eGolf max speed limiter change...? USA = 85mph while EU = 93mph
MK7
C?ID=220153
I would like to change my max speed limiter to 93 from 85.
PS... The Ross-Tech wiki seems to be down.
Autoscan =
Sunday,26,April,2020,19:00:02:61936
VCDS Version: 20.4.1.0 (x64)
VIN: WVWKR7AU7JW******   License Plate: 2018 EGOLF
Mileage: 19947km-12394mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 15 16 17 19 23 2B 42 44 51 52 5F 75 8C BD C0
          C6
VIN: WVWKR7AU7JW******   Mileage: 19947km-12394miles
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
C6-Batt. Chrg. -- Status: OK 0000
Address 01: Engine (J623-EAZA)       Labels:. 0EA-907-309-V1.clb
   Part No SW: 0EA 906 016 F    HW: 0EA 907 309 A
   Component: E-Vehicle     H24 4238
   Revision: WMH24---
   Coding: 000D0012002400007000
   ASAM Dataset: EV_VCU00XXX0110EA906016F 004005
   ROD: EV_VCU00XXX0110EA906016F_004.rod
   VCID: 326B032B65DE9116CD-8066
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
   Component: ESC           H62 0855
   Revision: 00000000    Serial number: 63337000000416
   Coding: 01FA40A12C202173857A0208A1C62980023484A14085943202815058C24203
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003.rod
   VCID: 7CF7ED13F71A976657-8028
16401 - Tire Pressure Warning
          C102D 00 [032] - -
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0463235047
   Coding: 032C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002020
   VCID: 3C772D13B79A576617-8068
   Part No SW: 5GE 907 044 AN    HW: 5GE 907 044 AN
   Component: Climatronic   H04 1702
   Revision: 00001K01
   Coding: 0002220020011001040500421211102A
   VCID: 081F81C3B3C2CBC643-805C
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Subsystem 3 - Part No SW: 12E 963 231 G    HW: 12E 963 231 G
   Component: J848 HV-PTC  H09 0208
   Serial number: LR173383003810000075
H02
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001733600116
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06038FFBB9D6DDB631-8052
   Component: WWS    171120  043 0551
   Serial number:         171125213505
   Component: RLHS  047 0105
   Serial number: S5Y17M12D08H08M34S55
   Coding: 00A8DD
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 177
                    Mileage: 2014 km
                    Date: 2019.03.02
                    Time: 18:50:32
   Serial number: 003GCR08UCE-
   Coding: 8CCCFC00002000005000001AC20800000065
   VCID: 479D42FFFE5C04BE8A-8012
   Occupant Detection:
   Serial number: IBH000000000007WYOS%
   Coding: 303253
   Subsystem 2 - Part No SW: -----------    HW: 480 000 812 17
   Serial number: 35700000000E4830482F
   Subsystem 3 - Part No SW: -----------    HW: 480 000 112 17
   Serial number: 35800000000D3D28482Q
   Subsystem 4 - Part No SW: -----------    HW: 480 401 112 17
   Serial number: 3510001BF28637D4C74G
   Subsystem 5 - Part No SW: -----------    HW: 480 401 112 17
   Serial number: 3520001C128AD0648470
   Subsystem 6 - Part No SW: -----------    HW: 480 400 812 17
   Serial number: 3550001C128637F1136-
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 812 17
   Component: FrontSensor_P  000 6149
   Serial number: 3560001BD28637E1B6CN
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 04121704400714
   Coding: 0410
   VCID: 071D82FFBEDCC4BE4A-8052
Address 17: Instruments (J285)       Labels:* None-SRI3
   Part No SW: 5GE 920 855 C    HW: 5GE 920 855 C
   Component: KOMBI         302 0310
   Coding: 0BB4281A2380CF05020829001700032080000000
   VCID: 41895CE7D0783A8E44-8014
   Part No SW: 3Q0 907 530 M    HW: 3Q0 907 530 D
   Component: GW MQB EV     618 6322
   Serial number: 24111710520722
   Coding: 0201001704F81000FB001200081D00000001070100070000000300000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 39793407B8A8624E0C-806C
   Subsystem 1 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29170002322470107421
   Coding: 30FFFF
   Subsystem 2 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Serial number: 6318546004
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 G    HW: 5QE 909 059 B
   Component: EBKV          H14 0211
   Serial number:   085460011232
   Coding: 06720100321A02030002000500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
   ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
   VCID: 52AB63AB051EB116ED-8006
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 D    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0155
   Serial number: 05802861251117031138
   Revision: 00000000    Serial number: 17000357002010
   Coding: 7900000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346705339FCA9F26DF-8060
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 170917EIG2546A
   Coding: 003013208000040000000000
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000017935568
   Coding: 111000
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1081
   Coding: C1020000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73E5C62FDA44D81E06-8026
Address 51: Electric Drive (J841)       Labels: None
   Part No SW: 5QE 907 080 L    HW: 5QE 907 080 L
   Component: LE Gen 3.3H16 2053
   Revision: 00H16000
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM10030115QE907080L 001008
   ROD: EV_DMCM10030115QE907080K.rod
   VCID: 4FAD6ADF162CDCFEC2-801A
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 291017EJT14707
   VCID: 408F59E3DB7233864B-8014
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000017999262
   Coding: 091000
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     722 0867
   Coding: 02738000FF00000051220001001808009F0505D40120050002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2E53175B71E6B5F6A9-807A
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJT3276802
          B11CF 53 [009] - Deactivated
                    Reset counter: 175
                    Mileage: 14982 km
                    Date: 2020.02.16
                    Time: 12:47:13
                    Voltage terminal 30: 12.1 V
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 102 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
   Component: OCULowMQBUS   009 0570
   Coding: 02737002C2829A017FFE06000000
   ROD: EV_OCULowMQB.rod
   VCID: 438556EFCA64289E56-8016
Address 8C: Hybrid Battery (J840)       Labels: None
   Part No SW: 5GE 915 225 A    HW: 5GE 915 225 A
   Component: K8C           005 0350
   Serial number: 31101707010206
   ASAM Dataset: EV_BECM08820215GE915225A 001003
   ROD: EV_BECM08820215GE915225A.rod
   VCID: 3A7B2B0BBDAE695605-806E
   Battery Junction Box:
   Subsystem 1 - Part No SW: 5GE 915 316 A    HW: 5GE 915 316 A
   Component: A2 HVSMBJBECU  011 0300
   Serial number: 00000022111705010029
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J991Battmod1  H08 0322
   Serial number: 17A07Y18AH0803227804
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J992Battmod2  H08 0322
   Serial number: 17A07Y18AH0803227425
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J993Battmod3  H08 0322
   Serial number: 17A07Y18AH0803227238
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J994Battmod4  H08 0322
   Serial number: 17A05Y18AH0803225308
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J995Battmod5  H08 0322
   Serial number: 17A07Y18AH0803227320
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J996Battmod6  H08 0322
   Serial number: 17A07Y18AH0803225061
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J997Battmod7  H08 0322
   Serial number: 17A07Y18AH0803227964
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J998Battmod8  H08 0322
   Serial number: 17A06Y18AH0803227987
Address BD: Hi Volt. Batt. Charg. (J966)       Labels:| 5QE-915-022.clb
   Part No SW: 5QE 915 022 AN    HW: 12E 915 022 G
   Component: LMSG          H20 1096
   Serial number: 01146070470019
   Coding: 484914000400
   ASAM Dataset: EV_HVChargManagVWMQB 003004
   ROD: EV_HVChargManagVWMQB.rod
   VCID: 0D11B0D7DCA0AEEE70-8058
Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
   Part No SW: 5QE 035 335 M    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H10 0223
   Serial number: EN174604000000
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 007015
   ROD: EV_ENoiseS1NNVW3707_007.rod
   VCID: 4B957ECFE234E0DEAE-801E
Address C6: Batt. Chrg. (J1050)       Labels: 5QE-915-681.clb
   Part No SW: 5QE 915 681 B    HW: 5QE 915 681 B
   Component: OBC Delta-ES  H59 1560
   ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
   ROD: EV_OBCTwoPhaseDT2VW3707.rod
End-------------------------(Elapsed Time: 04:44)--------------------------
TBAx
C?ID=287144
Not possible, as fas as I am informed.
MK7
C?ID=220153
Can you elaborate or were you just told nope...? Would a company that does tunes be able to flash my ecu?
I doubt anyone has tried to "tune" the e-Golf.
MK7
C?ID=220153
This is figured out. All set.
bojangles
London ON, Canada
C?ID=216260
Is there a way that i can get re-flashed for faster reverse speed?
