Results 1 to 6 of 6
Thread: DSG 7 speed DQ200 - Shift time measurment
    Question DSG 7 speed DQ200 - Shift time measurment
    My DSG seems slow to shift, it's as if both clutches are open for too long when changing up - I can hear the revs rise momentarily and the rev counter nudges up slightly.
    Is it possible to measure the time between clutch operations?
    Or maybe I could plot the engine RPM to show the spikes during shift, and therefore a) prove if there is an issue, b) get at least an idea of the shift delay.
    Any pointers to get me started much appreciated :-) Thanks.
    Stoke on Trent, England
    Welcome to the forum.
    You must have read posts on here? If you have a problem/query you post a full AutoScan in between CODE tags [CODE] Full AutoScan [/CODE]
    New User Keith
    Yep, and Auto Scan would be handy here, since it would help identify the data that your transmission has available to be logged, and to see if maybe there's a clutch adaptation possible.
    Ok, thanks - hopefully this is what's needed...
    To add to the info - I already successfully completed the basic settings of the DSG including the driving sequence to complete the calibrations, but that didn't improve matters
    The car is under warranty but the dealer doesn't agree that there is an issue seemingly based upon the lack of a fault code - they say that they have no justification to spend time on the vehicle.
    I'm not saying they are wrong, but if I could show them some data, and better still collect a comparison from another car, that will hopefully convince them, or me, as the case may be.
    Thanks again.
    Chassis Type: 1T (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 18 19 25 2E 42 44 46 52 56 61 62
              69 72 77
    VIN: WVGZZZ1TZDW052692   Mileage: 57210km-35548miles
    Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 PJ    HW: 03L 907 425 C
       Component: 1,6l R4 CR td H43 1842
       Revision: --H43---    Serial number: 00000000000000
       Coding: 00254014032500080000
       ASAM Dataset: EV_ECM16TDI02103L906023PJ 003004
       ROD: EV_ECM16TDI02103L906023NB_VW36.rod
       VCID: 7DDF13A8EC54ACC904D-8028
    Address 02: Auto Trans        Labels: 0AM-927-769.lbl
       Part No SW: 0AM 300 058 S    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 5270
       Revision: 00043014    Serial number: CU501210296255
       Shop #: WSC 62324 000 1048576
       VCID: 41A7AF58182C0829205-8014
       Revision: 00H31001
       Coding: 333B4016092706FCCC1102ED901B6081310150
       VCID: 7DDF13A8E454ACC904D-8028
       Part No SW: 7N0 907 426 BG    HW: 7N0 907 426 BG
       Component: AC Manuell    H20 0505
       Revision: 00001018
       Coding: 0010004002
       ROD: EV_ACManueBHBVW36X_SE36.rod
       VCID: 7AD518B4FD7A9BF121F-802F
       Part No SW: 5K0 937 084 H    HW: 5K0 937 084 H
       Component: BCM PQ35 B    021 0068
       Revision: BA021001
       Coding: 48180A38E025F1E0408800C0140000644B518E08526DA160648042000040
       VCID: 3753C18086E846999E1-8062
       Subsystem 1 - Part No: 1T2 955 119 A
       Component: Wischer 05101  26  0512
       Coding: 009795
       Component: RLS 271012 05  54  0403
       Coding: 0630ED
       Subsystem 3 - Part No: 7N0 951 171 A
       Component: DWA-Sensor 00  002 0206
    Address 10: Park/Steer Assist
    Address 15: Airbags        Labels: 1T0-909-605.lbl
       Part No SW: 1T0 909 605 E    HW: 1T0 909 605 E
       Component: 02 AIRBAG VW8   022 0100
       Revision: 02022000    Serial number: 003K4D082JN6
       Coding: 0012338
       VCID: 3753C18046E846999E1-8062
       Subsystem 1 - Serial number: 6332QSME09255764D
       Subsystem 2 - Serial number: 6342QSME0925284CI
       Subsystem 3 - Serial number: 6352QSME05234B56D
       Subsystem 4 - Serial number: 6362QSME23255762A
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Revision: --------    Serial number:  90440LJD000YC
       Coding: 1882140000
       ROD: EV_SMLSNGKUDS_SE36.rod
       VCID: 76CD0C84C962FF91457-8023
       Component: E221__MFL-TAS  H31 0033
       Serial number: 0326564
       Coding: 820000
       Part No SW: 1T0 920 975 C    HW: 1T0 920 975 C
       Coding: 181B00
       ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
       VCID: 3851C2BC83F649E197B-806D
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 7N0 963 271 E
       Component: Zuheizer        051 2940
       Revision: 00051000    Serial number: 09024297000000
       Coding: 0000011
       VCID: 364DCC8441E2BF91857-8063
       Part No SW: 7N0 907 530 AG    HW: 7N0 907 530 AG
       Component: J533  Gateway H53 1634
       Revision:   H53       Serial number: 271012F6000283
       Coding: 358003
       VCID: 75CF0B88DC64F4894CD-8020
    Address 25: Immobilizer
       Component: SG EXT.PLAYER H18 0546
       Revision: A1001003    Serial number: 7663744586
       Coding: 010100
       VCID: 2A75E8F4455AEB7111F-807F
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Component: Tuer-SG         009 2122
       Coding: 0000693
       VCID: 48B1B27C3B163961E7B-801D
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 70     3305
       Revision: 00H22000
       Shop #: WSC 01324 785 00200
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0000693
       VCID: 47B3B14036083619EE1-8012
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 186 AQ    HW: 1K0 035 186 AQ
       Component: Radio RCD310  004 0119
       Revision: 01000001    Serial number: VWZ1Z2M9675630
       Coding: 01000400040009
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AG
       Component: Batt.regelung H53 1634
       Coding: 01040859
       VCID: 71C73F98A80CD8A9905-8024
       Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
       Component: Tuer-SG         007 2104
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       VCID: 3245F094AD8AA3B1A9F-8067
    Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
       Revision: 3A001001    Serial number: 00008030512272
       Coding: 0100000100000000
       VCID: 3041FA9C638691A1DFB-8065
       Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
       Coding: 0000144
       VCID: 334BF5905290AAB9A29-8066
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
       Revision: 1B001001    Serial number: 00007663705544
       Coding: 0A11000000010101
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA.rod
       VCID: 3957C7B8B8FC50E9685-806C
    OK, that's a straightforward (non-UDS!) transmission still. Have a look at MVB 005 and 006 for all the speeds. It should be straightforward to log these as you drive. There's also detailed data bout the clutches, for clutch 1 its in MVB 090-099 and for clutch 2, it's in 110-119.
    Thanks for the pointers - I'm away for a week or so now, but I'll look at this as soon as I can and report back...
