eGolf trunk pop from key fob not where ECS instructions say it should be...?
MK7
C?ID=220153
I would like to change my trunk pop with key fob/remote to be able to use the ECSTuning trunk pop kit I bought and installed. The key fob button to pop the trunk just flashes the lights, does not trigger the trunk pop.
PS... The Ross-Tech wiki seems to be down.
Autoscan =
Sunday,26,April,2020,19:00:02:61936
VCDS Version: 20.4.1.0 (x64)
VIN: WVWKR7AU7JW******   License Plate: 2018 EGOLF
Mileage: 19947km-12394mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 15 16 17 19 23 2B 42 44 51 52 5F 75 8C BD C0
          C6
VIN: WVWKR7AU7JW******   Mileage: 19947km-12394miles
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
C6-Batt. Chrg. -- Status: OK 0000
Address 01: Engine (J623-EAZA)       Labels:. 0EA-907-309-V1.clb
   Part No SW: 0EA 906 016 F    HW: 0EA 907 309 A
   Component: E-Vehicle     H24 4238
   Revision: WMH24---
   Coding: 000D0012002400007000
   ASAM Dataset: EV_VCU00XXX0110EA906016F 004005
   ROD: EV_VCU00XXX0110EA906016F_004.rod
   VCID: 326B032B65DE9116CD-8066
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
   Component: ESC           H62 0855
   Revision: 00000000    Serial number: 63337000000416
   Coding: 01FA40A12C202173857A0208A1C62980023484A14085943202815058C24203
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003.rod
   VCID: 7CF7ED13F71A976657-8028
16401 - Tire Pressure Warning
          C102D 00 [032] - -
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0463235047
   Coding: 032C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002020
   VCID: 3C772D13B79A576617-8068
   Part No SW: 5GE 907 044 AN    HW: 5GE 907 044 AN
   Component: Climatronic   H04 1702
   Revision: 00001K01
   Coding: 0002220020011001040500421211102A
   VCID: 081F81C3B3C2CBC643-805C
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Subsystem 3 - Part No SW: 12E 963 231 G    HW: 12E 963 231 G
   Component: J848 HV-PTC  H09 0208
   Serial number: LR173383003810000075
H02
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001733600116
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06038FFBB9D6DDB631-8052
   Component: WWS    171120  043 0551
   Serial number:         171125213505
   Component: RLHS  047 0105
   Serial number: S5Y17M12D08H08M34S55
   Coding: 00A8DD
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 177
                    Mileage: 2014 km
                    Date: 2019.03.02
                    Time: 18:50:32
   Serial number: 003GCR08UCE-
   Coding: 8CCCFC00002000005000001AC20800000065
   VCID: 479D42FFFE5C04BE8A-8012
   Occupant Detection:
   Serial number: IBH000000000007WYOS%
   Coding: 303253
   Subsystem 2 - Part No SW: -----------    HW: 480 000 812 17
   Serial number: 35700000000E4830482F
   Subsystem 3 - Part No SW: -----------    HW: 480 000 112 17
   Serial number: 35800000000D3D28482Q
   Subsystem 4 - Part No SW: -----------    HW: 480 401 112 17
   Serial number: 3510001BF28637D4C74G
   Subsystem 5 - Part No SW: -----------    HW: 480 401 112 17
   Serial number: 3520001C128AD0648470
   Subsystem 6 - Part No SW: -----------    HW: 480 400 812 17
   Serial number: 3550001C128637F1136-
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 812 17
   Component: FrontSensor_P  000 6149
   Serial number: 3560001BD28637E1B6CN
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 04121704400714
   Coding: 0410
   VCID: 071D82FFBEDCC4BE4A-8052
Address 17: Instruments (J285)       Labels:* None-SRI3
   Part No SW: 5GE 920 855 C    HW: 5GE 920 855 C
   Component: KOMBI         302 0310
   Coding: 0BB4281A2380CF05020829001700032080000000
   VCID: 41895CE7D0783A8E44-8014
   Part No SW: 3Q0 907 530 M    HW: 3Q0 907 530 D
   Component: GW MQB EV     618 6322
   Serial number: 24111710520722
   Coding: 0201001704F81000FB001200081D00000001070100070000000300000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 39793407B8A8624E0C-806C
   Subsystem 1 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29170002322470107421
   Coding: 30FFFF
   Subsystem 2 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Serial number: 6318546004
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 G    HW: 5QE 909 059 B
   Component: EBKV          H14 0211
   Serial number:   085460011232
   Coding: 06720100321A02030002000500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
   ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
   VCID: 52AB63AB051EB116ED-8006
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 D    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0155
   Serial number: 05802861251117031138
   Revision: 00000000    Serial number: 17000357002010
   Coding: 7900000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346705339FCA9F26DF-8060
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 170917EIG2546A
   Coding: 003013208000040000000000
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000017935568
   Coding: 111000
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1081
   Coding: C1020000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73E5C62FDA44D81E06-8026
Address 51: Electric Drive (J841)       Labels: None
   Part No SW: 5QE 907 080 L    HW: 5QE 907 080 L
   Component: LE Gen 3.3H16 2053
   Revision: 00H16000
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM10030115QE907080L 001008
   ROD: EV_DMCM10030115QE907080K.rod
   VCID: 4FAD6ADF162CDCFEC2-801A
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 291017EJT14707
   VCID: 408F59E3DB7233864B-8014
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000017999262
   Coding: 091000
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     722 0867
   Coding: 02738000FF00000051220001001808009F0505D40120050002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2E53175B71E6B5F6A9-807A
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJT3276802
          B11CF 53 [009] - Deactivated
                    Reset counter: 175
                    Mileage: 14982 km
                    Date: 2020.02.16
                    Time: 12:47:13
                    Voltage terminal 30: 12.1 V
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 102 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
   Component: OCULowMQBUS   009 0570
   Coding: 02737002C2829A017FFE06000000
   ROD: EV_OCULowMQB.rod
   VCID: 438556EFCA64289E56-8016
Address 8C: Hybrid Battery (J840)       Labels: None
   Part No SW: 5GE 915 225 A    HW: 5GE 915 225 A
   Component: K8C           005 0350
   Serial number: 31101707010206
   ASAM Dataset: EV_BECM08820215GE915225A 001003
   ROD: EV_BECM08820215GE915225A.rod
   VCID: 3A7B2B0BBDAE695605-806E
   Battery Junction Box:
   Subsystem 1 - Part No SW: 5GE 915 316 A    HW: 5GE 915 316 A
   Component: A2 HVSMBJBECU  011 0300
   Serial number: 00000022111705010029
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J991Battmod1  H08 0322
   Serial number: 17A07Y18AH0803227804
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J992Battmod2  H08 0322
   Serial number: 17A07Y18AH0803227425
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J993Battmod3  H08 0322
   Serial number: 17A07Y18AH0803227238
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J994Battmod4  H08 0322
   Serial number: 17A05Y18AH0803225308
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J995Battmod5  H08 0322
   Serial number: 17A07Y18AH0803227320
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J996Battmod6  H08 0322
   Serial number: 17A07Y18AH0803225061
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J997Battmod7  H08 0322
   Serial number: 17A07Y18AH0803227964
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J998Battmod8  H08 0322
   Serial number: 17A06Y18AH0803227987
Address BD: Hi Volt. Batt. Charg. (J966)       Labels:| 5QE-915-022.clb
   Part No SW: 5QE 915 022 AN    HW: 12E 915 022 G
   Component: LMSG          H20 1096
   Serial number: 01146070470019
   Coding: 484914000400
   ASAM Dataset: EV_HVChargManagVWMQB 003004
   ROD: EV_HVChargManagVWMQB.rod
   VCID: 0D11B0D7DCA0AEEE70-8058
Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
   Part No SW: 5QE 035 335 M    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H10 0223
   Serial number: EN174604000000
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 007015
   ROD: EV_ENoiseS1NNVW3707_007.rod
   VCID: 4B957ECFE234E0DEAE-801E
Address C6: Batt. Chrg. (J1050)       Labels: 5QE-915-681.clb
   Part No SW: 5QE 915 681 B    HW: 5QE 915 681 B
   Component: OBC Delta-ES  H59 1560
   ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
   ROD: EV_OBCTwoPhaseDT2VW3707.rod
End-------------------------(Elapsed Time: 04:44)--------------------------
Dana
Western PA, USA
Adding to that, if ENG141653-ENG115759 - ZV Heck - Direkter Auswurf des Heckdeckels is already set to Active, and the function still isn't working correctly please paste the AdpLog.CSV contents here for review.
MK7
C?ID=220153
That link tells me it is in...
"(12)-Access control-Direkter Auswurf des Heckdeckels" of which it is not.
I already had ordered, received and installed these.
Thank you Dana, It was there and I have it now set to active and it is working. How did you know where to look? It was exactly where you said. I had searched all over looking for that and all of the posts and videos I could find said to look where Jetta ,97 said.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Because some cars has different set up, with your Autoscan she was able to pull up data and see.
Not all cars are made same way , they maybe G7 but different level. If instructions are not same , then what I usually do , I search by world in search box, in your case it would be search " Direkter Auswurf des Heckdeckels".
Also old data I would said 2 years ago in VCDS was not written same as current version, that could be other thing that you may not be able find it under instructions I gave you.
DV52
C?ID=194404
Thank you Dana, It was there and I have it now set to active and it is working. How did you know where to look? It was exactly where you said. I had searched all over looking for that and all of the posts and videos I could find said to look where Jetta, 97 said.
MK7: If I can add to Jetta 97's sage response - Because Dana is one of the Ross-Tech deities, she most likely has access to information facilities that us mere mortals can only dream about (and sadly, I often do :) ) !!!
But, since you already have a VCDS cable, you also have the capability to become a quasi-God (a bit like Dana- but most definitely, not the same). All you need to do is to generate a BCM adaptation channel map (otherwise called an "admap") with a .CSV file structure. To do this, make sure that you set-up the admap dialogue box in the VCDS software like this:
After you press the "Go" button, lots of secret VCDS magic happens (the BCM on a MQB platform vehicle can have a 2,000-3,000 channel count, so be patient and make sure the battery is OK).
When the process completes, go to the directory C:\Ross-Tech\VCDS\logs and open the file adpmap-09-5Q0-937-085-BN_WVWKR7AU7JW******-yearmonthday-time.CSV with a tool like notepad, or MS-excel
So, you then need to search the database for the adaptation channel name - but the trick to creating your search vector is to understand that mid-way through 2016, there was a change made to many of the BCM adaptation channel names.
A clue to the type of changes that was wrought can be found in a comparison of the adaptation channel names for your particular problem.
But first, here's my very unofficial explanation of the structure of adaptation channel names as reported by the current VCDS software:
Parent Tag number-Child Tag number-Parent name-Child name
and the old VCDS has this structure:
(bracket number)-Parent name-Child name
Ross-Tech doesn't use my nomenclature (I've borrowed terms from relational database theory), but notice that the name-parts are separated by "-".
So, for your problem - the 2 x adaptation channels are:
from your link = (12)-Access control-Direkter Auswurf des Heckdeckels
Dana's suggestion= ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels
Notice that the last part of the 2 x channel names is the same. This then becomes the content of your search: just enter any part of the Child name from the old VCDS software into the search facility (for notepad, or MS-excel) and bingo, you find the correct, new adaptation channel.
But the best part is that with this new skill, you become a quasi-God (albeit with feet of clay - as per the adage !!!;))
Dana
Western PA, USA
I absolutely agree with the guys and often search my own control module maps when looking to see if I have a particular channel that may add clarity to a support, tweak or retrofit.
In this case I looked at the VCDS ROD file shown in the Auto-Scan and searched for Heckdeckels. Using the Adaptation function search in VCDS -or- searching the CSV would yield the same results but less is more in some cases. So, searching for Heckdeckels (Boot lid) narrowed it down quickly even though the USP Motorsports tutorial was created with VCDS 15 (roughly 5 year ago). Searching for Heck (Rear) results in 380 hits so that wasn't specific enough.
