 - No Communication with Instrument Cluster
U0155 00 [008] - -
[Timeout Knoten 0x14 / 17 - Steuergerät für Schalttafeleinsatz]
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 19:04:32
Terminal 15: OFF
131605 - No Communications with Airbag Control Module
U0151 00 [008] - -
[Timeout Knoten 0x15 / 15 - Steuergerät für Airbag]
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 00:07:14
Supply voltage: Terminal 30: 10.0 V
Terminal 15: On
131654 - No Communications with HVAC Control Module (J301)
U0164 00 [008] - -
[Timeout Knoten 0x46 / 08 - Steuergerät für Klima]
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 00:00:02
Supply voltage: Terminal 30: 11.0 V
Terminal 15: OFF
131671 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [009] - -
[Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
Reset counter: 94
Mileage: 1916 km
Date: 2020.02.12
Time: 20:07:03
Terminal 15: On
131699 - Control unit for information electronics 1
U1054 00 [008] - No Communication
[Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 17:10:12
Supply voltage: Terminal 30: 12.0 V
Terminal 15: OFF
66051 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0011 00 [008] - Performance
[Globaler Timeout CAN-Komfort]
Fault Frequency: 73
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 19:27:36
Terminal 15: OFF
197169 - Controls in Steering Wheel
[MFL (LIN#2) Timeout]
Reset counter: 95
Mileage: 1916 km
Date: 2020.02.12
Time: 20:07:03
Terminal 15: On
Address 44: Steering Assist (J792) Labels:* None
Part No SW: 2Q2 909 144 J HW: 2Q2 909 144 F
Component: TRW_G4L_MQBA0 620 6030
Serial number: 0342263CB4J0383
Coding: 00000000000000000101020101000101000001
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
VCID: 3A2D3375BCD2CB2B5D6-806E
10486016 - Databus
[DEM_AIRBAG_MESSAGE_ABSENT_FAULT]
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 03:54:31
Engine speed: 0 /min
Voltage terminal 30: 10.74 V
Power steering current consumption: 0.5 A
max.value: 0.5 A
End stage temperature: 215 °C
Steering assistance: engine output: 100 %
Engine angle: 65535 °
Electric motor speed: 45535 /min
Steering assistance: target engine torque: 0.0 Nm
Steering torque: 0.1 Nm
15788544 - Crash Shut-Down Activated
P1609 00 [008] - -
[DEM_FRONT_CRASH_FAULT]
Mileage: 1916 km
Date: 2020.02.12
Time: 20:07:29
Voltage terminal 30: 12.44 V
max.value: 0.5 A
Part No SW: 3Q0 035 842 C HW: 3Q0 035 842 C
Component: MU-S-D-ER H41 0468
Serial number: VWZAZ2U0610664
Coding: 02720000BE00000041110101008808001F0500C60120010003
ROD: EV_MUStd4CTSAT_VW27.rod
VCID: 2D0708297D9C6C93C84-8078
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H50 8130
Serial number: VWZ6ZJV0481504
6179 - Display Module 1 for Multimedia System
B1297 F6 [009] - Cable for Video Signal; Open Circuit
Reset counter: 94
Mileage: 1920 km
Date: 2020.02.14
Time: 04:57:23
Voltage terminal 30: 13.6 V
6697 - Databus
[Airbag: no communication]
Reset counter: 134
Mileage: 1920 km
Date: 2020.02.14
Time: 04:57:31
7178 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 94
Mileage: 1916 km
Date: 2020.02.12
Time: 20:07:06
Voltage terminal 30: 12.4 V
BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 94
Mileage: 1916 km
Date: 2020.02.12
Time: 20:07:05
End----(Elapsed Time: 00:57, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
Address 44,2Q2 909 144 J,channel IDE00820-Activating and deactivating all development messages,adapted from,not active ,to,active ,
