Results 1 to 6 of 6
Thread: Ambient (puddle) mirror lights retro fit in a mk5 Jetta
    Jul 2017
    I have a 2007 Jetta. I swapped the mirrors out for those from a 2005.5 Jetta because they had factory ambient (puddle) lights. I installed them and plugged them into each side's door controller. I enabled Ambient mirror lights in both door controllers in VCDS. Both sides still don't work. I'm not seeing a reference to a fuse anywhere in the manual. Thoughts? I'll post a auto scan in a little bit.
    May 2017
    Are your sure your door control modules support puddle lights? Not all do.
    Please post an autoscan.
    Jul 2014
    Tallinn, Estonia
    There is no fuse for the ambient lights. In the autoscan, you should see either "MIN" or "MAX" in controllers 42 and 52. If they're MIN, you have to replace them with MAX controllers. Post an autoscan.
  4. Likes downtime, PetrolDave, Uwe liked this post
    Jul 2017
    Here we go... I haven't started it in a while.
    Tuesday,28,April,2020,12:42:42:41190
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
    VCDS Version 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
    VIN: 3VWEG71K57M125932   License Plate:
    Mileage: 295600km-183677mi   Repair Order:
    Chassis Type: 1K-VW35 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWEG71K57M125932   Mileage: 295600km-183677miles
    62-Door, Rear Left -- Status: Malfunction 1010
    72-Door, Rear Right -- Status: Sporadic communication error 1000
    Address 01: Engine        Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 Q    HW: 07K 906 032 Q
       Component: 2.5l R5/4V      G   9650
       Revision: --H01---    Serial number: VWZ7Z0G9019242
       Coding: 0000003
       VCID: 3728238D03478AD3A21-8063
    008577 - Performance Malfunction in Cooling System
                   P2181 - 008 -  - Intermittent
                        Mileage: 295245 km
                        Date: 2014.08.07
                        Time: 06:20:44
                        RPM: 3236 /min
                        Load: 83.1 %
                        Speed: 127.0 km/h
                        Temperature: 74.0C
                        Temperature: 26.0C
                        Absolute Pres.: 850.0 mbar
                        Voltage: 13.843 V
       Part No SW: 09G 927 750 FL    HW: 09G 927 750 FL
       Component: AQ 250 6F           0920
       Revision: 00H69000    Serial number:
       Coding: 0000072
       VCID: 005A885116090D6B53B-8055
       Revision: 00H11001
       Coding: 0021122
       VCID: 73B0D79D57BF26F35E9-8027
       Part No: 1K0 820 047 GS
       Component: Climatic PQ35   120 0606
       VCID: 7BA0FFBD7FEF6EB3069-802F
       Revision: 00H54000    Serial number: 00000007187910
       Coding: 05058A1700000000070A00000F000000000811035C000100000000000000
       Shop #: WSC 09513 444 52621
       VCID: 71BCDD952DA314E3AC5-8025
       Component: Wischer 020207 020  0501
       Coding: 00038805
       Shop #: WSC 09513
                        Reset counter: 55
                        Mileage: 294656 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.05 V
                        Reset counter: 55
                        Mileage: 294656 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.05 V
       Revision: 05034000    Serial number: 003B6M00UX8R
       Coding: 0013889
       VCID: 6C82CCE10A81F90B9F3-8039
       Subsystem 2 - Serial number: 6332MSME15144A499
       Subsystem 3 - Serial number: 6342MSME156E340DI
       Subsystem 4 - Serial number: 6351HSME0C2B4F5DT
       Subsystem 5 - Serial number: 6361HSME0C36602EB
       Subsystem 6 - Serial number: 63727SME0B636C68C
       Subsystem 7 - Serial number: 63827SME0B5D1C3EK
       Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
       Component: J0527           056 0111
       Coding: 0001731
       VCID: 7AAEFAB970D557BB1DF-802F
       Subsystem 1 - Part No: 5K0 959 542 A  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H09 0013
       Coding: 00000130
       Part No SW: 5K0 920 973 B    HW: 5K0 920 973 B
       Coding: 271D01
       Shop #: WSC 00066 123 00120
       VCID: 303A1891EAA95DEBE3B-8065
    9453074 - Fuel Level Sensor 1
              B103E 1B [008] - Resistance Too High
                        Reset counter: 82
       Revision:   H42       Serial number: 260412F2003028
       Coding: 351002
       VCID: 3A2E3AB93C5597BB5DF-806F
                        Fault Status: 00110100
                        Reset counter: 55
                        Mileage: 294656 km
                        Date: 2014.07.24
                        Time: 07:30:07
                        Reset counter: 55
                        Mileage: 294656 km
                        Date: 2014.07.24
                        Time: 07:30:07
       VCID: 6A8ECAF90CF5E73BEDF-803F
       Component: J386  TUER-SG FT    1133
       Revision: 32008001    Serial number: 00000108978115
       Coding: 0001207
       VCID: 3B203FBD3F6FAEB3469-806F
                        Fault Frequency: 181
                        Reset counter: 47
                        Mileage: 294113 km
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.070 H07 1806
       VCID: 34321481123161CB873-8061
       Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
       Component:    KSG PQ35 RDK 051 0215
       Revision: 00051000    Serial number: 00000000000000
       Coding: 13900F880186083F3F04058FB0880F0488DC40
       Shop #: WSC 00066 123 12345
       VCID: 74B2D48152B121CB473-8021
       Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
       Component: J387  TUER-SG BT    1133
       Revision: 32008001    Serial number: 00000576778105
       Coding: 0001206
       VCID: 3C223CA13A61A98B4F3-8069
    00110 - Right Mirror Turn Signal Lamp (L132)
                        Fault Status: 00101100
                        Reset counter: 87
       Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
       Component: Radio         534 5518
       Revision: --------    Serial number: VWZZZ4H6234825
       Coding: 16000440040006
       Shop #: WSC 00078 790 00217
       VCID: 46D65E4978ADE35B297-8013
       Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
       Component: J388   TUER-SG HL   1120
       Revision: 12006001    Serial number: 00000001060360
       Coding: 0001168
       VCID: 3E2636A92C7DBB9B617-806B
                        Fault Frequency: 35
                        Reset counter: 47
                        Mileage: 294142 km
       Component:    RDK              0420
       Coding: 0100101
       Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
       Component: J389   TUER-SG HR   1120
       Revision: 12006001    Serial number: 00000001047766
       Coding: 0001168
       VCID: 3FD84BAD2B77B2936A1-806B
    End----(Elapsed Time: 01:15, VBatt start/end: 11.5V/11.5V. VIgn 11.4V)-----
    Jul 2017
    Looks like you are right. Both min. Don't happen to have a part number for max would you?
    Jul 2014
    Tallinn, Estonia
    Quote Originally Posted by 801 View Post
    https://www.my-gti.com/2158/volkswag...rmation-mark-v
    According to this, its 1K0959701Q and 702Q. There may be supersessions of these suffixes.
  8. Likes downtime, Uwe liked this post
