Results 1 to 10 of 12
Thread: Touran 5T - Tire Size Related Speed Deviation after changing to summer tires
    Aug 2014
    Changed to summer tires the other day.
    Winter tires: 205/60 R16
    Summer tires: 225/40 R18
    Car starts without any problems but after driving approx 2-3 minutes / 700-800 meters, I've get this error in 13, 3C (and sub module CF):
    Error seems to start in 13, and after 10-15 minutes it logs the same error in 3C/CF. In the cluster is says that Front Assist / ACC is turned off.
    1311250 - Tire Size Related Speed Deviation
              C11E9 00 [008] - Too High
                        Reset counter: 217
                        Mileage: 69652 km
                        Date: 2020.04.19
                        Time: 12:07:54
                        Control Module temperature: 35 °C
                        Voltage terminal 30: Measured value not available
    The car was originally bought with these set of wheels so I know that it has been working without any problem.
    Looking at https://tiresize.com/calculator/ it says there is a 2,3% difference in the diameter.
    While running on winter tires, I've changed:
    - Gateway (5Q0 907 530 AM --> 3Q0 907 530 AA)
    - BCM (5Q0 937 086 AK --> 5Q0 937 086 BM)
    - Cluster (5TA 920 750 A --> 5NA 920 790 D)
    - Trunk elect (5Q0 959 107 J --> 5Q0 959 107 S)
    + added Side Assist (Lane Change Assist)
    ABS unit does say anything about tires so I've suspect this to be okay.
    Cluster is the only module not belonging to the car (it's from a Touran AD1), and the only thing is the wheelsize variant in one of the first bytes.
    Any idea or should I've just run on winter tires for the rest of the summer :-)
    Giving the fact that the winter tires did work perfect, there must be some variable stored somewhere telling the wheel size does not match. I've checked the tires and the PSI/bar is the same for all 4 wheels (approx 2,4 bar - can't remember exact)
    I also have some can-bus error, but right now my priority is the tire problem...
    PS - the errors in 03 and 05 could be that I've unplugged some of the coupling points the other day to add some more wires.
    PPS - error in 09 regarding rear door is that the ones right now is not supported by the BCM, so I have to replace them at some point.
    Thursday,23,April,2020,21:54:47:21529
    VIN: WVGZZZ1TZHW038734   License Plate: TOURAN UK LOG
    Mileage: 69789km-43364mi   Repair Order:
    Chassis Type: 1T-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 52 55 5F 69
              6C 6D A5 BB BC CF
    VIN: WVGZZZ1TZHW038734   Mileage: 69789km-43364miles
    CF-Lane Chge Asst 2 -- Status: Malfunction 0010
    Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 HQ    HW: 04E 907 309 BH
       Component: R4 1.4l TFS   H25 2484
       Revision: R7H25---
       Coding: 0125003224741D083000
       Shop #: WSC 10818 002 1048576
       ASAM Dataset: EV_ECM14TFS01104E906027HQ 001004
       ROD: EV_ECM14TFS01104E906027HQ.rod
       VCID: 7AADF0DDDC5A184B1D6-802E
       CAN Converter 01:
    17156 - Databus
                        Mileage: 69755 km
                        Date: 2020.04.22
                        Time: 16:15:21
                        Engine speed: 909.00 /min
                        Normed load value: 16.9 %
                        Vehicle speed: 32 km/h
                        Coolant temperature: 93 °C
                        Intake air temperature: 36 °C
                        Voltage terminal 30: 14.088 V
                        Unlearning counter according OBD: 34
                        Acceleration: -1.786 m/s²
                        Cruise Control System (CCS): status-Bits 0-7: 2
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                        Drivetrain coordinator: brake fault status-Bits 0-7: 0
    7158 - Please Check DTC Memory in CAN Gateway (J533)
              U1008 00 [040] - -
              [Diagnostic interface for data busRead out DTC]
                        Fault Frequency: 115
                        Mileage: 69616 km
                        Date: 2020.04.17
                        Time: 08:47:12
                        Engine speed: 1250.00 /min
                        Normed load value: 35.3 %
                        Vehicle speed: 49 km/h
                        Coolant temperature: 62 °C
                        Intake air temperature: 29 °C
                        Voltage terminal 30: 13.970 V
                        Outside air temperature: 7 °C
                        Absolute intake pressure: 89 kPa abs
                        Engine torque: 93.7 Nm
                        Fuel level: 11.00 l
                        Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                        Intake camshaft bank1 active operating mode-Bits 0-7: 0
                        Overrun cut-off-Bits 0-7: 0
       Part No SW: 0CW 300 049 Q    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 0907
       Revision: 00005025    Serial number: 5ZV01609145673
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 4BC36519C34051C3F60-801E
       Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
       Component: ESC           H62 0736
       Revision: 00000000    Serial number: 62296000001561
       Coding: 0CEA6AA034231374477E360341C72930562CC8E26C8294753822F078C22202
       VCID: 7BA3F5D9D3602143060-802E
    8330 - Databus
              [FCAN: MO_QBit_Fahrpedalrohwert signal is invalid]
                        Reset counter: 229
                        Mileage: 69740 km
                        Date: 2020.04.22
                        Time: 08:40:36
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0418113727
       Coding: 030C0C0703
       Shop #: WSC 00046 000 00000
       ROD: EV_KessyHellaMQBAB.rod
       VCID: 3C2136C596EEE67B4FA-8068
       Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
       Component: GEB.F.Heckoef  H17 0903
       Serial number: 98077301
    12718348 - Databus
              [Message "Motor_EV_01" missing]
                        Reset counter: 238
                        Mileage: 69789 km
                        Date: 2020.04.23
                        Time: 21:30:17
                        ZAT_pressed: OFF
                        Control Module Voltage: 11.822 V
                        Vehicle speed: 0.0 km/h
                        Engine speed: 0.0 /min
                        Coding information: coded
                        Coding information: Not coded
                        Driver door: Open
                        Front Passenger Door: Open
                        Left rear door: closed
                        Right rear door: closed
                        Active_LF_scans: Init
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
       Part No SW: 5G1 907 044 T    HW: 5G1 907 044 T
       Revision: 00001K10
       Coding: 08020004200410011105104D0010102A
       VCID: 392F2FD199DCD35354C-806C
       Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
       Component: BCM PQ37BOSCH 032 0245
       Revision: --------    Serial number: 8658080416017M
       Shop #: WSC 01608 111 28888
       ROD: EV_BCMBOSCH_018.rod
       VCID: 0655942D98A26CAB69E-8052
       Subsystem 1 - Part No SW: 5TB 955 119 A    HW: 5TB 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    160817  043 0608
       Serial number:         160824082627
       Component: RLHS  042 0105
       Serial number: S4Y16M09D30H17M16S41
       Coding: 00A8DD
       Ceiling Light Module:
       Subsystem 3 - Part No SW: 3G0 947 105 C    HW: 3G0 947 105 C
       Component: J528 Dachelek  H08 0008
       Serial number: 16080900010005C
       Coding: F38380
    197128 - Lock Module for Central Locking; Rear Left
              B12DB 29 [009] - Signal Implausible
                        Reset counter: 193
                        Mileage: 69621 km
                        Date: 2020.04.17
                        Time: 11:48:21
    197384 - Lock Module for Central Locking; Rear Right
              B12DC 29 [009] - Signal Implausible
                        Reset counter: 193
                        Mileage: 69621 km
                        Date: 2020.04.17
                        Time: 11:48:21
    733193 - Reading Light; Rear Left
              B1815 14 [009] - Open or Short to Ground
                        Fault Frequency: 12
                        Reset counter: 198
                        Mileage: 69625 km
                        Date: 2020.04.17
                        Time: 16:03:33
    733449 - Reading Light; Rear Right
              B1816 14 [009] - Open or Short to Ground
                        Fault Frequency: 12
                        Reset counter: 198
                        Mileage: 69625 km
                        Date: 2020.04.17
                        Time: 16:03:33
       Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
       Serial number: 000308417617172
       Coding: 0A71567A51
       Shop #: WSC 49885 002 104857
       ROD: EV_EPHVA2CAU3700000_009_VW37.rod
       VCID: 50F972752A66721B832-8004
       Component: ACC BOSCH MQB H04 0194
       Coding: 32016FCB55FFC428949C804D
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 34311EE5BEBE2E3B87A-8060
    0788 - Tire Diameter Implausible
              C10A8 00 [008] - -
              [FAULT_EVI_TIRE_SIZE]
                        Fault Frequency: 33
                        Reset counter: 238
                        Mileage: 69656 km
                        Date: 2020.04.19
                        Time: 19:30:16
                        Control Module temperature: 20 °C
                        Voltage terminal 15: 13.9 V
                        Velocity_vehicle_reference: 10.87 m/s
                        Longitudinal_acceleration_vehicle_reference: 1.00 m/s²
    2071 - Databus
              [FAULT_VDIS_PLAUS_FAIL]
                        Reset counter: 233
                        Mileage: 69755 km
                        Date: 2020.04.22
                        Time: 16:15:21
                        Control Module temperature: 32 °C
                        Velocity_vehicle_reference: 8.40 m/s
                        Longitudinal_acceleration_vehicle_reference: -1.52 m/s²
                        Status_ACC_System: ACC_activ_controlled
       Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
       Component: AirbagVW21    005 0130
       Serial number: 003NSR25CGM9
       Coding: 98CCC0C00C0000005C5450CF004800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
       VCID: 03538D39AB9059834E0-8056
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 5TB857705E0272Q00803
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 5TB857706E0272Q00021
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 002 709 16
       Serial number: 3570000000086145AD1K
       Subsystem 4 - Part No SW: -----------    HW: 480 002 709 16
       Serial number: 3580000000056BEC9F13
       Subsystem 5 - Part No SW: -----------    HW: 480 412 309 16
       Component: SideSensor_Dr  003 0189
       Serial number: 351001A058EA64927D8K
       Subsystem 6 - Part No SW: -----------    HW: 480 412 309 16
       Component: SideSensor_Pr  003 0189
       Serial number: 352001A058E4A8A0FED-
       Subsystem 7 - Part No SW: -----------    HW: 480 402 809 16
       Serial number: 3550001AB223535272F
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 480 402 909 16
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001C3227F923226Z
       Subsystem 9 - Part No SW: -----------    HW: 480 402 909 16
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001A52303C96757/
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 480 402 909 16
       Component: PedP_Sensor_C  000 6149
       Serial number: 2300001A92303C91A67Z
       Subsystem 11 - Part No SW: -----------    HW: 480 000 709 16
       Serial number: I0M00000000B11149D1
       Subsystem 12 - Part No SW: -----------    HW: 480 000 709 16
       Serial number: I0N00000000EEAB42E1P
    1053957 - Databus
              [NWD: 0x121 Motor_20 error value MO_Fahrpedalrohwert_01]
                        Reset counter: 229
                        Mileage: 69740 km
                        Date: 2020.04.22
                        Time: 08:40:37
       Part No SW: 3Q0 953 521 EJ    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0225
       Revision: FF036036    Serial number: 20160703500063
       Coding: 0410
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
       ROD: EV_SMLSVALEOMQBLRH.rod
       VCID: 7CA1F6C5D66E267B0FA-8028
    291104 - Temperature Sensor for Heated Steering Wheel
              B1455 01 [008] - Electrical Failure
                        Reset counter: 238
                        Mileage: 69569 km
                        Date: 2020.04.13
                        Time: 11:38:21
                        Ubat 30 Voltage: 13.00 V
                        Internal error state: 0
                        LIN_Temp: 254
                        Isense: 0
                        Max.Leistung: 110
                        PWM: 0
                        Offset: 245
                        Slope: 134
                        kp: 18
                        OUT: 50
                        Temperatur Statisch: 30
                        p_t_soll_0: 34.00 °C
                        p_t_soll_1: 39.00 °C
                        p_t_soll_2: 44.00 °C
       Part No SW: 5NA 920 790 D    HW: 5NA 920 790 D
       Component: KOMBI         508 1701
       Coding: 05AD011A6F8C00080188770B7001000180000000
       ASAM Dataset: EV_DashBoardVDDMQBA0 001026
       ROD: EV_DashBoardVDDMQBA0_VW37.rod
       VCID: 43D34D39EB1099830E0-8016
       Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Component: GW MQB High   521 5364
       Serial number: 26021810802796
       Coding: 030100347F085700FB00025C1C0F00010001070000000000000000000000
       Shop #: WSC 01730 666 28888
       ROD: EV_GatewNF_VW37.rod
       VCID: 6E85CC8D901244EBB1E-803A
       Component: 2-07-1f-07-1f
       Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
       Serial number: 2561612082701199AP2B
       Coding: 2F0000
       Serial number: 9070731604
    1 Faults Found:
              U1101 00 [009] - Active
                        Fault Frequency: 82
                        Reset counter: 198
                        Mileage: 69620 km
                        Date: 2020.04.17
                        Time: 11:39:47
                        Supply voltage: Terminal 30: 14.0 V
                        Terminal 15: On
       Serial number: 16000217536010
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BFD7F1812C5B13ACC-8024
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
       Component: MRR1Rear      H16 0510
       Revision: --------
       Coding: 14C002
       Shop #: WSC 06319 790 00021
       VCID: 3A2D30DD9CDAD84B5D6-806E
                        Fault Frequency: 18
                        Reset counter: 238
                        Mileage: 69634 km
                        Date: 2020.04.18
                        Time: 10:55:07
                        Control Module temperature: 28 °C
                        Vehicle speed: 51.62 km/h
                        Terminal 15 status: Measured value not available
                        Voltage terminal 15: 14.00 V
    267010 - Databus
              [FAULT_SLAVE]
                        Reset counter: 177
                        Mileage: 69652 km
                        Date: 2020.04.19
                        Time: 12:07:54
                        Control Module temperature: 37 °C
                        Vehicle speed: 48.65 km/h
       Serial number: 300716EGU23091
       Coding: 00199320D200048000001000
       Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    204 2041
       Revision: 00000000    Serial number: 0001069677
       Coding: 01010011005001
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
       ROD: EV_SteerAssisVWBSMQBA_008.rod
       VCID: 3D273BC18DF4EF73784-8068
       Serial number: 110816EHB14179
       Coding: 00199120DE00048000801000
       VCID: 42DD483DF40A908B056-8016
       Coding: 07CA020009000000
       VCID: 75B7E3E1F5447733704-8020
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 5NA 035 022 A    HW: 5NA 035 022
       Component: MU-H-LND-EU   H51 1121
       Serial number: A846E0HB063189
       Coding: 02730601FF0000005111110100880A101F0106E401200400FE
       Shop #: WSC 00046 123 12345
       VCID: 313F17F141AC1B13ECC-8064
       Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
       Component: ABT_High-2  H52 9130
       Serial number: VWZ6ZJV1770429
       Subsystem 2 - Part No SW: V03 959 806 FN    HW: -----------
       Component: ECE 2020  --- 0184
       Component: Gracenote2  --- 1015
    13697024 - Component Protection
              U1100 00 [009] - No Basic Setting
              [Anti-theft protection - component protection: no basic setting or basic setting incorrect]
                        Reset counter: 198
                        Mileage: 69789 km
                        Date: 2020.04.23
                        Time: 21:42:46
                        Voltage terminal 30: 11.9 V
    15361024 - Component Protection
              [Anti-theft protection - component protection active (0xEA6400)]
                        Reset counter: 198
                        Mileage: 69789 km
                        Date: 2020.04.23
                        Time: 21:42:46
       Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
       Component: Anhaenger     H27 0264
       Revision: 8A001003    Serial number: 0456658849
       Coding: 0100000202000000
       Shop #: WSC 00015 115 08193
       ROD: EV_TrailFunctGener2Hella_VW37.rod
       Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
       Component: Areaview 2    H13 0608
       Serial number: C854707JG024130
       Coding: 01230601A70F000000314814
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
    10489856 - No Basic Setting
              B2010 00 [009] - -
              [RearView system not calibrated]
                        Fault Frequency: 92
                        Reset counter: 198
                        Mileage: 69638 km
                        Date: 2020.04.18
                        Time: 11:11:19
    9616994 - Front Surroundings Camera
              B127C 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 174
                        Mileage: 69638 km
                        Date: 2020.04.18
                        Time: 11:11:19
    9617993 - Rear Surroundings Camera
              B127D 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 174
                        Mileage: 69638 km
                        Date: 2020.04.18
                        Time: 11:11:19
    9618000 - Left Surroundings Camera
              B127E 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 174
                        Mileage: 69638 km
                        Date: 2020.04.18
                        Time: 11:11:19
    9618001 - Right Surroundings Camera
              B127F 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 174
                        Mileage: 69638 km
                        Date: 2020.04.18
                        Time: 11:11:19
       Part No SW: 5Q0 959 107 S    HW: 5Q0 959 107 C
       Component: HDSG-Modul    H12 0271
       Revision: --------    Serial number: 31657583700000
       Coding: 03A8
       VCID: 48C95A15D236BADBDB2-801C
       Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H07 0272
       Serial number: 25101611K12644
       Coding: 000307080000040100262357C150850098000E230020
       Shop #: WSC 00069 790 00048
    1123187 - Local Data Bus
              U116B 00 [008] - Received Malfunction Value
              [RDR1_Header_FGN_Status]
                        Reset counter: 232
                        Mileage: 69755 km
                        Date: 2020.04.22
                        Time: 16:15:22
                        Outside air temperature: 19.0 °C
                        Vehicle speed: 31.65 km/h
                        System run time: 105.8 s
                        Voltage terminal 15: 13.8 V
                        mid: 02 C0
                        Status of camera: operational
                        Engine_Running_Info: 1
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
       Serial number: 170816DHH0229B
       Coding: 002091200000048000001000
       VCID: 45D75321E524A7B3204-8010
       Serial number: 170816DHH02711
    Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
       Revision: --------
       Coding: 14C002
       VCID: 372B29E9AFC8C523A28-8062
                        Reset counter: 217
                        Mileage: 69652 km
                        Date: 2020.04.19
                        Time: 12:07:54
    End----(Elapsed Time: 02:06, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
    Perhaps a silly question, but did you do a "reset" of the indirect TPMS after changing tires?
    There should be a button for it, or a menu item in the infotainment system, and there is a Basic Setting in the ABS as well.
  3. Likes Dana liked this post
    Aug 2014
    Yep - did that (several times). But shouldn’t that log an error in the ABS instead?
    (It’s under Car -> Tire pressure in the infotainment)
    United States
    The WSS info is used for VSS and generated by 03-ABS so the TPMS relearn was worth a shot.
    If you haven't already done so I would tinker with the Tire Circumference coding in address 17 to see which ones it will accept and then drive it with a GPS to see if the coding changes made the speedo more -or- less accurate. With any luck it may help with the 13/3C problem.
    Aug 2014
    I’ll try to reset tomorrow morning again.
    WSS?
    VSS?
    Do you mean the 7-8 variants in module 17?
    WSS = Wheel Speed Sensor
    VSS = Vehicle Speed Signal
  8. Likes diskoboy, Uwe liked this post
    Aug 2014
    A little update... Changed the coding in [17-Cluster] to test accepted values for the tires...
    Between each coding test I've (or the car) learned the current tire pressure.
    Standard, value 3, value 4 and value 6 is accepted. The rest is not...
    However value 4 + 6 throws the following error in [13-Auto Dist. Reg] - and can't be deleted.
    Saturday,25,April,2020,09:45:21:21529
    VCDS Version: Release 20.4.0 (x64) Running on Windows 10 x64
                    Address 13: Auto Dist. Reg       Labels: 3Q0-907-572.clb
    Control Module Part Number: 3Q0 907 572 B    HW: 3Q0 907 572 B
      Component and/or Version: ACC BOSCH MQB H04 0194
               Software Coding: 32016FCB55FFC428949C804D
                Work Shop Code: WSC 10818 002 104857
                  ASAM Dataset: EV_ACCBOSCHVW48X 001009 (VW37)
    0860 - Databus
              U1122 00 [009] - Implausible Message
              [FAULT_QBIT_REIFENUMFANG]
                        Reset counter: 202
                        Mileage: 69825 km
                        Date: 2020.04.25
                        Time: 09:41:38
                        Control Module temperature: 26 °C
                        Voltage terminal 15: 11.7 V
    So basically, only "standard" and "3" is working, but still it gives errors after some time...
    Could it be that the Tiguan cluster has some different tire sizes "hardcoded" in the eeprom / paramters?
  10. #8
    Aug 2014
    Yet another update....
    245/40R18 is an perfect match... however quite wide!
    215/45R18 is almost a perfect match. -0,4% diameter.
    For 17" it's impossible to find anyone. Nearest is 215/50R17 with a diff. of -0,8% or 205/55R17 with +0,8%
    Does anyone know what the tolerance is regarding the diameter?
    One of my friends get the 225/40 R18 for a fair price. I'll keep the VW Durban 18"×7,5 rims and everybody is happy... When I know that they match...
  11. #9
    Quote Originally Posted by diskoboy View Post
    The usual rule of thumb is to stay within 2%.
  12. Likes diskoboy liked this post
  13. #10
    Aug 2014
    Problem solved
    Changed to 215/45R18 and the car is running perfect now
  14. Likes iichel, Uwe, PetrolDave liked this post
